Stary 01-12-2009, 16:36   #2
mihowe
Zarejestrowany: 06-11-2007
Model: MK3
Silnik: TDCi 130
Postów: 239
Domyślnie Odp: zaświeciła sie pomarańczowa kontrolka chech engine czy jakos tak :)
Z chęcia ci pomożemy.
Oto lista ewentualnych usterek:
P0100 Mass or Volume Air Flow A Circuit
P0101 Mass or Volume Air Flow A Circuit Range/Performance
P0102 Mass or Volume Air Flow A Circuit Low Input
P0103 Mass or Volume Air Flow A Circuit High Input
P0104 Mass or Volume Air Flow A Circuit Intermittent/Erratic
P0105 Manifold Absolute Pressure/BARO Circuit
P0106 Manifold Absolute Pressure/BARO Sensor Range/Performance
P0107 Manifold Absolute Pressure/BARO Sensor Low Input
P0108 Manifold Absolute Pressure/BARO Sensor High Input
P0109 Manifold Absolute Pressure/BARO Sensor Intermittent
P010A Mass or Volume Air Flow B Circuit
P010B Mass or Volume Air Flow B Circuit Range/Performance
P010C Mass or Volume Air Flow B Circuit Low Input
P010D Mass or Volume Air Flow B Circuit High Input
P010E Mass or Volume Air Flow B Circuit Intermittent/Erratic
P010F Mass or Volume Air Flow Sensor A/B Correlation
P0110 Intake Air Temperature Sensor 1 Circuit
P0111 Intake Air Temperature Sensor 1 Circuit Range/Performance
P0112 Intake Air Temperature Sensor 1 Circuit Low Input
P0113 Intake Air Temperature Sensor 1 Circuit High Input
P0114 Intake Air Temperature Sensor 1 Intermittent/Erratic
P0115 Engine Coolant Temperature Sensor 1 Circuit
P0116 Engine Coolant Temperature Sensor 1 Circuit Range/Performance
P0117 Engine Coolant Temperature Sensor 1 Circuit Low Input
P0118 Engine Coolant Temperature Sensor 1 Circuit High Input
P0119 Engine Coolant Temperature Sensor 1 Circuit Intermittent/Erratic
P011A Engine Coolant Temperature Sensor 1/2 Correlation
P0120 Throttle/Pedal Position Sensor A Circuit
P0121 Throttle/Pedal Position Sensor A Circuit Range/Performance
P0122 Throttle/Pedal Position Sensor A Circuit Low Input
P0123 Throttle/Pedal Position Sensor A Circuit High Input
P0124 Throttle/Pedal Position Sensor A Intermittent
P0125 Insufficient Coolant Temp For Closed Loop Fuel Control
P0126 Insufficient Coolant Temp For Stable Operation
P0127 Intake Air Temperature Too High
P0128 Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
P0129 Barometric Pressure Too Low
P0130 O2 Circuit (Bank 1, Sensor 1)
P0131 O2 Circuit Low Voltage (Bank 1, Sensor 1)
P0132 O2 Circuit High Voltage (Bank 1, Sensor 1)
P0133 O2 Circuit Slow Response (Bank 1, Sensor 1)
P0134 O2 Circuit No Activity Detected (Bank 1, Sensor 1)
P0135 O2 Heater Circuit (Bank 1, Sensor 1)
P0136 O2 Circuit (Bank 1, Sensor 2) (See P2270, P2271)
P0137 O2 Circuit Low Voltage (Bank 1, Sensor 2)
P0138 O2 Circuit High Voltage (Bank 1, Sensor 2)
P0139 O2 Circuit Slow Response (Bank 1, Sensor 2)
P0140 O2 Circuit No Activity Detected (Bank 1, Sensor 2)
P0141 O2 Heater Circuit (Bank 1, Sensor 2)
P0142 O2 Circuit (Bank 1, Sensor 3)
P0143 O2 Circuit Low Voltage (Bank 1, Sensor 3)
P0144 O2 Circuit High Voltage (Bank 1, Sensor 3)
P0145 O2 Circuit Slow Response (Bank 1, Sensor 3)
P0146 O2 Circuit No Activity Detected (Bank 1, Sensor 3)
P0147 O2 Heater Circuit (Bank 1, Sensor 3)
P0148 Fuel Delivery Error
P0149 Fuel Timing Error
P0150 O2 Circuit (Bank 2, Sensor 1)
P0151 O2 Circuit Low Voltage (Bank 2, Sensor 1)
P0152 O2 Circuit High Voltage (Bank 2, Sensor 1)
P0153 O2 Circuit Slow Response (Bank 2, Sensor 1)
P0154 O2 Circuit No Activity Detected (Bank 2, Sensor 1)
P0155 O2 Heater Circuit (Bank 2, Sensor 1)
P0156 O2 Circuit (Bank 2, Sensor 2) (See P2272, P2273)
P0157 O2 Circuit Low Voltage (Bank 2, Sensor 2)
P0158 O2 Circuit High Voltage (Bank 2, Sensor 2)
P0159 O2 Circuit Slow Response (Bank 2, Sensor 2)
P0160 O2 Circuit No Activity Detected (Bank 2, Sensor 2)
P0161 O2 Heater Circuit (Bank 2, Sensor 2)
P0162 O2 Circuit (Bank 2, Sensor 3)
P0163 O2 Circuit Low Voltage (Bank 2, Sensor 3)
P0164 O2 Circuit High Voltage (Bank 2, Sensor 3)
P0165 O2 Circuit Slow Response (Bank 2, Sensor 3)
P0166 O2 Circuit No Activity Detected (Bank 2, Sensor 3)
P0167 O2 Heater Circuit (Bank 2, Sensor 3)
P0168 Engine Fuel Temperature Too High
P0169 Incorrect Fuel Composition
P0170 Fuel Trim (Bank 1)
P0171 System Too Lean (Bank 1)
P0172 System Too Rich (Bank 1)
P0173 Fuel Trim (Bank 2)
P0174 System Too Lean (Bank 2)
P0175 System Too Rich (Bank 2)
P0176 Flexible Fuel Sensor Circuit
P0177 Flexible Fuel Sensor Circuit Range/Performance
P0178 Flexible Fuel Sensor Circuit Low Input
P0179 Flexible Fuel Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P018A Fuel Pressure Sensor B Circuit
P018B Fuel Pressure Sensor B Circuit Range/Performance
P018C Fuel Pressure Sensor B Circuit Low
P018D Fuel Pressure Sensor B Circuit High
P018E Fuel Pressure Sensor B Circuit Intermittent/Erratic
P0190 Fuel Rail Pressure Sensor A Circuit
P0191 Fuel Rail Pressure Sensor A Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor A Circuit Low Input
P0193 Fuel Rail Pressure Sensor A Circuit High Input
P0194 Fuel Rail Pressure Sensor A Circuit Intermittent/Erratic
P0195 Engine Oil Temperature Sensor Circuit
P0196 Engine Oil Temperature Sensor Circuit Range/Performance
P0197 Engine Oil Temperature Sensor Circuit Low Input
P0198 Engine Oil Temperature Sensor Circuit High Input
P0199 Engine Oil Temperature Sensor Circuit Intermittent
P0200 Injector Circuit
P0201 Injector Circuit / Open - Cylinder 1
P0202 Injector Circuit / Open - Cylinder 2
P0203 Injector Circuit / Open - Cylinder 3
P0204 Injector Circuit / Open - Cylinder 4
P0205 Injector Circuit / Open - Cylinder 5
P0206 Injector Circuit / Open - Cylinder 6
P0207 Injector Circuit / Open - Cylinder 7
P0208 Injector Circuit / Open - Cylinder 8
P0209 Injector Circuit / Open - Cylinder 9
P020A Cylinder 1 Injection Timing
P020B Cylinder 2 Injection Timing
P020C Cylinder 3 Injection Timing
P020D Cylinder 4 Injection Timing
P020E Cylinder 5 Injection Timing
P020F Cylinder 6 Injection Timing
P0210 Injector Circuit / Open - Cylinder 10
P0211 Injector Circuit / Open - Cylinder 11
P0212 Injector Circuit / Open - Cylinder 12
P0213 Cold Start Injector 1
P0214 Cold Start Injector 2
P0215 Engine Shutoff Solenoid
P0216 Injector/Injection Timing Control Circuit
P0217 Engine Coolant Overtemperature Condition
P0218 Transmission Fluid Overtemperature Condition
P0219 Engine Overspeed Condition
P021A Cylinder 7 Injection Timing
P021B Cylinder 8 Injection Timing
P021C Cylinder 9 Injection Timing
P021D Cylinder 10 Injection Timing
P021E Cylinder 11 Injection Timing
P021F Cylinder 12 Injection Timing
P0220 Throttle/Pedal Position Sensor/Switch B Circuit
P0221 Throttle/Pedal Position Sensor/Switch B Circuit Range/Performance
P0222 Throttle/Pedal Position Sensor/Switch B Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch B Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch B Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch C Circuit
P0226 Throttle/Pedal Position Sensor/Switch C Circuit Range/Performance
P0227 Throttle/Pedal Position Sensor/Switch C Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch C Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch C Circuit Intermittent
P022A Intercooler Bypass Control A Circuit /Open
P022B Intercooler Bypass Control A Circuit Low
P022C Intercooler Bypass Control A Circuit High
P022D Intercooler Bypass Control B Circuit /Open
P022E Intercooler Bypass Control B Circuit Low
P022F Intercooler Bypass Control B Circuit High
P0230 Fuel Pump Primary Circuit
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Turbo/Super Charger Overboost Condition
P0235 Turbo/Super Charger Boost Sensor A Circuit
P0236 Turbo/Super Charger Boost Sensor A Circuit Range/Performance
P0237 Turbo/Super Charger Boost Sensor A Circuit Low
P0238 Turbo/Super Charger Boost Sensor A Circuit High
P0239 Turbo/Super Charger Boost Sensor B Circuit
P023A Turbocharger/Supercharger Intercooler Coolant Pump Control Circuit/Open
P023B Turbocharger/Supercharger Intercooler Coolant Pump Control Circuit Low
P023C Turbocharger/Supercharger Intercooler Coolant Pump Control Circuit High
P023D Manifold Absolute Pressure - Turbocharger/Supercharger Boost Sensor A Correlation
P023E Manifold Absolute Pressure - Turbocharger/Supercharger Boost Sensor B Correlation
P0240 Turbo/Super Charger Boost Sensor B Circuit Range/Performance
P0241 Turbo/Super Charger Boost Sensor B Circuit Low
P0242 Turbo/Super Charger Boost Sensor B Circuit High
P0243 Turbo/Super Charger Wastegate Solenoid A
P0244 Turbo/Super Charger Wastegate Solenoid A Range/Performance
P0245 Turbo/Super Charger Wastegate Solenoid A Low
P0246 Turbo/Super Charger Wastegate Solenoid A High
P0247 Turbo/Super Charger Wastegate Solenoid B
P0248 Turbo/Super Charger Wastegate Solenoid B Range/Performance
P0249 Turbo/Super Charger Wastegate Solenoid B Low
P0250 Turbo/Super Charger Wastegate Solenoid B High
P0251 Injection Pump Fuel Metering Control A
P0252 Injection Pump Fuel Metering Control A Range/Performance
P0253 Injection Pump Fuel Metering Control A Low
P0254 Injection Pump Fuel Metering Control A High
P0255 Injection Pump Fuel Metering Control A Intermittent
P0256 Injection Pump Fuel Metering Control B
P0257 Injection Pump Fuel Metering Control B Range/Performance
P0258 Injection Pump Fuel Metering Control B Low
P0259 Injection Pump Fuel Metering Control B High
P0260 Injection Pump Fuel Metering Control B Intermittent
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 3 Contribution/Balance
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance
P0276 Cylinder 6 Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Balance
P0297 Vehicle Overspeed Condition
P0298 Engine Oil Overtemperature Condition
P0299 Turbo / Super Charger Underboost
P0300 Random Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0313 Misfire Detected with Low Fuel
P0314 Single Cylinder Misfire (Cylinder not Specified)
P0315 Crankshaft Position System Variation Not Learned
P0316 Misfire Detected On Startup (First 1000 Revolutions)
P0317 Rough Road Hardware Not Present
P0318 Rough Road Sensor A Signal Circuit
P0319 Rough Road Sensor B Signal Circuit
P0320 Ignition/Distributor Engine Speed Input Circuit
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0324 Knock Control System Error
P0325 Knock Sensor 1 Circuit (Bank 1)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1)
P0327 Knock Sensor 1 Circuit Low Input (Bank1)
P0328 Knock Sensor 1 Circuit High Input (Bank 1)
P0329 Knock Sensor 1 Circuit Intermittent (Bank 1)
P0330 Knock Sensor 2 Circuit (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor A Circuit (Bank 1 or single sensor)
P0341 Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or single sensor)
P0342 Camshaft Position Sensor A Circuit Low Input (Bank 1 or single sensor)
P0343 Camshaft Position Sensor A Circuit High Input (Bank 1 or single sensor)
P0344 Camshaft Position Sensor A Circuit Intermittent (Bank 1 or single sensor)
P0345 Camshaft Position Sensor A Circuit (Bank 2)
P0346 Camshaft Position Sensor A Circuit Range/Performance (Bank 2)
P0347 Camshaft Position Sensor A Circuit Low Input (Bank 2)
P0348 Camshaft Position Sensor A Circuit High Input (Bank 2)
P0349 Camshaft Position Sensor A Circuit Intermittent (Bank 2)
P0350 Ignition Coil Primary/Secondary Circuit
P0351 Ignition Coil A Primary/Secondary Circuit
P0352 Ignition Coil B Primary/Secondary Circuit
P0353 Ignition Coil C Primary/Secondary Circuit
P0354 Ignition Coil D Primary/Secondary Circuit
P0355 Ignition Coil E Primary/Secondary Circuit
P0356 Ignition Coil F Primary/Secondary Circuit
P0357 Ignition Coil G Primary/Secondary Circuit
P0358 Ignition Coil H Primary/Secondary Circuit
P0359 Ignition Coil I Primary/Secondary Circuit
P0360 Ignition Coil J Primary/Secondary Circuit
P0361 Ignition Coil K Primary/Secondary Circuit
P0362 Ignition Coil L Primary/Secondary Circuit
P0363 Misfire Detected - Fueling Disabled
P0365 Camshaft Position Sensor B Circuit (Bank 1)
P0366 Camshaft Position Sensor B Circuit Range/Performance (Bank 1)
P0367 Camshaft Position Sensor B Circuit Low Input (Bank 1)
P0368 Camshaft Position Sensor B Circuit High Input (Bank 1)
P0369 Camshaft Position Sensor B Circuit Intermittent (Bank 1)
P0370 Timing Reference High Resolution Signal A
P0371 Timing Reference High Resolution Signal A Too Many Pulses
P0372 Timing Reference High Resolution Signal A Too Few Pulses
P0373 Timing Reference High Resolution Signal A Intermittent
P0374 Timing Reference High Resolution Signal A No Pulses
P0375 Timing Reference High Resolution Signal B
P0376 Timing Reference High Resolution Signal B Too Many Pulses
P0377 Timing Reference High Resolution Signal B Too Few Pulses
P0378 Timing Reference High Resolution Signal B Intermittent
P0379 Timing Reference High Resolution Signal B No Pulses
P0380 Glow Plug/Heater Circuit A
P0381 Glow Plug/Heater Indicator Circuit
P0382 Glow Plug/Heater Circuit B
P0383 Glow Plug Control Module Control Circuit Low
P0384 Glow Plug Control Module Control Circuit High
P0385 Crankshaft Position Sensor B Circuit
P0386 Crankshaft Position Sensor B Circuit Range/Performance
P0387 Crankshaft Position Sensor B Circuit Low Input
P0388 Crankshaft Position Sensor B Circuit High Input
P0389 Crankshaft Position Sensor B Circuit Intermittent
P0390 Camshaft Position Sensor B Circuit (Bank 2)
P0391 Camshaft Position Sensor B Circuit Range/Performance (Bank 2)
P0392 Camshaft Position Sensor B Circuit Low Input (Bank 2)
P0393 Camshaft Position Sensor B Circuit High Input (Bank 2)
P0394 Camshaft Position Sensor B Circuit Intermittent (Bank 2)
P0400 Exhaust Gas Recirculation Flow
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Control Circuit
P0404 Exhaust Gas Recirculation Control Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0409 Exhaust Gas Recirculation Sensor A Circuit
P040A Exhaust Gas Recirculation Temperature Sensor Circuit
P040B Exhaust Gas Recirculation Temperature Sensor Circuit Range/Performance
P040C Exhaust Gas Recirculation Temperature Sensor Circuit Low
P040D Exhaust Gas Recirculation Temperature Sensor Circuit High
P040E Exhaust Gas Recirculation Temperature Sensor Circuit Intermittent/Erratic
P0410 Secondary Air Injection System
P0411 Secondary Air Injection Incorrect Upstream Flow Detected
P0412 Secondary Air Injection Switching Valve A Circuit
P0413 Secondary Air Injection Switching Valve A Circuit Open
P0414 Secondary Air Injection Switching Valve A Circuit Shorted
P0415 Secondary Air Injection Switching Valve B Circuit
P0416 Secondary Air Injection Switching Valve B Circuit Open
P0417 Secondary Air Injection Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Control A Circuit
P0419 Secondary Air Injection System Control B Circuit
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0425 Catalyst Temperature Sensor Circuit (Bank 1, Sensor Circuit 1)
P0426 Catalyst Temperature Sensor Circuit Range/Performance (Bank 1, Sensor Circuit 1)
P0427 Catalyst Temperature Sensor Circuit Low Input (Bank 1, Sensor Circuit 1)
P0428 Catalyst Temperature Sensor Circuit High Input (Bank 1, Sensor Circuit 1)
P0429 Catalyst Heater Control Circuit (Bank 1)
P042A Catalyst Temperature Sensor Circuit (Bank 1, Sensor Circuit 2)
P042B Catalyst Temperature Sensor Circuit Range/Performance (Bank1, Sensor Circuit 2)
P042C Catalyst Temperature Sensor Circuit Low Input (Bank 1, Sensor Circuit 2)
P042D Catalyst Temperature Sensor Circuit High Input (Bank 1, Sensor Circuit 2)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0435 Catalyst Temperature Sensor Circuit (Bank 2, Sensor Circuit 1)
P0436 Catalyst Temperature Sensor Circuit Range/Performance (Bank 2, Sensor Circuit 1)
P0437 Catalyst Temperature Sensor Circuit Low Input (Bank 2, Sensor Circuit 1)
P0438 Catalyst Temperature Sensor Circuit High Input (Bank 2, Sensor Circuit 1)
P0439 Catalyst Heater Control Circuit (Bank 2)
P043A Catalyst Temperature Sensor Circuit (Bank 2, Sensor Circuit 2)
P043B Catalyst Temperature Sensor Circuit Range/Performance (Bank 2, Sensor Circuit 2)
P043C Catalyst Temperature Sensor Circuit Low Input (Bank 2, Sensor Circuit 2)
P043D Catalyst Temperature Sensor Circuit High Input (Bank 2, Sensor Circuit 2)
P043E Evaporative Emission System Leak Detection Reference Orifice Low Flow
P043F Evaporative Emission System Leak Detection Reference Orifice High Flow
P0440 Evaporative Emission System
P0441 Evaporative Emission System Incorrect Purge Flow
P0442 Evaporative Emission System Leak Detected (small leak)
P0443 Evaporative Emission System Purge Control Valve Circuit
P0444 Evaporative Emission System Purge Control Valve Circuit Open
P0445 Evaporative Emission System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission System Vent Control Circuit
P0447 Evaporative Emission System Vent Control Circuit Open
P0448 Evaporative Emission System Vent Control Circuit Shorted
P0449 Evaporative Emission System Vent Control Circuit Intermittent
P0450 Evaporative Emission System Pressure Sensor/Switch
P0451 Evaporative Emission System Pressure Sensor/Switch Range/Performance
P0452 Evaporative Emission System Pressure Sensor/Switch Low Input
P0453 Evaporative Emission System Pressure Sensor/Switch High Input
P0454 Evaporative Emission System Pressure Sensor/Switch Intermittent
P0455 Evaporative Emission System Leak Detected (gross leak/no flow)
P0456 Evaporative Emission System Leak Detected (very small leak)
P0457 Evaporative Emission System Leak Detected (fuel cap loose/off)
P0458 Evaporative Emission System Purge Control Valve Circuit Low
P0459 Evaporative Emission System Purge Control Valve Circuit High
P0460 Fuel Level Sensor A Circuit
P0461 Fuel Level Sensor A Circuit Range/Performance
P0462 Fuel Level Sensor A Circuit Low Input
P0463 Fuel Level Sensor A Circuit High Input
P0464 Fuel Level Sensor A Circuit Intermittent
P0465 Evaporative Emission System Purge Flow Sensor Circuit
P0466 Evaporative Emission System Purge Flow Sensor Circuit Range/Performance
P0467 Evaporative Emission System Purge Flow Sensor Circuit Low Input
P0468 Evaporative Emission System Purge Flow Sensor Circuit High Input
P0469 Evaporative Emission System Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low Input
P0473 Exhaust Pressure Sensor High Input
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low Input
P0478 Exhaust Pressure Control Valve High Input
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Fan 1 Control Circuit
P0481 Fan 2 Control Circuit
P0482 Fan 3 Control Circuit
P0483 Fan Performance
P0484 Fan Current
P0485 Fan Power/Ground Circuit
P0486 Exhaust Gas Recirculation Sensor B Circuit
P0487 EGR Throttle Position Control Circuit
P0488 EGR Throttle Position Control Range/Performance
P0489 Exhaust Gas Recirculation Control Circuit Low
P0490 Exhaust Gas Recirculation Control Circuit High
P0491 Secondary Air Injection System Insufficient Flow (Bank 1)
P0492 Secondary Air Injection System Insufficient Flow (Bank 2)
P0493 Fan Overspeed (clutch locked)
P0494 Fan Speed Low
P0495 Fan Speed High
P0496 Evaporative Emission System High Purge Flow
P0497 Evaporative Emission System Low Purge Flow
P0498 Evaporative Emission System Vent Control Circuit Low
P0499 Evaporative Emission System Vent Control Circuit High
P0500 Vehicle Speed Sensor A
P0501 Vehicle Speed Sensor A Range/Performance
P0502 Vehicle Speed Sensor A Circuit Low Input
P0503 Vehicle Speed Sensor A Intermittent/Erratic/High
P0504 Brake Switch A / B Correlation
P0505 Idle Air Control System
P0506 Idle Air Control System RPM Lower Than Expected
P0507 Idle Air Control System RPM Higher Than Expected
P0508 Idle Air Control System Circuit Low
P0509 Idle Air Control System Circuit High
P0510 Closed Throttle Position Switch
P0511 Idle Air Control Circuit
P0512 Starter Request Circuit
P0513 Incorrect Immobilizer Key
P0514 Battery Temperature Sensor Circuit Range/Performance
P0515 Battery Temperature Sensor Circuit
P0516 Battery Temperature Sensor Circuit Low
P0517 Battery Temperature Sensor Circuit High
P0518 Idle Air Control Circuit Intermittent
P0519 Idle Air Control Circuit System Performance
P0520 Engine Oil Pressure Sensor/Switch Circuit
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Input
P0523 Engine Oil Pressure Sensor/Switch Circuit High Input
P0524 Engine Oil Pressure Too Low
P0525 Cruise Control Servo Control Circuit Range/Performance
P0526 Fan Speed Sensor Circuit
P0527 Fan Speed Sensor Circuit Range/Performance
P0528 Fan Speed Sensor Circuit No Signal
P0529 Fan Speed Sensor Circuit Intermittent
P0530 A/C Refrigerant Pressure Sensor A Circuit
P0531 A/C Refrigerant Pressure Sensor A Circuit Range/Performance
P0532 A/C Refrigerant Pressure Sensor A Circuit Low Input
P0533 A/C Refrigerant Pressure Sensor A Circuit High Input
P0534 A/C Refrigerant Charge Loss
P0535 A/C Evaporator Temperature Sensor Circuit
P0536 A/C Evaporator Temperature Sensor Circuit Range/Performance
P0537 A/C Evaporator Temperature Sensor Circuit Low
P0538 A/C Evaporator Temperature Sensor Circuit High
P0539 A/C Evaporator Temperature Sensor Circuit Intermittent
P0540 Intake Air Heater A Circuit
P0541 Intake Air Heater A Circuit Low
P0542 Intake Air Heater A Circuit High
P0543 Intake Air Heater A Circuit Open
P0544 Exhaust Gas Temperature Sensor Circuit - Bank 1 Sensor 1
P0545 Exhaust Gas Temperature Sensor Circuit Low - Bank 1 Sensor 1
P0546 Exhaust Gas Temperature Sensor Circuit High - Bank 1 Sensor 1
P0547 Exhaust Gas Temperature Sensor Circuit - Bank 2 Sensor 1
P0548 Exhaust Gas Temperature Sensor Circuit Low - Bank 2 Sensor 1
P0549 Exhaust Gas Temperature Sensor Circuit High - Bank 2 Sensor 1
P0550 Power Steering Pressure Sensor/Switch Circuit
P0551 Power Steering Pressure Sensor/Switch Circuit Range/Performance
P0552 Power Steering Pressure Sensor/Switch Circuit Low Input
P0553 Power Steering Pressure Sensor/Switch Circuit High Input
P0554 Power Steering Pressure Sensor/Switch Circuit Intermittent
P0555 Brake Booster Pressure Sensor Circuit
P0556 Brake Booster Pressure Sensor Circuit Range/Performance
P0557 Brake Booster Pressure Sensor Circuit Low Input
P0558 Brake Booster Pressure Sensor Circuit High Input
P0559 Brake Booster Pressure Sensor Circuit Intermittent
P0560 System Voltage
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0564 Cruise Control Multi-Function Input A Circuit
P0565 Cruise Control ON Signal
P0566 Cruise Control OFF Signal
P0567 Cruise Control RESUME Signal
P0568 Cruise Control SET Signal
P0569 Cruise Control COAST Signal
P0570 Cruise Control ACCEL Signal
P0571 Brake Switch A Circuit
P0572 Brake Switch A Circuit Low
P0573 Brake Switch A Circuit High
P0574 Cruise Control System - Vehicle Speed Too High
P0575 Cruise Control Input Circuit
P0576 Cruise Control Input Circuit Low
P0577 Cruise Control Input Circuit High
P0578 Cruise Control Multi-Function Input A Circuit Stuck
P0579 Cruise Control Multi-Function Input A Circuit Range/Performance
P0580 Cruise Control Multi-Function Input A Circuit Low
P0581 Cruise Control Multi-Function Input A Circuit High
P0582 Cruise Control Vacuum Control Circuit /Open
P0583 Cruise Control Vacuum Control Circuit Low
P0584 Cruise Control Vacuum Control Circuit High
P0585 Cruise Control Multi-Function Input A / B Correlation
P0586 Cruise Control Vent Control Circuit / Open
P0587 Cruise Control Vent Control Circuit Low
P0588 Cruise Control Vent Control Circuit High
P0589 Cruise Control Multi-Function Input B Circuit
P0590 Cruise Control Multi-Function Input B Circuit Stuck
P0591 Cruise Control Multi-Function Input B Circuit Range/Performance
P0592 Cruise Control Multi-Function Input B Circuit Low
P0593 Cruise Control Multi-Function Input B Circuit High
P0594 Cruise Control Servo Control Circuit / Open
P0595 Cruise Control Servo Control Circuit Low
P0596 Cruise Control Servo Control Circuit High
P0597 Thermostat Heater Control Circuit / Open
P0598 Thermostat Heater Control Circuit Low
P0599 Thermostat Heater Control Circuit High
P0600 Serial Communication Link
P0601 Internal Control Module Memory Check Sum Error
P0602 Powertrain Control Module Programming Error
P0603 Powertrain Control Module Keep Alive Memory (KAM) Error
P0604 Powertrain Control Module Random Access Memory (RAM) Error
P0605 Powertrain Control Module Read Only Memory (ROM) Error
P0606 ECM / PCM Processor
P0607 Control Module Performance
P0608 Powertrain Control Module Vehicle Speed Output A
P0609 Powertrain Control Module Vehicle Speed Output B
P060A Internal Control Module Monitoring Processor Performance
P060B Internal Control Module A/D Processing Performance
P060C Internal Control Module Main Processor Performance
P060D Internal Control Module Accelerator Pedal Position Performance
P060E Internal Control Module Throttle Position Performance
P060F Internal Control Module Engine Coolant Temperature Performance
P0610 Control Module Vehicle Options Error
P0611 Fuel Injector Control Module Performance
P0612 Fuel Injector Control Module Relay Control Circuit
P0613 TCM Processor
P0614 ECM / TCM Incompatible
P0615 Starter Relay Circuit
P0616 Starter Relay Circuit Low
P0617 Starter Relay Circuit High
P0618 Alternative Fuel Control Module KAM Error
P0619 Alternative Fuel Control Module RAM/ROM Error
P061A Internal Control Module Torque Performance
P061B Internal Control Module Torque Calculation Performance
P061C Internal Control Module Engine RPM Performance
P061D Internal Control Module Engine Air Mass Performance
P061E Internal Control Module Brake Signal Performance
P061F Internal Control Module Throttle Actuator Controller Performance
P0620 Generator Control Circuit
P0621 Generator Lamp Terminal Circuit
P0622 Generator Field Terminal Circuit
P0623 Generator Lamp Control Circuit
P0624 Fuel Cap Lamp Control Circuit
P0625 Generator Field Terminal Circuit Low
P0626 Generator Field Terminal Circuit High
P0627 Fuel Pump A Control Circuit / Open
P0628 Fuel Pump A Control Circuit Low
P0629 Fuel Pump A Control Circuit High
P062A Fuel Pump A Control Circuit Range/Performance
P062B Internal Control Module Fuel Injector Control Performance
P062C Internal Control Module Vehicle Speed Performance
P062D Fuel Injector Driver Circuit Performance Bank 1
P062E Fuel Injector Driver Circuit Performance Bank 2
P062F Powertrain Control Module EEPROM Error
P0630 VIN Not Programmed or Incompatible - ECM/PCM
P0631 VIN Not Programmed or Incompatible - TCM
P0632 Odometer Not Programmed - ECM/PCM
P0633 Immobolizer Key Not Programmed - ECM/PCM
P0634 PCM / ECM / TCM Internal Temperature Too High
P0635 Power Steering Control Circuit
P0636 Power Steering Control Circuit Low
P0637 Power Steering Control Circuit High
P0638 Throttle Actuator Control Range/Performance - Bank 1
P0639 Throttle Actuator Control Range/Performance - Bank 2
P0640 Intake Air Heater Control Circuit
P0641 Sensor Reference Voltage A Circuit/Open
P0642 Sensor Reference Voltage A Circuit Low
P0643 Sensor Reference Voltage A Circuit High
P0644 Driver Display Serial Communication Circuit
P0645 A/C Clutch Relay Control Circuit
P0646 A/C Clutch Relay Control Circuit Low
P0647 A/C Clutch Relay Control Circuit High
P0648 Immobilizer Lamp Control Circuit
P0649 Cruise Control Lamp Control Circuit
P0650 Malfunction Indicator Light Control Circuit
P0651 Sensor Reference Voltage B Circuit/Open
P0652 Sensor Reference Voltage B Circuit Low
P0653 Sensor Reference Voltage B Circuit High
P0654 Engine RPM Output Circuit
P0655 Engine Hot Lamp Output Control Circuit
P0656 Fuel level Output Circuit
P0657 Actuator Supply Voltage A Circuit / Open
P0658 Actuator Supply Voltage A Circuit Low
P0659 Actuator Supply Voltage A Circuit High
P0660 Intake Manifold Tuning Valve Control Circuit / Open - Bank 1
P0661 Intake Manifold Tuning Valve Control Circuit Low - Bank 1
P0662 Intake Manifold Tuning Valve Control Circuit High - Bank 1
P0663 Intake Manifold Tuning Valve Control Circuit / Open - Bank 2
P0664 Intake Manifold Tuning Valve Control Circuit Low - Bank 2
P0665 Intake Manifold Tuning Valve Control Circuit High - Bank 2
P0666 PCM / ECM / TCM Internal Temperature Sensor Circuit
P0667 PCM / ECM / TCM Internal Temperature Sensor Range/Performance
P0668 PCM / ECM / TCM Internal Temperature Sensor Circuit Low
P0669 PCM / ECM / TCM Internal Temperature Sensor Circuit High
P0670 Glow Plug Control Module Control Circuit / Open
P0671 Cylinder 1 Glow Plug Circuit
P0672 Cylinder 2 Glow Plug Circuit
P0673 Cylinder 3 Glow Plug Circuit
P0674 Cylinder 4 Glow Plug Circuit
P0675 Cylinder 5 Glow Plug Circuit
P0676 Cylinder 6 Glow Plug Circuit
P0677 Cylinder 7 Glow Plug Circuit
P0678 Cylinder 8 Glow Plug Circuit
P0679 Cylinder 9 Glow Plug Circuit
P0680 Cylinder 10 Glow Plug Circuit
P0681 Cylinder 11 Glow Plug Circuit
P0682 Cylinder 12 Glow Plug Circuit
P0683 Glow Plug Control Module to PCM Communication Circuit
P0684 Glow Plug Control Module to PCM Communication Circuit Range/Performance
P0685 ECM/PCM Power Relay Control Circuit/Open
P0686 ECM/PCM Power Relay Control Circuit Low
P0687 ECM/PCM Power Relay Control Circuit High
P0688 ECM/PCM Power Relay Sense Circuit
P0689 ECM/PCM Power Relay Sense Circuit Low
P0690 ECM/PCM Power Relay Sense Circuit High
P0691 Fan 1 Control Circuit Low
P0692 Fan 1 Control Circuit High
P0693 Fan 2 Control Circuit Low
P0694 Fan 2 Control Circuit High
P0695 Fan 3 Control Circuit Low
P0696 Fan 3 Control Circuit High
P0697 Sensor Reference Voltage C Circuit / Open
P0698 Sensor Reference Voltage C Circuit Low
P0699 Sensor Reference Voltage C Circuit High
P0700 Transmission Control System (MIL Request)
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Brake Switch B Input Circuit
P0704 Clutch Switch Input Circuit
P0705 Transmission Range Sensor A Circuit (PRNDL Input)
P0706 Transmission Range Sensor A Circuit Range/Performance
P0707 Transmission Range Sensor A Circuit Low Input
P0708 Transmission Range Sensor A Circuit High Input
P0709 Transmission Range Sensor A Circuit Intermittent
P0710 Transmission Fluid Temperature Sensor A Circuit
P0711 Transmission Fluid Temperature Sensor A Circuit Range/Performance
P0712 Transmission Fluid Temperature Sensor A Circuit Low Input
P0713 Transmission Fluid Temperature Sensor A Circuit High Input
P0714 Transmission Fluid Temperature Sensor A Circuit Intermittent
P0715 Turbine/Input Shaft Speed Sensor A Circuit
P0716 Turbine/Input Shaft Speed Sensor A Circuit Range/Performance
P0717 Turbine/Input Shaft Speed Sensor A Circuit No Signal
P0718 Turbine/Input Shaft Speed Sensor A Circuit Intermittent
P0719 Brake Switch B Input Circuit Low
P0720 Output Shaft Speed Sensor Circuit
P0721 Output Shaft Speed Sensor Circuit Range/Performance
P0722 Output Shaft Speed Sensor Circuit No Signal
P0723 Output Shaft Speed Sensor Circuit Intermittent
P0724 Brake Switch B Input Circuit High
P0725 Engine Speed Input Circuit
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0729 Gear 6 Incorrect Ratio
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0735 Gear 5 Incorrect Ratio
P0736 Reverse Incorrect Ratio
P0737 TCM Engine Speed Output Circuit
P0738 TCM Engine Speed Output Circuit Low
P0739 TCM Engine Speed Output Circuit High
P0740 Torque Converter Clutch Solenoid Circuit / Open
P0741 Torque Converter Clutch Solenoid Circuit Performance Or Stuck Off
P0742 Torque Converter Clutch Solenoid Circuit Stuck On
P0743 Torque Converter Clutch Solenoid Circuit Electrical
P0744 Torque Converter Clutch Solenoid Circuit Intermittent
P0745 Pressure Control Solenoid A
P0746 Pressure Control Solenoid A Performance or Stuck Off
P0747 Pressure Control Solenoid A Stuck On
P0748 Pressure Control Solenoid A Electrical
P0749 Pressure Control Solenoid A Intermittent
P0750 Shift Solenoid A
P0751 Shift Solenoid A Performance or Stuck Off
P0752 Shift Solenoid A Stuck On
P0753 Shift Solenoid A Electrical
P0754 Shift Solenoid A Intermittent
P0755 Shift Solenoid B
P0756 Shift Solenoid B Performance or Stuck Off
P0757 Shift Solenoid B Stuck On
P0758 Shift Solenoid B Electrical
P0759 Shift Solenoid B Intermittent
P0760 Shift Solenoid C
P0761 Shift Solenoid C Performance or Stuck Off
P0762 Shift Solenoid C Stuck On
P0763 Shift Solenoid C Electrical
P0764 Shift Solenoid C Intermittent
P0765 Shift Solenoid D
P0766 Shift Solenoid D Performance or Stuck Off
P0767 Shift Solenoid D Stuck On
P0768 Shift Solenoid D Electrical
P0769 Shift Solenoid D Intermittent
P0770 Shift Solenoid E
P0771 Shift Solenoid E Performance or Stuck Off
P0772 Shift Solenoid E Stuck On
P0773 Shift Solenoid E Electrical
P0774 Shift Solenoid E Intermittent
P0775 Pressure Control Solenoid B
P0776 Pressure Control Solenoid B Performance or Stuck Off
P0777 Pressure Control Solenoid B Stuck On
P0778 Pressure Control Solenoid B Electrical
P0779 Pressure Control Solenoid B Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift
P0782 2-3 Shift
P0783 3-4 Shift
P0784 4-5 Shift
P0785 Shift/Timing Solenoid
P0786 Shift/Timing Solenoid Range/Performance
P0787 Shift/Timing Solenoid Low
P0788 Shift/Timing Solenoid High
P0789 Shift/Timing Solenoid Intermittent
P0790 Normal/Performance Switch Circuit
P0791 Intermediate Shaft Speed Sensor A Circuit
P0792 Intermediate Shaft Speed Sensor A Circuit Range/Performance
P0793 Intermediate Shaft Speed Sensor A Circuit No Signal
P0794 Intermediate Shaft Speed Sensor A Circuit Intermittent
P0795 Pressure Control Solenoid C
P0796 Pressure Control Solenoid C Performance or Stuck Off
