Temat: [Mondeo 2007-2014] Doinstalowanie modułu BT/VC
Stary 16-01-2014, 00:03   #1555
Postów: 17,698
Proszę bardzo podstawowe info o modułach FordSync Gen 1 (takich jak dyskutowane) ze wskazanego TSB 2013.60:
The following languages are supported by the SYNC module voice control feature:
• English
• French
• Spanish
• Portuguese
• German
• Italian
• Turkish
• Dutch
• Russian
Polish and Swedish can only be read in the text display. The SYNC module is delivered with 4 languages depending on the market.
1) AM5T/BM5T-14D212-A* English, German, Russian, Turkish
2) AM5T/BM5T-14D212-B* English, German, Russian, Polish*¹
3) AM5T/BM5T-14D212-C* English, German, French, Italian
4) AM5T/BM5T-14D212-D* English, German, French, Swedish*¹
5) AM5T/BM5T-14D212-E* English, Spanish, French, Portuguese
6) AM5T/BM5T -14D212-F* English, German, French, Dutch
*¹ SYNC does not support Voice Recognition in this language.
Please follow the instructions to change the predefined language pack to the desired one.
Changing the language pack
FordEtis (FDRS) allows changing of the language pack, it is a two stage process and is not
covered by warranty.
1. Enter the VIN of the vehicle.
2. Select the vehicle software tab.
3. Run the network test application.
4. Select SYNC Module [APIM] and then the Configuration link.
5. Run the Sync Language Selection application, this will allow the selection of the required language pack.
6. Select the required language pack.
NOTE: It is important to run Sync Language Selection application first and then Module Language Reprogramming application.
7. Run the Module Language Reprogramming application, this will place the selected
language pack onto the module.
Wniosek - wskazane moduły są perspektywiczne, bo da się z tego pakietu iberyjskiego zrobić pakiet angielsko/polski (bez polskiego VC, ale z obsługą języka polskiego pisanego).
Ostatnio edytowane przez tedi_k ; 16-01-2014 o 00:09