P0797 Pressure Control Solenoid C Stuck On
P0798 Pressure Control Solenoid C Electrical
P0799 Pressure Control Solenoid C Intermittent
P0800 Transfer Case Control System (MIL Request)
P0801 Reverse Inhibit Control Circuit
P0802 Transmission Control System MIL Request Circuit / Open
P0803 1-4 Upshift (skip shift) Solenoid Circuit
P0804 1-4 Upshift (skip shift) Lamp Control Circuit
P0805 Clutch Position Sensor Circuit
P0806 Clutch Position Sensor Circuit Range/Performance
P0807 Clutch Position Sensor Circuit Low
P0808 Clutch Position Sensor Circuit High
P0809 Clutch Position Sensor Circuit Intermittent
P080A Clutch Position Not Learned
P0810 Clutch Position Control Error
P0811 Excessive Clutch Slippage
P0812 Reverse Input Circuit
P0813 Reverse Output Circuit
P0814 Transmission Range Display Circuit
P0815 Upshift Switch Circuit
P0816 Downshift Switch Circuit
P0817 Starter Disable Circuit / Open
P0818 Driveline Disconnect Switch Input Circuit
P0819 Up and Down Shift Switch to Transmission Range Correlation
P081A Starter Disable Circuit Low
P081B Starter Disable Circuit High
P081C Park Input Circuit
P081D Neutral Input Circuit
P0820 Gear Lever X-Y Position Sensor Circuit
P0821 Gear Lever X Position Sensor Circuit
P0822 Gear Lever Y Position Sensor Circuit
P0823 Gear Lever X Position Sensor Circuit Intermittent
P0824 Gear Lever Y Position Sensor Circuit Intermittent
P0825 Gear Lever Push/Pull Switch Circuit (Shift Anticipate)
P0826 Up and Down Switch Input Circuit
P0827 Up and Down Switch Input Circuit Low
P0828 Up and Down Switch Input Circuit High
P0829 5-6 Shift
P0830 Clutch Pedal Switch A Circuit
P0831 Clutch Pedal Switch A Circuit Low
P0832 Clutch Pedal Switch A Circuit High
P0833 Clutch Pedal Switch B Circuit
P0834 Clutch Pedal Switch B Circuit Low
P0835 Clutch Pedal Switch B Circuit High
P0836 Four Wheel Drive (4WD) Switch Circuit
P0837 Four Wheel Drive (4WD) Switch Circuit Range/Performance
P0838 Four Wheel Drive (4WD) Switch Circuit Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
P0840 Transmission Fluid Pressure Sensor/Switch A Circuit
P0841 Transmission Fluid Pressure Sensor/Switch A Circuit Range/Performance
P0842 Transmission Fluid Pressure Sensor/Switch A Circuit Low
P0843 Transmission Fluid Pressure Sensor/Switch A Circuit High
P0844 Transmission Fluid Pressure Sensor/Switch A Circuit Intermittent
P0845 Transmission Fluid Pressure Sensor/Switch B Circuit
P0846 Transmission Fluid Pressure Sensor/Switch B Circuit Range/Performance
P0847 Transmission Fluid Pressure Sensor/Switch B Circuit Low
P0848 Transmission Fluid Pressure Sensor/Switch B Circuit High
P0849 Transmission Fluid Pressure Sensor/Switch B Circuit Intermittent
P0850 Park / Neutral Switch Input Circuit
P0851 Park / Neutral Switch Input Circuit Low
P0852 Park / Neutral Switch Input Circuit High
P0853 Drive Switch Input Circuit
P0854 Drive Switch Input Circuit Low
P0855 Drive Switch Input Circuit High
P0856 Traction Control Input Signal
P0857 Traction Control Input Signal Range/Performance
P0858 Traction Control Input Signal Low
P0859 Traction Control Input Signal High
P0860 Gear Shift Module Communication Circuit
P0861 Gear Shift Module Communication Circuit Low
P0862 Gear Shift Module Communication Circuit High
P0863 TCM Communication Circuit
P0864 TCM Communication Circuit Range/Performance
P0865 TCM Communication Circuit Low
P0866 TCM Communication Circuit High
P0867 Transmission Fluid Pressure
P0868 Transmission Fluid Pressure Low
P0869 Transmission Fluid Pressure High
P0870 Transmission Fluid Pressure Sensor/Switch C Circuit
P0871 Transmission Fluid Pressure Sensor/Switch C Circuit Range/Performance
P0872 Transmission Fluid Pressure Sensor/Switch C Circuit Low
P0873 Transmission Fluid Pressure Sensor/Switch C Circuit High
P0874 Transmission Fluid Pressure Sensor/Switch C Circuit Intermittent
P0875 Transmission Fluid Pressure Sensor/Switch D Circuit
P0876 Transmission Fluid Pressure Sensor/Switch D Circuit Range/Performance
P0877 Transmission Fluid Pressure Sensor/Switch D Circuit Low
P0878 Transmission Fluid Pressure Sensor/Switch D Circuit High
P0879 Transmission Fluid Pressure Sensor/Switch D Circuit Intermittent
P0880 TCM Power Input Signal
P0881 TCM Power Input Signal Range/Performance
P0882 TCM Power Input Signal Low
P0883 TCM Power Input Signal High
P0884 TCM Power Input Signal Intermittent
P0885 TCM Power Relay Control Circuit /Open
P0886 TCM Power Relay Control Circuit Low
P0887 TCM Power Relay Control Circuit High
P0888 TCM Power Relay Sense Circuit
P0889 TCM Power Relay Sense Circuit Range/Performance
P0890 TCM Power Relay Sense Circuit Low
P0891 TCM Power Relay Sense Circuit High
P0892 TCM Power Relay Sense Circuit Intermittent
P0893 Multiple Gears Engaged
P0894 Transmission Component Slipping
P0895 Shift Time Too Short
P0896 Shift Time Too Long
P0897 Transmission Fluid Deteriorated
P0898 Transmission Control System MIL Request Circuit Low
P0899 Transmission Control System MIL Request Circuit High
P0900 Clutch Actuator Circuit / Open
P0901 Clutch Actuator Circuit Range/Performance
P0902 Clutch Actuator Circuit Low
P0903 Clutch Actuator Circuit High
P0904 Gate Select Position Circuit [senses left / right position]
P0905 Gate Select Position Circuit Range/Performance
P0906 Gate Select Position Circuit Low
P0907 Gate Select Position Circuit High
P0908 Gate Select Position Circuit Intermittent
P0909 Gate Select Control Error
P0910 Gate Select Actuator Circuit / Open [left / right motion]
P0911 Gate Select Actuator Circuit Range/Performance
P0912 Gate Select Actuator Circuit Low
P0913 Gate Select Actuator Circuit High
P0914 Gear Shift Position Circuit [senses forward / rearward position, odd / even gears]
P0915 Gear Shift Position Circuit Range/Performance
P0916 Gear Shift Position Circuit Low
P0917 Gear Shift Position Circuit High
P0918 Gear Shift Position Circuit Intermittent
P0919 Gear Shift Position Control Error
P0920 Gear Shift Forward Actuator Circuit / Open [forward motion, odd gears, 1,3,5]
P0921 Gear Shift Forward Actuator Circuit Range/Performance
P0922 Gear Shift Forward Actuator Circuit Low
P0923 Gear Shift Forward Actuator Circuit High
P0924 Gear Shift Reverse Actuator Circuit / Open [rearward motion, even gears, 2,4,6]
P0925 Gear Shift Reverse Actuator Circuit Range/Performance
P0926 Gear Shift Reverse Actuator Circuit Low
P0927 Gear Shift Reverse Actuator Circuit High
P0928 Gear Shift Lock Solenoid Circuit / Open
P0929 Gear Shift Lock Solenoid Circuit Range/Performance
P0930 Gear Shift Lock Solenoid Circuit Low
P0931 Gear Shift Lock Solenoid Circuit High
P0932 Hydraulic Pressure Sensor Circuit
P0933 Hydraulic Pressure Sensor Range/Performance
P0934 Hydraulic Pressure Sensor Circuit Low Input
P0935 Hydraulic Pressure Sensor Circuit High Input
P0936 Hydraulic Pressure Sensor Circuit Intermittent
P0937 Hydraulic Oil Temperature Sensor Circuit
P0938 Hydraulic Oil Temperature Sensor Range/Performance
P0939 Hydraulic Oil Temperature Sensor Circuit Low Input
P0940 Hydraulic Oil Temperature Sensor Circuit High Input
P0941 Hydraulic Oil Temperature Sensor Circuit Intermittent
P0942 Hydraulic Pressure Unit
P0943 Hydraulic Pressure Unit Cycling Period Too Short
P0944 Hydraulic Pressure Unit Loss of Pressure
P0945 Hydraulic Pump Relay Circuit / Open
P0946 Hydraulic Pump Relay Circuit Range/Performance
P0947 Hydraulic Pump Relay Circuit Low
P0948 Hydraulic Pump Relay Circuit High
P0949 ASM Adaptive Learning Not Done
P0950 ASM Control Circuit [Up / Down / Auto / etc]
P0951 ASM Control Circuit Range/Performance
P0952 ASM Control Circuit Low
P0953 ASM Control Circuit High
P0954 ASM Control Circuit Intermittent
P0955 ASM Mode Circuit [Perf / Winter / Sport / etc]
P0956 ASM Mode Circuit Range/Performance
P0957 ASM Mode Circuit Low
P0958 ASM Mode Circuit High
P0959 ASM Mode Circuit Intermittent
P0960 Pressure Control Solenoid A Control Circuit / Open
P0961 Pressure Control Solenoid A Control Circuit Range/Performance
P0962 Pressure Control Solenoid A Control Circuit Low
P0963 Pressure Control Solenoid A Control Circuit High
P0964 Pressure Control Solenoid B Control Circuit / Open
P0965 Pressure Control Solenoid B Control Circuit Range/Performance
P0966 Pressure Control Solenoid B Control Circuit Low
P0967 Pressure Control Solenoid B Control Circuit High
P0968 Pressure Control Solenoid C Control Circuit / Open
P0969 Pressure Control Solenoid C Control Circuit Range/Performance
P0970 Pressure Control Solenoid C Control Circuit Low
P0971 Pressure Control Solenoid C Control Circuit High
P0972 Shift Solenoid A Control Circuit Range/Performance
P0973 Shift Solenoid A Control Circuit Low
P0974 Shift Solenoid A Control Circuit High
P0975 Shift Solenoid B Control Circuit Range/Performance
P0976 Shift Solenoid B Control Circuit Low
P0977 Shift Solenoid B Control Circuit High
P0978 Shift Solenoid C Control Circuit Range/Performance
P0979 Shift Solenoid C Control Circuit Low
P0980 Shift Solenoid C Control Circuit High
P0981 Shift Solenoid D Control Circuit Range/Performance
P0982 Shift Solenoid D Control Circuit Low
P0983 Shift Solenoid D Control Circuit High
P0984 Shift Solenoid E Control Circuit Range/Performance
P0985 Shift Solenoid E Control Circuit Low
P0986 Shift Solenoid E Control Circuit High
P0987 Transmission Fluid Pressure Sensor/Switch E Circuit
P0988 Transmission Fluid Pressure Sensor/Switch E Circuit Range/Performance
P0989 Transmission Fluid Pressure Sensor/Switch E Circuit Low
P0990 Transmission Fluid Pressure Sensor/Switch E Circuit High
P0991 Transmission Fluid Pressure Sensor/Switch E Circuit Intermittent
P0992 Transmission Fluid Pressure Sensor/Switch F Circuit
P0993 Transmission Fluid Pressure Sensor/Switch F Circuit Range/Performance
P0994 Transmission Fluid Pressure Sensor/Switch F Circuit Low
P0995 Transmission Fluid Pressure Sensor/Switch F Circuit High
P0996 Transmission Fluid Pressure Sensor/Switch F Circuit Intermittent
P0997 Shift Solenoid F Control Circuit Range/Performance
P0998 Shift Solenoid F Control Circuit Low
P0999 Shift Solenoid F Control Circuit High
P1000 OBD Systems Readiness Test Not Complete
P1001 KOER Not Able to Complete, KOER Aborted
P1100 Mass Air Flow Sensor Circuit Intermittent
P1101 Mass Air Flow Sensor Out Of Self Test Range
P1102 Mass Air Flow Sensor In Range But Lower Than Expected
P1103 Mass Air Flow Sensor In Range But Higher Than Expected
P1104 Mass Air Flow Sensor Circuit Ground
P1105 Dual Alternator Upper Fault
P1106 Dual Alternator Lower Fault
P1107 Dual Alternator Lower Circuit
P1108 Dual Alternator Battery Lamp Circuit
P1109 Intake Air Temperature 2 Circuit Intermittent
P1110 Intake Air Temperature Circuit (D/C) Open/Short
P1111 System Pass
P1112 Intake Air Temperature Circuit Intermittent
P1113 Intake Air Temperature Circuit (L/C) Open/Short
P1114 Intake Air Temperature 2 Circuit Low Input (Super/Turbo Charged engines)
P1115 Intake Air Temperature 2 Circuit High Input (Super/Turbo Charged engines)
P1116 Engine Coolant Temperature Sensor Out Of Self Test Range
P1117 Engine Coolant Temperature Sensor Circuit Intermittent
P1118 Manifold Air Temperature Circuit Low Input
P1119 Manifold Air Temperature Circuit High Input
P1120 Throttle Position Sensor A Out Of Range Low (Ratch too low)
P1121 Throttle Position Sensor A Inconsistent With MAF/MAP Sensor (see P006Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
P1122 Pedal Position Sensor A Circuit Low Input
P1123 Pedal Position Sensor A Circuit High Input
P1124 Throttle Position Sensor A Out Of Self Test Range
P1125 Throttle Position Sensor A Intermittent
P1126 Throttle Position (Narrow Range) Sensor Circuit
P1127 Exhaust Temperature Out of Range, O2 Sensor Tests Not Completed
P1128 Upstream HO2S Sensors Swapped (see P0040)
P1129 Downstream HO2S Sensors Swapped (see P0041)
P1130 Lack Of HO2S11 Switches - Fuel Trim At Limit
P1131 Lack Of HO2S11 Switches - Sensor Indicates Lean (see P2195)
P1132 Lack Of HO2S11 Switches - Sensor Indicates Rich (see P2196)
P1133 Bank 1 Fuel Control Shifted Lean (FAOSC) (See P2096)
P1134 Bank 1 Fuel Control Shifted Rich (FAOSC) (See P2097)
P1135 Pedal Position Sensor A Circuit Intermittent
P1136 Control Box Fan Circuit
P1137 Lack Of HO2S12 Switches - Sensor Indicates Lean (see P2270)
P1138 Lack Of HO2S12 Switches - Sensor Indicates Rich (see P2271)
P1139 Water in Fuel Indicator Circuit
P1140 Water in Fuel Condition
P1141 Fuel Restriction Indicator Circuit
P1142 Fuel Restriction Condition
P1143 Air Assisted Injector Control Valve Range/Performance
P1144 Air Assisted Injector Control Valve Circuit
P1145 Calculated Torque Error
P1146 Alternator Load Low Input (same as P1245, added for Jag)
P1147 Manifold Air Temperature / Intake Air Temperature Correlation
P1148 Generator 2 Control Circuit
P1149 Generator 2 Monitor Circuit High
P1150 Lack Of HO2S21 Switches - Fuel Trim At Limit
P1151 Lack Of HO2S21 Switches - Sensor Indicates Lean (see P2197)
P1152 Lack Of HO2S21 Switches - Sensor Indicates Rich (see P219Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
P1153 Bank 2 Fuel Control Shifted Lean (FAOSC) (See P209Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
P1154 Bank 2 Fuel Control Shifted Rich (FAOSC) (See P2099)
P1155 Alternative Fuel Control Module Has Activated the MIL
P1156 Fuel Select Switch Circuit
P1157 Lack Of HO2S22 Switches - Sensor Indicates Lean (see P2272)
P1158 Lack Of HO2S22 Switches - Sensor Indicates Rich (see P2273)
P1159 Fuel Stepper Motor
P115A Low Fuel Level - Forced Limited Power
P115B Low Fuel Level - Forced Engine Shutdown
P1167 Invalid Test, Operator Did Not Actuate Throttle
P1168 Fuel Rail Pressure Sensor In Range But Low
P1169 Fuel Rail Pressure Sensor In Range But High
P1170 Engine Shut Off Solenoid
P1171 Rotor Sensor
P1172 Rotor Control
P1173 Rotor Calibration
P1174 Cam Sensor
P1175 Cam Control
P1176 Cam Calibration
P1177 Synchronization
P1178 Boltup Limits
P1179 Long Term Fuel Trim Too Rich - Banks 1 and 2 (AMFR)
P1180 Fuel Delivery System - Low
P1181 Fuel Delivery System - High
P1182 Fuel Shut Off Solenoid Circuit
P1183 Engine Oil Temperature Sensor Circuit
P1184 Engine Oil Temperature Sensor Out Of Self Test Range
P1185 Fuel Pump Temperature Sensor High
P1186 Fuel Pump Temperature Sensor Low
P1187 Variant Selection
P1188 Calibration Memory
P1189 Pump Speed Signal
P1190 Calibration Resistor Out Of Range
P1191 Key Line Voltage
P1192 V External
P1193 EGR Driver Over Current
P1194 ECM/PCM A/D Converter
P1195 SCP HBCC Chip Failed to Initialize
P1196 Key Off Voltage High
P1197 Key Off Voltage Low
P1198 Pump Rotor Control Underfueling
P1199 Fuel Level Input Circuit Low
P1200 Injector Range/Performance
P1201 Cylinder #1 Injector Circuit Open/Shorted
P1202 Cylinder #2 Injector Circuit Open/Shorted
P1203 Cylinder #3 Injector Circuit Open/Shorted
P1204 Cylinder #4 Injector Circuit Open/Shorted
P1205 Cylinder #5 Injector Circuit Open/Shorted
P1206 Cylinder #6 Injector Circuit Open/Shorted
P1207 Cylinder #7 Injector Circuit Open/Shorted
P1208 Cylinder #8 Injector Circuit Open/Shorted
P1209 Injector Control Pressure Peak Delta Test Fault
P120A Secondary Fuel Injector Insufficient Flow, Bank 1 Secondary Fuel Injector Excessive Flow, Bank 1 Secondary Fuel Injector Insufficient Flow, Bank 2 Secondary Fuel Injector Insufficient Flow, Bank 1
P120B Secondary Fuel Injector Excessive Flow, Bank 1
P120C Secondary Fuel Injector Insufficient Flow, Bank 2
P120D Secondary Fuel Injector Excessive Flow, Bank 2
P1210 Injector Control Pressure Higher Than Desired (engine off)
P1211 Injector Control Pressure Higher/Lower Than Desired (engine running)
P1212 Injector Control Pressure Lower Than Desired (engine crank or run)
P1213 Start Injector Circuit
P1214 Pedal Position Sensor B Circuit Intermittent
P1215 Pedal Position Sensor C Circuit Low Input
P1216 Pedal Position Sensor C Circuit High Input
P1217 Pedal Position Sensor C Circuit Intermittent
P1218 CID High
P1219 CID Low
P1220 Series Throttle Control System
P1221 Traction Control System
P1222 Traction Control Output Circuit
P1223 Pedal Position Sensor B Circuit High Input
P1224 Throttle Position Sensor B Out Of Self Test Range
P1225 Needle Lift Sensor
P1226 Control Sleeve Sensor Circuit
P1227 Wastegate Failed Closed (Over pressure)
P1228 Wastegate Failed Open (Under pressure)
P1229 Charge Air Cooler Pump Driver
P1230 Fuel Pump Low Speed Malfunction (VLCM)
P1231 Fuel Pump Secondary Circuit Low, High Speed (VLCM)
P1232 Fuel Pump Speed Primary Circuit (Two speed fuel pump)
P1233 Fuel Pump Driver Module Disabled or Off Line (Fuel Pump Driver Module)
P1234 Fuel Pump Driver Module Disabled or Off Line (Fuel Pump Driver Module)
P1235 Fuel Pump Control out Of Range (Fuel Pump Driver Module/VLCM)
P1236 Fuel Pump Control Out Of Range (Fuel Pump Driver Module)
P1237 Fuel Pump Secondary Circuit (Fuel Pump Driver Module)
P1238 Fuel Pump Secondary Circuit (Fuel Pump Driver Module)
P1239 Speed Fuel Pump Positive Feed
P1240 Sensor Power Supply
P1241 Sensor Power Supply Low Input
P1242 Sensor Power Supply High Input
P1243 Second Fuel Pump Fault or Ground Fault
P1244 Alternator Load High Input (see P0626)
P1245 Alternator Load Low Input (see P0625)
P1246 Alternator Load Input (see P0622)
P1247 Turbo Boost Pressure Low
P1248 Turbo Boost Pressure Not Detected
P1249 Wastegate Control Valve Performance
P1250 Throttle Valve Spring
P1251 Air Mixture Solenoid Circuit
P1252 Pedal Correlation PDS1 and LPDS High
P1253 Pedal Correlation PDS1 and LPDS Low
P1254 Pedal Correlation PDS2 and LPDS High
P1255 Pedal Correlation PDS2 and LPDS Low
P1256 Pedal Correlation PDS1 and HPDS
P1257 Pedal Correlation PDS2 and HPDS
P1258 Pedal Correlation PDS1 and PDS2
P1259 Immobilizer to PCM Signal Error
P1260 Theft Detected, Vehicle Immobilized
P1261 Cylinder #1 High To Low Side Short
P1262 Cylinder #2 High To Low Side Short
P1263 Cylinder #3 High To Low Side Short
P1264 Cylinder #4 High To Low Side Short
P1265 Cylinder #5 High To Low Side Short
P1266 Cylinder #6 High To Low Side Short
P1267 Cylinder #7 High To Low Side Short
P1268 Cylinder #8 High To Low Side Short
P1269 Immobilizer Code Not Programmed
P1270 Engine RPM or Vehicle Speed Limiter Reached
P1271 Cylinder #1 High To Low Side Open
P1272 Cylinder #2 High To Low Side Open
P1273 Cylinder #3 High To Low Side Open
P1274 Cylinder #4 High To Low Side Open
P1275 Cylinder #5 High To Low Side Open
P1276 Cylinder #6 High To Low Side Open
P1277 Cylinder #7 High To Low Side Open
P1278 Cylinder #8 High To Low Side Open
P1279 Control Sleeve Sensor Circuit Range/Performance
P1280 Injector Control Pressure Sensor Circuit Low
P1281 Injector Control Pressure Sensor Circuit High
P1282 Injector Control Pressure Higher Than Desired (engine running)
P1283 Injector Pressure Regulator Control Circuit
P1284 Aborted KOER - Injector Control Pressure Failure
P1285 Cylinder Head Overtemperature Condition
P1286 Fuel Pulsewidth In Range But Lower Than Expected
P1287 Fuel Pulsewidth In Range But Higher Than Expected
P1288 Cylinder Head Temperature Sensor Out Of Self Test Range
P1289 Cylinder Head Temperature Sensor Circuit High Input
P128A Cylinder Head Temperature Sensor Circuit Intermittent/Erratic
P1290 Cylinder Head Temperature Sensor Circuit Low Input
P1291 Injector High Side Short To GND Or VBATT - Bank 1
P1292 Injector High Side Short To GND Or VBATT - Bank 2
P1293 Injector High Side Open - Bank 1
P1294 Injector High Side Open - Bank 2
P1295 Injector Multiple Faults - Bank 1
P1296 Injector Multiple Faults - Bank 2
P1297 Injector High Side Switches Shorted Together
P1298 Injector Driver Module Failure
P1299 Cylinder Head Overtemperature Protection Active
P1300 Boost Calibration Fault
P1301 Boost Calibration High
P1302 Boost Calibration Low
P1303 Exhaust Gas Recirculation Calibration Fault
P1304 Exhaust Gas Recirculation Calibration High
P1305 Exhaust Gas Recirculation Calibration Low
P1306 Kickdown Relay Pull-in Circuit
P1307 Kickdown Relay Hold Circuit
P1308 A/C Clutch Circuit
P1309 Misfire Monitor Hardware - CMP Misaligned, CKP/CMP Noise, PCM AICE Chip
P1310 Ionization Misfire Detection Module Fault
P1311 Ionization Misfire Detection Module Communication Fault
P1312 Injection Pump Timing Actuator Circuit
P1313 Misfire Rate Catalyst Damage Fault - Bank 1
P1314 Misfire Rate Catalyst Damage Fault - Bank 2
P1315 Persistent Misfire
P1316 Injector Driver Module Codes Detected
P1317 Injector Circuit/Injector Driver Module Codes Not Retrieved
P1318 Injection Timing Piston Position Sensor Circuit
P1319 Injection Timing Piston Position Sensor Circuit Range/Performance
P1320 Distributor Signal Interrupt
P1321 Cylinder #9 High To Low Side Short
P1322 Cylinder #10 High To Low Side Short
P1323 Cylinder #11 High To Low Side Short
P1324 Cylinder #12 High To Low Side Short
P1325 Cylinder #9 High To Low Side Open
P1326 Cylinder #10 High To Low Side Open
P1327 Cylinder #11 High To Low Side Open
P1328 Cylinder #12 High To Low Side Open
P1329 Injector Control Pressure Higher Than Desired (engine running)
P1330 Injector Control Pressure Lower Than Desired (engine running)
P1331 Turbo/Super Charger Boost High Side Control Circuit / Open
P1332 Turbo/Super Charger Boost High Side Control Circuit Low
P1333 Turbo/Super Charger Boost High Side Control Circuit High
P1334 EGR Throttle Position Sensor Minumum/Maximum Stop Performance
P1335 EGR Position Sensor Minimum/Maximum Stop Performance
P1336 Crankshaft/Camshaft Sensor Range/Performance
P1337 Throttle Position Output Circuit
P1338 Fuel Pump Driver Module Communication Circuit (Fuel Pump Driver Module)
P1339 Fuel Pump Driver Module Communication Circuit (Fuel Pump Driver Module)
P1340 Camshaft Position Sensor B Circuit
P1341 Camshaft Position Sensor B Circuit Range/Performance
P1342 Pedal Demand Sensor A Circuit Range/Performance
P1343 Pedal Demand Sensor B Circuit Range/Performance
P1344 Pedal Demand Sensor C Circuit Range/Performance
P1345 Cylinder Discrimination Signal (from CMP sensor)
P1346 Fuel Level Sensor B Circuit
P1347 Fuel Level Sensor B Circuit Range/Performance
P1348 Fuel Level Sensor B Circuit Low Input
P1349 Fuel Level Sensor B Circuit High Input
P1350 Fuel Level Sensor B Circuit Intermittent
P1351 Ignition Diagnostic Monitor Input Circuit
P1352 Ignition Coil A Primary Circuit
P1353 Ignition Coil B Primary Circuit
P1354 Ignition Coil C Primary Circuit
P1355 Ignition Coil D Primary Circuit
P1356 Ignition Diagnostic Monitor Indicates Engine Not Turning
P1357 Ignition Diagnostic Monitor Pulsewidth Not Defined
P1358 Ignition Diagnostic Monitor Signal Out Of Self Test Range (no CPU OK)
P1359 Spark Output Circuit
P1360 Ignition Coil A Secondary Circuit
P1361 Ignition Coil B Secondary Circuit
P1362 Ignition Coil C Secondary Circuit
P1363 Ignition Coil D Secondary Circuit
P1364 Ignition Coil Primary Circuit
P1365 Ignition Coil Secondary Circuit
P1366 Ignition Spare
P1367 Ignition Spare
P1368 Ignition Spare
P1369 Engine Temperature Light Circuit
P1370 Insufficient RPM Increase During Spark Test
P1371 Ignition Coil - Cylinder 1 - Early Activation Fault
P1372 Ignition Coil - Cylinder 2 - Early Activation Fault
P1373 Ignition Coil - Cylinder 3 - Early Activation Fault
P1374 Ignition Coil - Cylinder 4 - Early Activation Fault
P1375 Ignition Coil - Cylinder 5 - Early Activation Fault
P1376 Ignition Coil - Cylinder 6 - Early Activation Fault
P1377 Injector Overvoltage Shut-down
P1378 Fuel Injector Control Module System Voltage Low
P1379 Fuel Injector Control Module System Voltage High
P1380 Camshaft Position Actuator Circuit (Bank 1) (see P0010)
P1381 Camshaft Position Timing Over Advanced (Bank 1) (see P0011)
P1382 Camshaft Position Timing Solenoid #1 Circuit
P1383 Camshaft Position Timing Over Retarded (Bank 1) (see P0012)
P1384 Variable Valve Timing Solenoid A Circuit
P1385 Camshaft Position Actuator Circuit (Bank 2) (see P0013)
P1386 Camshaft Position Timing Over Advanced (Bank 2) (see P0014)
P1387 Camshaft Position Timing Solenoid #2 Circuit (see P0015)
P1388 Camshaft Position Timing Over Retarded (Bank 2) (see P0022)
P1389 Glow Plug Circuit High Side, Low Input
P138A Glow Plug Control Module Control Circuit Range/Performance
P138B Glow Plug Control Module System Voltage
P1390 Octane Adjust Service Pin In Use/Circuit Open
P1391 Glow Plug Circuit Low Input (Bank 1)
P1392 Glow Plug Circuit High Input (Bank 1)
P1393 Glow Plug Circuit Low Input (Bank 2)
P1394 Glow Plug Circuit High Input (Bank 2)
P1395 Glow Plug Monitor Fault (Bank 1)
P1396 Glow Plug Monitor Fault (Bank 2)
P1397 System Voltage Out Of Self Test Range
P1398 Variable Valve Timing Solenoid B Circuit High Input
P1399 Glow Plug Circuit High Side, High Input
P1400 Differential Pressure Feedback EGR Circuit Low Input
P1401 Differential Pressure Feedback EGR Circuit High Input
P1402 Exhaust Gas Recirculation Metering Orifice Restricted
P1403 Differential Pressure Feedback Sensor Hoses Reversed
P1404 EGR Temperature Sensor Circuit
P1405 Differential Pressure Feedback Sensor Upstream Hose Off Or Plugged
P1406 Differential Pressure Feedback Sensor Downstream Hose Off Or Plugged
P1407 Exhaust Gas Recirculation No Flow Detected
P1408 Exhaust Gas Recirculation Flow Out Of Self Test Range
P1409 EGR Vacuum Regulator Solenoid Circuit
P140A Exhaust Gas Recirculation Sensor C Circuit Low
P140B Exhaust Gas Recirculation Sensor C Circuit High
P140C Exhaust Gas Recirculation Control Circuit B
P140D Exhaust Gas Recirculation Control Circuit B Range/Performance
P140E EGR Position Sensor C Minimum/Maximum Stop Performance
P140F EGR Throttle Stuck
P1410 Air Cleaner Inlet Control Circuit
P1411 Secondary Air Injection Incorrect Downstream Flow Detected
P1412 Exhaust Gas Recirculation Valve Frozen
P1413 Secondary Air Injection Monitor Circuit Low Input (See P2257)
P1414 Secondary Air Injection Monitor Circuit High Input (See P225Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
P1415 Air Pump Circuit
P1416 Port Air Circuit
P1417 Port Air Relief Circuit
P1418 Split Air #1 Circuit
P1419 Split Air #2 Circuit
P141A Exhaust Gas Recirculation Sensor A Circuit Intermittent/Erratic
P141B Exhaust Gas Recirculation Sensor B Circuit Intermittent/Erratic
P141C Exhaust Gas Recirculation Sensor C Circuit Intermittent/Erratic
P141E Catalyst Temperature Sensor 1/2 Correlation, Bank 1
P141F Catalyst Temperature Sensor 1/2 Correlation, Bank 2
P1420 Catalyst Temperature Sensor
P1421 Catalyst Damage
P1422 Exhaust Gas Ignition Temperature Sensor
P1423 Exhaust Gas Ignition Functional Test
P1424 Exhaust Gas Ignition Plug Primary
P1425 Exhaust Gas Ignition Plug Secondary
P1426 Exhaust Gas Ignition mini-MAF Sensor Out of Range
P1427 Exhaust Gas Ignition mini-MAF Sensor Circuit Shorted
P1428 Exhaust Gas Ignition mini-MAF Sensor Circuit Open
P1429 Electric Air Pump Primary
P1430 Electric Air Pump Secondary
P1431 Misfire Monitor Disabled, unable to learn wheel profile (to be deleted, see P0315)
P1432 Thermostat Heater Control Circuit
P1433 A/C Refrigerant Temperature Circuit Low
P1434 A/C Refrigerant Temperature Circuit High
P1435 A/C Refrigerant Temperature Circuit Range/Performance
P1436 A/C Evaporator Air Temperature Circuit Low (see P0537)
P1437 A/C Evaporator Air Temperature Circuit High (see P053Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
P1438 A/C Evaporator Air Temperature Circuit Range/Performance
P1439 Floor Temp Switch Circuit
P1440 Purge Valve Stuck Open
P1441 ELC System 1
P1442 Evaporative Emission System Control Leak Detected
P1443 Evaporative Emission System Control Valve (low/no flow)
P1444 Evaporative Emission System Purge Flow Sensor Circuit Low Input
P1445 Evaporative Emission System Purge Flow Sensor Circuit High Input
P1446 Evaporative Vacuum Solenoid Circuit
P1447 ELC System Closure Valve Flow
P1448 ELC System 2
P1449 Evaporative Check Solenoid Circuit
P1450 Unable to Bleed Up Fuel Tank Vacuum
P1451 Evaporative Emission System Vent Control Circuit
P1452 Unable to Bleed Up Fuel Tank Vacuum
P1453 Fuel Tank Pressure Relief Valve Malfunction
P1454 Evaporative Emission System Vacuum Test
P1455 Evaporative Emission System Control Leak Detected (gross leak/no flow)
P1456 Fuel Tank Temperature Sensor Circuit
P1457 Unable To Pull Fuel Tank Vacuum
P1458 Ignition Timing Control Solenoid
P1459 A/C Recirculation Switch Out of Self Test Range
P1460 Wide Open Throttle A/C Cutout Circuit (see P0645)
P1461 A/C Pressure Sensor Circuit High Input
P1462 A/C Pressure Sensor Circuit Low Input
P1463 A/C Pressure Sensor Insufficient Pressure Change
P1464 A/C Demand Out Of Self Test Range
P1465 A/C Relay Circuit
P1466 A/C Refrigerant Temperature Sensor Circuit
P1467 A/C Compressor Temperature Sensor
P1468 SSPOD Open Circuit or Closed Circuit
P1469 Rapid A/C Cycling (see P0534)
P1470 A/C Cycling Period Too Short
P1471 Electrodrive Fan 1 Operational Failure (Driver side)
P1472 Electrodrive Fan 2 Operational Failure (Passenger side)
P1473 Fan Circuit Open (VLCM)
P1474 Fan Control Primary Circuit
P1475 Fan Relay (Low) Circuit
P1476 Fan Relay (High) Circuit
P1477 Additional Fan Relay Circuit (see P0482)
P1478 Cooling Fan Driver
P1479 High Fan Control Primary Circuit
P1480 Fan Secondary Low With Low Fan On
P1481 Fan Secondary Low With High Fan On
P1482 SCP
P1483 Fan Circuit Shorted To Ground (VLCM)
P1484 Fan Driver Circuit Open To Power Ground (VLCM)
P1485 EGRV Circuit
P1486 EGRA Circuit
P1487 Exhaust Gas Recirculation Check Solenoid Circuit
P1488 Exhaust (muffler) Bypass Control Circuit
P1489 PCV Heater Control Circuit
P1490 Secondary Air Relief Solenoid Circuit
P1491 Secondary Switch Solenoid Circuit
P1492 APLSOL Solenoid Circuit
P1493 RCNT Solenoid Circuit
P1494 SPCUT Solenoid Circuit
P1495 TCSPL Solenoid Circuit
P1496 EGR Stepper Motor 1 Control Circuit Low/High
P1497 EGR Stepper Motor 2 Control Circuit Low/High
P1498 EGR Stepper Motor 3 Control Circuit Low/High
P1499 EGR Stepper Motor 4 Control Circuit Low/High
P1500 Vehicle Speed Sensor
P1501 Vehicle Speed Sensor Out Of Self Test Range
P1502 Vehicle Speed Sensor Intermittent
P1503 Auxiliary Speed Sensor
P1504 Idle Air Control Circuit (see P0511)
P1505 Idle Air Control System At Adaptive Clip
P1506 Idle Air Control Overspeed Error (see P0507)
P1507 Idle Air Control Underspeed Error (see P0506)
P1508 Idle Up Solenoid 1 Circuit
P1509 Idle Up Solenoid 2 Circuit
P1510 Idle Signal Circuit
P1511 Idle Switch (Electric Control Throttle) Circuit
P1512 Intake Manifold Runner Control Stuck Closed (Bank 1) (see P2006)
P1513 Intake Manifold Runner Control Stuck Closed (Bank 2) (see P2007)
P1514 High Load Neutral/Drive Fault
P1515 Electric Current Circuit
P1516 Intake Manifold Runner Control Input Error (Bank 1) (see P2014)
P1517 Intake Manifold Runner Control Input Error (Bank 2) (see P2019)
P1518 Intake Manifold Runner Control Stuck Open (Bank 1) (see P2004)
P1519 Intake Manifold Runner Control Stuck Closed (Bank 1) (see P2006)
P151A Intake Manifold Runner Controller Performance
P151B Idle Speed Control - RPM Lower Than Expected
P151C Idle Speed Control - RPM Higher Than Expected
P1520 Intake Manifold Runner Control Circuit (see P200Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
P1521 Variable Resonance Induction System Solenoid #1 Circuit
P1522 Variable Resonance Induction System Solenoid #2 Circuit
P1523 IVC Solenoid Circuit
P1524 Variable Intake Solenoid Circuit
P1525 Air Bypass Valve
P1526 Air Bypass System
P1527 Bypass Air Solenoid (Accelerate Warm-up) Circuit
P1528 Subsidiary Throttle Valve Solenoid Circuit
P1529 SCAIR Solenoid Circuit
P1530 A/C Clutch Circuit Open (VLCM)
P1531 Invalid Test - Accelerator Pedal Movement
P1532 Intake Manifold Communication Control Circuit (Bank 2) (see P0663)
P1533 Air Assisted Injector Circuit
P1534 Restraint Deployment Indicator Circuit
P1535 Blower Fan Speed Circuit Range/Performance
P1536 Parking Brake Switch Circuit
P1537 Intake Manifold Runner Control Stuck Open (Bank 1) (see P2004)
P1538 Intake Manifold Runner Control Stuck Open (Bank 2) (see P2005)
P1539 A/C Clutch Circuit Overcurrent/Short (VLCM)
P1540 Air Bypass Valve Circuit
P1541 Intake Manifold Runner Control Circuit Range/Performance
P1542 Primary PCM ID Circuit (dual PCM application)
P1543 Engine Coolant Heater A Control Circuit
P1544 Engine Coolant Heater B Control Circuit
P1545 Exhaust Gas Recirculation High Side Control Circuit / Open
P1546 Exhaust Gas Recirculation High Side Control Circuit Low
P1547 Exhaust Gas Recirculation High Side Control Circuit High
P1549 Intake Manifold Communication Control Circuit (Bank 1) (see P0660)
P1550 Power Steering Pressure Sensor Out Of Self Test Range
P1551 Injector Circuit Range/Performance - Cylinder 1
P1552 Injector Circuit Range/Performance - Cylinder 2
P1553 Injector Circuit Range/Performance - Cylinder 3
P1554 Injector Circuit Range/Performance - Cylinder 4
P1555 Injector Circuit Range/Performance - Cylinder 5
P1556 Injector Circuit Range/Performance - Cylinder 6
P1557 Injector Circuit Range/Performance - Cylinder 7
P1558 Injector Circuit Range/Performance - Cylinder 8
P1562 PCM B+ Voltage Low (KAM power)
P1563 Injection Pump Control Module Requesting Engine Stop
P1564 Injection Pump Control Module Requesting Reduced Fueling
P1565 Speed Control Command Switch Out Of Range High
P1566 Speed Control Command Switch Out Of Range Low
P1567 Speed Control Output Circuit
P1568 Speed Control Unable to Hold Speed
P1569 Intake Manifold Runner Control Circuit Low (see P0661)
P1570 Intake Manifold Runner Control Circuit High (see P0662)
P1571 Brake Switch
P1572 Brake Pedal Switch Circuit
P1573 Throttle Position Not Available
P1574 Throttle Position Sensor Outputs Disagree
P1575 Pedal Position Out Of Self Test Range
P1576 Pedal Position Not Available
P1577 Pedal Position Sensor Outputs Disagree
P1578 ETC Power Less Than Demand
P1579 ETC In Power Limiting Mode
P1580 Electronic Throttle Monitor PCM Override
P1581 Electronic Throttle Monitor Malfunction
P1582 Electronic Throttle Monitor Data Available
P1583 Electronic Throttle Monitor Cruise Disablement
P1584 Throttle Control Detected ETB Malfunction
P1585 Throttle Control Malfunction
P1586 Electronic Throttle to PCM Communication Error
P1587 Throttle Control Modulated Command Malfunction
P1588 Throttle Control Detected Loss Of Return Spring
P1589 Throttle Control Unable To Control To Desired Throttle Angle
P1590 Cruise Control INCREASE DISTANCE Signal
P1591 Cruise Control DECREASE DISTANCE Signal
P1600 Loss Of KAM Power, Circuit Open
P1601 ECM/TCM Serial Communication Error
P1602 Immobilizer/ECM Communication Error
P1603 ID Number Unregistered
P1604 Code Word Unregistered
P1605 Keep Alive Memory Test Failure
P1606 ECM Control Relay Output Circuit
P1607 MIL Output Circuit
P1608 Watchdog Malfunction
P1609 Diagnostic Lamp Driver
P1610 Interactive Reprogramming Code - replace module (usd with P1615/17/19/20)
P1611 Interactive Reprogramming Code - diagnose further (used with P1616/1Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
P1612 Interactive Reprogramming Code - repeat test - engine is cranking
P1613 Interactive Reprogramming Code - TBD
P1614 Interactive Reprogramming Code - TBD
P1615 Interactive Reprogramming Code - erase error
P1616 Interactive Reprogramming Code - erase error, low voltage
P1617 Interactive Reprogramming Code - block program error
P1618 Interactive Reprogramming Code - block program error, low voltage
P1619 Interactive Reprogramming Code - total checksum error
P1620 Interactive Reprogramming Code - overlay checksum error
P1621 Immobilizer Code Words Do Not Match
P1622 Immobilizer ID Does Not Match
P1623 Immobilizer Code Word/ID Number Write Failure
P1624 Anti-theft System
P1625 Fan Driver Circuit Open to Power B+ (VLCM)
P1626 A/C Circuit Open to Power B+ (VLCM)
P1627 Module Supply Voltage Out Of Range
P1628 Module Ignition Supply Input
P1629 Internal Voltage Regulator
P162A Sensor Reference Voltage D Circuit/Open
P162B Sensor Reference Voltage D Circuit Low
P162C Sensor Reference Voltage D Circuit High
P1630 Internal Vref
P1631 Main Relay (power hold)
P1632 Smart Alternator Faults Sensor / Circuit
P1633 Keep Alive Power Voltage Too Low
P1634 Data Output Link Circuit
P1635 Tire/Axle Out of Acceptable Range
P1636 Inductive Signature Chip Communication Error
P1637 CAN Link ECM/ABS Control Module Circuit/Network
P1638 CAN Link ECM/INSTM Circuit/Network
P1639 Vehicle ID Block Corrupted, Not Programmed
P1640 Powertrain DTCs Available In Another Control Module (Ref. PID 0946)
P1641 Fuel Pump Primary Circuit
P1642 CAN Link Circuit
P1643 CAN Link Engine Control Module/Transmission Control Module Circuit/Network
P1644 Fuel Pump Speed Control Circuit
P1645 Fuel Pump Resistor Switch Circuit
P1646 Linear O2 Sensor Control Chip (Bank 1)
P1647 Linear O2 Sensor Control Chip (Bank 2)
P1648 Knock Sensor Input Chip
P1649 Fuel Injection Pump Module
P1650 Power Steering Pressure Switch Out Of Self Test Range
P1651 Power Steering Pressure Switch Input
P1652 Idle Air Control Monitor Disabled By PSPS Failed On
P1653 Power Steering Output Circuit
P1654 Recirculation Override Circuit
P1655 Starter Disable Circuit
P1656 CAN Link PCM/PCM Circuit/Network
P1657 CAN Link Chip Malfunction
P1658 Injection Pump Control Module System Voltage
P1659 Injection Pump Control Module Power Circuit
P1660 Output Circuit Check Circuit High Input
P1661 Output Circuit Check Circuit Low Input
P1662 EDU_EN Output Circuit
P1663 Fuel Demand Command Signal Output Circuit
P1664 Injection Pump Control Module Malfunction
P1665 Injection Pump Control Module Communications
P1666 Injection Pump Control Module/ECM Crank Reference Synchronization
P1667 Cylinder ID Circuit
P1668 PCM/IDM Communications Error
P1669 Injection Pump Control Module Monitoring ECM Fault
P1670 Electronic Feedback Signal Not Detected
P1671 Secondary Fuel Pump Relay
P1672 CAN Link ECM / Suspension Control Module Circuit/Network
P1673 ABS Lamp Control Circuit
P1674 Control Module Software Corrupted
P1675 Injector Data Not Programmed
P1676 Injector Data Incompatible
P1677 Alternative Fuel Control Module Communication Circuit
P1678 Low Oil Pressure Lamp Control Circuit
P1679 Engine Oil Pressure Output Circuit
P167A Alternative Fuel Control Module Communication Circuit Low
P1680 Metering Oil Pump Failure
P1681 Metering Oil Pump Failure
P1682 Metering Oil Pump Failure
P1683 Metering Oil Pump Temperature Sensor Circuit
P1684 Metering Oil Pump Position Sensor Circuit
P1685 Metering Oil Pump Stepping Motor Cont. Circuit
P1686 Metering Oil Pump Stepping Motor Cont. Circuit
P1687 Metering Oil Pump Stepping Motor Cont. Circuit
P1688 Metering Oil Pump Stepping Motor Cont. Circuit
P1689 Oil Pressure Control Solenoid Circuit
P1690 Wastegate Solenoid Circuit
P1691 Turbo Pressure Control Solenoid Circuit
P1692 Turbo Control Solenoid Circuit
P1693 Turbo Charge Control Circuit
P1694 Turbo Charge Relief Circuit
P1695 CAN Link Injection Pump Control Module/Engine Control Module
P1696 CAN Link Engine Control Module/Cruise Control Module Circuit/Network
P1697 Cruise Control Distance-Control Input Circuit
P1698 Cold Start Fuel Pump Primary Circuit (Brazil ethanol vehicles only)
P1699 CAN Link ECM / Climate Control Module
P1700 Transmission Indeterminate Failure (Failed to Neutral)
P1701 Reverse Engagement Error
P1702 Transmission Range Sensor Circuit Intermittent
P1703 Brake Switch Out Of Self Test Range
P1704 Transmission Range Circuit Not Indicating Park/Neutral During Self Test
P1705 Transmission Range Circuit Not Indicating Park/Neutral During Self Test
P1706 High Vehicle Speed Observed in Park
P1707 Park/Neutral Indication Circuit
P1708 Clutch Switch Circuit
P1709 Park Neutral Position Switch Out Of Self Test Range
P1710 Transmission Control Module Solenoid/Internal Ground Circuit
P1711 Transmission Fluid Temperature Sensor Out Of Self Test Range
P1712 Transmission Torque Reduction Request Signal
P1713 Transmission Fluid Temperature Sensor In Range Failure (< 50 deg F)
P1714 Shift Solenoid A Inductive Signature
P1715 Shift Solenoid B Inductive Signature
P1716 Shift Solenoid C Inductive Signature
P1717 Shift Solenoid D Inductive Signature
P1718 Transmission Fluid Temperature Sensor In Range Failure (> 250 deg F)
P1719 Engine Torque Signal
P1720 Vehicle Speed (Meter) Circuit
P1721 Gear 1 Incorrect Ratio
P1722 Stall Speed
P1723 Gear 3 Incorrect Ratio
P1724 Gear 4 Incorrect Ratio
P1725 Insufficient Engine Speed Increase During Self Test
P1726 Insufficient Engine Speed Decrease During Self Test
P1727 Coast Clutch Solenoid Inductive Signature
P1728 Transmission Slip
P1729 4x4L Switch
P1730 Gear Control Malfunction 2,3,5
P1731 1-2 Shift Malfunction
P1732 2-3 Shift Malfunction
P1733 3-4 Shift Malfunction
P1734 Gear Control Malfunction
P1735 First Gear Switch Circuit Failure
P1736 Second Gear Switch Circuit Failure
P1737 Lockup Solenoid
P1738 Shift Time Error
P1739 Slip Solenoid
P173A Clutch Actuator Position Sensor Circuit Range/Performance
P173B Clutch Actuator Position Sensor Circuit Low
P173C Clutch Actuator Position Sensor Circuit High
P173D Ignition Key Lock Solenoid Circuit / Open
P173E Ignition Key Lock Solenoid Circuit Low
P173F Ignition Key Lock Solenoid Circuit High
P1740 Torque Converter Clutch Solenoid Inductive Signature
P1741 Torque Converter Clutch Solenoid Control Error
P1742 Torque Converter Clutch Solenoid Circuit Failed On
P1743 Torque Converter Clutch Solenoid Circuit Failed On
P1744 Torque Converter Clutch Solenoid Circuit Performance
P1745 Line Pressure Solenoid
P1746 Pressure Control Solenoid A Open Circuit (see P0960)
P1747 Pressure Control Solenoid A Short Circuit (see P0962)
P1748 Pressure Control Solenoid A
P1749 Pressure Control Solenoid A Failed Low
P174A Gear Lever X Position Sensor Circuit Low
P174B Gear Lever X Position Sensor Circuit High
P174C Gear Lever Y Position Sensor Circuit Low
P174D Gear Lever Y Position Sensor Circuit High
P1750 Clutch Adaptive Learning Not Done
P1751 Shift Solenoid A Performance
P1752 Shift Solenoid A Circuit Short
P1754 Coast Clutch Solenoid Circuit
P1756 Shift Solenoid B Performance
P1757 Shift Solenoid B Circuit Short
P1758 Pressure Solenoid Control System Incorrect Current
P1759 2-4 Brake Failsafe Valve Malfunction
P1760 Pressure Control Solenoid A Short Circuit Intermittent (see P0963)
P1761 Shift Solenoid C Performance
P1762 Overdrive Band Failed Off
P1763 Low and Reverse Brake Pressure Switch Circuit
P1764 Low and Reverse Brake Failsafe Valve Malfunction
P1765 Timing Solenoid Circuit
P1766 Shift Solenoid D Performance
P1767 Torque Converter Clutch Circuit
P1768 Performance/Normal/Winter Mode Input
P1769 AG4 Transmission Torque Modulation Fault (VW trans)
P1770 Clutch Solenoid Circuit
P1771 Shift Solenoid E Performance
P1772 Throttle Position Sensor Circuit Low Input
P1773 CAN Link PCM/Fuel Fired Heater Malfunction
P1774 CAN Link Gear Shift Module / TCM
P1775 Torque Down Signal #1 Circuit
P1776 Torque Down Signal #2 Circuit
P1777 Torque Down Response Signal Circuit
P1778 Transmission Reverse I/P Circuit
P1779 Transmission Control Indicator Light Circuit
P1780 Transmission Control Switch (O/D Cancel) Circuit Out Of Self Test Range
P1781 4X4L Circuit Out Of Self Test Range
P1782 Performance/Economy Switch Circuit Out Of Self Test Range
P1783 Transmission Overtemperature Condition
P1784 Transmission Mechanical Failure - First And Reverse
P1785 Transmission Mechanical Failure - First And Second
P1786 3-2 Downshift Error
P1787 2-1 Downshift Error
P1788 Pressure Control Solenoid B Open Circuit (see P0964)
P1789 Pressure Control Solenoid B Short Circuit (see P0966)
P1790 TP (Mechanical) Circuit
P1791 TP (Electric) Circuit
P1792 Barometer Pressure Circuit
P1793 Intake Air Volume Circuit
P1794 Battery Voltage Circuit
P1795 Inconsistent CAN Level
P1796 CAN Controller Circuit (Bus off)
P1797 CAN TCM/ECM Circuit Malfunction
P1798 CAN TCM/INST Circuit Malfunction
P1799 CAN TCM/ABS Circuit Malfunction
P1800 Transmission Clutch Interlock Safety Switch Circuit Failure
P1801 Transmission Clutch Interlock Safety Switch Open Circuit
P1802 Transmission Clutch Interlock Safety Switch Short Circuit To Battery
P1803 Transmission Clutch Interlock Safety Switch Short Circuit To Ground
P1804 4-Wheel Drive High Indicator Circuit Failure
P1805 4-Wheel Drive High Indicator Open Circuit
P1806 4-Wheel Drive High Indicator Short Circuit To Battery
P1807 4-Wheel Drive High Indicator Short Circuit To Ground
P1808 4-Wheel Drive Low Indicator Circuit Failure
P1809 4-Wheel Drive Low Indicator Open Circuit
P1810 4-Wheel Drive Low Indicator Short Circuit To Battery
P1811 4-Wheel Drive Low Indicator Short Circuit To Ground
P1812 4-Wheel Drive Mode Select Circuit Failure
P1813 4-Wheel Drive Mode Select Open Circuit
P1814 4-Wheel Drive Mode Select Short Circuit To Battery
P1815 4-Wheel Drive Mode Select Short Circuit To Ground
P1816 Transmission Neutral Safety Switch Circuit Failure
P1817 Transmission Neutral Safety Switch Open Circuit
P1818 Transmission Neutral Safety Switch Short Circuit To Battery
P1819 Transmission Neutral Safety Switch Short Circuit To Ground
P181A Clutch Actuator Changeover Solenoid / Open
P181B Clutch Actuator Changeover Solenoid Low
P181C Clutch Actuator Changeover Solenoid High
P181D Clutch Actuator Changeover Solenoid Range/Performance
P1820 Transfer Case Clockwise Shift Relay Coil Circuit Failure
P1821 Transfer Case Clockwise Shift Relay Coil Open Circuit
P1822 Transfer Case Clockwise Shift Relay Coil Short Circuit To Battery
P1823 Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground
P1824 4-Wheel Drive Clutch Relay Circuit Failure
P1825 4-Wheel Drive Clutch Relay Open Circuit
P1826 4-Wheel Drive Low Clutch Relay Circuit To Battery
P1827 4-Wheel Drive Low Clutch Relay Circuit To Ground
P1828 Transfer Case Counter Clockwise Shift Relay Coil Circuit Failure
P1829 Transfer Case Counter Clockwise Shift Relay Coil Open Circuit
P1830 Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
P1831 Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Ground
P1832 Transfer Case Differential Lock-Up Solenoid Circuit Failure
P1833 Transfer Case Differential Lock-Up Solenoid Open Circuit
P1834 Transfer Case Differential Lock-Up Solenoid Short Circuit To Battery
P1835 Transfer Case Differential Lock-Up Solenoid Short Circuit To Ground
P1836 Transfer Case Front Shaft Speed Sensor Circuit Failure
P1837 Transfer Case Rear Shaft Speed Sensor Circuit Failure
P1838 Transfer Case Shift Motor Circuit Failure
P1839 Transfer Case Shift Motor Open Circuit
P1840 Transfer Case Shift Motor Short Circuit To Battery
P1841 Transfer Case Shift Motor Short Circuit To Ground
P1842 Transfer Case Differential Lock-Up Feedback Switch Circuit Failure
P1843 Transfer Case Differential Lock-Up Feedback Switch Open Circuit
P1844 Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Battery
P1845 Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Ground
P1846 Transfer Case Contact Plate 'A' Circuit Failure
P1847 Transfer Case Contact Plate 'A' Open Circuit
P1848 Transfer Case Contact Plate 'A' Short Circuit To Battery
P1849 Transfer Case Contact Plate 'A' Short Circuit To Ground
P1850 Transfer Case Contact Plate 'B' Circuit Failure
P1851 Transfer Case Contact Plate 'B' Open Circuit
P1852 Transfer Case Contact Plate 'B' Short Circuit To Battery
P1853 Transfer Case Contact Plate 'B' Short Circuit To Ground
P1854 Transfer Case Contact Plate 'C' Circuit Failure
P1855 Transfer Case Contact Plate 'C' Open Circuit
P1856 Transfer Case Contact Plate 'C' Short Circuit To Battery
P1857 Transfer Case Contact Plate 'C' Short Circuit To Ground
P1858 Transfer Case Contact Plate 'D' Circuit Failure
P1859 Transfer Case Contact Plate 'D' Open Circuit
P1860 Transfer Case Contact Plate 'D' Short Circuit To Battery
P1861 Transfer Case Contact Plate 'D' Short Circuit To Ground
P1862 Transfer Case Contact Plate Power Circuit Failure
P1863 Transfer Case Contact Plate Power Open Circuit
P1864 Transfer Case Contact Plate Power Short To Battery
P1865 Transfer Case Contact Plate Power Short To Ground
P1866 Transfer Case System Concern - Servicing Required
P1867 Transfer Case Contact Plate General Circuit Failure
P1868 4-Wheel Drive Indicator (Lamp) Circuit Failure
P1869 4-Wheel Drive Indicator (Lamp) Circuit Short To Battery
P186A Differential Lock-up Actuator Brake Control Circuit / Open
P186B Differential Lock-up Actuator Brake Control Circuit Low
P186C Differential Lock-up Actuator Brake Control Circuit High
P1870 Mechanical Transfer Case 4x4 Switch Circuit Failure
P1871 Mechanical Transfer Case 4x4 Switch Circuit Short To Battery
P1872 Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Failure
P1873 Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Short To Battery
P1874 Transfer Case Hall Effect Sensor Power Circuit Failure
P1875 Transfer Case Hall Effect Sensor Power Circuit Short To Battery
P1876 Transfer Case 2-Wheel Drive Solenoid Circuit Failure
P1877 Transfer Case 2-Wheel Drive Solenoid Circuit Short To Battery
P1878 Transfer Case Disengaged Solenoid Circuit Failure
P1879 Transfer Case Disengaged Solenoid Open Circuit
P1880 Transfer Case Disengaged Solenoid Short to Battery
P1881 Engine Coolant Level Switch Circuit
P1882 Engine Coolant Level Switch Circuit Short To Ground
P1883 Engine Coolant Level Switch Circuit
P1884 Engine Coolant Level Lamp Circuit Short To Ground
P1885 Transfer Case Disengaged Solenoid Short to Ground
P1886 4X4 Initialization Failure
P1887 4-Wheel Drive Control Solenoid Circuit Failure
P1888 Differential Oil Temperature Sensor Circuit Failure
P1889 Oil Pressure Pump Performance
P188F Transfer Case Contact Plate Ground Return Short to Battery
P1890 4-Wheel Drive Mode Select Return Input Circuit Failure
P1891 Transfer Case Contact Plate Ground Return Open Circuit
P1892 Axle Disconnect Engagement Solenoid Circuit High
P1893 Axle Disconnect Engagement Solenoid Circuit Low
P1894 Axle Disconnect Disengagement Solenoid Circuit High
P1895 Axle Disconnect Disengagement Solenoid Circuit Low
P1896 Axle Disconnect Engagement Position Sensor Circuit High
P1897 Axle Disconnect Engagement Position Sensor Circuit Low
P1898 Axle Disconnect Indicator Circuit High
P1899 Axle Disconnect Indicator Circuit Low
P189A Axle Disconnect Input Switch Circuit Low
P189B Axle Disconnect Input Switch Circuit High
P1900 Output Shaft Speed Sensor Circuit Intermittent
P1901 Turbine Shaft Speed Sensor Circuit Intermittent
P1902 Kickdown Solenoid Relay Control Circuit (Allison
P1903 Kickdown Solenoid Circuit Low Voltage
P1904 Kickdown Solenoid Circuit High Voltage
P1905 Control Module Configured for End-of-Line Test Mode
P1906 Kickdown Pull Relay Open Or Short Circuit To Ground (A4LD)
P1907 Kickdown Hold Relay Open Or Short Circuit To Ground (A4LD)
P1908 Transmission Pressure Control Solenoid Open Or Short (A4LD)
P1909 Transmission Fluid Temperature Sensor Circuit Open Or Short (A4LD)
P1910 Reverse Lamp Control Circuit / Open
P1911 Reverse Lamp Control Circuit Low
P1912 Reverse Lamp Control Circuit High
P1913 Sensor Ground Reference A Circuit/Open
P1914 Sensor Ground Reference A Circuit Low
P1915 Sensor Ground Reference A Circuit High
P1916 Sensor Ground Reference B Circuit/Open
P1917 Sensor Ground Reference B Circuit Low
P1918 Sensor Ground Reference B Circuit High
P1919 Engine Coolant Temperature Signal
P1920 Engine Speed Signal
P1921 Transmission Range Signal
P1922 Fuel Additive Level Circuit
P1923 Fuel Additive Level Circuit Range/Performance
P1924 Fuel Additive Level Circuit Low
P1925 Fuel Additive Level Circuit High
P1926 Fuel Additive Level Circuit Intermittent/Erratic
P1927 Fuel Additive Level Too Low/Empty
P1928 Fuel Additive Pump Control Circuit / Open
P1929 Fuel Additive Pump Control Circuit Performance
P1930 Fuel Additive Pump Control Circuit Low
P1931 Fuel Additive Pump Control Circuit High
P1932 Fuel Additive Level Low
P1933 Fuel Level Signal
P1934 Vehicle Speed Signal
P1935 Brake Switch/Sensor Signal
P1936 Clutch Switch/Sensor Signal
P1937 Fuel Fired Heater Control Circuit / Open
P1938 Fuel Fired Heater Control Circuit Low
P1939 Fuel Fired Heater Control Circuit High
P2000 NOx Trap Efficiency Below Threshold (Bank 1)
P2001 NOx Trap Efficiency Below Threshold (Bank 2)
P2002 Particulate Trap Efficiency Below Threshold (Bank 1)
P2003 Particulate Trap Efficiency Below Threshold (Bank 2)
P2004 Intake Manifold Runner Control Stuck Open (Bank 1)
P2005 Intake Manifold Runner Control Stuck Open (Bank 2)
P2006 Intake Manifold Runner Control Stuck Closed (Bank 1)
P2007 Intake Manifold Runner Control Stuck Closed (Bank 2)
P2008 Intake Manifold Runner Control Circuit / Open (Bank 1)
P2009 Intake Manifold Runner Control Circuit Low (Bank 1)
P2010 Intake Manifold Runner Control Circuit High (Bank 1)
P2011 Intake Manifold Runner Control Circuit / Open (Bank 2)
P2012 Intake Manifold Runner Control Circuit Low (Bank 2)
P2013 Intake Manifold Runner Control Circuit High (Bank 2)
P2014 Intake Manifold Runner Position Sensor/Switch Circuit (Bank 1)
P2015 Intake Manifold Runner Position Sensor/Switch Circuit Range/Perf. (Bank 1)
P2016 Intake Manifold Runner Position Sensor/Switch Circuit Low (Bank 1)
P2017 Intake Manifold Runner Position Sensor/Switch Circuit High (Bank 1)
P2018 Intake Manifold Runner Position Sensor/Switch Circuit Intermittent (Bank 1)
P2019 Intake Manifold Runner Position Sensor/Switch Circuit (Bank 2)
P2020 Intake Manifold Runner Position Sensor/Switch Circuit Range/Perf. (Bank 2)
P2021 Intake Manifold Runner Position Sensor/Switch Circuit Low (Bank 2)
P2022 Intake Manifold Runner Position Sensor/Switch Circuit High (Bank 2)
P2023 Intake Manifold Runner Position Sensor/Switch Circuit Intermittent (Bank 2)
P2024 Evaporative Emissions Fuel Vapor Temperature Sensor Circuit
P2025 Evaporative Emissions Fuel Vapor Temperature Sensor Circuit Performance
P2026 Evaporative Emissions Fuel Vapor Temperature Sensor Circuit Low Voltage
P2027 Evaporative Emissions Fuel Vapor Temperature Sensor Circuit High Voltage
P2028 Evaporative Emissions Fuel Vapor Temperature Sensor Circuit Intermittent
P2029 Fuel Fired Heater Disabled
P2030 Fuel Fired Heater Performance
P2031 Exhaust Gas Temperature Sensor Circuit Bank 1 Sensor 2
P2032 Exhaust Gas Temperature Sensor Circuit Low Bank 1 Sensor 2
P2033 Exhaust Gas Temperature Sensor Circuit High Bank 1 Sensor 2
P2034 Exhaust Gas Temperature Sensor Circuit Bank 2 Sensor 2
P2035 Exhaust Gas Temperature Sensor Circuit Low Bank 2 Sensor 2
P2036 Exhaust Gas Temperature Sensor Circuit High Bank 2 Sensor 2
P2037 Reductant Injection Air Pressure Sensor Circuit
P2038 Reductant Injection Air Pressure Sensor Circuit Range/Performance
P2039 Reductant Injection Air Pressure Sensor Circuit Low Input
P203A Reductant Level Sensor Circuit
P203B Reductant Level Sensor Circuit Range/Performance
P203C Reductant Level Sensor Circuit Low
P203D Reductant Level Sensor Circuit High
P203E Reductant Level Sensor Circuit Intermittent/Erratic
P203F Reductant Level Low
P2040 Reductant Injection Air Pressure Sensor Circuit High Input
P2041 Reductant Injection Air Pressure Sensor Circuit Intermittent
P2042 Reductant Temperature Sensor Circuit
P2043 Reductant Temperature Sensor Circuit Range/Performance
P2044 Reductant Temperature Sensor Circuit Low Input
P2045 Reductant Temperature Sensor Circuit High Input
P2046 Reductant Temperature Sensor Circuit Intermittent
P2047 Reductant Injector Circuit / Open Bank 1 Unit 1
P2048 Reductant Injector Circuit Low Bank 1 Unit 1
P2049 Reductant Injector Circuit High Bank 1 Unit 1
P204A Reductant Pressure Sensor Circuit
P204B Reductant Pressure Sensor Circuit Range/Performance
P204C Reductant Pressure Sensor Circuit Low
P204D Reductant Pressure Sensor Circuit High
P204E Reductant Pressure Sensor Circuit Intermittent/Erratic
P2050 Reductant Injector Circuit / Open Bank 2 Unit 1
P2051 Reductant Injector Circuit Low Bank 2 Unit 1
P2052 Reductant Injector Circuit High Bank 2 Unit 1
P2053 Reductant Injector Circuit / Open Bank 1 Unit 2
P2054 Reductant Injector Circuit Low Bank 1 Unit 2
P2055 Reductant Injector Circuit High Bank 1 Unit 2
P2056 Reductant Injector Circuit / Open Bank 2 Unit 2
P2057 Reductant Injector Circuit Low Bank 2 Unit 2
P2058 Reductant Injector Circuit High Bank 2 Unit 2
P2059 Reductant Injection Air Pump Control Circuit / Open
P205A Reductant Tank Temperature Sensor Circuit
P205B Reductant Tank Temperature Sensor Circuit Range/Performance
P205C Reductant Tank Temperature Sensor Circuit Low
P205D Reductant Tank Temperature Sensor Circuit High
P205E Reductant Tank Temperature Sensor Circuit Intermittent/Erratic
P2060 Reductant Injection Air Pump Control Circuit Low
P2061 Reductant Injection Air Pump Control Circuit High
P2062 Reductant Supply Control Circuit / Open
P2063 Reductant Supply Control Circuit Low
P2064 Reductant Supply Control Circuit High
P2065 Fuel Level Sensor B Circuit
P2066 Fuel Level Sensor B Circuit Range/Performance
P2067 Fuel Level Sensor B Circuit Low
P2068 Fuel Level Sensor B Circuit High
P2069 Fuel Level Sensor B Circuit Intermittent
P206E Intake Manifold Tuning Valve Stuck Open Bank 2
P206F Intake Manifold Tuning Valve Stuck Closed Bank 2
P2070 Intake Manifold Tuning Valve Stuck Open Bank 1
P2071 Intake Manifold Tuning Valve Stuck Closed Bank 1
P2072 Throttle Actuator Control System - Ice Breakage
P2073 Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Idle
P2074 Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher Load
P2075 Intake Manifold Tuning Valve Position Sensor/Switch Circuit Bank 1
P2076 Intake Manifold Tuning Valve Position Sensor/Switch Circuit Range/Performance Bank 1
P2077 Intake Manifold Tuning Valve Position Sensor/Switch Circuit Low Bank 1
P2078 Intake Manifold Tuning Valve Position Sensor/Switch Circuit High Bank 1
P2079 Intake Manifold Tuning Valve Position Sensor/Switch Circuit Intermittent Bank 1
P207A Intake Manifold Tuning Valve Position Sensor/Switch Circuit Bank 2
P207B Intake Manifold Tuning Valve Position Sensor/Switch Circuit Range/Performance Bank 2
P207C Intake Manifold Tuning Valve Position Sensor/Switch Circuit Low Bank 2
P207D Intake Manifold Tuning Valve Position Sensor/Switch Circuit High Bank 2
P207E Intake Manifold Tuning Valve Position Sensor/Switch Circuit Intermittent Bank 2
P2080 Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor 1
P2081 Exhaust Gas Temperature Sensor Circuit Intermittent Bank 1 Sensor 1
P2082 Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 2 Sensor 1
P2083 Exhaust Gas Temperature Sensor Circuit Intermittent Bank 2 Sensor 1
P2084 Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 1 Sensor 2
P2085 Exhaust Gas Temperature Sensor Circuit Intermittent Bank 1 Sensor 2
P2086 Exhaust Gas Temperature Sensor Circuit Range/Performance Bank 2 Sensor 2
P2087 Exhaust Gas Temperature Sensor Circuit Intermittent Bank 2 Sensor 2
P2088 A Camshaft Position Actuator Control Circuit Low Bank 1
P2089 A Camshaft Position Actuator Control Circuit High Bank 1
P2090 B Camshaft Position Actuator Control Circuit Low Bank 1
P2091 B Camshaft Position Actuator Control Circuit High Bank 1
P2092 A Camshaft Position Actuator Control Circuit Low Bank 2
P2093 A Camshaft Position Actuator Control Circuit High Bank 2
P2094 B Camshaft Position Actuator Control Circuit Low Bank 2
P2095 B Camshaft Position Actuator Control Circuit High Bank 2
P2096 Post Catalyst Fuel Trim System Too Lean Bank 1
P2097 Post Catalyst Fuel Trim System Too Rich Bank 1
P2098 Post Catalyst Fuel Trim System Too Lean Bank 2
P2099 Post Catalyst Fuel Trim System Too Rich Bank 2
P2100 Throttle Actuator Control Motor Circuit /Open
P2101 Throttle Actuator Control Motor Circuit Range/Performance
P2102 Throttle Actuator Control Motor Circuit Low
P2103 Throttle Actuator Control Motor Circuit High
P2104 Throttle Actuator Control System - Forced Idle
P2105 Throttle Actuator Control System - Forced Engine Shutdown
P2106 Throttle Actuator Control System - Forced Limited Power
P2107 Throttle Actuator Control Module Processor
P2108 Throttle Actuator Control Module Performance
P2109 Throttle / Pedal Position Sensor A Minimum Stop Performance
P2110 Throttle Actuator Control System - Forced Limited RPM
P2111 Throttle Actuator Control System - Stuck Open
P2112 Throttle Actuator Control System - Stuck Closed
P2113 Throttle / Pedal Position Sensor B Minimum Stop Performance
P2114 Throttle / Pedal Position Sensor C Minimum Stop Performance
P2115 Throttle / Pedal Position Sensor D Minimum Stop Performance
P2116 Throttle / Pedal Position Sensor E Minimum Stop Performance
P2117 Throttle / Pedal Position Sensor F Minimum Stop Performance
P2118 Throttle Actuator Control Motor Current Range/Performance
P2119 Throttle Actuator Control Throttle Body Range/Performance
P2120 Throttle/Pedal Position Sensor/Switch D Circuit
P2121 Throttle/Pedal Position Sensor/Switch D Circuit Range/Performance
P2122 Throttle/Pedal Position Sensor/Switch D Circuit Low Input
P2123 Throttle/Pedal Position Sensor/Switch D Circuit High Input
P2124 Throttle/Pedal Position Sensor/Switch D Circuit Intermittent
P2125 Throttle/Pedal Position Sensor/Switch E Circuit
P2126 Throttle/Pedal Position Sensor/Switch E Circuit Range/Performance
P2127 Throttle/Pedal Position Sensor/Switch E Circuit Low Input
P2128 Throttle/Pedal Position Sensor/Switch E Circuit High Input
P2129 Throttle/Pedal Position Sensor/Switch E Circuit Intermittent
P2130 Throttle/Pedal Position Sensor/Switch F Circuit
P2131 Throttle/Pedal Position Sensor/Switch F Circuit Range/Performance
P2132 Throttle/Pedal Position Sensor/Switch F Circuit Low Input
P2133 Throttle/Pedal Position Sensor/Switch F Circuit High Input
P2134 Throttle/Pedal Position Sensor/Switch F Circuit Intermittent
P2135 Throttle/Pedal Position Sensor/Switch A / B Voltage Correlation
P2136 Throttle/Pedal Position Sensor/Switch A / C Voltage Correlation
P2137 Throttle/Pedal Position Sensor/Switch B / C Voltage Correlation
P2138 Throttle/Pedal Position Sensor/Switch D / E Voltage Correlation
P2139 Throttle/Pedal Position Sensor/Switch D / F Voltage Correlation
P2140 Throttle/Pedal Position Sensor/Switch E / F Voltage Correlation
P2141 Exhaust Gas Recirculation Throttle Control Circuit Low
P2142 Exhaust Gas Recirculation Throttle Control Circuit High
P2143 Exhaust Gas Recirculation Vent Control Circuit / Open
P2144 Exhaust Gas Recirculation Vent Control Circuit Low
P2145 Exhaust Gas Recirculation Vent Control Circuit High
P2146 Fuel Injector Group A Supply Voltage Circuit / Open
P2147 Fuel Injector Group A Supply Voltage Circuit Low
P2148 Fuel Injector Group A Supply Voltage Circuit High
P2149 Fuel Injector Group B Supply Voltage Circuit / Open
P2150 Fuel Injector Group B Supply Voltage Circuit Low
P2151 Fuel Injector Group B Supply Voltage Circuit High
P2152 Fuel Injector Group C Supply Voltage Circuit / Open
P2153 Fuel Injector Group C Supply Voltage Circuit Low
P2154 Fuel Injector Group C Supply Voltage Circuit High
P2155 Fuel Injector Group D Supply Voltage Circuit / Open
P2156 Fuel Injector Group D Supply Voltage Circuit Low
P2157 Fuel Injector Group D Supply Voltage Circuit High
P2158 Vehicle Speed Sensor B
P2159 Vehicle Speed Sensor B Range/Performance
P2160 Vehicle Speed Sensor B Circuit Low
P2161 Vehicle Speed Sensor A Intermittent/Erratic
P2162 Vehicle Speed Sensor A / B Correlation
P2163 Throttle/Pedal Position Sensor A Maximum Stop Performance
P2164 Throttle/Pedal Position Sensor B Maximum Stop Performance
P2165 Throttle/Pedal Position Sensor C Maximum Stop Performance
P2166 Throttle/Pedal Position Sensor D Maximum Stop Performance
P2167 Throttle/Pedal Position Sensor E Maximum Stop Performance
P2168 Throttle/Pedal Position Sensor F Maximum Stop Performance
P2169 Exhaust Pressure Regulator Vent Solenoid Control Circuit / Open
P2170 Exhaust Pressure Regulator Vent Solenoid Control Circuit Low
P2171 Exhaust Pressure Regulator Vent Solenoid Control Circuit high
P2172 Throttle Actuator Control System - Sudden High Airflow Detected
P2173 Throttle Actuator Control System - High Airflow Detected
P2174 Throttle Actuator Control System - Sudden Low Airflow Detected
P2175 Throttle Actuator Control System - Low Airflow Detected
P2176 Throttle Actuator Control System - Idle Position Not Learned
P2177 System Too Lean Off Idle - Bank 1
P2178 System Too Rich Off Idle - Bank 1
P2179 System Too Lean Off Idle - Bank 2
P2180 System Too Rich Off Idle - Bank 2
P2181 Cooling System Performance
P2182 Engine Coolant Temperature Sensor 2 Circuit
P2183 Engine Coolant Temperature Sensor 2 Circuit Range/Performance
P2184 Engine Coolant Temperature Sensor 2 Circuit Low
P2185 Engine Coolant Temperature Sensor 2 Circuit High
P2186 Engine Coolant Temperature Sensor 2 Circuit Intermittent/Erratic
P2187 System Too Lean at Idle - Bank 1
P2188 System Too Rich at Idle - Bank 1
P2189 System Too Lean at Idle - Bank 2
P2190 System Too Rich at Idle - Bank 2
P2191 System Too Lean at Higher Load - Bank 1
P2192 System Too Rich at Higher Load - Bank 1
P2193 System Too Lean at Higher Load - Bank 2
P2194 System Too Rich at Higher Load - Bank 2
P2195 O2 Sensor Signal Biased/Stuck Lean - Bank 1, Sensor 1
P2196 O2 Sensor Signal Biased/Stuck Rich - Bank 1, Sensor 1
P2197 O2 Sensor Signal Biased/Stuck Lean - Bank 2, Sensor 1
P2198 O2 Sensor Signal Biased/Stuck Rich - Bank 2, Sensor 1
P2199 Intake Air Temperature 1/2 Correlation
P2200 NOx Sensor Circuit Bank 1
P2201 NOx Sensor Circuit Range/Performance Bank 1
P2202 NOx Sensor Circuit Low Input Bank 1
P2203 NOx Sensor Circuit High Input Bank 1
P2204 NOx Sensor Circuit Intermittent Bank 1
P2205 NOx Sensor Heater Control Circuit / Open Bank 1
P2206 NOx Sensor Heater Control Circuit Low Bank 1
P2207 NOx Sensor Heater Control Circuit High Bank 1
P2208 NOx Sensor Heater Sense Circuit Bank 1
P2209 NOx Sensor Heater Sense Circuit Range/Performance Bank 1
P2210 NOx Sensor Heater Sense Circuit Low Input Bank 1
P2211 NOx Sensor Heater Sense Circuit High Input Bank 1
P2212 NOx Sensor Heater Sense Circuit Intermittent Bank 1
P2213 NOx Sensor Circuit Bank 2
P2214 NOx Sensor Circuit Range/Performance Bank 2
P2215 NOx Sensor Circuit Low Input Bank 2
P2216 NOx Sensor Circuit High Input Bank 2
P2217 NOx Sensor Circuit Intermittent Bank 2
P2218 NOx Sensor Heater Control Circuit / Open Bank 2
P2219 NOx Sensor Heater Control Circuit Low Bank 2
P2220 NOx Sensor Heater Control Circuit High Bank 2
P2221 NOx Sensor Heater Sense Circuit Bank 2
P2222 NOx Sensor Heater Sense Circuit Range/Performance Bank 2
P2223 NOx Sensor Heater Sense Circuit Low Input Bank 2
P2224 NOx Sensor Heater Sense Circuit High Input Bank 2
P2225 NOx Sensor Heater Sense Circuit Intermittent Bank 2
P2226 Barometric Pressure Circuit
P2227 Barometric Pressure Circuit Range/Performance
P2228 Barometric Pressure Circuit Low Input
P2229 Barometric Pressure Circuit High Input
P2230 Barometric Pressure Circuit Intermittent
P2231 O2 Sensor Signal Circuit Shorted to Heater Circuit - Bank 1, Sensor 1
P2232 O2 Sensor Signal Circuit Shorted to Heater Circuit - Bank 1, Sensor 2
P2233 O2 Sensor Signal Circuit Shorted to Heater Circuit - Bank 1, Sensor 3
P2234 O2 Sensor Signal Circuit Shorted to Heater Circuit - Bank 2, Sensor 1
P2235 O2 Sensor Signal Circuit Shorted to Heater Circuit - Bank 2, Sensor 2
P2236 O2 Sensor Signal Circuit Shorted to Heater Circuit - Bank 2, Sensor 3
P2237 O2 Sensor Positive Current Control Circuit / Open - Bank 1, Sensor 1
P2238 O2 Sensor Positive Current Control Circuit Low - Bank 1, Sensor 1
P2239 O2 Sensor Positive Current Control Circuit High - Bank 1, Sensor 1
P2240 O2 Sensor Positive Current Control Circuit / Open - Bank 2, Sensor 1
P2241 O2 Sensor Positive Current Control Circuit Low - Bank 2, Sensor 1
P2242 O2 Sensor Positive Current Control Circuit High - Bank 2, Sensor 1
P2243 O2 Sensor Reference Voltage Circuit / Open - Bank 1, Sensor 1
P2244 O2 Sensor Reference Voltage Performance - Bank 1, Sensor 1
P2245 O2 Sensor Reference Voltage Circuit Low - Bank 1, Sensor 1
P2246 O2 Sensor Reference Voltage Circuit High - Bank 1, Sensor 1
P2247 O2 Sensor Reference Voltage Circuit / Open - Bank 2, Sensor 1
P2248 O2 Sensor Reference Voltage Performance - Bank 2, Sensor 1
P2249 O2 Sensor Reference Voltage Circuit Low - Bank 2, Sensor 1
P2250 O2 Sensor Reference Voltage Circuit High - Bank 2, Sensor 1
P2251 O2 Sensor Negative Current Control Circuit / Open - Bank 1, Sensor 1
P2252 O2 Sensor Negative Current Control Circuit Low - Bank 1, Sensor 1
P2253 O2 Sensor Negative Current Control Circuit High - Bank 1, Sensor 1
P2254 O2 Sensor Negative Current Control Circuit / Open - Bank 2, Sensor 1
P2255 O2 Sensor Negative Current Control Circuit Low - Bank 2, Sensor 1
P2256 O2 Sensor Negative Current Control Circuit High - Bank 2, Sensor 1
P2257 Secondary Air Injection System Control A Circuit Low
P2258 Secondary Air Injection System Control A Circuit High
P2259 Secondary Air Injection System Control B Circuit Low
P2260 Secondary Air Injection System Control B Circuit High
P2261 Turbo / Super Charger Bypass Valve - Mechanical
P2262 Turbo / Super Charger Boost Pressure Not Detected - Mechanical
P2263 Turbo / Super Charge Boost System Performance
P2264 Water in Fuel Sensor Circuit
P2265 Water in Fuel Sensor Circuit Range/Performance
P2266 Water in Fuel Sensor Circuit Low
P2267 Water in Fuel Sensor Circuit High
P2268 Water in Fuel Sensor Circuit Intermittent
P2269 Water in Fuel Condition
P2270 O2 Sensor Signal Stuck Lean - Bank 1, Sensor 2
P2271 O2 Sensor Signal Stuck Rich - Bank 1, Sensor 2
P2272 O2 Sensor Signal Stuck Lean - Bank 2, Sensor 2
P2273 O2 Sensor Signal Stuck Rich - Bank 2, Sensor 2
P2274 O2 Sensor Signal Stuck Lean - Bank 1, Sensor 3
P2275 O2 Sensor Signal Stuck Rich - Bank 1, Sensor 3
P2276 O2 Sensor Signal Stuck Lean - Bank 2, Sensor 3
P2277 O2 Sensor Signal Stuck Rich - Bank 2, Sensor 3
P2278 Oxygen Sensor Signals Swapped Bank 1 Sensor 3 / Bank 2 Sensor 3
P2279 Intake Air System Leak
P2280 Air Flow Restriction / Air Leak Between Air Cleaner and MAF
P2281 Air Leak Bewteen MAF and Throttle Body
P2282 Air Leak Bewteen Throttle Body and Intake Valve
P2283 Injector Control Pressure Sensor Circuit
P2284 Injector Control Pressure Sensor Circuit Range/Performance
P2285 Injector Control Pressure Sensor Circuit Low
P2286 Injector Control Pressure Sensor Circuit High
P2287 Injector Control Pressure Sensor Circuit Intermittent
P2288 Injector Control Pessure Too High
P2289 Injector Control Pessure Too High - Engine Off
P2290 Injector Control Pessure Too Low
P2291 Injector Control Pessure Too Low - Engine Cranking
P2292 Injector Control Pressure Erratic
P2293 Fuel Pressure Regulator 2 Performance
P2294 Fuel Pressure Regulator 2 Control Circuit
P2295 Fuel Pressure Regulator 2 Control Circuit Low
P2296 Fuel Pressure Regulator 2 Control Circuit High
P2297 O2 Sensor Out of Range During Deceleration Bank 1, Sensor 1
P2298 O2 Sensor Out of Range During Deceleration Bank 2, Sensor 1
P2299 Brake Pedal Position/Accelerator Pedal Position Incompatible
P2300 Ignition Coil A Primary Control Circuit Low
P2301 Ignition Coil A Primary Control Circuit High
P2302 Ignition Coil A Secondary Circuit
P2303 Ignition Coil B Primary Control Circuit Low
P2304 Ignition Coil B Primary Control Circuit High
P2305 Ignition Coil B Secondary Circuit
P2306 Ignition Coil C Primary Control Circuit Low
P2307 Ignition Coil C Primary Control Circuit High
P2308 Ignition Coil C Secondary Circuit
P2309 Ignition Coil D Primary Control Circuit Low
P2310 Ignition Coil D Primary Control Circuit High
P2311 Ignition Coil D Secondary Circuit
P2312 Ignition Coil E Primary Control Circuit Low
P2313 Ignition Coil E Primary Control Circuit High
P2314 Ignition Coil E Secondary Circuit
P2315 Ignition Coil F Primary Control Circuit Low
P2316 Ignition Coil F Primary Control Circuit High
P2317 Ignition Coil F Secondary Circuit
P2318 Ignition Coil G Primary Control Circuit Low
P2319 Ignition Coil G Primary Control Circuit High
P2320 Ignition Coil G Secondary Circuit
P2321 Ignition Coil H Primary Control Circuit Low
P2322 Ignition Coil H Primary Control Circuit High
P2323 Ignition Coil H Secondary Circuit
P2324 Ignition Coil I Primary Control Circuit Low
P2325 Ignition Coil I Primary Control Circuit High
P2326 Ignition Coil I Secondary Circuit
P2327 Ignition Coil J Primary Control Circuit Low
P2328 Ignition Coil J Primary Control Circuit High
P2329 Ignition Coil J Secondary Circuit
P2330 Ignition Coil K Primary Control Circuit Low
P2331 Ignition Coil K Primary Control Circuit High
P2332 Ignition Coil K Secondary Circuit
P2333 Ignition Coil L Primary Control Circuit Low
P2334 Ignition Coil L Primary Control Circuit High
P2335 Ignition Coil L Secondary Circuit
P2336 Cylinder #1 Above Knock Threshold
P2337 Cylinder #2 Above Knock Threshold
P2338 Cylinder #3 Above Knock Threshold
P2339 Cylinder #4 Above Knock Threshold
P2340 Cylinder #5 Above Knock Threshold
P2341 Cylinder #6 Above Knock Threshold
P2342 Cylinder #7 Above Knock Threshold
P2343 Cylinder #8 Above Knock Threshold
P2344 Cylinder #9 Above Knock Threshold
P2345 Cylinder #10 Above Knock Threshold
P2346 Cylinder #11 Above Knock Threshold
P2347 Cylinder #12 Above Knock Threshold
P2400 Evaporative Emission System Leak Detection Pump Control Circuit / Open
P2401 Evaporative Emission System Leak Detection Pump Control Circuit Low
P2402 Evaporative Emission System Leak Detection Pump Control Circuit High
P2403 Evaporative Emission System Leak Detection Pump Sense Circuit / Open
P2404 Evaporative Emission System Leak Detection Pump Sense Circuit Range/Performance
P2405 Evaporative Emission System Leak Detection Pump Sense Circuit Low
P2406 Evaporative Emission System Leak Detection Pump Sense Circuit High
P2407 Evaporative Emission System Leak Detection Pump Sense Circuit Intermittent/Erratic
P2408 Fuel Cap Sensor/Switch Circuit
P2409 Fuel Cap Sensor/Switch Circuit Range/Performance
P2410 Fuel Cap Sensor/Switch Circuit Low
P2411 Fuel Cap Sensor/Switch Circuit High
P2412 Fuel Cap Sensor/Switch Circuit Intermittent/Erratic
P2413 Exhaust Gas Recirculation System Performance
P2414 O2 Sensor Exhaust Sample Error Bank 1, Sensor 1
P2415 O2 Sensor Exhaust Sample Error Bank 2, Sensor 1
P2416 Oxygen Sensor Signals Swapped Bank 1 Sensor 2 / Bank 1 Sensor 3
P2417 Oxygen Sensor Signals Swapped Bank 2 Sensor 2 / Bank 2 Sensor 3
P2418 Evaporative Emission Control System Switching Valve Control Circuit / Open
P2419 Evaporative Emission Control System Switching Valve Control Circuit Low
P2420 Evaporative Emission Control System Switching Valve Control Circuit High
P2421 Evaporative Emission Control System Vent Valve Stuck Open
P2422 Evaporative Emission Control System Vent Valve Stuck Closed
P2423 HC Adsorbtion Catalyst Efficiency Below Threshold Bank 1
P2424 HC Adsorbtion Catalyst Efficiency Below Threshold Bank 2
P2425 Exhaust Gas Recirculation Cooling Valve Control Circuit / Open
P2426 Exhaust Gas Recirculation Cooling Valve Control Circuit Low
P2427 Exhaust Gas Recirculation Cooling Valve Control Circuit High
P2428 Exhaust Gas Temperature Too High Bank 1
P2429 Exhaust Gas Temperature Too High Bank 2
P2430 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Bank 1
P2431 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Range/Performance Bank 1
P2432 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Low Input Bank 1
P2433 Secondary Air Injection System Air Flow/Pressure Sensor Circuit High Input Bank 1
P2434 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Intermittent High Input Bank 1
P2435 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Bank 2
P2436 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Range/Performance Bank 2
P2437 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Low Input Bank 2
P2438 Secondary Air Injection System Air Flow/Pressure Sensor Circuit High Input Bank 2
P2439 Secondary Air Injection System Air Flow/Pressure Sensor Circuit Intermittent High Input Bank 2
P2440 Secondary Air Injection System Switching Valve Stuck Open Bank 1
P2441 Secondary Air Injection System Switching Valve Stuck Closed Bank 1
P2442 Secondary Air Injection System Switching Valve Stuck Open Bank 2
P2443 Secondary Air Injection System Switching Valve Stuck Closed Bank 2
P2444 Secondary Air Injection System Pump Stuck On Bank 1
P2445 Secondary Air Injection System Pump Stuck Off Bank 1
P2446 Secondary Air Injection System Pump Stuck On Bank 2
P2447 Secondary Air Injection System Pump Stuck Off Bank 2
P2448 Secondary Air Injection System High Airflow Bank 1
P2449 Secondary Air Injection System High Airflow Bank 2
P2450 Evaporative Emission Control System Switching Valve Performance or Stuck Open
P2451 Evaporative Emission Control System Switching Valve Stuck Closed
P2452 Particulate Matter Trap Differential Pressure Sensor Circuit
P2453 Particulate Matter Trap Differential Pressure Sensor Circuit Range/Performance
P2454 Particulate Matter Trap Differential Pressure Sensor Circuit Low
P2455 Particulate Matter Trap Differential Pressure Sensor Circuit High
P2456 Particulate Matter Trap Differential Pressure Sensor Circuit Intermittent/Erratic
P2457 Exhaust Gas Recirculation Cooler System Performance
P2500 Generator Lamp Terminal Circuit Low
P2501 Generator Lamp Terminal Circuit High
P2502 Charging System Voltage
P2503 Charging System Voltage Low
P2504 Charging System Voltage High
P2505 ECM / PCM Power Input Signal
P2506 ECM / PCM Power Input Signal Range/Performance
P2507 ECM / PCM Power Input Signal Low
P2508 ECM / PCM Power Input Signal High
P2509 ECM / PCM Power Input Signal Intermittent
P250A Engine Oil Level Sensor Circuit
P250B Engine Oil Level Sensor Circuit Range/Performance
P250C Engine Oil Level Sensor Circuit Low
P250D Engine Oil Level Sensor Circuit High
P250E Engine Oil Level Sensor Circuit Intermittent/Erratic
P250F Engine Oil Level Too Low
P2510 ECM / PCM Power Relay Sense Circuit Range/Performance
P2511 ECM / PCM Power Relay Sense Circuit Intermittent
P2512 Event Data Recorder Request Circuit / Open
P2513 Event Data Recorder Request Circuit Low
P2514 Event Data Recorder Request Circuit High
P2515 A/C Refrigerant Pressure Sensor B Circuit
P2516 A/C Refrigerant Pressure Sensor B Circuit Range/Performance
P2517 A/C Refrigerant Pressure Sensor B Circuit Low Input
P2518 A/C Refrigerant Pressure Sensor B Circuit High Input
P2519 A/C Request A Circuit
P251A PTO Enable Switch Circuit / Open
P251B PTO Enable Switch Circuit Low
P251C PTO Enable Switch Circuit High
P251D PTO Engine Shutdown Circuit / Open
P251E PTO Engine Shutdown Circuit Low
P251F PTO Engine Shutdown Circuit High
P2520 A/C Request A Circuit Low
P2521 A/C Request A Circuit High
P2522 A/C Request B Circuit
P2523 A/C Request B Circuit Low
P2524 A/C Request B Circuit High
P2525 Vacuum Reservoir Pressure Sensor Circuit
P2526 Vacuum Reservoir Pressure Sensor Circuit Range/Performance
P2527 Vacuum Reservoir Pressure Sensor Circuit Low
P2528 Vacuum Reservoir Pressure Sensor Circuit High
P2529 Vacuum Reservoir Pressure Sensor Circuit Intermittent
P252A Engine Oil Quality Sensor Circuit
P252B Engine Oil Quality Sensor Circuit Range/Performance
P252C Engine Oil Quality Sensor Circuit Low
P252D Engine Oil Quality Sensor Circuit High
P252E Engine Oil Quality Circuit Intermittent/Erratic
P252F Engine Oil Level Too High
P2530 Ignition Switch Run Position Circuit
P2531 Ignition Switch Run Position Circuit Low
P2532 Ignition Switch Run Position Circuit High
P2533 Ignition Switch Run/Start Position Circuit
P2534 Ignition Switch Run/Start Position Circuit Low
P2535 Ignition Switch Run/Start Position Circuit High
P2536 Ignition Switch Accessory Position Circuit
P2537 Ignition Switch Accessory Position Circuit Low
P2538 Ignition Switch Accessory Position Circuit High
P2539 Low Presure Fuel System Sensor Circuit
P253A PTO Sense Circuit / Open
P253B PTO Sense Circuit Range/Performance
P253C PTO Sense Circuit Low
P253D PTO Sense Circuit High
P253E PTO Sense Circuit Intermittent/Erratic
P253F Engine Oil Deteriorated
P2540 Low Presure Fuel System Sensor Circuit Range / Performance
P2541 Low Presure Fuel System Sensor Circuit Low Input
P2542 Low Presure Fuel System Sensor Circuit High Input
P2543 Low Presure Fuel System Sensor Circuit Intermittent
P2544 Torque Management Request Input Signal A
P2545 Torque Management Request Input Signal A Range / Performance
P2546 Torque Management Request Input Signal A Low
P2547 Torque Management Request Input Signal A High
P2548 Torque Management Request Input Signal B
P2549 Torque Management Request Input Signal B Range / Performance
P254A PTO Speed Selector Sensor/Switch 1 Circuit / Open
P254B PTO Speed Selector Sensor/Switch 1 Circuit Range/Performance
P254C PTO Speed Selector Sensor/Switch 1 Circuit Low
P254D PTO Speed Selector Sensor/Switch 1 Circuit High
P254E PTO Speed Selector Sensor/Switch 1 Circuit Intermittent/Erratic
P2550 Torque Management Request Input Signal B Low
P2551 Torque Management Request Input Signal B High
P2552 Throttle/Fuel Inhibit Circuit / Open
P2553 Throttle/Fuel Inhibit Circuit Range / Performance
P2554 Throttle/Fuel Inhibit Circuit Low
P2555 Throttle/Fuel Inhibit Circuit High
P2556 Engine Coolant Level Sensor/Switch Circuit
P2557 Engine Coolant Level Sensor/Switch Circuit Range / Performance
P2558 Engine Coolant Level Sensor/Switch Circuit Low
P2559 Engine Coolant Level Sensor/Switch Circuit High
P255A PTO Speed Selector Sensor/Switch 2 Circuit / Open
P255B PTO Speed Selector Sensor/Switch 2 Circuit Range/Performance
P255C PTO Speed Selector Sensor/Switch 2 Circuit Low
P255D PTO Speed Selector Sensor/Switch 2 Circuit High
P255E PTO Speed Selector Sensor/Switch 2 Circuit Intermittent/Erratic
P2560 Engine Coolant Level Low
P2561 A/C Control Module Requested MIL Illumination
P2562 Turbocharger Boost Control Position Sensor A Circuit
P2563 Turbocharger Boost Control Position Sensor A Circuit Range/Performance
P2564 Turbocharger Boost Control Position Sensor A Circuit Low
P2565 Turbocharger Boost Control Position Sensor A Circuit High
P2566 Turbocharger Boost Control Position Sensor A Circuit Intermittent
P2567 Direct Ozone Reduction Catalyst Temperature Sensor Circuit
P2568 Direct Ozone Reduction Catalyst Temperature Sensor Circuit Range/Performance
P2569 Direct Ozone Reduction Catalyst Temperature Sensor Circuit Low
P256A Engine Idle Speed Selector Sensor/Switch Circuit / Open
P256B Engine Idle Speed Selector Sensor/Switch Circuit Range/Performance
P256C Engine Idle Speed Selector Sensor/Switch Circuit Low
P256D Engine Idle Speed Selector Sensor/Switch Circuit High
P256E Engine Idle Speed Selector Sensor/Switch Circuit Intermittent/Erratic
P2570 Direct Ozone Reduction Catalyst Temperature Sensor Circuit High
P2571 Direct Ozone Reduction Catalyst Temperature Sensor Circuit Intermittent/Erratic
P2572 Direct Ozone Reduction Catalyst Deterioration Sensor Circuit
P2573 Direct Ozone Reduction Catalyst Deterioration Sensor Circuit Range/Performance
P2574 Direct Ozone Reduction Catalyst Deterioration Sensor Circuit Low
P2575 Direct Ozone Reduction Catalyst Deterioration Sensor Circuit High
P2576 Direct Ozone Reduction Catalyst Deterioration Sensor Circuit IIntermittetent/Erratic
P2577 Direct Ozone Reduction Catalyst Efficiency Below Threshold
P2578 Turbocharger Speed Sensor Circuit
P2579 Turbocharger Speed Sensor Circuit Range/Performance
P2580 Turbocharger Speed Sensor Circuit Low
P2581 Turbocharger Speed Sensor Circuit High
P2582 Turbocharger Speed Sensor Intermittent
P2583 Cruise Control Front Distance Range Sensor
P2584 Fuel Additive Control Module MIL Request
P2585 Fuel Additive Control Module Warning Lamp Request
P2586 Turbocharger Boost Control Position Sensor B Circuit
P2587 Turbocharger Boost Control Position Sensor B Circuit Range/Performance
P2588 Turbocharger Boost Control Position Sensor B Circuit Low
P2589 Turbocharger Boost Control Position Sensor B Circuit High
P2590 Turbocharger Boost Control Position Sensor B Circuit Intermittent
P2600 Coolant Pump Control Circuit / Open
P2601 Coolant Pump Control Circuit Range/Performance
P2602 Coolant Pump Control Circuit Low
P2603 Coolant Pump Control Circuit High
P2604 Intake Air Heater A Circuit Range/Performance
P2605 Intake Air Heater B Circuit / Open
P2606 Intake Air Heater B Circuit Range/Performance
P2607 Intake Air Heater B Circuit Low
P2608 Intake Air Heater B Circuit High
P2609 Intake Air Heater System Performance
P260A PTO Control Circuit / Open
P260B PTO Control Circuit Low
P260C PTO Control Circuit High
P260D PTO Engaged Lamp Control Circuit
P260F Evaporative System Monitoring Processor Performance
P2610 ECM/PCM Internal Engine Off Timer Performance
P2611 A/C Refrigerant Distribution Valve Control Circuit / Open
P2612 A/C Refrigerant Distribution Valve Control Circuit Low
P2613 A/C Refrigerant Distribution Valve Control Circuit High
P2614 Camshaft Position Output Circuit / Open
P2615 Camshaft Position Output Circuit Low
P2616 Camshaft Position Output Circuit high
P2617 Crankshaft Position Output Circuit / Open
P2618 Crankshaft Position Output Circuit Low
P2619 Crankshaft Position Output Circuit high
P2620 Throttle Position Output Circuit / Open
P2621 Throttle Position Output Circuit Low
P2622 Throttle Position Output Circuit high
P2623 Injector Control Pressure Regulator / Open
P2624 Injector Control Pressure Regulator Low
P2625 Injector Control Pressure Regulator High
P2626 O2 Sensor Pumping Current Trim Circuit / Open Bank 1 Sensor 1
P2627 O2 Sensor Pumping Current Trim Circuit Low Bank 1, Sensor 1
P2628 O2 Sensor Pumping Current Trim Circuit High Bank 1, Sensor 1
P2629 O2 Sensor Pumping Current Trim Circuit / Open Bank 2 Sensor 1
P2630 O2 Sensor Pumping Current Trim Circuit Low Bank 2, Sensor 1
P2631 O2 Sensor Pumping Current Trim Circuit High Bank 2, Sensor 1
P2632 Fuel Pump B Control Circuit / Open
P2633 Fuel Pump B Control Circuit Low
P2634 Fuel Pump B Control Circuit High
P2635 Fuel Pump A Low Flow / Performance
P2636 Fuel Pump B Low Flow / Performance
P2637 Torque Management Feedback Signal A
P2638 Torque Management Feedback Signal A Range / Performance
P2639 Torque Management Feedback Signal A Low
P2640 Torque Management Feedback Signal A High
P2641 Torque Management Feedback Signal B
P2642 Torque Management Feedback Signal B Range / Performance
P2643 Torque Management Feedback Signal B Low
P2644 Torque Management Feedback Signal B High
P2645 A Rocker Arm Actuator Control Circuit / Open Bank 1
P2646 A Rocker Arm Actuator Control System Performance or Stuck Off Bank 1
P2647 A Rocker Arm Actuator Control System Stuck On Bank 1
P2648 A Rocker Arm Actuator Control Circuit Low Bank 1
P2649 A Rocker Arm Actuator Control Circuit High Bank 1
P2650 B Rocker Arm Actuator Control Circuit / Open Bank 1
P2651 B Rocker Arm Actuator Control System Performance or Stuck Off Bank 1
P2652 B Rocker Arm Actuator Control System Stuck On Bank 1
P2653 B Rocker Arm Actuator Control Circuit Low Bank 1
P2654 B Rocker Arm Actuator Control Circuit High Bank 1
P2655 A Rocker Arm Actuator Control Circuit / Open Bank 2
P2656 A Rocker Arm Actuator Control System Performance or Stuck Off Bank 2
P2657 A Rocker Arm Actuator Control System Stuck On Bank 2
P2658 A Rocker Arm Actuator Control Circuit Low Bank 2
P2659 A Rocker Arm Actuator Control Circuit High Bank 2
P2660 B Rocker Arm Actuator Control Circuit / Open Bank 2
P2661 B Rocker Arm Actuator Control System Performance or Stuck Off Bank 2
P2662 B Rocker Arm Actuator Control System Stuck On Bank 2
P2663 B Rocker Arm Actuator Control Circuit Low Bank 2
P2664 B Rocker Arm Actuator Control Circuit High Bank 2
P2665 Fuel Shutoff Valve B Control Circuit / Open
P2666 Fuel Shutoff Valve B Control Circuit Low
P2667 Fuel Shutoff Valve B Control Circuit High
P2668 Fuel Indicator Lamp Control Circuit
P2669 Actuator Supply Voltage B Circuit / Open
P2670 Actuator Supply Voltage B Circuit Low
P2671 Actuator Supply Voltage B Circuit High
P2672 Injection Pump Timing Offset
P2673 Injection Pump Timing Calibration Not Learned
P2674 Injection Pump Fuel Calibration Not Learned
P2675 Air Cleaner Inlet Control Circuit / Open
P2676 Air Cleaner Inlet Control Circuit Low
P2677 Air Cleaner Inlet Control Circuit High
P2678 Coolant Degassing Valve Control Circuit / Open
P2679 Coolant Degassing Valve Control Circuit Low
P2680 Coolant Degassing Valve Control Circuit High
P2681 Engine Coolant Bypass Valve Control Circuit / Open
P2682 Engine Coolant Bypass Valve Control Circuit Low
P2683 Engine Coolant Bypass Valve Control Circuit High
P2700 Transmission Friction Element A Apply Time Range/Performance
P2701 Transmission Friction Element B Apply Time Range/Performance
P2702 Transmission Friction Element C Apply Time Range/Performance
P2703 Transmission Friction Element D Apply Time Range/Performance
P2704 Transmission Friction Element E Apply Time Range/Performance
P2705 Transmission Friction Element F Apply Time Range/Performance
P2706 Shift Solenoid F
P2707 Shift Solenoid F Performance or Stuck Off
P2708 Shift Solenoid F Stuck On
P2709 Shift Solenoid F Electrical
P2710 Shift Solenoid F Intermittent
P2711 Unexpected Mechanical Gear Disengagement
P2712 Hydraulic Pressure Unit Leakage
P2713 Pressure Control Solenoid D
P2714 Pressure Control Solenoid D Performance or Stuck Off
P2715 Pressure Control Solenoid D Stuck On
P2716 Pressure Control Solenoid D Electrical
P2717 Pressure Control Solenoid D Intermittent
P2718 Pressure Control Solenoid D Control Circuit / Open
P2719 Pressure Control Solenoid D Control Circuit Range/Performance
P2720 Pressure Control Solenoid D Control Circuit Low
P2721 Pressure Control Solenoid D Control Circuit High
P2722 Pressure Control Solenoid E
P2723 Pressure Control Solenoid E Performance or Stuck Off
P2724 Pressure Control Solenoid E Stuck On
P2725 Pressure Control Solenoid E Electrical
P2726 Pressure Control Solenoid E Intermittent
P2727 Pressure Control Solenoid E Control Circuit / Open
P2728 Pressure Control Solenoid E Control Circuit Range/Performance
P2729 Pressure Control Solenoid E Control Circuit Low
P2730 Pressure Control Solenoid E Control Circuit High
P2731 Pressure Control Solenoid F
P2732 Pressure Control Solenoid F Performance or Stuck Off
P2733 Pressure Control Solenoid F Stuck On
P2734 Pressure Control Solenoid F Electrical
P2735 Pressure Control Solenoid F Intermittent
P2736 Pressure Control Solenoid F Control Circuit / Open
P2737 Pressure Control Solenoid F Control Circuit Range/Performance
P2738 Pressure Control Solenoid F Control Circuit Low
P2739 Pressure Control Solenoid F Control Circuit High
P2740 Transmission Fluid Temperature Sensor B Circuit
P2741 Transmission Fluid Temperature Sensor B Circuit Range/Performance
P2742 Transmission Fluid Temperature Sensor B Circuit Low Input
P2743 Transmission Fluid Temperature Sensor B Circuit High Input
P2744 Transmission Fluid Temperature Sensor B Circuit Intermittent
P2745 Intermediate Shaft Speed Sensor B Circuit
P2746 Intermediate Shaft Speed Sensor B Circuit Range/Performance
P2747 Intermediate Shaft Speed Sensor B Circuit No Signal
P2748 Intermediate Shaft Speed Sensor B Circuit Intermittent
P2749 Intermediate Shaft Speed Sensor C Circuit
P2750 Intermediate Shaft Speed Sensor C Circuit Range/Performance
P2751 Intermediate Shaft Speed Sensor C Circuit No Signal
P2752 Intermediate Shaft Speed Sensor C Circuit Intermittent
P2753 Transmision Fluid Cooler Control Circuit / Open
P2754 Transmision Fluid Cooler Control Circuit Low
P2755 Transmision Fluid Cooler Control Circuit High
P2756 Torque Converter Clutch Pressure Control Solenoid
P2757 Torque Converter Clutch Pressure Control Solenoid Control Circuit Perf or Stuck Off
P2758 Torque Converter Clutch Pressure Control Solenoid Stuck On
P2759 Torque Converter Clutch Pressure Control Solenoid Electrical
P2760 Torque Converter Clutch Pressure Control Solenoid Intermittent
P2761 Torque Converter Clutch Pressure Control Solenoid Control Circuit / Open
P2762 Torque Converter Clutch Pressure Control Solenoid Control Circuit Range / Perf
P2763 Torque Converter Clutch Pressure Control Solenoid Control Circuit High
P2764 Torque Converter Clutch Pressure Control Solenoid Control Circuit Low
P2765 Input / Turbine Speed Sensor B Circuit
P2766 Input / Turbine Speed Sensor B Circuit Range / Performance
P2767 Input / Turbine Speed Sensor B Circuit No Signal
P2768 Input / Turbine Speed Sensor B Circuit Intermittent
P2769 Torque Converter Clutch Circuit Low
P2770 Torque Converter Clutch Circuit High
P2771 Four Wheel Drive (4WD) Low Switch Circuit
P2772 Four Wheel Drive (4WD) Low Switch Circuit Range/Performance
P2773 Four Wheel Drive (4WD) Low Switch Circuit Low
P2774 Four Wheel Drive (4WD) Low Switch Circuit High
P2775 Upshift Switch Circuit Range/Performance
P2776 Upshift Switch Circuit Low
P2777 Upshift Switch Circuit High
P2778 Upshift Switch Circuit Intermittent/Erratic
P2779 Downshift Switch Circuit Range/Performance
P2780 Downshift Switch Circuit Low
P2781 Downshift Switch Circuit High
P2782 Downshift Switch Circuit Intermittent/Erratic
P2783 Torque Converter Temperature Too High
P2784 Input / Turbine Speed Sensor A / B Correlation
P2785 Clutch Actuator Temperature Too High
P2786 Gear Shift Actuator Temperature Too High
P2787 Clutch Temperature Too High
P2788 Auto Shift Manual Adaptive Learning at Limit
P2789 Clutch Adaptive Learning at Limit
P2790 Gate Select Direction Circuit
P2791 Gate Select Direction Circuit Low
P2792 Gate Select Direction Circuit High
P2793 Gear Shift Direction Circuit
P2794 Gear Shift Direction Circuit Low
P2795 Gear Shift Direction Circuit High
P2796 Auxiliary Transmission Fluid Pump Control Circuit
P2797 Auxiliary Transmission Fluid Pump Circuit Performance
P2798 Auxiliary Transmission Fluid Pump Control Circuit Low
P2799 Auxiliary Transmission Fluid Pump Control Circuit High
P2800 Transmission Range Sensor B Circuit (PRNDL Input)
P2801 Transmission Range Sensor B Circuit Range/Performance
P2802 Transmission Range Sensor B Circuit Low Input
P2803 Transmission Range Sensor B Circuit High Input
P2804 Transmission Range Sensor B Circuit Intermittent
P2805 Transmission Range Sensor A/B Correlation
P2806 Transmission Range Sensor Alignment
P2807 Pressure Control Solenoid G
P2808 Pressure Control Solenoid G Performance or Stuck Off
P2809 Pressure Control Solenoid G Stuck On
P2810 Pressure Control Solenoid G Electrical
P2811 Pressure Control Solenoid G Intermittent
P2812 Pressure Control Solenoid G Control Circuit / Open
P2813 Pressure Control Solenoid G Control Circuit Range/Performance
P2814 Pressure Control Solenoid G Control Circuit Low
P2815 Pressure Control Solenoid G Control Circuit High
P2A06 O2 Circuit Negative Voltage (Bank 1, Sensor 1)
P2A07 O2 Circuit Negative Voltage (Bank 1, Sensor 2)
P2A08 O2 Circuit Negative Voltage (Bank 1, Sensor 3)
P2A09 O2 Circuit Negative Voltage (Bank 2, Sensor 1)
P2A10 O2 Circuit Negative Voltage (Bank 2, Sensor 2)
P2A11 O2 Circuit Negative Voltage (Bank 2, Sensor 3)
P3400 Cylinder Deactivation System Bank 1
P3401 Cylinder 1 Deactivation/Intake Valve Control Circuit / Open
P3402 Cylinder 1 Deactivation/Intake Valve Control Circuit Performance
P3403 Cylinder 1 Deactivation/Intake Valve Control Circuit Low
P3404 Cylinder 1 Deactivation/Intake Valve Control Circuit High
P3405 Cylinder 1 Exhaust Valve Control Circuit
P3406 Cylinder 1 Exhaust Valve Control Circuit Performance
P3407 Cylinder 1 Exhaust Valve Control Circuit Low
P3408 Cylinder 1 Exhaust Valve Control Circuit High
P3409 Cylinder 2 Deactivation/Intake Valve Control Circuit / Open
P3410 Cylinder 2 Deactivation/Intake Valve Control Circuit Performance
P3411 Cylinder 2 Deactivation/Intake Valve Control Circuit Low
P3412 Cylinder 2 Deactivation/Intake Valve Control Circuit High
P3413 Cylinder 2 Exhaust Valve Control Circuit
P3414 Cylinder 2 Exhaust Valve Control Circuit Performance
P3415 Cylinder 2 Exhaust Valve Control Circuit Low
P3416 Cylinder 2 Exhaust Valve Control Circuit High
P3417 Cylinder 3 Deactivation/Intake Valve Control Circuit / Open
P3418 Cylinder 3 Deactivation/Intake Valve Control Circuit Performance
P3419 Cylinder 3 Deactivation/Intake Valve Control Circuit Low
P3420 Cylinder 3 Deactivation/Intake Valve Control Circuit High
P3421 Cylinder 3 Exhaust Valve Control Circuit
P3422 Cylinder 3 Exhaust Valve Control Circuit Performance
P3423 Cylinder 3 Exhaust Valve Control Circuit Low
P3424 Cylinder 3 Exhaust Valve Control Circuit High
P3425 Cylinder 4 Deactivation/Intake Valve Control Circuit / Open
P3426 Cylinder 4 Deactivation/Intake Valve Control Circuit Performance
P3427 Cylinder 4 Deactivation/Intake Valve Control Circuit Low
P3428 Cylinder 4 Deactivation/Intake Valve Control Circuit High
P3429 Cylinder 4 Exhaust Valve Control Circuit
P3430 Cylinder 4 Exhaust Valve Control Circuit Performance
P3431 Cylinder 4 Exhaust Valve Control Circuit Low
P3432 Cylinder 4 Exhaust Valve Control Circuit High
P3433 Cylinder 5 Deactivation/Intake Valve Control Circuit / Open
P3434 Cylinder 5 Deactivation/Intake Valve Control Circuit Performance
P3435 Cylinder 5 Deactivation/Intake Valve Control Circuit Low
P3436 Cylinder 5 Deactivation/Intake Valve Control Circuit High
P3437 Cylinder 5 Exhaust Valve Control Circuit
P3438 Cylinder 5 Exhaust Valve Control Circuit Performance
P3439 Cylinder 5 Exhaust Valve Control Circuit Low
P3440 Cylinder 5 Exhaust Valve Control Circuit High
P3441 Cylinder 6 Deactivation/Intake Valve Control Circuit / Open
P3442 Cylinder 6 Deactivation/Intake Valve Control Circuit Performance
P3443 Cylinder 6 Deactivation/Intake Valve Control Circuit Low
P3444 Cylinder 6 Deactivation/Intake Valve Control Circuit High
P3445 Cylinder 6 Exhaust Valve Control Circuit
P3446 Cylinder 6 Exhaust Valve Control Circuit Performance
P3447 Cylinder 6 Exhaust Valve Control Circuit Low
P3448 Cylinder 6 Exhaust Valve Control Circuit High
P3449 Cylinder 7 Deactivation/Intake Valve Control Circuit / Open
P3450 Cylinder 7 Deactivation/Intake Valve Control Circuit Performance
P3451 Cylinder 7 Deactivation/Intake Valve Control Circuit Low
P3452 Cylinder 7 Deactivation/Intake Valve Control Circuit High
P3453 Cylinder 7 Exhaust Valve Control Circuit
P3454 Cylinder 7 Exhaust Valve Control Circuit Performance
P3455 Cylinder 7 Exhaust Valve Control Circuit Low
P3456 Cylinder 7 Exhaust Valve Control Circuit High
P3457 Cylinder 8 Deactivation/Intake Valve Control Circuit / Open
P3458 Cylinder 8 Deactivation/Intake Valve Control Circuit Performance
P3459 Cylinder 8 Deactivation/Intake Valve Control Circuit Low
P3460 Cylinder 8 Deactivation/Intake Valve Control Circuit High
P3461 Cylinder 8 Exhaust Valve Control Circuit
P3462 Cylinder 8 Exhaust Valve Control Circuit Performance
P3463 Cylinder 8 Exhaust Valve Control Circuit Low
P3464 Cylinder 8 Exhaust Valve Control Circuit High
P3465 Cylinder 9 Deactivation/Intake Valve Control Circuit / Open
P3466 Cylinder 9 Deactivation/Intake Valve Control Circuit Performance
P3467 Cylinder 9 Deactivation/Intake Valve Control Circuit Low
P3468 Cylinder 9 Deactivation/Intake Valve Control Circuit High
P3469 Cylinder 9 Exhaust Valve Control Circuit
P3470 Cylinder 9 Exhaust Valve Control Circuit Performance
P3471 Cylinder 9 Exhaust Valve Control Circuit Low
P3472 Cylinder 9 Exhaust Valve Control Circuit High
P3473 Cylinder 10 Deactivation/Intake Valve Control Circuit / Open
P3474 Cylinder 10 Deactivation/Intake Valve Control Circuit Performance
P3475 Cylinder 10 Deactivation/Intake Valve Control Circuit Low
P3476 Cylinder 10 Deactivation/Intake Valve Control Circuit High
P3477 Cylinder 10 Exhaust Valve Control Circuit
P3478 Cylinder 10 Exhaust Valve Control Circuit Performance
P3479 Cylinder 10 Exhaust Valve Control Circuit Low
P3480 Cylinder 10 Exhaust Valve Control Circuit High
P3481 Cylinder 11 Deactivation/Intake Valve Control Circuit / Open
P3482 Cylinder 11 Deactivation/Intake Valve Control Circuit Performance
P3483 Cylinder 11 Deactivation/Intake Valve Control Circuit Low
P3484 Cylinder 11 Deactivation/Intake Valve Control Circuit High
P3485 Cylinder 11 Exhaust Valve Control Circuit
P3486 Cylinder 11 Exhaust Valve Control Circuit Performance
P3487 Cylinder 11 Exhaust Valve Control Circuit Low
P3488 Cylinder 11 Exhaust Valve Control Circuit High
P3489 Cylinder 12 Deactivation/Intake Valve Control Circuit / Open
P3490 Cylinder 12 Deactivation/Intake Valve Control Circuit Performance
P3491 Cylinder 12 Deactivation/Intake Valve Control Circuit Low
P3492 Cylinder 12 Deactivation/Intake Valve Control Circuit High
P3493 Cylinder 12 Exhaust Valve Control Circuit
P3494 Cylinder 12 Exhaust Valve Control Circuit Performance
P3495 Cylinder 12 Exhaust Valve Control Circuit Low
P3496 Cylinder 12 Exhaust Valve Control Circuit High
P3497 Cylinder Deactivation System Bank 2
C0869 Air Suspension Auxiliary Inflator Indicator Lamp Circuit Failure
C1091 Speed Wheel Sensor All Coherency Failure
C1092 Unable to calculate engine torque data
C1093 Traction Control Disable Switch Circuit Failure
C1094 Park Brake Apply Switch Circuit Failure
C1095 ABS Hydraulic Pump Motor Circuit Failure
C1096 ABS Hydraulic Pump Motor Circuit Open
C1097 ABS Hydraulic Pump Motor Circuit Short To Ground
C1098 ABS Hydraulic Pump Motor Circuit Short To Battery
C1099 Electronic Power steering motor malfunction
C1100 ABS Pump Switch Circuit Failure
C1101 ABS Hydraulic Valve Circuit Failure
C1102 ABS Acceleration Switch Circuit Failure
C1103 ABS Hydraulic Brake Switch Circuit Failure
C1104 Traction Control Active Lamp - Circuit Short to Battery
C1105 Traction Control Disable Lamp - Circuit Short to Battery
C1106 Traction Control Disable Switch Circuit Short to Battery
C1107 ABS Function Enabled Input Circuit Failure
C1108 Air in Hydraulic System
C1109 Speed Control Actuator Assembly Cable Release Failure
C1110 ABS Power Relay Coil Circuit Failure
C1111 ABS Power Relay Coil Open Circuit
C1112 ABS Power Relay Coil Short Circuit To Ground
C1113 ABS Power Relay Coil Short Circuit To Battery
C1114 ABS Power Relay Output Short Circuit To Ground
C1115 ABS Power Relay Output Short Circuit To Battery
C1116 Starter Motor Circuit Failure
C1117 RPM Input Circuit Failure
C1118 Traction Control Indicated Troque Reduction Circuit Failure
C1119 Traction Control Actual Torque Reduction Circuit Failure
C1120 Left Front Vertical Accelerometer Offset Out Of Range
C1121 Right Front Vertical Accelerometer Offset Out Of Range
C1122 Rear Vertical Accelerometer Offset Out Of Range
C1123 Vehicle Speed Sensor Input Short to Battery
C1124 Input shaft speed signal missing/faulted
C1125 Brake Fluid Level Sensor Input Circuit Failure
C1126 Cruise Control Command Switch Assembly Circuit Failure
C1127 Cruise Control Deactivator Brake Switch Circuit Failure
C1128 Lateral Accelerometer Offset Out Of Range
C1129 RR Height Sensor Circuit Failure
C1130 RR Height Sensor Circuit 'Out of Range'
C1131 Clutch Circuit Failure
C1132 Clutch position ckt short to ground
C1133 Clutch position ckt short to battery
C1134 Gear Shift position short to ground
C1135 Gear Shift position short to battery
C1136 Gear Select position short to ground
C1137 "ECU is Defective - don't use; use 9342"
C1138 Gear Select position short to Battery
C1139 Wheel Speed Sensor Center Tone Ring Missing Tooth Fault
C1140 Hydraulic Base Brake Failure
C1141 Wheel Speed Sensor LF Tone Ring Tooth Missing Fault
C1142 Wheel Speed Sensor RF Tone Ring Tooth Missing Fault
C1143 Wheel Speed Sensor LR Tone Ring Tooth Missing Fault
C1144 Wheel Speed Sensor RR Tone Ring Tooth Missing Fault
C1145 Speed Wheel Sensor RF Input Circuit Failure
C1146 Speed Wheel Sensor RF Circuit Open
C1147 Vehicle Speed Sensor Signal Short to Ground
C1148 Speed Wheel Sensor RF Coherency Fault
C1149 Hydraulic Fluid Pressure/ Flow Circuit Failure
C1150 Two Speed Rear Axle Input Switch Circuit Short to Vbatt
C1151 Used for 1995 Contour
C1152 Used for 1995 Contour
C1153 Height Sensor Power Circuit Failure
C1154 Height Sensor Power Circuit Short to Battery
C1155 Speed Wheel Sensor LF Input Circuit Failure
C1156 Speed Wheel Sensor LF Circuit Open
C1157 Park Brake Actuator Assembly Switch Applied Circuit Failure
C1158 Speed Wheel Sensor LF Coherency Fault
C1159 Hydraulic Fluid Pressure/ Flow Circuit Short to Gnd
C1160 Center Axle Disconnect (CAD) System General Failure
C1161 Air Pressure Low Circuit Short to Gnd
C1162 Park Brake Switch # 2 Released Circuit Failure
C1163 Park Brake Switch # 2 Applied Circuit Short to Gnd
C1164 Park Brake Actuator Assembly Switch Circuit Failure
C1165 Speed Wheel Sensor RR Input Circuit Failure
C1166 Speed Wheel Sensor RR Input Open Circuit
C1167 Park Brake Actuator Assembly Switch Released Circuit Short to Gnd
C1168 Speed Wheel Sensor RR Coherency Fault
C1169 ABS Fluid Dumping Exceeds Maximum Timing
C1170 PRNDL Switch Circuit Failure
C1172 Park Brake Switch # 1 Applied Circuit Failure
C1173 Park Brake Switch # 1 Released Circuit Short to Gnd
C1174 Park Brake Switch # 2 Applied Circuit Failure
C1175 Speed Wheel Sensor LR Input Circuit Failure
C1176 Speed Wheel Sensor LR Circuit Open
C1177 Park Brake Actuator Assembly Switch Released Circuit Failure
C1178 Speed Wheel Sensor LR Coherency Fault
C1179 Speed Control Actuator Assembly Cable Slack Failure
C1180 Park Brake Valve Solenoid #1 Sense Input Circuit Failure
C1181 Park Brake Valve Solenoid #1 Sense Input Circuit Short to Gound
C1182 Park Lamp Flash Relay Circuit Failure
C1183 Park Lamp Flash Relay Circuit Short to Battery
C1184 ABS System Is Not Operational
C1185 ABS Power Relay Output Circuit Failure
C1186 ABS Power Relay Output Open Circuit
C1187 Brake Fluid Level Sensor Input Open Circuit
C1188 Brake Fluid Level Sensor Input Short Circuit To Battery
C1189 Brake Fluid Level Sensor Input Short Circuit To Ground
C1190 Speed Wheel Sensor LF Input Short Circuit To Battery
C1191 Speed Wheel Sensor LF Input Short Circuit To Ground
C1192 Speed Wheel Sensor RF Input Short Circuit To Battery
C1193 Speed Wheel Sensor RF Input Short Circuit To Ground
C1194 ABS Outlet Valve Coil LF Circuit Failure
C1195 ABS Outlet Valve Coil LF Circuit Open
C1196 ABS Outlet Valve Coil LF Circuit Short To Battery
C1197 ABS Outlet Valve Coil LF Circuit Short To Ground
C1198 ABS Inlet Valve Coil LF Circuit Failure
C1199 ABS Inlet Valve Coil LF Circuit Open
C1200 ABS Inlet Valve Coil LF Circuit Short To Battery
C1201 ABS Inlet Valve Coil LF Circuit Short To Ground
C1202 ABS Outlet Valve Coil Rear Circuit Failure
C1203 ABS Outlet Valve Coil Rear Circuit Open
C1204 ABS Outlet Valve Coil Rear Circuit Short To Battery
C1205 ABS Outlet Valve Coil Rear Circuit Short To Ground
C1206 ABS Inlet Valve Coil Rear Circuit Failure
C1207 ABS Inlet Valve Coil Rear Circuit Open
C1208 ABS Inlet Valve Coil Rear Circuit Short To Battery
C1209 ABS Inlet Valve Coil Rear Circuit Short To Ground
C1210 ABS Outlet Valve Coil RF Circuit Failure
C1211 ABS Outlet Valve Coil RF Circuit Open
C1212 ABS Outlet Valve Coil RF Circuit Short To Battery
C1213 ABS Outlet Valve Coil RF Circuit Short To Ground
C1214 ABS Inlet Valve Coil RF Circuit Failure
C1215 ABS Inlet Valve Coil RF Circuit Open
C1216 ABS Inlet Valve Coil RF Circuit Short To Battery
C1217 ABS Inlet Valve Coil RF Circuit Short To Ground
C1218 Lamp ABS Warning Output Circuit Failure
C1219 Lamp ABS Warning Output Circuit Open
C1220 Lamp ABS Warning Output Circuit Short To Battery
C1221 Lamp ABS Warning Output Circuit Short To Ground
C1222 Speed Wheel Mismatch
C1223 Lamp Brake Warning Output Circuit Failure
C1224 Lamp Brake Warning Output Circuit Open
C1225 Lamp Brake Warning Output Circuit Short To Battery
C1226 Lamp Brake Warning Output Circuit Short To Ground
C1227 Speed Wheel Sensor LR Input Short Circuit To Battery
C1228 Speed Wheel Sensor LR Input Short Circuit To Ground
C1229 Speed Wheel Sensor Rear Center Coherency Fault
C1230 Speed Wheel Sensor Rear Center Input Circuit Failure
C1231 Speed Wheel Sensor Rear Center Circuit Open
C1232 Speed Wheel Sensor Rear Center Input Short Circuit To Battery
C1233 Speed Wheel LF Input Signal Missing
C1234 Speed Wheel RF Input Signal Missing
C1235 Speed Wheel RR Input Signal Missing
C1236 Speed Wheel LR Input Signal Missing
C1237 Speed Wheel Rear Input Signal Missing
C1238 ABS Hydraulic Pressure Differential Switch Input Circuit Failure
C1239 ABS Hydraulic Pressure Differential Switch Input Open Circuit
C1240 ABS Hydraulic Pressure Differential Switch Input Short Circuit To Battery
C1241 ABS Hydraulic Pressure Differential Switch Input Short Circuit To Ground
C1242 ABS Outlet Valve Coil LR Circuit Failure
C1243 ABS Outlet Valve Coil LR Circuit Open
C1244 ABS Outlet Valve Coil LR Circuit Short To Battery
C1245 ABS Outlet Valve Coil LR Circuit Short To Ground
C1246 ABS Outlet Valve Coil RR Circuit Failure
C1247 ABS Outlet Valve Coil RR Circuit Open
C1248 ABS Outlet Valve Coil RR Circuit Short To Battery
C1249 ABS Outlet Valve Coil RR Circuit Short To Ground
C1250 ABS Inlet Valve Coil LR Circuit Failure
C1251 ABS Inlet Valve Coil LR Circuit Open
C1252 ABS Inlet Valve Coil LR Circuit Short To Battery
C1253 ABS Inlet Valve Coil LR Circuit Short To Ground
C1254 ABS Inlet Valve Coil RR Circuit Failure
C1255 ABS Inlet Valve Coil RR Circuit Open
C1256 ABS Inlet Valve Coil RR Circuit Short To Battery
C1257 ABS Inlet Valve Coil RR Circuit Short To Ground
C1258 Speed Wheel LF Comparison Failure
C1259 Speed Wheel RF Comparison Failure
C1260 Speed Wheel RR Comparison Failure
C1261 Speed Wheel LR Comparison Failure
C1262 Lamp Warning Relay Circuit Failure
C1263 Lamp Warning Relay Circuit Open
C1264 Lamp Warning Relay Circuit Short To Battery
C1265 Lamp Warning Relay Circuit Short To Ground
C1266 ABS Valve Power Relay Circuit Failure
C1267 ABS Functions Temporarily Disabled
C1268 Motor Relay # 1 Circuit Failure
C1269 Motor Relay # 1 Circuit Short to Battery
C1270 Motor # 1 Input Circuit Failure
C1271 Motor # 1 Input Circuit Short to Gnd
C1272 Motor # 2 Input Circuit Failure
C1273 Motor # 2 Input Circuit Short to Vbat
C1274 Solenoid Relay # 1 Circuit Failure
C1275 Solenoid Relay # 1 Circuit Short to Vbatt
C1276 Park Brake Actuator Assembly Switch Applied Circuit Short to Gnd
C1277 STEERING Wheel Angle 1and 2 Circuit Failure
C1278 STEERING Wheel Angle 1and 2 Signal Faulted
C1279 Yaw Rate Sensor circuit Failure
C1280 Yaw Rate Sensor Signal Fault
C1281 Lateral Accelerometer circuit Failure
C1282 Lateral Accelerometer Signal Fault
C1283 Switch Test Signal Failure
C1284 Oil Pressure Switch Failure
C1285 Booster Solenoid circuit Failure
C1286 Booster Mechanical Failure
C1287 Booster Pedal Force switch circuit Failure
C1288 Pressure Transducer Main / Primary Input Circuit Failure
C1289 Pressure Transducer Redundant / Secondary Input Circuit Failure
C1290 Pressure Transducer Circuit Failure
C1291 ACC Module Overheated
C1292 ACC Blockage detection
C1293 ACC Alignment offset angle out of range
C1294 ACC Active speed out of range
C1295 Steering Wheel Angle Sensor Internal Fault
C1296 Wheel Speed LF Signal Fault
C1297 Wheel Speed RF Signal Fault
C1298 Wheel Speed RR Signal Fault
C1299 Wheel Speed LR Signal Fault
C1300 ABS Pump Motor Ckt Failure
C1301 ABS Operation timed out
C1302 Left Front Isolation Clamping Circuit Failure
C1303 Right Front Isolation Clamping Circuit Failure
C1304 Cruise Control Command Switch Resistance Out of Range
C1305 Longitudinal Accelerometer Signal Fault
C1306 Steering Wheel Angle - No Center Found During Initialization
C1307 Steering Wheel Angle Sensor Encoder Ring Defective
C1308 Wheel Speed Sensor Wire(s) Shorted to Ground
C1309 Wheel Speed Sensor Wires Shorted Together
C1310 Brake Hydraulic Pressure Transducer Front Left Wheel Circuit Failure
C1311 Brake Hydraulic Pressure Transducer Front Left Wheel Signal Fault
C1312 Brake Hydraulic Pressure Transducer Front Right Wheel Circuit Failure
C1313 Brake Hydraulic Pressure Transducer Front Right Wheel Signal Fault
C1314 Brake Hydraulic Pressure Transducer Rear Left Wheel Circuit Failure
C1315 Brake Hydraulic Pressure Transducer Rear Left Wheel Signal Fault
C1316 Brake Hydraulic Pressure Transducer Rear Right Wheel Circuit Failure
C1317 Brake Hydraulic Pressure Transducer Rear Right Wheel Signal Fault
C1318 Brake Hydraulic Pressure Transducer Accumulator Circuit Fault
C1319 Brake Hydraulic Pressure Transducer Accumulator Signal Fault
C1320 Brake Hydraulic Accumulator Travel Sensor Circuit Failure
C1321 Brake Hydraulic Accumulator Travel Sensor Signal Fault
C1322 Brake Hydraulic Master Cylinder Piston-Travel Sensor 1 Circuit Failure
C1323 Brake Hydraulic Master Cylinder piston-Travel Sensor 1 Signal Fault
C1324 Brake Hydraulic Master Cylinder piston-Travel Sensor 2 Circuit Failure
C1325 Brake Hydraulic Master Cylinder piston-Travel Sensor 2 Signal Fault
C1326 Hydraulic Control Unit is Faulted
C1327 Brake Fluid Level Low
C1328 Electro-Hydraulic General Pressure Sensor Failure
C1329 ABS Outlet Valve Coil RF Circuit Excessive Temperature
C1330 ABS Outlet Valve Coil LR Circuit Excessive Temperature
C1331 ABS Outlet Valve Coil RR Circuit Excessive Temperature
C1332 ABS Outlet Valve Coil LF Circuit Excessive Temperature
C1333 ABS Inlet Valve Coil LR Circuit Excessive Temperature
C1334 ABS Inlet Valve Coil LF Circuit Excessive Temperature
C1335 ABS Inlet Valve Coil RF Circuit Excessive Temperature
C1336 ABS Inlet Valve Coil RR Circuit Excessive Temperature
C1400 Traction Control Valve RF Circuit Failure
C1401 Traction Control Valve RF Circuit Open
C1402 Traction Control Valve RF Circuit Short To Ground
C1403 Traction Control Valve RF Circuit Short To Battery
C1404 Traction Control Valve Rear Circuit Failure
C1405 Traction Control Valve Rear Circuit Open
C1406 Traction Control Valve Rear Circuit Short To Ground
C1407 Traction Control Valve Rear Circuit Short To Battery
C1408 Park Brake Release Switch Circuit Out of Range
C1409 Park Brake Apply Switch Circuit Out of Range
C1410 Traction Control Valve LF Circuit Failure
C1411 Traction Control Valve LF Circuit Open
C1412 Traction Control Valve LF Circuit Short To Ground
C1413 Traction Control Valve LF Circuit Short To Battery
C1414 Incorrect Module Design Level 5969 596C
C1415 Incorrect Module Configuration
C1416 Damper RF Circuit Short To Battery
C1417 Damper RF Circuit Short to Ground
C1418 Damper RF Circuit Failure
C1419 Damper RF Circuit Open
C1420 Hydraulic Fluid Pressure/ Flow Circuit Short to Vbatt
C1421 Damper LF Circuit Short To Battery
C1422 Damper LF Circuit Short to Ground
C1423 Damper LF Circuit Failure
C1424 Damper LF Circuit Open
C1425 Damper RR Circuit Short to Ground
C1426 Damper RR Circuit Short To Battery
C1427 Damper RR Circuit Open
C1428 Damper RR Circuit Failure
C1429 Input-shaft-speed input circuit failure
C1430 Damper LR Circuit Open
C1431 Damper LR Circuit Short To Battery
C1432 Damper LR Circuit Short to Ground
C1433 Damper LR Circuit Failure
C1435 Accelerometer Rear Circuit Failure
C1436 Accelerometer Rear Circuit Signal Is Not Sensed
C1437 Accelerometer Rear Circuit Short To Ground
C1438 Accelerometer Rear Circuit Short To Battery
C1439 Vehicle Acceleration EEC-IV Circuit Failure
C1440 Pressure Transducer Main / Primary signal Faulted
C1441 Steering Phase A Circuit Signal Is Not Sensed
C1442 Steering Phase B Circuit Signal Is Not Sensed
C1443 Steering Phase A Circuit Short To Ground
C1444 Steering Phase B Circuit Short To Ground
C1445 Speed Vehicle Signal Circuit Failure
C1446 Brake Switch Circuit Failure
C1447 Traction Control Module Request Circuit Failure
C1448 Lamp Adaptive Damping Warning Circuit Failure
C1449 Traction Control Motor Coherency Fault
C1450 Traction Control Motor Circuit Failure
C1451 Traction Control Motor Circuit Open
C1452 Traction Control Motor Circuit Short to Battery
C1453 Traction Control Motor Circuit Short to Ground
C1454 Front Lateral Accelerometer Circuit Failure
C1455 Accelerometer Front Circuit Failure
C1456 Accelerometer Front Circuit Is Not Sensed
C1457 Accelerometer Front Circuit Short To Ground
C1458 Accelerometer Front Circuit Short To Battery
C1459 Adaptive Mode Switch Circuit Failure
C1460 Vehicle Accelerometer Power Circuit Failure
C1461 Vehicle Accelerometer Power Circuit Short to Battery
C1462 Left Front Vertical Accelerometer Circuit Failure
C1463 Right Front Vertical Accelerometer Circuit Failure
C1464 Pressure Transducer Redundant / Secondary Signal Faulted
C1465 Damper High Side Front Circuit Short To Battery
C1466 Damper Circuit Failure
C1467 Damper High Side Rear Circuit Short To Battery
C1468 Damper Low Side Front Circuit Failure
C1469 Damper Low Side Rear Circuit Failure
C1470 TCS Functions Temporarily Disabled (Thermal Brake Protection)
C1471 High Pressure Accumulator (HPA) Volume Consumption Plausibility Failure
C1472 Master Cylinder Volume/Travel Plausibility Failure
C1473 Brake System Valve Calibration Data Failure
C1474 High Pressure Accumulator (HPA) Sensor Calibration Data Failure
C1475 High Pressure Accumulator (HPA) Pressure/Volume/Temperature Plausibility Failure
C1476 Brake System Pump Volume Feed Too Low Plausibility Failure
C1477 High Pressure Hydraulic Circuit Leakage Plausibility Failure
C1478 Left Front Wheel Brake Pressure Control Plausibility Failure
C1479 Left Rear Wheel Brake Pressure Control Plausibility Failure
C1480 Right Front Wheel Brake Pressure Control Plausibility Failure
C1481 Right Rear Wheel Brake Pressure Control Plausibility Failure
C1482 Air Bleed Check Incomplete
C1483 Valve Calibration Incomplete
C1495 Traction Control Motor Potentiometer Circuit Failure
C1496 Traction Control Motor Potentiometer Circuit Open
C1497 Traction Control Motor Potentiometer Circuit Short to Battery
C1498 Traction Control Motor Potentiometer Circuit Short to Ground
C1499 "Transfer Case Contact Plate ""A"" Encoder Circuit Failure"
C1500 "Transfer Case Contact Plate ""B"" Encoder Circuit Failure"
C1501 "Transfer Case Contact Plate ""C"" Encoder Circuit Failure"
C1502 "Transfer Case Contact Plate ""D"" Encoder Circuit Failure"
C1503 Dynamic Stability Control Left Front Valve Malfunction
C1504 Dynamic Stability Control Right Front Valve Malfunction
C1505 Dynamic Stability Control Left Rear Valve Malfunction
C1506 Dynamic Stability Control Right Rear Valve Malfunction
C1507 Traction Control of Brake Exceeds Time-Out
C1508 Traction Control of Engine Exceeds Time-Out
C1510 Right Front Wheel Pressure Reduction Performance Problem
C1511 Left Front Wheel Pressure Reduction Performance Problem
C1512 Right Rear Wheel Pressure Reduction Performance Problem
C1513 Left rear Wheel Pressure Reduction Performance Problem
C1515 Lateral Accelerometer Open/Short or Disorientation
C1516 Roll Rate Sensor Signal Fault
C1517 Roll Rate Sensor Circuit Failure
C1518 Red Fault Warning Lamp Indicator Short to Battery
C1519 Red Fault Warning Lamp Indicator Circuit Failure
C1520 Delta-S Plausibility Failure
C1521 Delta-S Circuit Failure
C1522 Brake Pedal Travel Sensor Internal Power Supply Failure
C1523 Brake Fluid Level Sensor Out of Range
C1524 Brake Pedal Travel Sensor Calibration Incomplete
C1525 Brake System Initialization Incomplete
C1526 Brake Pedal Travel Sensor Fault
C1527 Traction Control Rear Valve Circuit Excessive Temperature
C1528 Traction Control LF Valve Circuit Excessive Temperature
C1529 Booster Solenoid Circuit Excessive Temperature
C1530 Dynamic Stability Control RF Valve Circuit Excessive Temperature
C1531 Dynamic Stability Control LF Valve Circuit Excessive Temperature
C1600 Regenerative Brake System Fault
C1699 Left Rear Sensor Circuit Short to Vbat
C1700 Left Rear Sensor Circuit Failure or Blockage
C1701 Left Rear Sensor Circuit Fault
C1702 RightRear Sensor Circuit Short to Vbat
C1703 Right Rear Sensor Circuit Failure or Blockage
C1704 Right Rear Sensor Circuit Fault
C1705 Left Rear Center Sensor Circuit Short to Vbat
C1706 Left Rear Center Sensor Circuit Failure
C1707 Left Rear Center Sensor Circuit Fault
C1708 Right Rear Center Sensor Circuit Short to Vbat
C1709 Right Rear Center Sensor Circuit Failure
C1710 Right Rear Center Sensor Circuit Fault
C1711 Left Front Sensor Circuit Short to Vbat
C1712 Left Front Sensor Circuit Failure
C1713 Left Front Sensor Circuit Fault
C1714 Right Front Sensor Circuit Short to Vbat
C1715 Right Front Sensor Circuit Failure
C1716 Right Front Sensor Circuit Fault
C1717 Left Front Center Sensor Circuit Short to Vbat
C1718 Left Front Center Sensor Circuit Failure
C1719 Left Front Center Sensor Circuit Fault
C1721 Air Suspension Height Sensor Power Circuit Open
C1722 Air Suspension Height Sensor Power Circuit Short To Battery
C1723 Air Suspension Height Sensor Power Circuit Short To Ground
C1724 Fault DTC: Air Suspension Height Sensor Power Circuit Failure 395D 395C
C1725 Air Suspension Front Pneumatic Failure
C1726 Air Suspension Rear Pneumatic Failure
C1727 Air Suspension Reservoir Pneumatic Failure
C1728 Transfer Case Unable to Transition Between 2H and 4H
C1729 Transfer Case Unable to Transition Between 4H and 4L
C1730 Reference Voltage Out of Range (+5 v)
C1731 Air Suspension LF Corner Up Timeout
C1732 Air Suspension LF Corner Down Timeout
C1733 Air Suspension RF Corner Up Timeout
C1734 Air Suspension RF Corner Down Timeout
C1735 Air Suspension LR Corner Up Timeout
C1736 Air Suspension LR Corner Down Timeout
C1737 Air Suspension RR Corner Up Timeout
C1738 Air Suspension RR Corner Down Timeout
C1739 Right Front Center Sensor Circuit Short to Vbat
C1740 Right Front Center Sensor Circuit Failure
C1741 Right Front Center Sensor Circuit Fault
C1742 Rear Sounder Circuit Failure
C1743 Rear Sounder Circuit Short to Vbatt
C1744 Front Sounder Circuit Failure
C1745 Front Sounder Circuit Short to Vbatt
C1748 Switch input Circuit Short to Gnd
C1749 Trailer Input Circuit Failure
C1750 Accelerator Position Sensor Out of Range
C1751 Vehicle Speed Sensor # 1 Output Circuit Short to Vbatt
C1752 Vehicle Speed Sensor # 1 Output Circuit Short to Gnd
C1753 Hydraulic Clutch Actuator Valve Signal Fault
C1754 Hydraulic Clutch Actuator Valve Circuit Failure
C1755 Power Limit Shutdown Fault
C1756 Air Suspension Front Height Sensor High (SE) Signal Circuit Failure
C1757 Air Suspension Front Height Sensor High (SE) Signal Circuit Open
C1758 Air Suspension Front Height Sensor High (SE) Signal Circuit Short To Battery
C1759 Air Suspension Front Height Sensor High (SE) Signal Circuit Short To Ground
C1760 Air Suspension Rear Height Sensor High (SE) Signal Circuit Failure
C1761 Air Suspension Rear Height Sensor High (SE) Signal Circuit Open
C1762 Air Suspension Rear Height Sensor High (SE) Signal Circuit Short To Battery
C1763 Air Suspension Rear Height Sensor High (SE) Signal Circuit Short To Ground
C1765 Air Suspension Rear Height Sensor Low Signal Circuit Failure
C1766 Air Suspension Rear Height Sensor Low Signal Circuit Open
C1767 Air Suspension Rear Height Sensor Low Signal Circuit Short To Battery
C1768 Air Suspension Rear Height Sensor Low Signal Circuit Short To Ground
C1769 Park Brake Apply Switch Circuit Short to Ground
C1770 Air Suspension Vent Solenoid Output Circuit Failure
C1771 Air Suspension Vent Solenoid Output Circuit Open
C1772 Air Suspension Vent Solenoid Output Circuit Short To Battery
C1773 Air Suspension Vent Solenoid Output Circuit Short To Ground
C1774 Coolant Temp. Out of Range
C1775 DC-DC Converter Failure
C1776 Heater System Failure
C1777 Vacuum Pressure Circuit Failure
C1778 Power Steering Failure
C1779 Blower Switch Failure
C1780 Temperature Select Failure
C1781 Engine Coolant Temperature Signal Missing/Fault
C1782 Park Brake Release Switch Circuit Failure
C1783 Park Brake Release Switch Short to Ground
C1784 Electric Park Brake Motor Output Short to Ground
C1785 Electric Park Brake Motor Output Open Circuit
C1786 Electric Park Brake Motor Output Battery Short to Ground
C1787 Stoplamp Relay Output Circuit Short to Battery
C1788 Stoplamp Relay Output Circuit Short to Ground
C1789 Stoplamp Relay Output Circuit Open
C1790 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Failure
C1791 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Open
C1792 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Battery
C1793 Air Suspension LR Air Spring/Shock Solenoid Output Circuit Short To Ground
C1794 Air Suspension Vehicle Over Gross Vehicle Weight
C1795 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Failure
C1796 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Open
C1797 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Battery
C1798 Air Suspension RR Air Spring/Shock Solenoid Output Circuit Short To Ground
C1799 Hall Effect Circuit Failure
C1800 Air Suspension Reservoir Solenoid Circuit Failure
C1801 Motor Engage Current Reached Before Full Apply Travel Distance
C1802 Motor Engage Current Not Reached or Traveled Too Far Apply
C1803 Motor Disengage Full Travel Distance Not Reached Upon Release
C1804 Park Brake Apply Switch Stuck ON
C1805 Mismatched PCM and/or ABS-TC Module
C1806 Park Brake Release Switch Stuck ON
C1807 Vent solenoid supply short to battery
C1808 Vent solenoid supply short to ground
C1809 Air Suspension Vent Timeout
C1810 Air Suspension Height Sensor Out of Range
C1811 Air Suspension Return to Trim Timeout Many valve failure DTCs.
C1812 Air Suspension Height Sensor Failure
C1813 Air Suspension LR Vent Request Exceeded Max. Timing
C1814 Air Suspension RR Vent Request Exceeded Max. Timing
C1815 Electric Park Brake Motor Output Short to Battery
C1816 Electric Park Brake Needs Service
C1818 Air Suspension LR Air Compress Request Exceeded Max. Timing
C1819 Air Suspension RR Air Compress Request Exceeded Max. Timing
C1820 Air Suspension RF Air Compress Request Exceeded Max. Timing
C1821 Electric Park Brake Motor Failure
C1822 Electric Park Brake Sensor Electrical Failure
C1823 Electric Park Brake Sensor Signal Failure
C1824 Electric Park Brake Motor H-Bridge Failure
C1825 Missing Cranking Signal
C1826 Electric Park Brake Electrical Failure
C1827 Electric Park Brake Switch Defective
C1828 Electric Park Brake Force Sensor Not Calibrated
C1829 Electric Park Brake Switch Not Connected
C1830 Air Suspension Compressor Relay Circuit Failure
C1831 Air Suspension Compressor Relay Circuit Open
C1832 Air Suspension Compressor Relay Circuit Short To Battery
C1833 Air Suspension Compressor Relay Circuit Short To Ground
C1834 Gauge Drive Current Fault
C1835 Current Sense Circuit Failure
C1836 Battery Temp. Out of Range
C1837 Battery Heater Circuit Failure
C1838 Charging System Fault 4912
C1839 Leakage Fault
C1840 Air Suspension Disable Switch Circuit Failure
C1841 Air Suspension Disable Switch Circuit Open
C1842 Air Suspension Disable Switch Circuit Short To Battery
C1843 Air Suspension Disable Switch Circuit Short To Ground
C1844 Air Suspension Secondary Front Inflator Solenoid Output Circuit Failure
C1845 Air Suspension Front Inflator Solenoid Output Circuit Failure
C1846 Air Suspension Front Inflator Solenoid Output Circuit Open
C1847 Air Suspension Front Inflator Solenoid Output Circuit Short To Battery
C1848 Air Suspension Front Inflator Solenoid Output Circuit Short To Ground
C1849 Master Cylinder Pressure Out of Range
C1850 Air Suspension Warning Lamp Circuit Failure
C1851 Air Suspension Warning Lamp Circuit Open
C1852 Air Suspension Warning Lamp Circuit Short To Battery
C1853 Air Suspension Warning Lamp Circuit Short To Ground
C1854 Motor Temperature Out of Range
C1855 Acceleration Position Sensor Conflict
C1856 Traction Motor Encoder circuit Failure
C1859 PRNDL Input #2 Circuit Failure
C1860 PRNDL Input #3 Circuit Failure
C1861 PRNDL Input #4 Circuit Failure
C1862 Contactor Circuit Failure
C1863 External Charging Fault
C1864 Battery Module Fault 4900, 4901
C1865 Air Suspension Rear Inflator Solenoid Output Circuit Failure
C1866 Air Suspension Rear Inflator Solenoid Output Circuit Open
C1867 Air Suspension Rear Inflator Solenoid Output Circuit Short To Battery
C1868 Air Suspension Rear Inflator Solenoid Output Circuit Short To Ground
C1869 Air Suspension Gate Solenoid Output Circuit Failure
C1870 Air Suspension Gate Solenoid Output Circuit Open
C1871 Air Suspension Gate Solenoid Output Circuit Short To Battery
C1872 Air Suspension Gate Solenoid Output Circuit Short To Ground
C1873 Air Suspension RF Air Spring Solenoid Output Circuit Failure
C1874 Air Suspension RF Air Spring Solenoid Output Circuit Open
C1875 Air Suspension RF Air Spring Solenoid Output Circuit Short To Battery
C1876 Air Suspension RF Air Spring Solenoid Output Circuit Short To Ground
C1877 Air Suspension LF Air Spring Solenoid Output Circuit Failure
C1878 Air Suspension LF Air Spring Solenoid Output Circuit Open
C1879 Air Suspension LF Air Spring Solenoid Output Circuit Short To Battery
C1880 Air Suspension LF Air Spring Solenoid Output Circuit Short To Ground
C1881 Air Suspension RF Height Sensor Circuit Failure
C1882 Air Suspension RF Height Sensor Circuit Open
C1883 Air Suspension RF Height Sensor Circuit Short To Battery
C1884 Air Suspension RF Height Sensor Circuit Short To Ground
C1885 Air Suspension RR Height Sensor Circuit Failure
C1886 Air Suspension RR Height Sensor Circuit Open
C1887 Air Suspension RR Height Sensor Circuit Short To Battery
C1888 Air Suspension RR Height Sensor Circuit Short To Ground
C1889 Air Suspension LF Height Sensor Circuit Failure
C1890 Air Suspension LF Height Sensor Circuit Open
C1891 Air Suspension LF Height Sensor Circuit Short To Battery
C1892 Air Suspension LF Height Sensor Circuit Short To Ground
C1893 Air Suspension LR Height Sensor Circuit Failure
C1894 Air Suspension LR Height Sensor Circuit Open
C1895 Air Suspension LR Height Sensor Circuit Short To Battery
C1896 Air Suspension LR Height Sensor Circuit Short To Ground
C1897 Steering VAPS II Circuit Loop Failure
C1898 Steering VAPS II Circuit Loop Open
C1899 Steering VAPS II Circuit Loop Short To Battery
C1900 Steering VAPS II Circuit Loop Short To Ground
C1901 Ride Control RR Shock Actuator Circuit Failure
C1902 Ride Control RR Shock Actuator Circuit Open
C1903 Ride Control RR Shock Actuator Circuit Short To Battery
C1904 Ride Control RR Shock Actuator Circuit Short To Ground
C1905 Ride Control LR Shock Actuator Circuit Failure
C1906 Ride Control LR Shock Actuator Circuit Open
C1907 Ride Control LR Shock Actuator Circuit Short To Battery
C1908 Ride Control LR Shock Actuator Circuit Short To Ground
C1909 Ride Control RF Shock Actuator Circuit Failure
C1910 Ride Control RF Shock Actuator Circuit Open
C1911 Ride Control RF Shock Actuator Circuit Short To Battery
C1912 Ride Control RF Shock Actuator Circuit Short To Ground
C1913 Ride Control LF Shock Actuator Circuit Failure
C1914 Ride Control LF Shock Actuator Circuit Open
C1915 Ride Control LF Shock Actuator Circuit Short To Battery
C1916 Ride Control LF Shock Actuator Circuit Short To Ground
C1917 Steering EVO Out-of-Range Fault
C1918 Air Suspension Ride Height Select Switch Circuit Failure
C1920 Led #1 Circuit Failure
C1921 VAPS Solenoid Actuator Output Circuit Failure
C1922 VAPS Solenoid Actuator Output Circuit Open
C1923 VAPS Solenoid Actuator Output Circuit Short To Battery
C1924 VAPS Solenoid Actuator Output Circuit Short To Ground
C1925 VAPS Solenoid Actuator Return Circuit Failure
C1926 VAPS Solenoid Actuator Return Circuit Open
C1927 VAPS Solenoid Actuator Return Circuit Short To Battery
C1928 VAPS Solenoid Actuator Return Circuit Short To Ground
C1929 Air Suspension Front Compressor Relay Circuit Failure
C1930 Air Suspension Front Compressor Relay Circuit Open
C1931 Air Suspension Front Compressor Relay Circuit Short To Battery
C1932 Air Suspension Front Compressor Relay Circuit Short To Ground
C1933 Solenoid Current Out Of Range
C1934 HPU (Hydraulic Pump Unit) Pressurisation Failure
C1935 Chime Circuit Failure
C1936 Hydraulic Pump Relay Circuit Failure
C1937 Steering Wheel Angle Sensor Offset Failure
C1938 Invalid Steering Wheel Angle Sensor ID
C1939 Brake Pressure Switch Input Circuit Failure
C1940 Brake Pressure Switch Mechanical Failure
C1941 Zero Seat Weight Test Failure
C1942 Unrecognized Powertrain Configuration
C1943 Airbag Deployment Indication Input Fault
C1944 Gauge Driver Circuit Fault
C1945 Park Switch Indicates Park with Vehicle Moving
C1946 Front Driver's Seat Track Position Switch Circuit Open
C1947 Front Driver's Seat Track Position Switch Circuit Short to Ground
C1948 Front Driver's Seat Track Position Switch Circuit Resistance Out of Range
C1949 Accelerometer Sensor Circuit Open
C1950 Accelerometer Sensor Circuit Failure
C1951 Lateral Accelerometer Sensor Circuit Open
C1952 Yaw Rate Sensor Circuit Open
C1953 Master Cylinder Pressure Sensor Circuit Open
C1954 Master Cylinder Pressure Sensor Circuit Failure
C1955 Steering Angle Sensor Circuit Open
C1956 Steering Angle Sensor Circuit Failure
C1957 Dynamic Stability Control Valve RF Circuit Failure
C1958 Dynamic Stability Control Valve LF Circuit Failure
C1959 Lateral Accelerometer Sensor Circuit Failure
C1960 Driver Brake Apply Circuit Fault
C1961 Park Lamp Relay Coil Circuit Failure
C1962 Park Lamp Relay Coil Short to Battery
C1963 Stability Control Inhibit Warning
C1964 Air Susp'n Air Compressor Request Exceeded Max Timing
C1965 Fuel Level Circuit Failure
C1966 Low Fuel Indicator Circuit Short to Battery
C1967 Low Fuel Indicator Circuit Failure
C1968 Electronic Panic Brake Assist Failure
C1969 TC/YC Switch Lamp Circuit Fault.
C1970 4x4 Low Mode Switch LED Short To Battery
C1971 4x4 Low Mode Switch LED Circuit Failure
C1972 Air Suspension Kneel Switch Circuit Failure
C1973 Air Suspension Inching Switch Circuit Failure
C1974 Air Reservoir Not Filling
C1975 IVD Plausibilty failure
C1976 Audio Steering Wheel Switch Circuit - Open Circuit
C1977 Audio Steering Wheel Switch Circuit Short to GND
C1978 Audio Steering Wheel Switch Circuit short to Battery
C1979 IWE Solenoid Circuit Failure
C1980 IWE Solenoid Short to Battery
C1981 Front Driver's Seat Track Position Switch Circuit Fault
C1982 Front Driver's Seat Track Position Switch Circuit Short to Battery
C1983 Radar sensor fault
C1984 Radar sensor Circuit failure
C1985 Back up aid disable switch stuck low
C1986 VAPS Initial Speed Above Threshold
C1987 Yellow fault warning lamp indicator short to battery
C1988 Yellow fault warning lamp indicator circuit failure
C1989 Park Brake Apply and Release Switch Contacts Energized Simultaneously
C1990 Incomplete online tests
C1991 Module Calibration Failure
C1992 Vehicle Speed circuit failure
C1993 Air Suspension Pressure Sensor Circuit Failure
C1994 ESP Continuous Operation Fault
C1995 Air Suspension Moisture Ejector Valve Circuit Failure
C1996 Active Yaw and/or Roll Control Disabled
C1997 Pressure Controller plausibility fault
C1998 Module Calibration Not Complete
C1999 Vehicle Speed Signal Circuit Short to Ground
C2000 Steering Angle Sensor Not Calibrated
C2200 Front Passenger's Seat Track Position Switch Circuit Fault
C2201 Front Passenger's Seat Track Position Switch Circuit Open
C2202 Front Passenger's Seat Track Position Switch Circuit Short to Ground
C2203 Front Passenger's Seat Track Position Switch Circuit Short to Battery
C2204 Front Passenger's Seat Track Position Switch Circuit Resistance Out of Range
C2250 Vehicle Speed Signal Circuit Short to Battery
C2251 Implausible Vehicle Speed Deceleration
C2300 Valve Supply Circuit Failure
C2301 Damper Supply Circuit Failure
C2302 Levelling Plausibility Failure
C2303 Reservoir Plausibility Failure
C2304 Damper Supply Circuit Short to Ground
C2305 Damper Supply Circuit Short to Battery
C2767 Reserved - TBD
C2768 Sensor Self Test Signal Faulted
C2769 Longitudinal Acceleration Sensor Electrical Failure
C2770 Longitudinal Acceleration Sensor Plausibility Failure
C2774 Pedal Travel Sensor Plausibility Failure
C2775 TC/AYC ON/OFF Switch Stuck Failure
C2777 Sensor Cluster BUS Failure
C2778 Sensor Power Supply Failure
C2779 Fault DTC (CM): Air Suspension Air Spring/Shock Solenoid Circuit Failure 395E
C2780 ECU in manufacturer sub-state
C2781 Compressor solenoid circuit fault
C2782 Temperature sensor fault
C2783 Sensor Cluster Incorrect
C2784 RAM Checksum Failure
C2785 Sensor(s) Out of Calibration
C2786 Left Rear Sensor Open Circuit
C2787 Right Rear Sensor Open Circuit
C2788 Left Rear Center Sensor Open Circuit
C2789 Right Rear Center Sensor Open Circuit
C2790 LED Array Circuit Failure
C2791 Power Steering Motor Circuit Open
C2792 Power Steering Motor Circuit Short to Battery
C2793 Power Steering Motor Circuit Short to Ground
C2794 Power Steering Motor Overheat Protection
C2795 Brake Assist Unable to Initialize
C2796 Brake Pressure Transducer Supply Circuit Failure
C2797 Brake Pressure Transducer Supply Short to Battery
C2798 Brake Pressure Transducer Supply Short to Ground
C2799 Brake Pressure Transducer Supply Circuit Open
C2800 Brake Pressure Transducer Sense Circuit Open
C2801 Brake Pressure Transducer Sense Short to Ground
C2802 Brake Pressure Transducer Sense Short to Battery
C2803 Brake Pressure Transducer Sense Circuit Failure
C2804 Brake Pressure Transducer Ground Circuit Open
C2805 Brake Pressure Transducer Ground Circuit Short to Battery
C2806 Trailer Brake Output Circuit Short to Vbatt
C2807 Trailer Brake Output Circuit Short to Ground
C2808 Trailer Brake Output Circuit Open
B1001 Headlamp Leveling Relay Coil Short to Battery
B1002 Headlamp Leveling Relay Coil Failure
B1003 Mode Door Circuit Failure
B1004 Glow Plug Short to Battery or Transistor failure
B1005 Fuel Pump Short to Battery or Transistor Failure
B1006 Low Fuel Level to Start Heater
B1007 Coolant Pump Short to Battery or Transistor Failure
B1008 Blower Fan Short to Battery or Transistor Failure
B1009 Heat Switch Short to Ground
B1010 Parking Aid Module Switch Not Connected
B1011 Rear Wiper Park Sense Stuck
B1012 Rear Wiper Park Sense Failure
B1013 Occupant Classification System Calibration Fault
B1014 Rain Sensor Internal Fault
B1015 CEI Unconfigured
B1016 Jump Start Control Module Fault
B1017 Airbag Deployment Disabled for Manufacturing
B1018 (HEV) Power Check Failure
B1019 Headlamp Leveling Switch Signal Input Circuit Failure
B101A Right Headlamp Leveling Motor Circuit Failure
B101B Right Headlamp Leveling Motor Short to Ground
B101C Left Headlamp Leveling Motor Circuit Failure
B101D Left Headlamp Leveling Motor Short to Ground
B101E Keyless Vehicle Security ID Mismatch
B101F Headlamp Reverse Signal Invalid or Not Found
B1020 Door Motor Driver Circuit Failure
B1021 End Button Circuit Short to Battery
B1022 End Button Circuit Failure
B1023 Talk Button Circuit Short to Battery
B1024 Talk Button Circuit Failure
B1025 Send Button Circuit Short to Battery
B1026 Send Button Circuit Failure
B1027 Air Discharge Temperature Sensor (Right) Floor Short to Ground
B1028 Air Discharge Temperature Sensor (Right) Floor Open Circuit
B1029 Air Discharge Temperature Sensor (Right) Panel Short to Ground
B1030 Air Discharge Temperature Sensor (Right) Panel Open Circuit
B1031 SDARS Satellite Antenna Open
B1032 SDARS Satellite Antenna Short
B1033 SDARS Service Deactivated
B1034 Radio Start Signal Circuit Failure
B1035 CD-Read-Test Read Error
B1038 Microphone Input Circuit Failure
B1039 Microphone Input Circuit Short to Battery
B1040 LED Array Circuit Short to Battery
B1041 Direction Indicator Power Feed Blown Fuse
B1042 Front Crash Sensor #2 Internal Fault
B1043 Front Crash Sensor #2 Driver Communications Fault
B1044 Front Crash Sensor #2 Short to Ground/Vbatt
B1045 Front Crash Sensor #2 cross link to another Sensor
B1046 Driver Side Airbag Curtain cross link to another firing loop
B1047 Driver Side, Side Mount Airbag cross link to another firing loop
B1048 Passenger Side Airbag cross link to another firing loop
B1049 Passenger Seatbelt Pretensioner cross link to another firing loop
B104A Front Crash Sensor #2 ID fault
B104B Driver Side Crash Sensor cross link to another Sensor
B104C Passenger Side Crash Sensor cross link to another Sensor
B104D Front Crash Sensor cross link to another Sensor
B104E Driver Side Crash Sensor circuit short to gnd/Vbatt
B104F Passenger Side Crash Sensor Internal Fault
B1050 Passenger Side Crash Sensor circuit short to gnd/Vbatt
B1051 Driver Side Crash Sensor Internal Fault
B1052 Passenger Seatbelt Buckle Switch cross link to another Sensor
B1053 Driver Seatbelt Buckle Switch cross link to another Sensor
B1054 Driver Seatbelt Pretensioner cross link to another firing loop
B1055 Passenger Side, Side Mount Airbag cross link to another firing loop
B1056 Passenger Side Airbag Curtain cross link to another firing loop
B1057 Driver Airbag cross link to another firing loop
B1058 Driver Airbag cross link to another firing loop - Loop #2
B1059 Passenger Airbag cross link to another firing loop - Loop #2
B105A Crash Counter - reached Maximum
B1060 Tire Pressure Monitor System (TPMS) Telltale Circuit Short to Ground
B1061 Tire Pressure Monitor System (TPMS) Telltale Circuit Short to Battery/Open
B1062 Tire Pressure Monitor System (TPMS) Telltale Circuit Incorrect PWM Frequency
B1063 Inner Left Rear (ILR) Tire Pressure Sensor Fault
B1064 Inner Right Rear (IRR) Tire Pressure Sensor Fault
B1065 Radio Volume Cutback Circuit Short to Battery
B1066 Radio Volume Cutback Circuit Failure
B1067 Climate Control / Audio Illumination Output Failure
B1068 Switch Illumination Output Failure
B1069 Keyless Vehicle Secure ID not transferred
B1070 Interior Antenna Group Circuit Short to Ground
B1071 Interior Trunk Antenna Circuit Short to Ground
B1072 Driver Door Handle Antenna Not Connected
B1073 Passenger Door Handle Antenna Not Connected
B1074 Exterior Trunk (bumper) Antenna Not Connected
B1075 Passsenger Interior Antenna Group Not Connected
B1076 Interior Trunk Antenna Not Connected
B1077 Driver Door Handle Antenna Circuit Short to Ground
B1078 Driver Door Handle Antenna Circuit Short to Battery
B1079 Passenger Door Handle Antenna Circuit Short to Battery
B1080 Exterior Trunk (bumper) Antenna Circuit Short to Battery
B1081 Passenger Interior Antenna Group Circuit Short to Battery
B1082 Interior Trunk Antenna Circuit Short to Battery
B1083 Passenger Door Handle Antenna Circuit Short to Ground
B1084 Trunk Lamp Circuit Failure
B1085 Restraint System - Seatbelt Load Limiter Status
B1086 Exterior Trunk (bumper) Antenna Circuit Short to Ground
B1087 Passenger Rear(PR) Latch Clutch Switch Active without PR Unlock Pull Switch
B1088 Driver Rear(DR) Latch Clutch Switch Active without DR Unlock Pull Switch
B1089 Passenger Front(PF) Latch Clutch Switch Active without PF Unlock Pull Switch
B1090 Driver Front(DF) Latch Clutch Switch Active without DF Unlock Pull Switch
B1091 Passive Key (PK) Programming Error
B1092 Serial Line to Smart Steering Column Device (SSCD) Short to Battery or Ground
B1093 Smart Steering Column Device (SSCD) - ID Mismatch
B1094 Smart Steering Column Device (SSCD) ID not stored
B1095 Smart Steering Column Device (SSCD) Hardware Error
B1096 Smart Steering Column Device (SSCD) Communication Timeout
B1097 Audio System Tweeter Circuit Fault
B1098 Mirror Power Fold Output Malfunction
B1099 Mirror Power Fold Output Open Circuit
B1100 Mirror Power Fold Output Short to Battery
B1101 Mirror Power Fold Output Short to Ground
B1102 Mirror Power Fold Switch Input Short to Ground
B1103 Vehicle Horn Control Circuit Failure
B1104 Steering angle sensor signal error
B1105 Rear Open/Close Switch Active During Self Test
B1106 Heater Core Shut off Valve Control Circuit Failure
B1107 Fire Suppression Control Module Sense Circuit Open
B1108 Fire Suppression Control Module Sense Circuit Short to Battery
B1109 Fire Suppression Control Module Sense Circuit Short to Ground
B1110 Fire Suppression Control Module Sense Circuit Resistance Low
B1111 Driver Thermal Electric Device Control Overtemperature Fault
B1112 Driver Thermal Electric Device Control Shorted Fault
B1113 Passenger Thermal Electric Device Control Overtemperature Fault
B1114 Passenger Thermal Electric Device Control Shorted Fault
B1115 Rear Parking Aid Signal Circuit (Short to Ground)
B1116 Rear Parking Aid Signal Circuit Open
B1117 Audio Steering Wheel Button Stuck
B1118 Passenger Front Crash Sensor Mount/Communication Fault
B1119 Audio Disc DVD Player Thermal Shutdown
B1120 Driver Fan Feedback Circuit Short to Ground
B1121 Driver Fan Feedback Circuit Resistance Low
B1122 Passenger Fan Feedback Circuit Short to Ground
B1123 Passenger Fan Feedback Circuit Resistance Low
B1124 Ultrasound Inhibit Switch Short to Ground
B1125 Illuminated Power Window Switches Power Supply Short to Ground
B1126 Steering Column Lock Module Internal Failure
B1127 Low Frequency Antenna#1 Circuit Failure
B1128 Low Frequency Antenna#2 Circuit Failure
B1129 Low Frequency Antenna#3 Circuit Failure
B1130 Security Indicator Circuit Open
B1131 LiftGate/Trunk Low Frequency Antenna Circuit Failure
B1132 Left Front Door Low Frequency Antenna Circuit Failure
B1133 Right Front Door Low Frequency Antenna Circuit Failure
B1134 Card Key Unregistered
B1135 Passenger Front Crash Sensor Internal Fault
B1197 Fuel Operated Heater (FOH) Fuel Pressure Switch Stuck Open
B1198 Fuel Operated Heater (FOH) Fuel Check Valve Short to Ground
B1199 Fuel Operated Heater (FOH) Fuel Check Valve Open/Short to Battery
B1200 Climate Control Pushbutton Circuit Failure
B1201 Fuel Sender Circuit Failure
B1202 Fuel Sender Circuit Open
B1203 Fuel Sender Circuit Short To Battery
B1204 Fuel Sender Circuit Short To Ground
B1205 EIC Switch-1 Assembly Circuit Failure
B1206 EIC Switch-1 Assembly Circuit Open
B1207 EIC Switch-1 Assembly Circuit Short To Battery
B1208 EIC Switch-1 Assembly Circuit Short To Ground
B1209 EIC Switch-2 Assembly Circuit Failure
B1210 EIC Switch-2 Assembly Circuit Open
B1211 EIC Switch-2 Assembly Circuit Short To Battery
B1212 EIC Switch-2 Assembly Circuit Short To Ground
B1213 Anti-Theft Number of Programmed Keys Is Below Minimum
B1214 Running Board Lamp Circuit Failure
B1215 Running Board Lamp Circuit Short to Battery
B1216 Emergency & Road Side Assistance Switch Circuit Short to Ground
B1217 Horn Relay Coil Circuit Failure
B1218 Horn Relay Coil Circuit Short to Vbatt
B1219 Fuel Tank Pressure Sensor Circuit Failure
B1220 Fuel Tank Pressure Sensor Circuit Open
B1221 Driver Seat Heater Output Fault
B1222 Fuel Temperature Sensor #1 Circuit Failure
B1223 Fuel Temperature Sensor #1 Circuit Open
B1224 Fuel Temperature Sensor #1 Circuit Short to Battery
B1225 Fuel Temperature Sensor #1 Circuit Short to Ground
B1226 Fuel Temperature Sensor #2 Circuit Failure
B1227 Fuel Temperature Sensor #2 Circuit Open
B1228 Fuel Temperature Sensor #2 Circuit Short to Battery
B1229 Fuel Temperature Sensor #2 Circuit Short to Ground
B1230 Driver Seat Switch Fault
B1231 Event Threshold Exceeded
B1232 DO NOT USE (See Shop Manual for Description)
B1233 Glass Break Sensor Failure
B1234 Mirror Switch Invalid Code
B1235 Window Feedback Failure
B1236 Window Feedback Loss of Signal
B1237 Window Feedback Out of Range
B1238 Over Temperature Fault
B1239 Air Flow Blend Door Driver Circuit Failure
B1240 Wiper Washer Rear Pump Relay Circuit Failure
B1241 Wiper Washer Rear Pump Relay Circuit Short to Battery
B1242 Air Flow Recirculation Door Driver Circuit Failure
B1243 Express Window Down Switch Circuit Short to Battery
B1244 Wiper Rear Motor Run Relay Circuit Failure
B1245 Wiper Rear Motor Run Relay Circuit Short to Battery
B1246 Dim Panel Potentiometer Switch Circuit Failure
B1247 Panel Dim Switch Circuit Open
B1248 Passenger's Seatback Autoglide Rearward Switch Circuit Short to Ground
B1249 Blend Door Failure
B1250 Air Temperature Internal Sensor Circuit Failure
B1251 Air Temperature Internal Sensor Circuit Open
B1252 Air Temperature Internal Sensor Circuit Short To Battery
B1253 Air Temperature Internal Sensor Circuit Short To Ground
B1254 Air Temperature External Sensor Circuit Failure
B1255 Air Temperature External Sensor Circuit Open
B1256 Air Temperature External Sensor Circuit Short To Battery
B1257 Air Temperature External Sensor Circuit Short To Ground
B1258 Solar Radiation Sensor Circuit Failure
B1259 Solar Radiation Sensor Circuit Open
B1260 Solar Radiation Sensor Circuit Short To Battery
B1261 Solar Radiation Sensor Circuit Short To Ground
B1262 Servo Motor Defrost Circuit Failure
B1263 Servo Motor Vent Circuit Failure
B1264 Servo Motor Foot Circuit Failure
B1265 Servo Motor Coolair Bypass Circuit Failure
B1266 Servo Motor Airintake Left Circuit Failure
B1267 Servo Motor Airintake Right Circuit Failure
B1268 Servo Motor Potentiometer Defrost Circuit Failure
B1269 Servo Motor Potentiometer Defrost Circuit Open
B1270 Servo Motor Potentiometer Defrost Circuit Short To Battery
B1271 Servo Motor Potentiometer Defrost Circuit Short To Ground
B1272 Servo Motor Potentiometer Vent Circuit Failure
B1273 Servo Motor Potentiometer Vent Circuit Open
B1274 Servo Motor Potentiometer Vent Circuit Short To Battery
B1275 Servo Motor Potentiometer Vent Circuit Short To Ground
B1276 Servo Motor Potentiometer Foot Circuit Failure
B1277 Servo Motor Potentiometer Foot Circuit Open
B1278 Servo Motor Potentiometer Foot Circuit Short To Battery
B1279 Servo Motor Potentiometer Foot Circuit Short To Ground
B1280 Servo Motor Potentiometer Coolair Circuit Failure
B1281 Servo Motor Potentiometer Coolair Circuit Open
B1282 Servo Motor Potentiometer Coolair Circuit Short To Battery
B1283 Servo Motor Potentiometer Coolair Circuit Short To Ground
B1284 Servo Motor Potentiometer Airintake Left Circuit Failure
B1285 Servo Motor Potentiometer Airintake Left Circuit Open
B1286 Servo Motor Potentiometer Airintake Left Circuit Short To Battery
B1287 Servo Motor Potentiometer Airintake Left Circuit Short To Ground
B1288 Servo Motor Potentiometer Airintake Right Circuit Failure
B1289 Servo Motor Potentiometer Airintake Right Circuit Open
B1290 Servo Motor Potentiometer Airintake Right Circuit Short To Battery
B1291 Servo Motor Potentiometer Airintake Right Circuit Short To Ground
B1292 Battery Power Relay Circuit Failure
B1293 Battery Power Relay Circuit Open
B1294 Battery Power Relay Circuit Short To Battery
B1295 Battery Power Relay Circuit Short To Ground
B1296 Power Supply Sensor Circuit Failure
B1297 Power Supply Sensor Circuit Open
B1298 Power Supply Sensor Circuit Short To Battery
B1299 Power Supply Sensor Circuit Short To Ground
B1300 Power Door Lock Circuit Failure
B1301 Power Door Lock Circuit Open
B1302 Accessory Delay Relay Coil Circuit Failure
B1303 Accessory Delay Relay Coil Circuit Open
B1304 Accessory Delay Relay Coil Circuit Short To Battery
B1305 Accessory Delay Relay Coil Circuit Short To Ground
B1306 Oil Level Switch Circuit Open
B1307 Oil Level Switch Circuit Short To Battery
B1308 Oil Level Switch Circuit Short To Ground
B1309 Power Door Lock Circuit Short To Ground
B1310 Power Door Unlock Circuit Failure
B1311 Power Door Unlock Circuit Open
B1312 Lamp Headlamp Input Circuit Short To Battery
B1313 Battery Saver Relay Coil Circuit Failure
B1314 Battery Saver Relay Coil Circuit Open
B1315 Battery Saver Relay Coil Circuit Short To Battery
B1316 Battery Saver Relay Coil Circuit Short To Ground
B1317 Battery Voltage High
B1318 Battery Voltage Low
B1319 Driver Door Ajar Circuit Failure
B1320 Driver Door Ajar Circuit Open
B1321 Driver Door Ajar Circuit Short To Battery
B1322 Driver Door Ajar Circuit Short To Ground
B1323 Door Ajar Lamp Circuit Failure
B1324 Door Ajar Lamp Circuit Open
B1325 Door Ajar Lamp Circuit Short To Battery
B1326 Door Ajar Lamp Circuit Short To Ground
B1327 Passenger Door Ajar Circuit Failure
B1328 Passenger Door Ajar Circuit Open
B1329 Passenger Door Ajar Circuit Short To Battery
B1330 Passenger Door Ajar Circuit Short To Ground
B1331 Decklid Ajar Rear Door Circuit Failure
B1332 Decklid Ajar Rear Door Circuit Open
B1333 Decklid Ajar Rear Door Circuit Short To Battery
B1334 Decklid Ajar Rear Door Circuit Short To Ground
B1335 Door Ajar RR Circuit Failure
B1336 Door Ajar RR Circuit Open
B1337 Door Ajar RR Circuit Short To Battery
B1338 Door Ajar RR Circuit Short To Ground
B1339 Chime Input Request Circuit Short To Battery
B1340 Chime Input Request Circuit Short To Ground
B1341 Power Door Unlock Circuit Short To Ground
B1342 ECU Is Faulted
B1343 Heated Backlite Input Circuit Failure
B1344 Heated Backlite Input Circuit Open
B1345 Heated Backlite Input Circuit Short To Ground
B1346 Heated Backlite Input Circuit Short To Battery
B1347 Heated Backlite Relay Circuit Failure
B1348 Heated Backlite Relay Circuit Open
B1349 Heated Backlite Relay Short To Battery
B1350 Heated Backlite Relay Short To Ground
B1351 Ignition Key-In Circuit Short To Battery
B1352 Ignition Key-In Circuit Failure
B1353 Ignition Key-In Circuit Open
B1354 Ignition Key-In Circuit Short To Ground
B1355 Ignition Run Circuit Failure
B1356 Ignition Run Circuit Open
B1357 Ignition Run Circuit Short To Battery
B1358 Ignition Run Circuit Short To Ground
B1359 Ignition Run/Acc Circuit Failure
B1360 Ignition Run/Acc Circuit Open
B1361 Ignition Run/Acc Circuit Short To Battery
B1362 Ignition Run/Acc Circuit Short To Ground
B1363 Ignition Start Circuit Failure
B1364 Ignition Start Circuit Open
B1365 Ignition Start Circuit Short To Battery
B1366 Ignition Start Circuit Short To Ground
B1367 Ignition Tach Circuit Failure
B1368 Ignition Tach Circuit Open
B1369 Ignition Tach Circuit Short To Battery
B1370 Ignition Tach Circuit Short To Ground
B1371 Illuminated Entry Relay Circuit Failure
B1372 Illuminated Entry Relay Circuit Open
B1373 Illuminated Entry Relay Short To Battery
B1374 Illuminated Entry Relay Short To Ground
B1375 Oil Change Lamp Circuit Open
B1376 Oil Change Lamp Circuit Short To Battery
B1377 Oil Change Lamp Circuit Failure
B1378 Oil Change Lamp Circuit Short To Ground
B1379 Oil Change Reset Button Circuit Short To Ground
B1380 Oil Change Reset Button Circuit Failure
B1381 Oil Change Reset Button Circuit Open
B1382 Oil Change Reset Button Circuit Short To Battery
B1383 Oil Level Lamp Circuit Short To Battery
B1384 Oil Level Lamp Circuit Failure
B1385 Oil Level Lamp Circuit Open
B1386 Oil Level Lamp Circuit Short To Ground
B1387 Oil Temperature Sensor Circuit Open
B1388 Oil Temperature Sensor Circuit Short To Battery
B1389 Oil Temperature Sensor Circuit Failure
B1390 Oil Temperature Sensor Circuit Short To Ground
B1391 Oil Level Switch Circuit Failure
B1392 Power Door Memory Lock Relay Circuit Failure
B1393 Power Door Memory Lock Relay Circuit Open
B1394 Power Door Memory Lock Relay Circuit Short To Battery
B1395 Power Door Memory Lock Relay Circuit Short To Ground
B1396 Power Door Lock Circuit Short To Battery
B1397 Power Door Unlock Circuit Short To Battery
B1398 Driver Power Window One Touch Window Relay Circuit Failure
B1399 Driver Power Window One Touch Window Relay Circuit Open
B1400 Driver Power Window One Touch Window Relay Circuit Short To Battery
B1401 Driver Power Window One Touch Window Relay Circuit Short To Ground
B1402 Driver Power Window Down Switch Circuit Failure
B1403 Driver Power Window Up Switch Circuit Failure
B1404 Driver Power Window Down Circuit Open
B1405 Driver Power Window Down Circuit Short To Battery
B1406 Driver Power Window Down Circuit Short To Ground
B1407 Driver Power Window Up Circuit Open
B1408 Driver Power Window Up Circuit Short To Battery
B1409 Driver Power Window Up Circuit Short To Ground
B1410 Driver Power Window Motor Circuit Failure
B1411 Driver Power Window Motor Circuit Open
B1412 Driver Power Window Motor Circuit Short To Battery
B1413 Driver Power Window Motor Circuit Short To Ground
B1414 Power Window LR Motor Circuit Failure
B1415 Power Window LR Motor Circuit Open
B1416 Power Window LR Motor Circuit Short To Battery
B1417 Power Window LR Motor Circuit Short To Ground
B1418 Passenger Power Window Motor Circuit Failure
B1419 Passenger Power Window Motor Circuit Open
B1420 Passenger Power Window Motor Circuit Short To Battery
B1421 Passenger Power Window Motor Circuit Short To Ground
B1422 Power Window RR Motor Circuit Failure
B1423 Power Window RR Motor Circuit Open
B1424 Power Window RR Motor Circuit Short To Battery
B1425 Power Window RR Motor Circuit Short To Ground
B1426 Lamp Seat Belt Circuit Short To Battery
B1427 Lamp Seat Belt Circuit Open
B1428 Lamp Seat Belt Circuit Failure
B1429 Lamp Seat Belt Circuit Short To Ground
B1430 Seat Belt Switch Circuit Short To Ground
B1431 Wiper Brake/Run Relay Circuit Failure
B1432 Wiper Brake/Run Relay Circuit Short To Battery
B1433 Wiper Brake/Run Relay Circuit Short To Ground
B1434 Wiper Hi/Low Speed Relay Coil Circuit Failure
B1435 Wiper Hi/Low Speed Relay Coil Circuit Open
B1436 Wiper Hi/Low Speed Relay Coil Circuit Short To Battery
B1437 Wiper Hi/Low Speed Relay Coil Circuit Short To Ground
B1438 Wiper Mode Select Switch Circuit Failure
B1439 Wiper Mode Select Switch Circuit Open
B1440 Wiper Mode Select Switch Circuit Short To Battery
B1441 Wiper Mode Select Switch Circuit Short To Ground
B1442 Door Handle Switch Circuit Failure
B1443 Door Handle Switch Circuit Open
B1444 Door Handle Switch Circuit Short To Battery
B1445 Door Handle Switch Circuit Short To Ground
B1446 Wiper Park Sense Circuit Failure
B1447 Wiper Park Sense Circuit Open
B1448 Wiper Park Sense Circuit Short To Battery
B1449 Wiper Park Sense Circuit Short To Ground
B1450 Wiper Wash/Delay Switch Circuit Failure
B1451 Wiper Wash/Delay Switch Circuit Open
B1452 Wiper Wash/Delay Switch Circuit Short To Battery
B1453 Wiper Wash/Delay Switch Circuit Short To Ground
B1454 Wiper Washer Fluid Lamp Circuit Failure
B1455 Wiper Washer Fluid Lamp Circuit Open
B1456 Wiper Washer Fluid Lamp Circuit Short To Battery
B1457 Wiper Washer Fluid Lamp Circuit Short To Ground
B1458 Wiper Washer Pump Motor Relay Circuit Failure
B1459 Wiper Washer Pump Motor Relay Coil Circuit Open
B1460 Wiper Washer Pump Motor Relay Coil Circuit Short To Battery
B1461 Wiper Washer Pump Motor Relay Coil Circuit Short To Ground
B1462 Seat Belt Switch Circuit Failure
B1463 Seat Belt Switch Circuit Open
B1464 Seat Belt Switch Circuit Short To Battery
B1465 Wiper Brake/Run Relay Circuit Open
B1466 Wiper Hi/Low Speed Not Switching
B1467 Wiper Hi/Low Speed Circuit Motor Short To Battery
B1468 Chime Input Request Circuit Failure
B1469 Chime Input Request Circuit Open
B1470 Lamp Headlamp Input Circuit Failure
B1471 Lamp Headlamp Input Circuit Open
B1472 Lamp Headlamp Input Circuit Short To Ground
B1473 Wiper Low Speed Circuit Motor Failure
B1474 Battery Saver Power Relay Circuit Short To Battery
B1475 Accessory Delay Relay Short To Battery
B1476 Wiper High Speed Circuit Motor Failure
B1477 Wiper Hi/Low Circuit Motor Short To Ground
B1478 Power Window One Touch Up/Down Activated Simultaneously
B1479 Wiper Washer Fluid Level Sensor Circuit Failure
B1480 Wiper Washer Fluid Level Sensor Circuit Open
B1481 Wiper Washer Fluid Level Sensor Circuit Short To Battery
B1482 Wiper Washer Fluid Level Sensor Circuit Short To Ground
B1483 Brake Pedal Input Circuit Failure
B1484 Brake Pedal Input Open Circuit
B1485 Brake Pedal Input Short to Battery
B1486 Brake Pedal Input Circuit Ground Short
B1487 Door Handle Right Front Circuit Failure
B1488 Door Handle Right Front Circuit Open
B1489 Door Handle Right Front Short To Battery
B1490 Door Handle Right Front Short To Ground
B1491 Ignition Cylinder Sensor Circuit Failure
B1492 Ignition Cylinder Sensor Open Circuit
B1493 Ignition Cylinder Sensor Battery Short
B1494 Ignition Cylinder Sensor Ground Short
B1495 Decklid Punch-Out Sensor Circuit Failure
B1496 Decklid Punch-Out Sensor Open Circuit
B1497 Decklid Punch-Out Sensor Battery Short
B1498 Decklid Punch-Out Sensor Ground Short
B1499 Lamp Turn Signal Left Circuit Failure
B1500 Lamp Turn Signal Left Circuit Open
B1501 Lamp Turn Signal Left Circuit Short To Battery
B1502 Lamp Turn Signal Left Circuit Short To Ground
B1503 Lamp Turn Signal Right Circuit Failure
B1504 Lamp Turn Signal Right Circuit Open
B1505 Lamp Turn Signal Right Circuit Short To Battery
B1506 Lamp Turn Signal Right Circuit Short To Ground
B1507 Flash To Pass Switch Circuit Failure
B1508 Flash To Pass Switch Circuit Open
B1509 Flash To Pass Switch Circuit Short To Battery
B1510 Flash To Pass Switch Circuit Short To Ground
B1511 Driver Door Handle Circuit Failure
B1512 Driver Door Handle Circuit Open
B1513 Driver Door Handle Circuit Short To Battery
B1514 Driver Door Handle Circuit Short To Ground
B1515 Seat Driver Occupied Switch Circuit Failure
B1516 Seat Driver Occupied Switch Circuit Open
B1517 Seat Driver Occupied Switch Circuit Short To Battery
B1518 Seat Driver Occupied Switch Circuit Short To Ground
B1519 Hood Switch Circuit Failure
B1520 Hood Switch Circuit Open
B1521 Hood Switch Circuit Short To Battery
B1522 Hood Switch Circuit Short To Ground
B1523 Keyless Entry Circuit Failure
B1524 Keyless Entry Circuit Open
B1525 Keyless Entry Circuit Short To Battery
B1526 Keyless Entry Circuit Short To Ground
B1527 Memory Set Switch Circuit Failure
B1528 Memory Set Switch Circuit Open
B1529 Memory Set Switch Circuit Short To Battery
B1530 Memory Set Switch Circuit Short To Ground
B1531 Memory 1 Switch Circuit Failure
B1532 Memory 1 Switch Circuit Open
B1533 Memory 1 Switch Circuit Short To Battery
B1534 Memory 1 Switch Circuit Short To Ground
B1535 Memory 2 Switch Circuit Failure
B1536 Memory 2 Switch Circuit Open
B1537 Memory 2 Switch Circuit Short To Battery
B1538 Memory 2 Switch Circuit Short To Ground
B1539 Mirror Driver Switch Assembly Circuit Failure
B1540 Mirror Driver Switch Assembly Circuit Open
B1541 Mirror Driver Switch Assembly Circuit Short To Battery
B1542 Mirror Driver Switch Assembly Circuit Short To Ground
B1543 Seat Direction Switch Assembly Circuit Failure
B1544 Seat Direction Switch Assembly Circuit Open
B1545 Seat Direction Switch Assembly Circuit Short To Battery
B1546 Seat Direction Switch Assembly Circuit Short To Ground
B1547 Power Window Master Circuit Failure
B1548 Power Window Master Circuit Open
B1549 Power Window Master Circuit Short To Battery
B1550 Power Window Master Circuit Short To Ground
B1551 Latch/Deck Lid Release Circuit Failure
B1552 Decklid Release Circuit Open
B1553 Decklid Release Circuit Short To Battery
B1554 Decklid Release Circuit Short To Ground
B1555 Ignition Run/Start Circuit Failure
B1556 Ignition Run/Start Circuit Open
B1557 Ignition Run/Start Circuit Short To Battery
B1558 Ignition Run/Start Circuit Short To Ground
B1559 Door Lock Cylinder Circuit Failure
B1560 Door Lock Cylinder Circuit Open
B1561 Door Lock Cylinder Circuit Short To Battery
B1562 Door Lock Cylinder Circuit Short To Ground
B1563 Door Ajar Circuit Failure
B1564 Door Ajar Circuit Open
B1565 Door Ajar Circuit Short To Battery
B1566 Door Ajar Circuit Short To Ground
B1567 Lamp Headlamp High-Beam Circuit Failure
B1568 Lamp Headlamp High-Beam Circuit Open
B1569 Lamp Headlamp High-Beam Circuit Short To Battery
B1570 Lamp Headlamp High-Beam Circuit Short To Ground
B1571 Door Ajar LR Circuit Failure
B1572 Door Ajar LR Circuit Open
B1573 Door Ajar LR Circuit Short To Battery
B1574 Door Ajar LR Circuit Short To Ground
B1575 Lamp Park Input Circuit Failure
B1576 Lamp Park Input Circuit Open
B1577 Lamp Park Input Circuit Short To Battery
B1578 Lamp Park Input Circuit Short To Ground
B1579 Dim Panel Increase Input Circuit Failure
B1580 Dim Panel Increase Input Circuit Open
B1581 Dim Panel Increase Input Circuit Short To Battery
B1582 Dim Panel Increase Input Circuit Short To Ground
B1583 Dim Panel Decrease Input Circuit Failure
B1584 Dim Panel Decrease Input Circuit Open
B1585 Dim Panel Decrease Input Circuit Short To Battery
B1586 Dim Panel Decrease Input Circuit Short To Ground
B1587 Autolamp Delay Increase Circuit Failure
B1588 Autolamp Delay Increase Circuit Open
B1589 Autolamp Delay Increase Circuit Short To Battery
B1590 Autolamp Delay Increase Circuit Short To Ground
B1591 Autolamp Delay Decrease Circuit Failure
B1592 Autolamp Delay Decrease Circuit Open
B1593 Autolamp Delay Decrease Circuit Short To Battery
B1594 Autolamp Delay Decrease Circuit Short To Ground
B1595 Ignition Switch Illegal Input Code
B1596 Service Continuous Codes
B1597 Driver's Seat Seatback Autoglide Forward Switch Circuit Short to Ground
B1598 Driver's Seat Seatback Autoglide Rearward Switch Circuit Short to Ground
B1599 Passenger's Seatback Autoglide Forward Switch Circuit Short to Ground
B1600 PATS Ignition Key Transponder Signal Is Not Received
B1601 PATS Received Incorrect Key-Code From Ignition Key Transponder
B1602 PATS Received Invalid Format Of Key-Code From Ignition Key Transponder
B1603 Lamp Anti-Theft Indicator Circuit Failure
B1604 Lamp Anti-Theft Indicator Circuit Open
B1605 Lamp Anti-Theft Indicator Circuit Short To Battery
B1606 Lamp Anti-Theft Indicator Circuit Short To Ground
B1607 Illuminated Entry Input Circuit Failure
B1608 Illuminated Entry Input Open Circuit
B1609 Illuminated Entry Input Short Circuit To Battery
B1610 Illuminated Entry Input Short Circuit To Ground
B1611 Wiper Rear Mode Select Switch Circuit Failure
B1612 Wiper Rear Mode Select Switch Circuit Open
B1613 Wiper Rear Mode Select Switch Circuit Short To Battery
B1614 Wiper Rear Mode Select Switch Circuit Short To Ground
B1615 Wiper Rear Disable Switch Circuit Failure
B1616 Wiper Rear Disable Switch Circuit Open
B1617 Wiper Rear Disable Switch Circuit Short To Battery
B1618 Wiper Rear Disable Switch Circuit Short To Ground
B1619 Wiper Rear Low Limit Input Circuit Failure
B1620 Wiper Rear Low Limit Input Circuit Open
B1621 Wiper Rear Low Limit Input Circuit Short To Battery
B1622 Wiper Rear Low Limit Input Circuit Short To Ground
B1623 Lamp Keypad Output Circuit Failure
B1624 Lamp Keypad Output Open Circuit
B1625 Lamp Keypad Output Short Circuit To Battery
B1626 Lamp Keypad Output Short Circuit To Ground
B1627 PRNDL Reverse Input Circuit Failure
B1628 PRNDL Reverse Input Open Circuit
B1629 PRNDL Reverse Input Short To Battery
B1630 PRNDL Reverse Input Short Circuit To Ground
B1631 Mirror Driver Left Circuit Failure
B1632 Mirror Driver Left Circuit Open
B1633 Mirror Driver Left Circuit Short To Battery
B1634 Mirror Driver Left Circuit Short To Ground
B1635 Mirror Driver Right Circuit Failure
B1636 Mirror Driver Right Circuit Open
B1637 Mirror Driver Right Circuit Short To Battery
B1638 Mirror Driver Right Short To Ground
B1639 Mirror Passenger Left Circuit Failure
B1640 Mirror Passenger Left Circuit Open
B1641 Mirror Passenger Left Circuit Short To Battery
B1642 Mirror Passenger Left Circuit Short To Ground
B1643 Mirror Passenger Right Circuit Failure
B1644 Mirror Passenger Right Circuit Open
B1645 Mirror Passenger Right Circuit Short To Battery
B1646 Mirror Passenger Right Circuit Short To Ground
B1647 Seat Driver Recline Forward Circuit Failure
B1648 Seat Driver Recline Forward Circuit Open
B1649 Seat Driver Recline Forward Circuit Short To Battery
B1650 Seat Driver Recline Forward Circuit Short To Ground
B1651 Seat Driver Recline Backward Circuit Failure
B1652 Seat Driver Recline Backward Circuit Open
B1653 Seat Driver Recline Backward Circuit Short To Battery
B1654 Seat Driver Recline Backward Circuit Short To Ground
B1655 Seat Driver Rear Up Circuit Failure
B1656 Seat Driver Rear Up Circuit Open
B1657 Seat Driver Rear Up Circuit Short To Battery
B1658 Seat Driver Rear Up Circuit Short To Ground
B1659 Seat Driver Front Up Circuit Failure
B1660 Seat Driver Front Up Circuit Open
B1661 Seat Driver Front Up Circuit Short To Battery
B1662 Seat Driver Front Up Circuit Short To Ground
B1663 Seat Driver Front Up/Down Motor Stalled
B1664 Seat Driver Rear Up/Down Motor Stalled
B1665 Seat Driver Forward/Backward Motor Stalled
B1666 Seat Driver Recline Motor Stalled
B1667 Mirror Driver Up/Down Motor Stalled
B1668 Mirror Driver Right/Left Motor Stalled
B1669 Mirror Passenger Up/Down Motor Stalled
B1670 Mirror Passenger Right/Left Motor Stalled
B1671 Battery Module Voltage Out Of Range
B1672 Seat Driver Occupied Input Circuit Failure
B1673 Seat Driver Occupied Input Circuit Open
B1674 Seat Driver Occupied Input Circuit Short To Battery
B1675 Seat Driver Occupied Input Circuit Short To Ground
B1676 Battery Pack Voltage Out Of Range
B1677 Alarm Panic Input Circuit Failure
B1678 Alarm Panic Input Circuit Open
B1679 Alarm Panic Input Circuit Short To Battery
B1680 Alarm Panic Input Circuit Short To Ground
B1681 PATS Transceiver Module Signal Is Not Received
B1682 PATS Is Disabled (Check Link Between PATS And Transponder)
B1683 Mirror Driver/Passenger Switch Circuit Failure
B1684 Mirror Driver/Passenger Switch Circuit Open
B1685 Lamp Dome Input Circuit Failure
B1686 Lamp Dome Input Circuit Open
B1687 Lamp Dome Input Circuit Short To Battery
B1688 Lamp Dome Input Circuit Short To Ground
B1689 Autolamp Delay Circuit Failure
B1690 Autolamp Delay Circuit Open
B1691 Autolamp Delay Circuit Short To Battery
B1692 Autolamp Delay Circuit Short To Ground
B1693 Autolamp On Circuit Failure
B1694 Autolamp On Circuit Open
B1695 Autolamp On Circuit Short To Battery
B1696 Autolamp On Circuit Short To Ground
B1697 Mirror Driver/Passenger Switch Circuit Short To Battery
B1698 Mirror Driver/Passenger Switch Circuit Short To Ground
B1699 Passenger's Seat Occupied Switch Circuit Short to Ground
B1700 Passenger's Seatbelt Tension Reducer Circuit Short to Ground
B1701 Seat Driver Recline Forward Switch Circuit Failure
B1702 Seat Driver Recline Forward Switch Circuit Open
B1703 Seat Driver Recline Forward Switch Circuit Short To Battery
B1704 Seat Driver Recline Forward Switch Circuit Short To Ground
B1705 Seat Driver Recline Rearward Switch Circuit Failure
B1706 Seat Driver Recline Rearward Switch Circuit Open
B1707 Seat Driver Recline Rearward Switch Circuit Short To Battery
B1708 Seat Driver Recline Rearward Switch Circuit Short To Ground
B1709 Seat Driver Front Up Switch Circuit Failure
B1710 Seat Driver Front Up Switch Circuit Open
B1711 Seat Driver Front Up Switch Circuit Short To Battery
B1712 Seat Driver Front Up Switch Circuit Short To Ground
B1713 Seat Driver Front Down Switch Circuit Failure
B1714 Seat Driver Front Down Switch Circuit Open
B1715 Seat Driver Front Down Switch Circuit Short To Battery
B1716 Seat Driver Front Down Switch Circuit Short To Ground
B1717 Seat Driver Forward Switch Circuit Failure
B1718 Seat Driver Forward Switch Circuit Open
B1719 Seat Driver Forward Switch Circuit Short To Battery
B1720 Seat Driver Forward Switch Circuit Short To Ground
B1721 Seat Driver Rearward Switch Circuit Failure
B1722 Seat Driver Rearward Switch Circuit Open
B1723 Seat Driver Rearward Switch Circuit Short To Battery
B1724 Seat Driver Rearward Switch Circuit Short To Ground
B1725 Seat Driver Rear Up Switch Circuit Failure
B1726 Seat Driver Rear Up Switch Circuit Open
B1727 Seat Driver Rear Up Switch Circuit Short To Battery
B1728 Seat Driver Rear Up Switch Circuit Short To Ground
B1729 Seat Driver Rear Down Switch Circuit Failure
B1730 Seat Driver Rear Down Switch Circuit Open
B1731 Seat Driver Rear Down Switch Circuit Short To Battery
B1732 Seat Driver Rear Down Switch Circuit Short To Ground
B1733 Mirror Driver Vertical Switch Circuit Failure
B1734 Mirror Driver Vertical Switch Circuit Open
B1735 Mirror Driver Vertical Switch Circuit Short To Battery
B1736 Mirror Driver Vertical Switch Circuit Short To Ground
B1737 Mirror Driver Horizontal Switch Circuit Failure
B1738 Mirror Driver Horizontal Switch Circuit Open
B1739 Mirror Driver Horizontal Switch Circuit Short To Battery
B1740 Mirror Driver Horizontal Switch Circuit Short To Ground
B1741 Mirror Passenger Vertical Switch Circuit Failure
B1742 Mirror Passenger Vertical Switch Circuit Open
B1743 Mirror Passenger Vertical Switch Circuit Short To Battery
B1744 Mirror Passenger Vertical Switch Circuit Short To Ground
B1745 Mirror Passenger Horizontal Switch Circuit Failure
B1746 Mirror Passenger Horizontal Switch Circuit Open
B1747 Mirror Passenger Horizontal Switch Circuit Short To Battery
B1748 Mirror Passenger Horizontal Switch Circuit Short To Ground
B1749 Park/Neutral Switch Circuit Failure
B1750 Park/Neutral Switch Circuit Open
B1751 Park/Neutral Switch Circuit Short To Battery
B1752 Park/Neutral Switch Circuit Short To Ground
B1753 Hazard Flash Output Circuit Failure
B1754 Hazard Flash Output Circuit Open
B1755 Hazard Flash Output Circuit Short Battery
B1756 Hazard Flash Output Circuit Short To Ground
B1757 Seat Driver Rear Down Circuit Failure
B1758 Seat Driver Rear Down Circuit Open
B1759 Seat Driver Rear Down Circuit Short To Battery
B1760 Seat Driver Rear Down Circuit Short To Ground
B1761 Seat Driver Front Down Circuit Failure
B1762 Seat Driver Front Down Circuit Open
B1763 Seat Driver Front Down Circuit Short To Battery
B1764 Seat Driver Front Down Circuit Short To Ground
B1765 Seat Driver Forward Circuit Failure
B1766 Seat Driver Forward Circuit Open
B1767 Seat Driver Forward Circuit Short To Battery
B1768 Seat Driver Forward Circuit Short To Ground
B1769 Seat Driver Backward Circuit Failure
B1770 Seat Driver Backward Circuit Open
B1771 Seat Driver Backward Circuit Short To Battery
B1772 Seat Driver Backward Circuit Short To Ground
B1773 Mirror Driver Up Circuit Failure
B1774 Mirror Driver Up Circuit Open
B1775 Mirror Driver Up Circuit Short To Battery
B1776 Mirror Driver Up Circuit Short To Ground
B1777 Driver's Seatbelt Tension Reducer Circuit Short to Ground
B1778 Mirror Driver Down Circuit Failure
B1779 Mirror Driver Down Circuit Open
B1780 Mirror Driver Down Circuit Short To Battery
B1781 Mirror Driver Down Short To Ground
B1782 Mirror Passenger Up Circuit Failure
B1783 Mirror Passenger Up Circuit Open
B1784 Mirror Passenger Up Circuit Short To Battery
B1785 Mirror Passenger Up Circuit Short To Ground
B1786 Mirror Passenger Down Circuit Failure
B1787 Mirror Passenger Down Circuit Open
B1788 Mirror Passenger Down Circuit Short To Battery
B1789 Mirror Passenger Down Circuit Short To Ground
B1790 Autolamp Sensor Input Circuit Failure
B1791 Autolamp Sensor Input Circuit Open
B1792 Autolamp Sensor Input Circuit Short To Battery
B1793 Autolamp Sensor Input Circuit Short To Ground
B1794 Lamp Headlamp Low-Beam Circuit Failure
B1795 Lamp Headlamp Low-Beam Circuit Open
B1796 Lamp Headlamp Low-Beam Circuit Short To Battery
B1797 Lamp Headlamp Low-Beam Circuit Short To Ground
B1798 Lamp Turn Signal Front Output Circuit Failure
B1799 Lamp Turn Signal Front Output Circuit Open
B1800 Lamp Turn Signal Front Output Circuit Short To Battery
B1801 Lamp Turn Signal Front Output Circuit Short To Ground
B1802 Lamp Turn Signal Rear Output Circuit Failure
B1803 Lamp Turn Signal Rear Output Circuit Open
B1804 Lamp Turn Signal Rear Output Circuit Short To Battery
B1805 Lamp Turn Signal Rear Output Circuit Short To Ground
B1806 Lamp Tail Output Circuit Failure
B1807 Lamp Tail Output Circuit Open
B1808 Lamp Tail Output Circuit Short To Battery
B1809 Lamp Tail Output Circuit Short To Ground
B1810 Lamp Backup Switch Input Circuit Failure
B1811 Lamp Backup Switch Input Circuit Open
B1812 Lamp Backup Switch Input Circuit Short To Battery
B1813 Lamp Backup Switch Input Circuit Short To Ground
B1814 Wiper Rear Motor Down Relay Coil Circuit Failure
B1815 Wiper Rear Motor Down Relay Coil Circuit Open
B1816 Wiper Rear Motor Down Relay Coil Circuit Short To Battery
B1817 Wiper Rear Motor Down Relay Coil Circuit Short To Ground
B1818 Wiper Rear Motor Up Relay Coil Circuit Failure
B1819 Wiper Rear Motor Up Relay Coil Circuit Open
B1820 Wiper Rear Motor Up Relay Coil Circuit Short To Battery
B1821 Wiper Rear Motor Up Relay Coil Circuit Short To Ground
B1822 Wiper Rear Park Sense Input Circuit Failure
B1823 Wiper Rear Park Sense Input Circuit Open
B1824 Wiper Rear Park Sense Input Circuit Short To Battery
B1825 Wiper Rear Park Sense Input Circuit Short To Ground
B1826 Wiper Rear High Limit Input Circuit Failure
B1827 Wiper Rear High Limit Input Circuit Open
B1828 Wiper Rear High Limit Input Circuit Short To Battery
B1829 Wiper Rear High Limit Input Circuit Short To Ground
B1830 Door Unlock Disarm Switch Circuit Failure
B1831 Door Unlock Disarm Switch Circuit Open
B1832 Door Unlock Disarm Switch Circuit Short To Battery
B1833 Door Unlock Disarm Switch Circuit Short To Ground
B1834 Door Unlock Disarm Output Circuit Failure
B1835 Door Unlock Disarm Output Circuit Open
B1836 Door Unlock Disarm Output Circuit Short To Battery
B1837 Door Unlock Disarm Output Circuit Short To Ground
B1838 Battery Saver Power Relay Circuit Failure
B1839 Wiper Rear Motor Circuit Failure
B1840 Wiper Front Power Circuit Failure
B1841 Wiper Front Power Circuit Open
B1842 Wiper Front Power Circuit Short To Battery
B1843 Wiper Front Power Circuit Short To Ground
B1844 Phone Handset Circuit Failure
B1845 Ignition Tamper Circuit Failure
B1846 Ignition Tamper Circuit Open
B1847 Ignition Tamper Circuit Short To Battery
B1848 Ignition Tamper Circuit Short To Ground
B1849 Climate Control Temperature Differential Circuit Failure
B1850 Climate Control Temperature Differential Circuit Open
B1851 Climate Control Temperature Differential Circuit Short To Battery
B1852 Climate Control Temperature Differential Circuit Short To Ground
B1853 Climate Control Air Temperature Internal Sensor Motor Circuit Failure
B1854 Climate Control Air Temperature Internal Sensor Motor Circuit Open
B1855 Climate Control Air Temperature Internal Sensor Motor Circuit Short To Battery
B1856 Climate Control Air Temperature Internal Sensor Motor Circuit Short To Ground
B1857 Climate Control On/Off Switch Circuit Failure
B1858 Climate Control A/C Pressure Switch Circuit Failure
B1859 Climate Control A/C Pressure Switch Circuit Open
B1860 Climate Control A/C Pressure Switch Circuit Short To Battery
B1861 Climate Control A/C Pressure Switch Circuit Short To Ground
B1862 Climate Control A/C Lock Sensor Failure
B1863 Ground ECU Circuit Open
B1864 Battery Power Supply ECU Circuit Failure
B1865 Battery Power Supply ECU Circuit Open
B1866 Battery Power Supply ECU Circuit Short To Battery
B1867 Battery Power Supply ECU Circuit Short To Ground
B1868 Lamp Air Bag Warning Indicator Circuit Failure
B1869 Lamp Air Bag Warning Indicator Circuit Open
B1870 Lamp Air Bag Warning Indicator Circuit Short To Battery
B1871 Passenger Air Bag Disable Module Fault
B1872 Turn Signal / Hazard Power Feed Circuit Short To Battery
B1873 Turn Signal / Hazard Power Feed Circuit Short To Ground
B1874 Cellular Phone Handset Not Present
B1875 Turn Signal / Hazard Switch Signal Circuit Failure
B1876 Seatbelt Driver Pretensioner Circuit Failure
B1877 Seatbelt Driver Pretensioner Circuit Open
B1878 Seatbelt Driver Pretensioner Circuit Short to Battery
B1879 Seatbelt Driver Pretensioner Circuit Short to Ground
B1880 Seatbelt Passenger Pretensioner Circuit Failure
B1881 Seatbelt Passenger Pretensioner Circuit Open
B1882 Seatbelt Passenger Pretensioner Circuit Short to Battery
B1883 Seatbelt Passenger Pretensioner Circuit Short to Ground
B1884 PAD Warning Lamp Circuit Failure
B1885 Seatbelt Driver Pretensioner Circuit Resistance Low on Squib
B1886 Seatbelt Passenger Pretensioner Circuit Resistance Low on Squib
B1887 Air Bag Driver Circuit Resistance Low or Shorted Together
B1888 Air Bag Passenger Circuit Resistance Low or Shorted Together
B1889 Passenger Airbag Disable Module Sensor Obstructed
B1890 PAD Warning Lamp Circuit Short to Battery
B1891 Air Bag Tone Warning Indicator Circuit Short to Battery
B1892 Air Bag Tone Warning Indicator Circuit Failure
B1893 GPS Antenna Open Circuit
B1894 Wiper Rear Motor Speed Sense Circuit Failure
B1895 Driver's / Passenger's Door Ajar Output Circuit Failure
B1896 Driver's / Passenger's Door Ajar Output Circuit Short to Battery
B1897 Horn Switch Circuit Failure
B1898 Chime Input #2 Circuit Short to Ground
B1899 Microphone Input Signal Circuit Open
B1900 Driver Side Airbag Fault
B1901 Air Bag Crash Sensor #1 Feed/Return Circuit Short To Ground
B1902 Air Bag Crash Sensor #1 Ground Circuit Failure
B1903 Air Bag Crash Sensor #1 Ground Circuit Short To Battery
B1904 Air Bag Crash Sensor #2 Feed/Return Circuit Failure
B1905 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Battery
B1906 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Ground
B1907 Air Bag Crash Sensor #2 Ground Circuit Failure
B1908 Air Bag Crash Sensor #2 Ground Circuit Short To Battery
B1909 Air Bag Crash Sensor #2 Ground Circuit Short To Ground
B1910 Air Bag Diagnostic Monitor Ground Circuit Failure
B1911 Air Bag Diagnostic Monitor Ground Circuit Short To Battery
B1912 Air Bag Diagnostic Monitor Ground Circuit Short To Ground
B1913 Air Bag Driver/Passenger Circuit Short To Ground
B1914 Air Bag Crash Sensors #1 / #2 Circuit Short To Ground
B1915 Air Bag Driver Circuit Failure
B1916 Air Bag Driver Circuit Short To Battery
B1917 Air Bag Memory Clear Circuit Failure
B1918 Air Bag Memory Clear Circuit Open
B1919 Air Bag Memory Clear Circuit Short To Battery
B1920 Air Bag Passenger Circuit Failure
B1921 Air Bag Diagnostic Monitor Ground Circuit Open
B1922 Air Bag Safing Sensor Output Circuit Short To Battery
B1923 Air Bag Memory Clear Circuit Short To Ground
B1924 Air Bag Internal Diagnostic Monitor Fault or System Disarm Fault
B1925 Air Bag Passenger Circuit Short To Battery
B1926 Air Bag Passenger Pressure Switch Circuit Failure
B1927 Passenger Side Airbag Fault
B1928 Air Bag Safing Sensor Output Circuit Failure
B1929 Air Bag Safing Sensor Output Circuit Open
B1930 Air Bag Safing Sensor Output Circuit Short To Ground
B1931 Air Bag Crash Sensor #1 Feed/Return Circuit Failure
B1932 Air Bag Driver Circuit Open
B1933 Air Bag Passenger Circuit Open
B1934 Air Bag Driver Inflator Circuit Resistance Low on Squib
B1935 Air Bag Passenger Inflator Circuit Resistance Low on Squib
B1936 Air Bag Driver Circuit Short To Ground
B1937 Air Bag Passenger Pressure Switch Circuit Open
B1938 Air Bag Passenger Circuit Short To Ground
B1939 Air Bag Passenger Pressure Switch Circuit Short To Ground
B1940 Seat Memory Position Out Of Range. A102
B1941 Air Bag Crash Sensor #1 Feed/Return Circuit Open
B1942 Air Bag Crash Sensor #2 Feed/Return Circuit Open
B1943 Air Bag Crash Sensor #1 Ground Circuit Short To Ground
B1944 Air Bag Crash Sensor #1 Ground Circuit Open
B1945 Air Bag Crash Sensor #2 Ground Circuit Open
B1946 Climate Control A/C Post Evaporator Sensor Circuit Failure
B1947 Climate Control A/C Post Evaporator Sensor Circuit Short To Ground
B1948 Climate Control Water Temperature Sensor Circuit Failure
B1949 Climate Control Water Temperature Sensor Circuit Short To Ground
B1950 Seat Rear Up/Down Position Feedback Circuit Failure
B1951 Seat Rear Up/Down Position Feedback Circuit Open
B1952 Seat Rear Up/Down Position Feedback Circuit Short To Battery
B1953 Seat Rear Up/Down Position Feedback Circuit Short To Ground
B1954 Seat Front Up/Down Position Feedback Circuit Failure
B1955 Seat Front Up/Down Position Feedback Circuit Open
B1956 Seat Front Up/Down Position Feedback Circuit Short To Battery
B1957 Seat Front Up/Down Position Feedback Circuit Short To Ground
B1958 Seat Recline Forward/Backward Position Feedback Circuit Failure
B1959 Seat Recline Forward/Backward Position Feedback Circuit Open
B1960 Seat Recline Forward/Backward Position Feedback Circuit Short To Battery
B1961 Seat Recline Forward/Backward Position Feedback Circuit Short To Ground
B1962 Seat Horizontal Forward/Rearward Position Feedback Circuit Failure
B1963 Seat Horizontal Forward/Rearward Position Feedback Circuit Open
B1964 Seat Horizontal Forward/Rearward Position Feedback Circuit Short To Battery
B1965 Seat Horizontal Forward/Rearward Position Feedback Circuit Short To Ground
B1966 A/C Post Heater Sensor Circuit Failure
B1967 A/C Post Heater Sensor Circuit Short To Ground
B1968 A/C Water Pump Detection Circuit Failure
B1969 A/C Clutch Magnetic Control Circuit Failure
B1970 Passenger Seatback Forward Switch Circuit Short to Ground
B1971 Passenger Seatback Rearward Switch Circuit Short to Ground
B1972 Passenger Rear Seat Up Switch Circuit Short to Battery
B1973 Passenger Rear Seat Down Switch Circuit Short to Battery
B1974 Passenger's Seat Recline Forward Switch Circuit Short to Battery
B1975 Passenger's Seat Recline Back Switch Circuit Short to Battery
B1976 Passenger's Seat Forward Switch Circuit Short to Battery
B1977 Passenger's Front Seat Up Switch Circuit Short to Battery
B1978 Passenger's Front Seat Down Switch Circuit Short to Battery
B1979 Passenger Seat Rearward Switch Circuit Short to Battery
B1980 Bulb - Outage Condition Detected
B1981 Memory Off Switch Circuit Short to Battery
B1982 Driver's Door Unlock Relay Circuit Failure
B1983 Driver's Door Unlock Relay Circuit Short to Battery
B1984 Seat Switch Lumbar Inflate Circuit Failure
B1985 Seat Switch Lumbar Deflate Circuit Failure
B1986 Driver's Seat Seatback Autoglide Rearward Switch Circuit Failure
B1987 Pedal Forward / Rearward Motor Stalled
B1988 Pedal Position Forward Switch Circuit Short to Battery
B1989 Pedal Position Rearward Switch Circuit Short to Battery
B1990 Pedal Forward / Rearward Potentiometer Feedback Circuit Failure
B1991 Pedal Forward / Rearward Potentiometer Feedback Circuit Short to Battery
B1992 Driver Side, Side mount Airbag Circuit Short to Vbatt
B1993 Driver Side, Side mount Airbag Circuit Short to Ground
B1994 Driver Side, Side mount Airbag Circuit Open
B1995 Driver Side, Side mount Airbag Low resistance on Squib
B1996 Passenger Side, Side mount Airbag Circuit Short to Vbatt
B1997 Passenger Side, Side mount Airbag Circuit Short to Ground
B1998 Passenger Side, Side mount Airbag Circuit Open
B1999 Passenger Side, Side mount Airbag Low resistance on Squib
B2000 Pedal position forward switch circuit short to ground
B2001 Pedal position rearward switch circuit short to ground
B2002 ECU Body & Assembly Testing Incomplete
B2003 Incorrect Vehicle Security IVIN
B2004 Internal Media Over Temperature Fault
B2005 Climate Control Temperature Switch Out of Range
B2006 Blower Motor Switch Out of Range
B2007 Driver Solar Radiation Sensor Out of Range
B2008 Wipers On Signal Circuit Short to Ground
B2009 Security Status Mismatch
B200A VSM Inclination Failure
B200B VSM Ultrasonic Failure
B200C VSM Module Failure
B2010 Servo Motor Panel Door Circuit Failure
B2011 Panel Door Actuator Motor Out of Range
B2012 Driver Airintake Actuator Motor Out of Range
B2013 Passenger Airintake Actuator Motor Out of Range
B2014 Climate Control A/C Post Evaporator Sensor Open Circuit
B2015 Power Sliding Door Latch Switch Short to Ground
B2016 Power Sliding Door Latch Switch Open Circuit
B2017 Daytime Running Lamp Left Output Circuit Failure
B2018 Daytime Running Lamp Right Output Circuit Failure
B2019 Liftage Exceeded Time Allowed to Cinch Door
B2020 Courtesy Lamp Output Ckt Short to Ground
B2021 Dome Lamp Output Return Circuit Failure
B2022 Rear Courtesy Lamp Output Circuit Failure
B2023 Rear Courtesy Lamp Output Circuit Short to Ground
B2024 Rear Courtesy Lamp Output Return Circuit Failure
B2025 Demand Lamps Circuit Failure
B2026 Incandescent Backlighting Output Circuit Failure
B2027 LED Backlighting Output Circuit Failure
B2028 Power Liftgate Open/Close Output Circuit Failure
B2029 Power Liftgate Open/Close Output Circuit Short to Battery
B2030 Front Fog Lamp Relay Ckt Failure
B2031 Left Corner Lamp Output Circuit Failure
B2032 Right Corner Lamp Output Circuit Failure
B2033 Left Aux Park Lamp Output Circuit Failure
B2034 Right Aux Park Lamp Output Circuit Failure
B2035 LF Side Repeater Lamp Output Ckt Failure
B2036 LF Side Repeater Lamp Output Ckt Short to Ground
B2037 RF Side Repeater Lamp Output Ckt Failure
B2038 RF Side Repeater Lamp Output Ckt Short to Ground
B2039 License Lamp Circuit Short to Ground
B2040 Mirror Lamp Output Circuit Failure
B2041 Mirror Lamp Output Circuit Short to Ground
B2042 Left Mirror Turn Signal Output Circuit Failure
B2043 Right Mirror Turn Signal Output Circuit Failure
B2044 Left Rear Stop Lamp Circuit Short to Ground
B2045 Left Rear Stop Lamp Circuit Open
B2046 Right Rear Stop Lamp Circuit Short to Ground
B2047 Right Rear Stop Lamp Circuit Open
B2048 Left Rear Turn Lamp Circuit Short to Ground
B2049 Left Rear Turn Lamp Circuit Open
B2050 Right Rear Turn Lamp Circuit Short to Ground
B2051 Right Rear Turn Lamp Circuit Open
B2052 Accessory Delay Relay Output Failure
B2053 Accessory Delay Relay2 Output Failure
B2054 Accessory Delay Relay2 Short To Battery
B2055 Left Power Sliding Door Open/Close Output Circuit Failure
B2056 Right Power Sliding Door Open/Close Output Circuit Failure
B2057 Left Power Sliding Door Open/Close Switch Circuit Short to Ground
B2058 Right Power Sliding Door Open/Close Switch Circuit Short to Ground
B2059 A/C Request Indicator Short to Ground
B2060 Heated Backlite Indicator Circuit Failure
B2061 Heated Backlite Indicator Circuit Shorted to Ground
B2062 Driver Window Data Output Circuit Failure
B2063 Pass Window Data Output Circuit Failure
B2064 Power Pedals Disable Relay Circuit Failure
B2065 Power Pedals Disable Relay Circuit Short to Ground
B2066 Park Enabled Status Output Circuit Failure
B2067 Park Enabled Status Output Circuit Short to Ground
B2068 Convertible Top Up Output Circuit Failure
B2069 Convertible Top Down Output Circuit Failure
B2070 Trailer Tow Relay Coil(s) Circuit Failure
B2071 Hazard Switch Signal Short to Ground
B2072 Seat Memory Module Data Line Short to Battery
B2073 Seat Memory Module Data Line Open or Short to Ground
B2074 Seat Memory Module Enable Line Short to Battery
B2075 Seat Memory Module Enable Line Open or Short to Ground
B2076 Cellular Antenna Connection Open
B2077 Liftgate Ajar Sw Circuit Failure
B2078 Driver Airbag Deactivation Indicator Lamp Fault
B2079 Driver Airbag Deactivation Indicator Short to Battery
B2080 Driver Airbag Deactivation Indicator Short to Ground
B2081 Driver Airbag Deactivation Indicator Open Circuit
B2082 Mirror Vertical Output Fault
B2083 Mirror Horizontal Output Fault
B2084 Memory Set Indicator Short to Ground
B2085 Rear Window Lockout Indicator Short to Ground
B2086 Rear Window Lockout Indicator Short to Battery
B2087 Security Line Short to Ground
B2088 Cellular Antenna Short to Ground
B2089 Puddle / Approach Lamp Fault 7142
B2090 Remote Key Entry Data Line Failure
B2091 Remote Key Communication Failure
B2092 Remote Key Low Battery
B2093 Heated Windshield Circuit Short to Ground
B2094 Heated Windshield Circuit Short to Battery
B2095 Front Reset Switch Circuit Failure
B2096 Front Set Switch Circuit Failure
B2097 Compass Module Failure
B2098 Audio Network Initialization (ASYSON) Circuit Fault
B2100 Door Driver Key Cylinder Switch Failure
B2101 Head Rest Switch Circuit Failure
B2102 Antenna Circuit Short to Ground
B2103 Antenna Not Connected
B2104 Door Passenger Key Cylinder Switch Failure
B2105 Throttle Position Input Out of Range Low
B2106 Throttle Position Input Out of Range High
B2107 Front Wiper Motor Relay Circuit Short to Vbatt
B2108 Trunk Key Cylinder Switch Failure
B2109 Heated Wind Shield Relay Short to Vbatt (changed from Failure 2/6/97)
B2110 Front Wiper Motor Relay Circuit Open (changed from Failure 2/6/97)
B2111 All Door Lock Input Short to Ground
B2112 Door Driver Set Switch Stuck Failure
B2113 Heated Windshield Input Short to Ground
B2114 Front Washer Input Short to Ground
B2115 Rear Washer Input Short to Ground
B2116 Door Driver Reset Switch Stuck Failure
B2117 Driver Side, Side mount Airbag Low capacitance on Squib
B2118 Passenger Side, Side mount Airbag Low capacitance on Squib
B2119 Compressor Failure
B2120 Door Passenger Set Switch Stuck Failure
B2121 Illumination Switch Short to Battery
B2122 Driver Side Satellite Communication Circuit Short to Ground
B2123 Passenger Side Satellite Communication Circuit Short to Ground
B2124 Door Passenger Reset Switch Stuck Failure
B2125 Open Circuit on Double Lock Reset Line
B2126 Short Circuit to Battery on Double Lock Reset Line
B2127 Short Circuit to Ground on Double Lock Reset Line
B2128 Central Lock Motor Failure
B2129 Central Lock Feedback Failure
B2130 Double Lock Timeout Failure
B2131 Double Lock Feedback Failure
B2132 Dimmer switch Circuit Short to Gnd
B2133 Brake Motor Warning lamp Circuit Failure
B2134 Brake Motor Warning lamp Circuit Short to Vbatt
B2135 Park Brake Applied Warning Lamp Circuit Failure
B2136 Park Brake Applied Warning Lamp Circuit Short To Battery
B2137 Rear Evaporator Temperature Sensor out of Range
B2138 Coolant Overtemp
B2139 Data Mismatch (receive data does not match what was expected)
B2140 Initialization Failure
B2141 NVM Configuration Failure
B2142 NVM TIC Failure
B2143 NVM Memory Failure
B2144 NVM Alarm Data Failure
B2145 NVM RF HR Failure
B2146 Seat Recline Motor Position Out of Range
B2147 Driver Seat Switch Fault A103
B2148 PWM Input Circuit Failure
B2149 Seat Front Vertical Motor Position Out of Range
B2150 Power Supply #1 Circuit Short to Ground
B2151 Power Supply #2 Circuit Short to Ground
B2152 Seat Rear Vertical Motor Position Out of Range
B2153 Rear Echo Sensor Circuit Failure
B2154 Front Echo Sensor Circuit Failure
B2155 Seat Horizontal Motor Position Out of Range
B2156 Rear Doppler Sensor Circuit Failure
B2157 Front Doppler Sensor Circuit Failure
B2158 Seat Recline Motor Memory Position Out of Range
B2159 Memory #1 output Short to Ground
B2160 Memory #1 output Short to VBatt
B2161 Seat Front Vertical Motor Memory Position Out of Range
B2162 Data Mismatch #2 (receive data does not match what was expected)
B2163 Clutch Position Fault
B2164 Seat Rear Vertical Motor Memory Position Out of Range
B2165 Gear shift position Fault
B2166 Gear select position Fault
B2167 Seat Horizontal Motor Memory Position Out of Range
B2168 Unable to confirm Unlock Condition
B2169 Unable to confirm lock Condition
B2170 Steering Column Lock Switch Circuit Failure
B2171 LH Rear Seat Switch Fault A104
B2172 Inertia Switch input Circuit Open
B2173 RH Rear Seat Switch Fault A105
B2174 Window Driver Rear Remote Up Switch Short to Battery
B2175 A/C Request Signal Circuit Short to Ground
B2176 Overdrive switch circuit short to Vbatt
B2177 Interior Scanning Sensor Circuit Failure
B2178 Window Driver Rear Remote Down Switch Short to Battery
B2179 "Front Wiper Select Switch ""A"" Short to Ground"
B2180 "Front Wiper Select Switch ""B"" Short to Ground"
B2181 "Front Wiper Select Switch ""C"" Short to Ground"
B2182 Window Passenger Front Remote Up Switch Short to Battery
B2183 "Front Wiper Select Switch ""H"" Short to Ground"
B2184 "Front Wiper Select Switch ""W"" Short to Ground"
B2185 "Rear Wiper Select Switch ""D"" Short to Ground"
B2186 Window Passenger Front Remote Down Switch Short to Battery
B2187 "Rear Wiper Select Switch ""B"" Short to Ground"
B2188 "Rear Wiper Select Switch ""E"" Short to Ground"
B2189 Double Lock Open Circuit, Front Drv. and Rear Psg. Doors
B2190 Window Passenger Rear Remote Up Switch Short to Battery
B2191 Double Lock Short to Ground, Front Drv. and Rear Psg. Doors
B2192 Double Lock Short to Batt, Front Drv. and Rear Psg. Doors
B2193 Double Lock Open Circuit, Front Psg. and Rear Drv. Doors
B2194 Window Passenger Rear Remote Down Switch Short to Battery
B2195 Driver Window Up / Down Power Circuit Short to Ground
B2196 Passenger Window Up / Down Power Circuit Short to Ground
B2197 TV Module Error
B2198 TrafficMaster Module Error
B2199 VICS Module Error
B2200 No Communication to TV Module (No Fitting of TV)
B2201 No Communication With Traffic MasterModule
B2202 No Communication to VICS Module (No Fitting of VICS)
B2203 CD-ROM Error
B2204 GPS Antenna Connection Open or Short
B2205 GPS Receiver Error
B2206 Gyroscope Error
B2207 ECU ROM Checksum Error
B2208 Navigation to Head Unit Communication Error
B2209 Interior Lamp Override Switch Open Circuit
B2210 Interior Lamp Override Switch Short to Ground
B2211 Low Coolant Lamp Output Circuit Short to Battery
B2212 Panel Dim Switch Out of Range
B2213 Double Lock Short to Ground, Front Psg. and Rear Drv. Doors
B2214 Window Passenger Front Up Switch Short to Battery
B2215 Window Passenger Front Down Switch Short to Battery
B2216 Double Lock Set 2 Short to Batt, Front Psg. and Rear Drv. Doors
B2217 Central Lock Open Circuit Failure
B2218 Central Lock Short to Ground
B2219 Window Driver Front Current Feedback Exceeded
B2220 Window Driver Rear Current Feedback Exceeded
B2221 Window Passenger Front Current Feedback Exceeded
B2222 Window Passenger Rear Current Feedback Exceeded
B2223 Mirror Driver Drive Circuit Failure
B2224 Mirror Passenger Drive Circuit Failure
B2225 Front Crash Sensor Mount Fault
B2226 Front Crash Sensor Internal Fault
B2227 Front Crash Sensor Driver Communications Fault
B2228 Air Bag Driver Circuit Short to Ground - Loop #2
B2229 Air Bag Passenger Circuit Short to Ground - Loop #2
B2230 Air Bag Driver Circuit Short to Battery - Loop #2
B2231 Air Bag Passenger Circuit Short to Battery - Loop #2
B2232 Air Bag Driver Circuit Open - Loop #2
B2233 Air Bag passenger Circuit Open - Loop #2
B2234 Air Bag Driver Inflator Circuit Resistance Low on Squib - Loop #2
B2235 Air Bag Passenger Inflator Circuit
B2236 Weak or Defected Electric Vehicle Battery Module Fault
B2237 Vehicle Signal indicating Park While VSS Present
B2238 Power Cable For Power Sliding Door Broken
B2239 Rear Cargo Door Set Switch Stuck (Short to Ground)
B2240 Rear Cargo Door Reset Switch Stuck (Short to Ground)
B2241 Rear Cargo Door Lock Circuit Short to Ground
B2242 Rear Cargo Door Unlock Circuit Open
B2243 Driver Rear Door Ajar Circuit Open
B2244 Driver Sliding Door Ajar Circuit Short to GND
B2245 Passenger Rear Door Ajar Circuit Open
B2246 Passenger Sliding Door Ajar Circuit Short to GND
B2247 EV Battery Pack Temperature Fault
B2248 Heated Windshield Relay Coil Circuit Failure
B2249 Head Lamp Relay Coil Short to Battery
B2250 All Doors Unlock Relay Circuit Failure
B2251 Parklamp Output Relay Driver Circuit Failure
B2252 Parklamp Output Relay Driver Short to Battery
B2253 Central Lock Short to Battery
B2254 Front Fog Lamp Switch Failure
B2255 Front Washer Request Timeout
B2256 Front Window Heater Relay Short to Ground
B2257 Front Window Heater Switch Short to Ground
B2258 Headlamp Washer Relay Circuit Short to Battery
B2259 Intermittent Wiper Circuit Short to Battery
B2260 Door Motor Circuit Short to Battery
B2261 Park Lamp Switch Failure
B2262 Wiper Park to Park Timeout
B2263 Radio Input Circuit Short to Ground
B2264 Rear Fog Lamp Switch Short to Ground
B2265 Unlock Line Circuit Short to Ground
B2266 Left Side Blend Door Circuit Failure
B2267 Right Side Blend Door Circuit Failure
B2268 Steering Wheel Climate Control Circuit Open
B2269 Steering Wheel Climate Control Circuit Short to Ground
B2270 Excessive Door Effort Detected
B2271 Obstacle Detected During Opening
B2272 Microphone Bias Circuit Failure
B2273 Run-Dry Output Feedback Circuit Fault
B2274 Phone Transceiver Active Circuit Failure
B2275 Pedal Forward/Rearward Pot. Feedback Ckt. Short to GND
B2276 Less than 2 transmitters programmed
B2277 Electronic Power Steering Motor Malfunction
B2278 Steering Shaft Torque Sensor Malfunction
B2279 Engine RUN signal short to battery
B2280 Crash unlock signal not present
B2281 Right turn switch short to ground
B2282 Left turn switch short to ground
B2283 Turn signal chime short to battery
B2284 Turn Signal Chime Short to Ground
B2285 SIM Card Failure
B2286 Trip Computer Mode Switch Short to Ground
B2287 Inclination Sensor Circuit Failure
B2288 Voice Module Error
B2289 Voice Module Communication Error
B2290 Occupant Classification System Fault 5959 5952
B2291 Occupant Position System Fault 5960 5953
B2292 Restraint System - Seatbelt Pretensioner Fault 5961 5954
B2293 Restraint System - Airbag Fault 5962 5955
B2294 Restraint System - Curtain Fault 5963 5956
B2295 Restraint System - Side Airbag Fault 5964 5957
B2296 Restraint System - Impact Sensor Fault 5965, 5976 5958, 5975
B2297 Air discharge temperature sensor (panel) circuit open
B2298 Air discharge temperature sensor (panel) short to ground
B2299 Air discharge temperature sensor (floor) circuit open
B2300 Seat Driver Memory Position Error
B2301 Seat Passenger Memory Position Error
B2302 Seat Headrest Feedback Potentiometer Circuit Failure
B2303 Seat Headrest Feedback Potentiometer Circuit Open
B2304 Seat Headrest Feedback Potentiometer Circuit Short to Battery
B2305 Seat Headrest Feedback Potentiometer Circuit Short to Ground
B2306 Seat Headrest Motor Stalled
B2307 Air discharge temperature sensor (floor) short to ground
B2308 Interior Air Temperature Inlet Motor Failure
B2309 Seat Motor Out Of Range A106
B2310 Mirror Driver Memory Position Error
B2311 Mirror Passenger Memory Position Error
B2312 Mirror Passenger Horizontal Feedback Potentiometer Circuit Failure
B2313 Mirror Passenger Horizontal Feedback Potentiometer Circuit Open
B2314 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Battery
B2315 Mirror Passenger Horizontal Feedback Potentiometer Circuit Short to Ground
B2316 Mirror Passenger Vertical Feedback Potentiometer Circuit Failure
B2317 Mirror Passenger Vertical Feedback Potentiometer Circuit Open
B2318 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Battery
B2319 Mirror Passenger Vertical Feedback Potentiometer Circuit Short to Ground
B2320 Mirror Driver Horizontal Feedback Potentiometer Circuit Failure
B2321 Mirror Driver Horizontal Feedback Potentiometer Circuit Open
B2322 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Battery
B2323 Mirror Driver Horizontal Feedback Potentiometer Circuit Short to Ground
B2324 Mirror Driver Vertical Feedback Potentiometer Circuit Failure
B2325 Mirror Driver Vertical Feedback Potentiometer Circuit Open
B2326 Mirror Driver Vertical Feedback Potentiometer Circuit Short to Battery
B2327 Mirror Driver Vertical Feedback Potentiometer Circuit Short to Ground
B2328 Column Reach Feedback Potentiometer Circuit Failure
B2329 Column Reach Feedback Potentiometer Circuit Open
B2330 Column Reach Feedback Potentiometer Circuit Short to Battery
B2331 Column Reach Feedback Potentiometer Circuit Short to Ground
B2332 Column Tilt Feedback Potentiometer Circuit Failure
B2333 Column Tilt Feedback Potentiometer Circuit Open
B2334 Column Tilt Feedback Potentiometer Circuit Short to Battery
B2335 Column Tilt Feedback Potentiometer Circuit Short to Ground
B2336 Mirror Switch Assembly Circuit Failure
B2337 Mirror Switch Assembly Circuit Open
B2338 Mirror Switch Assembly Circuit Short to Battery
B2339 Mirror Switch Assembly Circuit Short to Ground
B2340 Column Reach Motor Stalled
B2341 Column Tilt Motor Stalled
B2342 Seat Switch Reference Voltage Positive Common Open Circuit
B2343 Seat Switch Reference Voltage Positive Common Supply Low Voltage
B2344 Seat Switch Reference Voltage Positive Common Supply Voltage Fault
B2345 Seat Switch Reference Voltage Negative Common Open Circuit
B2346 Mirror Switch Reference Voltage Positive Common Open Circuit
B2347 Mirror Switch Reference Voltage Positive Common Supply Low Voltage
B2348 Mirror Switch Reference Voltage Positive Common Supply Voltage Fault
B2349 Mirror Switch Reference Voltage Negative Common Open Circuit
B2350 Steering Column Switch Circuit Short to Battery
B2351 Steering Column Switch Circuit Failure
B2352 Driver Memory Power Switch Indicator Circuit Short to Battery
B2353 Driver Mirror Power Driver Circuit Short Ground
B2354 Driver Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open
B2355 Passenger Mirror Horizontal / Vertical Feedback Potentiometer Circuit Open
B2356 Driver Seat Heater Output Fault
B2357 Driver Window Down Current Sense Low Circuit Failure
B2358 Adjustable Pedal Switch Failure
B2359 Accessory Delay output circuit failure
B2360 Window Motor Control Output Circuit Failure
B2361 Passenger Seat Heater Output Fault
B2362 Remote Open/Close signal Circuit Short to Ground
B2363 Optical Sensor System Failure
B2364 Fuel Filler Door Circuit Open
B2365 B-pillar Power Sliding Door Open/Close Switch Input Ckt. Short to Gnd.
B2366 IP Power Sliding Door Open/Close switch Ckt. Short to Gnd.
B2367 Power Sliding Door Override Switch Input Ckt. Short to Gnd.
B2368 Steering Column Switch Circuit Out of Range
B2369 Chime OUTPUT Request Ckt. Short to Ground
B236A Chime Output Circuit Open
B2370 Seat Heater Power Shutdown
B2371 Invalid Driver Seat Temperature Set Point
B2372 Invalid Passenger Seat Temperature Set Point
B2373 LED #1 Circuit Short to Battery
B2374 Power Sliding Detent (Latch) Circuit Failure
B2375 SCLM Invalid Unlock Action
B2376 SCLM Lock status not confirmed.
B2377 SCLM Unlock status not confirmed.
B2378 SCLM Invalid Lock Action
B2379 SCL Not Configured - ID Not Stored
B2380 Heater Coolant Temp. sensor circuit Short to GND
B2381 Heater Coolant Temp. sensor circuit Open
B2382 Backup Light Relay Circuit- Open
B2383 Backup Light Relay Cirucit- Low
B2384 Audio Reverse Aid Mute Input Ckt. Failure
B2385 Audio Navigation Mute Input Ckt. Failure
B2386 Gas discharge lamp ingition failed
B2387 Gas Discharge Lamp Ignitor Module Circuit Failure
B2388 Gas Discharge Lamp Operating Voltage Out of Range during static operation
B2389 Ignition counter or timeout expired
B2390 Master / Slave Communication Failure
B2391 Resistance at Low Beam headlight switch input too high
B2392 Voltage at low beam headlight switch input too high
B2393 ECU output to ignitor circuit failure
B2394 Headrest Up Switch Timeout
B2395 Headrest Down Switch Timeout
B2396 Headrest Ident-Input Circuit Failure
B2397 Headrest Potentiometer Reference Circuit Failure
B2398 Headrest Potentiometer Reference Circuit Short to Ground
B2399 Headrest Potentiometer Ground Circuit Failure
B2400 Headrest Potentiometer Ground Circuit Short to Battery
B2401 Audio Tape Deck Mechanism Fault
B2402 Audio CD/DJ Thermal Shutdown Fault
B2403 Audio CD/DJ Internal Fault
B2404 Audio Steering Wheel Switch Circuit Fault
B2405 Audio Disc CD Player Thermal Shutdown Fault
B2406 Audio Disc CD Player Internal Fault
B2407 Backup Light Relay Circuit - High
B2408 Speaker line short circuit
B2409 AM receiving signal error
B2410 FM receiving signal error
B2411 Humidity Sensor Open
B2412 Humidity Sensor Short
B2413 Humidity Sensor Failure
B2414 Headlamp Washer Relay Circuit Short Circuit GND
B2415 Pinch Strip Open or Short to Battery
B2416 Climate Control Recirculation Actuator Out of Limits
B2417 Pinch Strip Stuck Active
B2418 Sensor Power Short to Ground
B2419 Sensor 1 Invalid
B2420 Sensor 2 Invalid
B2421 VSS Stuck High
B2422 OPENSW Input Stuck Active
B2423 CLOSESW Input Stuck Active
B2424 "Latch ""Engaged"" Mismatch"
B2425 Remote Keyless Entry Out of Synchronization
B2426 Passenger Solar Radiation Sensor Circuit Open
B2427 Passenger Solar Radiation Sensor Circuit Short to Ground
B2428 A/C Post Heater Sensor #2 Circuit Failure
B2429 A/C Post Heater Sensor #2 Circuit Short to Ground
B2430 "Latch ""Up"" Mismatch"
B2431 Transponder Programming Failed
B2432 Drivers Seat Belt Buckle Switch Circuit Open
B2433 Drivers Seat Belt Buckle Switch Circuit Short to Battery
B2434 Drivers Seat Belt Buckle Switch Circuit Short to Ground
B2435 Drivers Seat Belt Buckle Switch Resistance out of Range
B2436 Passengers Seat Belt Buckle Switch Circuit Open
B2437 Passengers Seat Belt Buckle Switch Circuit Short to Battery
B2438 Passengers Seat Belt Buckle Switch Circuit Short to Ground
B2439 Passengers Seat Belt Buckle Switch Resistance out of Range
B2440 Passenger side impact sensor mounting fault
B2441 Driver side impact sensor mounting fault
B2442 Intrusion Sensor Fault
B2443 Powertrain Performance Mode Switch Circuit failure
B2444 Driver side impact sensor is faulted
B2445 Passenger side impact sensor is faulted
B2446 RESCU/VEMS Input Circuit Open
B2447 RESCU/VEMS Input Circuit Short to Battery
B2448 RESCU/VEMS Input Circuit Short to Ground
B2449 Aux. Heater Glow Plug Circuit Short to Ground
B2450 Aux. Heater Glow Plug Circuit Open
B2451 Aux. Heater Fuel Pump Circuit Short to Ground
B2452 Aux. Heater Fuel Pump Circuit Open
B2453 Aux. Heater Blower Fan Circuit Short to Ground
B2454 Aux. Heater Blower Fan Circuit Open
B2455 Aux. Heater Blower Faulted
B2456 Aux. Heater Coolant Sensor Circuit Short to Ground
B2457 Aux. Heater Coolant Sensor Circuit Open
B2458 Aux. Heater Overheat Sensor Circuit Short to Ground
B2459 Aux. Heater Overheat Sensor Circuit Open
B2460 Aux. Heater Flame Sensor Circuit Short to Ground
B2461 Aux. Heater Flame Sensor Circuit Open
B2462 Aux. Heater Flame Out Fault
B2463 Aux. Heater Overheat Fault
B2464 Aux. Heater Start Time Exceeded
B2465 Aux. Heater Start Counter Overrun/System Locked (same as below ?)
B2466 Aux. Heater Overheat Counter Overrun/System Locked
B2467 Aux. Heater Cool Down Time Exceeded (may be con. to a453-5 )
B2468 Aux. Heater Coolant Pump Circuit Short to Ground
B2469 Aux. Heater Coolant Pump Circuit Open
B2470 Interior Fan Control Circuit Short to Ground
B2471 Interior Fan Control Circuit Open
B2472 Fog Lamp Switch Failure
B2473 Passenger Door Disarm Switch ckt Short to Gnd
B2474 PASSENGER DOOR LOCK SWITCH CKT. SHORT TO GROUND
B2475 PASSENGER DOOR UNLOCK SWITCH CKT. SHORT TO GROUND
B2476 RADIO PRESENT SWITCH Ckt Failure
B2477 Module Configuration Failure
B2478 ANTI THEFT INPUT SIGNAL SHORT TO GROUND
B2479 BRAKE PARK SWITCH CIRCUIT SHORT TO GROUND
B2480 LF CORNER LAMP OUTPUT Ckt Short to Battery
B2481 Convertible Top Up/Down switch Fault
B2482 RF Corner Lamp Output Ckt Short to Battery
B2483 Enable Signal Open Circuit
B2484 Disable Signal Short to Ground
B2485 LF Side Repeater Lamp Output Ckt Short to Battery
B2486 Climate Control Seat Module Voltage Out of Range
B2487 RF Side Repeater Lamp Output Ckt Short to Battery
B2488 Thumb-wheel Switch Voltage Out of Range High
B2489 UNDERHOOD LAMP OUTPUT CIRCUIT Failure
B2490 UNDERHOOD LAMP OUTPUT CIRCUIT Short to Battery
B2491 RF PARK LAMP OUTPUT CIRCUIT Short to Battery
B2492 Already Programmed (Test Mode DTC Only !!!)
B2493 LF PARK LAMP OUTPUT CIRCUIT Short to Battery
B2494 ANTI THEFT HORN OUTPUT CIRCUIT Short to Batt
B2495 ANTI THEFT HORN OUTPUT CIRCUIT Failure
B2496 ANTI THEFT HORN OUTPUT CIRCUIT Short to Gnd
B2497 Blower RPM out of range
B2498 Headlamp Switch Multiple Signals Input Active
B2499 Courtesy Lamp Output Failure
B2500 Courtesy Lamp Output Ckt Short to Battery
B2501 LF LAMP LOW BEAM CIRCUIT Failure
B2502 LF LAMP LOW BEAM CIRCUIT Short to Battery
B2503 RF LAMP LOW BEAM CIRCUIT Failure
B2504 RF LAMP LOW BEAM CIRCUIT Short to Battery
B2505 LF LAMP HIGH BEAM CIRCUIT Failure
B2506 LF LAMP HIGH BEAM CIRCUIT Short to Battery
B2507 RF LAMP HIGH BEAM CIRCUIT Failure
B2508 RF LAMP HIGH BEAM CIRCUIT Short to Battery
B2509 Rear Fog Lamp Switch Circuit Failure
B2510 Main Blower Motor Relay Circuit Short to Battery
B2511 Horn Output Relay Circuit Short to Battery
B2512 Front Fog Lamp Relay Ckt Short to Battery
B2513 Blower (Fan) Circuit Failure
B2514 Blower (Fan) Circuit Short to Vbatt
B2515 Heater Blower Relay Circuit Failure
B2516 Blower Control Circuit Failure
B2517 Emergency Power Off System Faulted
B2518 Compressor Overtemp Fault
B2519 High Mount Stop Lamp Circuit Failure
B251A Passenger Tach Circuit Failure
B2520 High Mount Stop Lamp Circuit Short to Battery
B2521 Tach Circuit Failure
B2522 VBatt 1 Circuit Failure
B2523 License Lamp Circuit Failure
B2524 License Lamp Circuit Short to Battery
B2525 Left Rear Backup Lamp Circuit Failure
B2526 Left Rear Backup Lamp Circuit Short to Battery
B2527 Left Rear Stop lamp Circuit Failure
B2528 Left Rear Stop lamp Circuit Short to Battery
B2529 Left Rear Turn Lamp Circuit Failure
B2530 Left Rear Turn Lamp Circuit Short to Battery
B2531 Right Rear Backup Lamp Circuit Failure
B2532 Right Rear Backup Lamp Circuit Short to Battery
B2533 Right Rear Stop lamp Circuit Failure
B2534 Right Rear Stop lamp Circuit Short to Battery
B2535 Right Rear Turn Lamp Circuit Failure
B2536 Right Rear Turn Lamp Circuit Short to Battery
B2537 Aux. Heater no start fault
B2538 Aux. Heater unstable flame fault
B2539 Aux A/C Mode Position Reference Circuit Short to Ground
B2540 Aux A/C Mode Position Reference Circuit Short to Battery
B2541 "Latch ""Down"" Mismatch"
B2542 LCLUTCH Open Circuit
B2543 Aux A/C Control Switch Reference Circuit Short to Ground
B2544 Aux A/C Control Switch Reference Circuit Short to Battery
B2545 System Power Relay Circuit Short to Battery
B2546 System Power Relay Circuit Failure
B2547 Aux. Heater flame prior to operation fault
B2548 Aux. Heater lock out mode fault
B2549 Vehicle air fan actuation circuit short to ground
B2550 Dome Lamp Output Circuit Short to Ground
B2551 RCLUTCH Open Circuit
B2552 Vbatt 2 Circuit Open
B2553 Disable Signal Output Circuit Short to Battery
B2554 Dome Lamp Output Circuit Failure
B2555 Dome Lamp Output Circuit Short to Battery
B2556 Enable Signal Circuit Short to Battery
B2557 Left Power Sliding Door Open/Close Output Circuit Short to Battery
B2558 Right Power Sliding Door Open/Close Output Circuit Short to Battery
B2559 Aux A/C Blower Motor Relay Circuit Short to Battery
B2560 Aux A/C Blower Motor Relay Circuit Short to Ground
B2561 Aux A/C Blower Speed 1 Circuit Failure
B2562 Aux A/C Blower Speed 1 Circuit Short to Ground
B2563 Aux A/C Blower Speed 2 Circuit Failure
B2564 Aux A/C Blower Speed 2 Circuit Short to Ground
B2565 Right Tail Lamp Circuit Failure
B2566 Right Tail Lamp Circuit Short to Ground
B2567 Reverse Mirror Output Circuit Failure
B2568 Reverse Mirror Output Circuit Short to Ground
B2569 Liftgate Disarm Switch Circuit Short to Ground
B2570 Right Lamp Outage Signal Circuit Short to Ground
B2571 Left Lamp Outage Signal Circuit Short to Ground
B2572 Brake Shift Interlock Output Circuit Failure
B2573 Brake Shift Interlock Output Circuit Short to Ground
B2574 Drivers Door LOCK Switch Short to Ground
B2575 Drivers Door UNLOCK Switch Short to Ground
B2576 Hardtop Sense Input Short to Ground
B2577 Left Tail Lamp Circuit Failure
B2578 Passenger power window down switch circuit failure
B2579 Passenger power window up switch circuit failure
B2580 Aux Blower Sense Switch Circuit Failure
B2581 Passenger Seat Occupant Detection Circuit Short To Ground
B2582 Passenger Seat Occupant Detection Circuit Open
B2583 Child Seat Detection Circuit Short to Ground
B2584 Child Seat Detection Circuit Open
B2585 Anti Theft Input Signal Circuit Short To Battery
B2586 Headlamp Mode Select Circuit Failure
B2587 Passenger Seat Occupant Detection Circuit Short To Battery
B2588 Child Seat Detection Circuit Short To Battery
B2589 Unexpected Door Reversal During Close
B2590 Vehicle Park/Speed Signal Circuit Failure
B2591 Detent Signal Missing During Unlatch
B2592 PSD Not Fully Closed (Module Commanded Successfully)
B2593 Power Sliding Door Opened During Module Close Command
B2594 No Movement Detected After an Unlatch During Power Open
B2595 Anti Theft Input Signal Circuit Failure
B2596 Headlamp Aim Output Relay Circuit Short To Battery
B2597 Headlamp Aim Output Relay Circuit Failure
B2598 Headlamp Relay Circuit Failure
B2599 Tailgate Release Open Circuit
B2600 Double Locking Door Motor Frozen
B2601 No Latch Signal Sensed on Closing and Door Reversed
B2602 Missing Latch Signal During Power Sliding Door Unlatch
B2603 PSD Not Fully Closed During Self-Test
B2604 Power Sliding Door On/Off Switch Open Circuit
B2605 Disable Signal Open Circuit
B2606 A/C Temperature Sensor Out of Range
B2607 Harness/configuration Mismatch
B2608 ECU output to left headlamp stepper motor short to ground
B2609 ECU output to left headlamp stepper motor circuit failure
B2610 ECU output driver to left headlamp stepper motor overtemperature
B2611 ECU output to right headlamp stepper motor short to ground
B2612 ECU output to right headlamp stepper motor circuit failure
B2613 ECU output driver to right headlamp stepper motor overtemperature
B2614 Front or rear axle vehicle level sensor supply short to ground.
B2615 Front or rear axle vehicle level sensor supply circuit failure
B2616 Front axle vehicle level sensor signal circuit failure
B2617 Front axle vehicle level sensor signal short to ground.
B2618 Front axle vehicle level sensor signal not plausible.
B2619 Rear axle vehicle level sensor signal circuit failure
B2620 Rear axle vehicle level sensor signal short to ground.
B2621 Rear axle vehicle level sensor signal not plausible.
B2622 Auto levelling ECU speed message invalid / not available
B2623 Auto levelling ECU low beam message invalid / not available
B2624 Auto levelling ECU speed signal not available
B2625 Auto levelling ECU low beam signal input open circuit.
B2626 Autolevelling ECU not calibrated
B2627 Fuel Sender Circuit Open #2
B2628 Fuel Sender Circuit Short to Ground #2
B2629 Offboard Charging Continued After Stop Command Issued
B2630 Over Current Fault During Offboard Charging
B2631 Under Current Fault During Offboard Charging
B2632 Over Voltage Fault During Offboard Charging
B2633 Driver-Front Microphone Circuit Failure
B2634 Left-Rear Microphone Circuit Failure
B2635 Right-Rear Microphone Circuit Failure
B2636 Emergency (SOS) Switch input Short to Ground
B2637 Information Switch input Short to Ground
B2638 Phone Rechargeable Battery Fault
B2639 Deployment Indication input Open
B2640 Deployment Indication input Short to Ground
B2641 Deployment Indication input Short to Battery
B2642 Low Power Detected
B2643 High Power Detected
B2644 Phone mute signal open circuit
B2645 Under Temperature Fault
B2646 Antenna Circuit Open Circuit #1
B2647 Antenna Circuit Open Circuit #2
B2648 Antenna Circuit Open Circuit #3
B2649 Antenna Circuit Open Circuit #4
B2650 Antenna Circuit Short Circuit #1
B2651 Antenna Circuit Short Circuit #2
B2652 Antenna Circuit Short Circuit #3
B2653 Antenna Circuit Short Circuit #4
B2654 Hard/Soft key fault
B2655 Switch and Display ECU is defective
B2656 DVD (Digital Versatile Disk) Error
B2657 Electric Vehicle Degraded Battery Capacity Fault
B2658 Wait to Start Warning Indicator Circuit Open
B2659 Courtesy Switch Fault
B2660 Cycling Fault During Offboard Charging
B2661 Parklamp Relay Output Short to Vbatt
B2662 Parklamp Relay Output Open Circuit
B2663 Headlamp Relay Output Short to Vbatt
B2664 Headlamp Relay Output Open Circuit
B2665 Battery Back Sounder Circuit Failure
B2666 Liftgate Release Switch Circuit Failure
B2667 Liftglass Release Switch Circuit Failure
B2668 Liftgate Release Relay Coil Short to Vbatt
B2669 Liftgate Release Relay Coil Failure
B2670 Liftglass Release Relay Coil Short to Vbatt
B2671 Liftglass Release Relay Coil Circuit Failure
B2672 Discharge air temperature sensor circuit open
B2673 Discharge air temperature sensor circuit short to ground
B2674 Double Lock Output Short to Vbatt
B2675 Trip reset button stuck
B2676 LPG Sender Failure
B2677 Low Oil Pressure Warning Activated
B2678 Low Coolant Sender Failure
B2679 Airbag Warning Activated
B2680 Odometer Changed
B2681 PRNDL Sender Failure
B2682 EEC (PCM) Communication Fault
B2683 "Overspeed ""-"" button stuck"
B2684 "Overspeed ""+"" button stuck"
B2685 "Overspeed ""Seek"" button stuck"
B2686 Right Tail Lamp Circuit Short to Battery
B2687 Left Tail Lamp Circuit Short to Battery
B2688 Aux A/C Blower Motor Relay Circuit Failure
B2689 Aux A/C Blower Speed 1 Circuit Short to Vbatt
B2690 Aux A/C Blower Speed 2 Circuit Short to Vbatt
B2691 Seat Belt Buckle Switch Circuit Fault, Front Driver's side
B2692 Front Passenger's Seat Belt Buckle Switch Circuit Fault
B2693 Intrusion Power Short to Vbatt
B2694 Intrusion Power Output Failure
B2695 Keypad_A Switch Circuit Failure
B2696 Keypad_B Switch Circuit Failure
B2697 Keypad_C Switch Circuit Failure
B2698 Vbatt 2 Circuit Failure
B2699 Left Pinch Strip Open or Short to Battery
B2700 Right Pinch Strip Open or Short to Battery
B2701 Left Pinch Strip Stuck Active
B2702 Right Pinch Strip Stuck Active
B2703 Open/Close Switch Stuck Active
B2704 Optical Sensor Power Short to Ground
B2705 Optical Sensor 1 Input Not Active During Powered Gate Movement
B2706 Optical Sensor 2 Input Not Active During Powered Gate Movement
B2707 Deck Lid/Gate Open Output Over Current
B2708 Decklid/Gate Close Output Over Current
B2709 Gate Open Short to Battery
B2710 Gate Close Short to Battery
B2711 Gate Open Output Short to Ground or Open
B2712 Gate Close Output Short to Ground or Open
B2713 Unlatch Output Short to Ground
B2714 Uncinch Output Short to Ground
B2715 Cinch Output Short to Ground
B2716 Left Power Running Board Output Short to Battery
B2717 Right Power Running Board Output Short to Battery
B2718 Liftgate/Decklid Ajar Output Short to Battery
B2719 Left Power Running Board Output Short to Ground or Open
B2720 Right Power Running Board Output Short to Ground or Open
B2721 Liftgate/Decklid Ajar Output Short to Ground or Open
B2722 Open/Close Switch Active During Selftest
B2723 Glass Position Switch Active During Selftest
B2724 Forkbolt Switch Invalid During Selftest
B2725 Detent Switch Invalid During Selftest
B2726 Home Switch Invalid During Selftest
B2727 Headrest Tilt Switch Timeout
B2728 Cushion Temp 20 Deg.C less than Back Temp
B2729 Cushion Over-Temp Detected
B272A Passenger Cushion Over-Temp Detected
B272B Passenger Back-Over Temp Detected
B272C Driver Differential Temperature Fault
B272D Passenger Differential Temperature Fault
B272E Driver Ignition Run/Blowe Circuit Short to Ground
B272F Passenger Ignition Run/Blowe Circuit Short to Ground
B2730 Back-Over Temp Detected
B2731 Cushion Temp 20 Deg. C higher than Back Temp
B2732 Pedal Travel Sensor Short to Ground
B2733 Pedal Travel Sensor Short to Ignition
B2734 Pedal Travel Sensor Supply Error
B2735 ECU output to headlamp stepper motor circuit failure
B2736 Pedal Travel Sensor Circuit Fault
B2737 Pedal Travel Sensor Jammed Error
B2738 Pedal Travel Sensor Velocity Error
B2739 Pedal Travel Senosr Signal Fault
B2740 Pedal Travel Sensor Spike Error
B2741 Sensor Cluster Defective
B2742 Sensor Cluster Overvoltage
B2743 Sensor Cluster Undervoltage
B2744 Left cover open output circuit over current
B2745 Left cover open output over current
B2746 Left cover close output over current
B2747 Left cincher motor short to battery
B2748 Left drive motor open circuit
B2749 Right cover open output over current
B2750 Right cover close output over current
B2751 Right cincher motor short to battery
B2752 Right drive motor open circuit
B2753 Left Cinch output over current
B2754 Left uncinch output over current
B2755 Left drive short to battery
B2756 Left cincher motor open
B2757 Left drive output short to ground
B2758 Right cinch output over current
B2759 Right uncinch output over current
B2760 Right drive short to battery
B2761 Right cincher motor open
B2762 Right drive output short to ground
B2763 Sensor Calibration Short to Ground
B2764 Sesnor Calibration Supply Error
B2765 Sensor Calibration Short to Ignition
B2766 Sensor Calibration Circuit Fault
B2767 Sensor Calibration Jammed Error
B2768 Sensor Calibration Velocity Error
B2769 Sensor Calibration Spike Error
B2770 Sensor Calibration Signal Fault
B2771 Left Front Door Ajar CKT. Short to Ground
B2772 Right Front Door Ajar Ckt Short to Ground
B2773 Drivers side air bag curtain resistance too low
B2774 Drivers side air bag curtain open circuit
B2775 Drivers side air bag curtain short to ground
B2776 Drivers side air bag curtain short to battery
B2777 Passenger's side air bag curtain resistance to low
B2778 Passenger's side air bag curtain open circuit
B2779 Passenger's side air bag curtain short to ground
B2780 Passenger's side air bag curtain short to battery
B2781 Interior Air Quality Sensor to DATC Open Circuit
B2782 Interior Air Quality Sensor to DATC Short Circuit
B2783 Interior Humidity Sensor to DATC Short Circuit
B2784 Interior Humidity Sensor to DATC Open Circuit
B2785 TIM Digital Outputs Circuit Failure
B2786 Latch switches mismatch
B2787 Right Latch Switch Invalid
B2788 Left Latch Switch Invalid
B2789 Left or right latch release circuit failure
B2790 LCLUTCH or RCLUTCH circuit failure
B2791 Airbag cutoff switch (ACS) out of range
B2792 Cross Link Between Firing Loops
B2793 Cool switch short to ground
B2794 3rd Row Power Fold Circuit Failure
B2795 Driver Solar Radiation Sensor Circuit Short to Ground
B2796 Driver Solar Radiation Sensor Circuit Open
B2797 Driver Water Valve Circuit Open
B2798 Driver Water Valve Circuit Short
B2799 Passenger Water Valve Circuit Open
B2800 Passenger Water Valve Circuit Short
B2801 Head Lamp open circuit
B2802 Head lamp short to battery
B2803 Head lamp short to ground
B2804 Reservoir solenoid signal short to battery
B2805 Reservoir solenoid sensor supply short to battery
B2806 Reservoir solenoid sensor supply short to ground
B2807 Pressure Sensor signal short to battery
B2808 Pressure Sensor supply short to battery
B2809 Pressure Sensor supply short to ground
B2810 Air Suspension Vent Solenoid Circuit Failure
B2811 ECU is in assembly state
B2812 LH Power Running Board Connection Fail
B2813 LH Power Running Board Stow Time Fail
B2814 LH Power Running Board Deploy Time Fail
B2815 RH Power Running Board Connection Fail
B2816 RH Power Running Board Stow Time Fail
B2817 RH Power Running Board Deploy Time Fail
B2818 A/C Request Signal Circuit Short to Battery
B2819 Gate Motor Circuit Short to Battery
B2820 Gate Motor Circuit Short to Ground or Open
B2821 Cincher Motor / Unlatch Actuator Short to Ground or Open
B2822 Cincher Motor / Unlatch Actuator Short to Battery
B2823 Left Tailgate Door Ajar Circuit Short to Ground
B2824 Right Tailgate Door Ajar Circuit Short to Ground
B2825 Movement ceased due to excessive speed deviation
B2826 Front Evaporator Temp Sensor Circuit Failure
B2827 Front Evaporator Temp Sensor Short to Ground
B2828 Rear Evaporator Temp Sensor Circuit Failure
B2829 Rear Evaporator Temp Sensor Short to Ground
B2830 Raw Attitude signal not plausable
B2831 Raw Attitude circuit failure
B2832 Fault DTC (CM): Mode Servo Failure 995E
B2833 Fault DTC (CM): Sensor Supply Fault 995F
B2834 Fault DTC (CM): Air Mix Servo Failure 3967
B2835 Fault DTC (CM): Outlet Air Temperature Thermistor Circuit Failure 3968
B2836 Front thermistor circuit failure
B2837 Front thermistor short to ground
B2838 Rear thermistor circuit failure
B2839 Rear thermistor short to ground
B2840 Ambient air thermistor circuit failure
B2841 Ambient air thermistor short to ground
B2842 Fatult DTC (CM): Cool air bypass failure 991F
B2843 Fault DTC (CM): Air intake failure 992F
B2844 Ignition fault
B2845 Smog sensor circuit failure
B2846 Solar sensor circuit failure 996C
B2847 Intrusion Sensor Power Short to Ground
B2848 Horn Output Relay Circuit Short to Ground
B2849 Horn Output Relay Circuit Open
B2850 Driver's Side Air Bag Curtain Low Capacitance on Squib
B2851 Passenger's Side Air Bag Curtain Low Capacitance on Squib
B2852 Right Side Satellite Sensor Circuit Short to Ground/Vbatt
B2853 Left Side Satellite Sensor Circuit Short to Ground/Vbatt
B2854 Left Side Crash Sensor ID Fault
B2855 Front Crash Sensor Short to Ground/Vbatt
B2856 Front Crash Sensor ID Fault
B2857 Audio Internal Multi-Disc Fault
B2858 SDARS Module is defective
B2859 Power Sliding Door Position Sensor Out of Range
B2860 Airbag Cutoff Switch (ACS) ECU Failure
B2861 Airbag Cutoff Switch (ACS) Communication Failure
B2862 Airbag Cutoff Switch (ACS) Indicator Failure
B2863 Aux. Cabin Heater #1 Relay Circuit Open
B2864 Aux. Cabin Heater #1 Relay Circuit Short to Battery
B2865 Aux. Cabin Heater #2 Relay Circuit Open
B2866 Aux. Cabin Heater #2 Relay Circuit Short to Battery
B2867 Connector Half Insertion Detected
B2868 Left Front Tire Pressure Sensor Fault
B2869 Right Front Tire Pressure Sensor Fault
B2870 Right Rear Tire Pressure Sensor Fault
B2871 Left Rear Tire Pressure Sensor Fault
B2872 Tire Pressure Sensor Fault
B2873 Left Side Crash Sensor Internal Fault
B2874 Right Side Crash Sensor Internal Fault
B2875 Right Side Crash Sensor ID Fault
B2876 Striker Drive Motor Short to Battery
B2877 Striker Drive Output Short to Ground
B2878 Telematics/OHC Button Stuck Failure
B2879 Fuel Tank Jet Pump Fault
B2880 SDARS Terrestrial Antenna Open/Short
B2881 Column Reach Movement Fault - Primary Axis
B2882 Column Reach Movement Fault - Secondary Axis
B2883 Column Tilt Movement Fault - Primary Axis
B2884 Column Tilt Movement Fault - Secondary Axis
B2885 Spare Tire Pressure Sensor Fault
B2886 Passenger side crash sensor ID fault
B2887 Driver side crash sensor ID fault
B2888 Audio Head Unit Media Fault
B2889 Passenger Solar Radiation Sensor Circuit Short to Battery
B2890 Passenger Solar Radiation Sensor Out of Range
B2891 Front Wiper Switch Potentiometer Circuit Failure
B2892 Front Wiper Switch Potentiometer Out of Range
B2893 Front Wiper Motor Circuit Failure
B2894 Liftgate/Decklid Release Circuit Failure
B2895 Trip Computer Mode Switch Circuit Failure
B2896 Odometer Data Failure
B2897 Autolamp Relay Circuit Failure
B2898 Right Turn Signal Indicator Output Failure
B2899 Left Turn Signal Indicator Output Failure
B2900 VIN Mismatch
B2901 Park Brake Switch Input Circuit Failure
B2902 Rear Window Ajar Switch Input Failure
B2903 Chime Output Circuit Short to Battery
B2904 Partial Mute Circuit Failure
B2905 Striker Drive Motor Open Circuit
B2906 Striker Up Switch Input Invalid
B2907 Striker Down Switch Input Invalid
B2908 Latch Switch Invalid
B2909 Belt Tension Sensor Fault 5939
B2910 Striker Up / Striker Down Switch Mismatch
B2911 Trip Computer Data Unavailable
B2912 Reverse Gear Switch Plausibility Failure
B2913 Audio Subwoofer Not Connected
B2914 Center Subwoofer / Speaker Not Connected
B2915 Fuel Sender Circuit Failure #2
B2916 Rear Blend Door Circuit Failure
B2917 Rear Mode Door Circuit Failure
B2918 Aux Temp Blend Input Circuit Failure
B2919 Aux Blower Motor Speed Input Circuit Failure
B2920 Aux (Rear) Mode Door Position Failure
B2921 Aux (Rear) Temp Blend Door Circuit Failure
B2922 Auxliary Button Stuck
B2923 Climate Control Button Stuck
B2924 Audio Button Stuck
B2925 Subwoofer Speaker Short Circuit
B2926 Defrost Actuator Motor Out of Range
B2927 Mirror Switch Assembly Circuit - Over Voltage
B2928 RF Receiver Not Connected
B2929 Transmit Data Line Short to Battery
B2930 Transmit Data Line Open Circuit or Short to Ground
B2931 Optical Sensor 1 Short to Battery or Open
B2932 Optical Sensor 1 Short to Ground
B2933 Optical Sensor 2 Short to Battery or Open
B2934 Optical Sensor 2 Short to Ground
B2935 Drive Unit Failure
B2936 Gate Motor Open
B2937 Gate Motor Short to Ground
B2938 Gate Clutch Short to Battery
B2939 Gate Clutch Short to Ground or Open
B2940 Chime Output Circuit Short to Ground
B2941 Cinch Motor Open
B2942 Cinch Output Short to Battery
B2943 Uncinch Output Short to Battery
B2944 Unlatch Output Short to Battery
B2945 RF Receiver Enable Short to Ground
B2946 RF Receiver Power Short to Ground
B2947 Global Opening/Closing Circuit Open
B2948 Global Opening/Closing Circuit Short to Ground
B2949 Global Opening/Closing Circuit Short to Battery
B2950 Air Conditioning System Fault
B2951 Three-way Valve Relay Circuit Failure
B2952 Wakeup Circuit Failure
B2953 Electrical Hazard Lamp Citcuit Failure
B2954 Charge Lamp Circuit Failure
B2955 Cluster Power Circuit Failure
B2956 Servo Motor Left Blend Door Close Line Circuit Failure
B2957 Servo Motor Left Blend Door Open Line Circuit Failure
B2958 Servo Motor Vent Open Line Circuit Failure
B2959 Servo Motor Vent Close Line Circuit Failure
B2960 Air Flow Recirculation Door Open Line Driver Circuit Failure
B2961 Air Flow Recirculation Door Close Line Driver Circuit Failure
B2962 Passenger Seat Heater Output Fault
B2963 Driver Seat Heater Feedback Circuit Fault
B2964 Passenger Seat Heater Feedback Circuit Fault
B2965 Audio System Speaker Circuit Fault 8150
B2966 Front Washer Switch Stuck
B2967 Rear Washer Switch Stuck
B2968 Battery Back Sounder Circuit Short to Ground
B2969 Fuel Pump Status Input Circuit Failure
B2970 Tailgate Release Switch Circuit Failure
B2971 Pedal Position Input Short to Ground
B2972 Pedal Position Input Short to Battery
B2973 Daytime Running Lamp Output Shorted to Ground
B2974 Lighting Mode Switch Input Circuit Failure
B2975 Aux. Heater Line Overload
B2976 Aux. Heater Line Failure
B2977 Pedal Memory Position Out of Range
B2978 Pedal Motor Out of Range
B2979 High Pressure A/C Compressor Cut Out
B2980 Servo Motor Right Blend Door Close Line Circuit Failure
B2981 Servo Motor Right Blend Door Open Line Circuit Failure
B2982 Park Brake Switch Input Circuit Open
B2983 Driver Door Switch Out of Self Test Range
B2984 Deployable Steering Column Circuit Open
B2985 Deployable Steering Column Circuit Short to Battery
B2986 Deployable Steering Column Circuit Short to Ground
B2987 Deployable Steering Column Circuit Resistance Low on Squib
B2988 Knee Bolster Column Circuit Open
B2989 Knee Bolster Circuit Short to Battery
B2990 Knee Bolster Circuit Short to Ground
B2991 Knee Bolster Circuit Resistance Low on Squib
B2992 Electric Park Brake Overload
B2993 Electric Park Brake Temperature Model too High
B2994 Electric Park Brake Temperature Sensor too High
B2995 Video Feed Missing
B2996 Servo Motor Floor Close Line Circuit Failure
B2997 Servo Motor Floor Open Line Circuit Failure
B2998 Inflatable Knee Bolster Circuit Failure 596E
B2999 Restraint Event Notification Signal Fault
U0001 High Speed CAN Communication Bus
U0002 High Speed CAN Communication Bus Performance
U0003 High Speed CAN Communication Bus (+) Open
U0004 High Speed CAN Communication Bus (+) Low
U0005 High Speed CAN Communication Bus (+) High
U0006 High Speed CAN Communication Bus (-) Open
U0007 High Speed CAN Communication Bus (-) Low
U0008 High Speed CAN Communication Bus (-) High
U0009 High Speed CAN Communication Bus (-) shorted to Bus (+)
U0010 Medium Speed CAN Communication Bus
U0011 Medium Speed CAN Communication Bus Performance
U0012 Medium Speed CAN Communication Bus (+) Open
U0013 Medium Speed CAN Communication Bus (+) Low
U0014 Medium Speed CAN Communication Bus (+) High
U0015 Medium Speed CAN Communication Bus (-) Open
U0016 Medium Speed CAN Communication Bus (-) Low
U0017 Medium Speed CAN Communication Bus (-) High
U0018 Medium Speed CAN Communication Bus (-) shorted to Bus (+)
U0019 Low Speed CAN Communication Bus
U0020 Low Speed CAN Communication Bus Performance
U0021 Low Speed CAN Communication Bus (+) Open
U0022 Low Speed CAN Communication Bus (+) Low
U0023 Low Speed CAN Communication Bus (+) High
U0024 Low Speed CAN Communication Bus (-) Open
U0025 Low Speed CAN Communication Bus (-) Low
U0026 Low Speed CAN Communication Bus (-) High
U0027 Low Speed CAN Communication Bus (-) shorted to Bus (+)
U0028 Vehicle Communication Bus A
U0029 Vehicle Communication Bus A Performance
U0030 Vehicle Communication Bus A (+) Open
U0031 Vehicle Communication Bus A (+) Low
U0032 Vehicle Communication Bus A (+) High
U0033 Vehicle Communication Bus A (-) Open
U0034 Vehicle Communication Bus A (-) Low
U0035 Vehicle Communication Bus A (-) High
U0036 Vehicle Communication Bus A (-) shorted to Bus A (+)
U0037 Vehicle Communication Bus B
U0038 Vehicle Communication Bus B Performance
U0039 Vehicle Communication Bus B (+) Open
U0040 Vehicle Communication Bus B (+) Low
U0041 Vehicle Communication Bus B (+) High
U0042 Vehicle Communication Bus B (-) Open
U0043 Vehicle Communication Bus B (-) Low
U0044 Vehicle Communication Bus B (-) High
U0045 Vehicle Communication Bus B (-) shorted to Bus B (+)
U0046 Vehicle Communication Bus C
U0047 Vehicle Communication Bus C Performance
U0048 Vehicle Communication Bus C (+) Open
U0049 Vehicle Communication Bus C (+) Low
U0050 Vehicle Communication Bus C (+) High
U0051 Vehicle Communication Bus C (-) Open
U0052 Vehicle Communication Bus C (-) Low
U0053 Vehicle Communication Bus C (-) High
U0054 Vehicle Communication Bus C (-) shorted to Bus C (+)
U0055 Vehicle Communication Bus D
U0056 Vehicle Communication Bus D Performance
U0057 Vehicle Communication Bus D (+) Open
U0058 Vehicle Communication Bus D (+) Low
U0059 Vehicle Communication Bus D (+) High
U0060 Vehicle Communication Bus D (-) Open
U0061 Vehicle Communication Bus D (-) Low
U0062 Vehicle Communication Bus D (-) High
U0063 Vehicle Communication Bus D (-) shorted to Bus D (+)
U0064 Vehicle Communication Bus E
U0065 Vehicle Communication Bus E Performance
U0066 Vehicle Communication Bus E (+) Open
U0067 Vehicle Communication Bus E (+) Low
U0068 Vehicle Communication Bus E (+) High
U0069 Vehicle Communication Bus E (-) Open
U0070 Vehicle Communication Bus E (-) Low
U0071 Vehicle Communication Bus E (-) High
U0072 Vehicle Communication Bus E (-) shorted to Bus E (+)
U0073 Control Module Communication Bus Off
U0100 Lost Communication With ECM/PCM “A”
U0101 Lost Communication with TCM
U0102 Lost Communication with Transfer Case Control Module
U0103 Lost Communication With Gear Shift Module
U0104 Lost Communication With Cruise Control Module
U0105 Lost Communication With Fuel Injector Control Module
U0106 Lost Communication With Glow Plug Control Module
U0107 Lost Communication With Throttle Actuator Control Module
U0108 Lost Communication With Alternative Fuel Control Module
U0109 Lost Communication With Fuel Pump Control Module
U0110 Lost Communication With Drive Motor Control Module
U0111 "Lost Communication With Battery Energy Control Module ""A"""
U0112 "Lost Communication With Battery Energy Control Module ""B"""
U0113 Lost Communication With Emissions Critical Control Information
U0114 Lost Communication With Four-Wheel Drive Clutch Control Module
U0115 Lost Communication With ECM/PCM “B”
U0116 Lost Communications with Coolant Temperature Control Module
U0117 Lost Communications With Electrical PTO Control Module
U0118 Lost Communications With Fuel Additive Control Module
U0119 Lost Communication With Fuel Cell Control Module
U0120 Lost Communication with Starter/ Generator Control Module
U0121 Lost Communication With Anti-Lock Brake System (ABS) Control Module
U0122 Lost Communication With Vehicle Dynamics Control Module
U0123 Lost Communication With Yaw Rate Sensor Module
U0124 Lost Communication With Lateral Acceleration Sensor Module
U0125 Lost Communication With Multi-axis Acceleration Sensor Module
U0126 Lost Communication With Steering Angle Sensor Module
U0127 Lost Communication With Tire Pressure Monitor Module
U0128 Lost Communication With Park Brake Control Module
U0129 Lost Communication With Brake System Control Module
U0130 Lost Communication With Steering Effort Control Module
U0131 Lost Communication With Power Steering Control Module
U0132 Lost Communication With Ride Level Control Module
U0133 Lost Communication With Active Roll Control Module
U0134 Lost Communication With Power Steering Control Module
U0135 Lost Communication With Differential Control Module
U0136 Lost Communication With Differential Control Module
U0137 Lost Communication With Trailer Brake Control Module
U0138 Lost Communication with All Terrain Control Module
U0139 ISO/SAE reserved
U0140 Lost Communication With Body Control Module
U0141 "Lost Communication With Body Control Module ""A"""
U0142 "Lost Communication With Body Control Module ""B"""
U0143 "Lost Communication With Body Control Module ""C"""
U0144 "Lost Communication With Body Control Module ""D"""
U0145 "Lost Communication With Body Control Module ""E"""
U0146 "Lost Communication With Gateway ""A"""
U0147 "Lost Communication With Gateway ""B"""
U0148 "Lost Communication With Gateway ""C"""
U0149 "Lost Communication With Gateway ""D"""
U0150 "Lost Communication With Gateway ""E"""
U0151 Lost Communication With Restraints Control Module
U0152 Lost Communication With Side Restraints Control Module
U0153 Lost Communication With Side Restraints Control Module
U0154 Lost Communication With Restraints Occupant Classification System Module
U0155 Lost Communication With Instrument Panel Cluster (IPC) Control Module
U0156 "Lost Communication With Information Center ""A"""
U0157 "Lost Communication With Information Center ""B"""
U0158 Lost Communication With Head Up Display
U0159 "Lost Communication With Parking Assist Control Module ""A"""
U0160 Lost Communication With Audible Alert Control Module
U0161 Lost Communication With Compass Module
U0162 Lost Communication With Navigation Display Module
U0163 Lost Communication With Navigation Control Module
U0164 Lost Communication With HVAC Control Module
U0165 Lost Communication With HVAC Control Module
U0166 Lost Communication With Auxiliary Heater Control Module
U0167 Lost Communication With Vehicle Immobilizer Control Module
U0168 Lost Communication With Vehicle Security Control Module
U0169 Lost Communication With Sunroof Control Module
U0170 "Lost Communication With ""Restraints System Sensor A"""
U0171 "Lost Communication With ""Restraints System Sensor B"""
U0172 "Lost Communication With ""Restraints System Sensor C"""
U0173 "Lost Communication With ""Restraints System Sensor D"""
U0174 "Lost Communication With ""Restraints System Sensor E"""
U0175 "Lost Communication With ""Restraints System Sensor F"""
U0176 "Lost Communication With ""Restraints System Sensor G"""
U0177 "Lost Communication With ""Restraints System Sensor H"""
U0178 "Lost Communication With ""Restraints System Sensor I"""
U0179 "Lost Communication With ""Restraints System Sensor J"""
U0180 Lost Communication With Automatic Lighting Control Module
U0181 Lost Communication With Headlamp Leveling Control Module
U0182 Lost Communication With Lighting Control Module
U0183 Lost Communication With Lighting Control Module
U0184 Lost Communication With Radio
U0185 Lost Communication With Antenna Control Module
U0186 Lost Communication With Audio Amplifier
U0187 "Lost Communication With Digital Disc Player/Changer Module ""A"""
U0188 "Lost Communication With Digital Disc Player/Changer Module ""B"""
U0189 "Lost Communication With Digital Disc Player/Changer Module ""C"""
U0190 "Lost Communication With Digital Disc Player/Changer Module ""D"""
U0191 Lost Communication With Television
U0192 Lost Communication With Personal Computer
U0193 "Lost Communication With ""Digital Audio Control Module A"""
U0194 "Lost Communication With ""Digital Audio Control Module B"""
U0195 Lost Communication With Subscription Entertainment Receiver Module
U0196 "Lost Communication With Entertainment Control Module-Rear ""A"""
U0197 Lost Communication With Telephone Control Module
U0198 Lost Communication With Telematic Control Module
U0199 "Lost Communication With ""Door Control Module A"""
U0200 "Lost Communication With ""Door Control Module B"""
U0201 "Lost Communication With ""Door Control Module C"""
U0202 "Lost Communication With ""Door Control Module D"""
U0203 "Lost Communication With ""Door Control Module E"""
U0204 "Lost Communication With ""Door Control Module F"""
U0205 "Lost Communication With ""Door Control Module G"""
U0206 Lost Communication With Folding Top Control Module
U0207 Lost Communication With Moveable Roof Control Module
U0208 "Lost Communication With ""Seat Control Module A"""
U0209 "Lost Communication With ""Seat Control Module B"""
U0210 "Lost Communication With ""Seat Control Module C"""
U0211 "Lost Communication With ""Seat Control Module D"""
U0212 Lost Communication With Steering Column Control Module
U0213 "Lost Communication With Mirror Control Module ""A"""
U0214 Lost Communication With Remote Function Actuation
U0215 "Lost Communication With ""Door Switch A"""
U0216 "Lost Communication With ""Door Switch B"""
U0217 "Lost Communication With ""Door Switch C"""
U0218 "Lost Communication With ""Door Switch D"""
U0219 "Lost Communication With ""Door Switch E"""
U0220 "Lost Communication With ""Door Switch F"""
U0221 "Lost Communication With ""Door Switch G"""
U0222 "Lost Communication With ""Door Window Motor A"""
U0223 "Lost Communication With ""Door Window Motor B"""
U0224 "Lost Communication With ""Door Window Motor C"""
U0225 "Lost Communication With ""Door Window Motor D"""
U0226 "Lost Communication With ""Door Window Motor E"""
U0227 "Lost Communication With ""Door Window Motor F"""
U0228 "Lost Communication With ""Door Window Motor G"""
U0229 Lost Communication With Heated Steering Wheel Module
U0230 Lost Communication With Rear Gate Module
U0231 Lost Communication With Rain Sensing Module
U0232 Lost Communication With Side Obstacle Detection Control Module
U0233 Lost Communication With Side Obstacle Detection Control Module
U0234 Lost Communication With Convenience Recall Module
U0235 Lost Communication With Cruise Control Front Distance Range Sensor
U0236 Lost Communication With Column Lock Module
U0237 "Lost Communication With Digital Audio Control Module ""C"""
U0238 "Lost Communication With Digital Audio Control Module ""D"""
U0239 "Lost Communication With Entrapment Control Module ""A"""
U0240 "Lost Communication With Entrapment Control Module ""B"""
U0241 "Lost Communication With Headlamp Control Module ""A"""
U0242 "Lost Communication With Headlamp Control Module ""B"""
U0243 "Lost Communication With Parking Assist Control Module ""B"""
U0244 Lost Communication With Running Board Control Module
U0245 Lost Communication With Entertainment Control Module-Front
U0246 "Lost Communication With Seat Control Module ""E"""
U0247 "Lost Communication With Seat Control Module ""F"""
U0248 Lost Communication with Remote Accessory Module
U0249 "Lost Communication With Entertainment Control Module -Rear ""B"""
U0293 Lost Communication With Hybrid Powertrain Control Module
U0294 Lost Communication With Powertrain Control Monitor Module
U0295 Lost Communication With AC to AC Converter Control Module
U0296 "Lost Communication With AC to DC Converter Control Module ""A"""
U0297 "Lost Communication With AC to DC Converter Control Module ""B"""
U0298 "Lost Communication With DC to DC Converter Control Module ""A"""
U0299 "Lost Communication With DC to DC Converter Control Module ""B"""
U0300 Internal Control Module Software Incompatibility
U0301 Software Incompatibility with Engine/Powertrain Control Module
U0302 Software Incompatibility with Transmission Control Module
U0303 Software Incompatibility with Transfer Case Control Module
U0304 Software Incompatibility with Gear Shift Control Module
U0305 Software Incompatibility with Cruise Control Module
U0306 Software Incompatibility with Fuel Injector Control Module
U0307 Software Incompatibility with Glow Plug Control Module
U0308 Software Incompatibility with Throttle Actuator Control Module
U0309 Software Incompatibility with Alternative Fuel Control Module
U0310 Software Incompatibility with Fuel Pump Control Module
U0311 Software Incompatibility with Drive Motor Control Module
U0312 Software Incompatibility with Battery Energy Control Module A
U0313 Software Incompatibility with Battery Energy Control Module B
U0314 Software Incompatibility with For-Wheel Drive Clutch Control Module
U0315 Software Incompatibility with Anti-Lock Brake System Control Module
U0316 Software Incompatibility with Vehicle Dynamics Control Module
U0317 Software Incompatibility with Park Brake Control Module
U0318 Software Incompatibility with Brake System Control Module
U0319 Software Incompatibility with Steering Effort Control Module
U0320 Software Incompatibility with Power Steering Control Module
U0321 Software Incompatibility with Ride Level Control Module
U0322 Software Incompatibility with Body Control Module
U0323 Software Incompatibility with Instrument Panel Control Module
U0324 Software Incompatibility with HVAC Control Module
U0325 Software Incompatibility with Auxiliary Heater Control Module
U0326 Software Incompatibility with Vehicle Immobilizer Control Module
U0327 Software Incompatibility with Vehicle Security Control Module
U0328 Software Incompatibility with Steering Angle Sensor Module
U0329 Software Incompatibility with Steering Column Control Module
U0330 Software Incompatibility with Tire Pressure Monitor Module
U0331 Software Incompatibility with Body Control Module A
U0332 Software Incompatibility with Multi-axis Acceleration Sensor Module
U1000 SCP (J1850) Invalid or Missing Data for Primary Id $00
D000. D000 - D806 SCP Bus DTCs
U1001 SCP (J1850) Invalid or Missing Data for Primary Id $01
U1002 SCP (J1850) Invalid or Missing Data for Primary Id $02
U1003 SCP (J1850) Invalid or Missing Data for Primary Id $03
U1004 SCP (J1850) Invalid or Missing Data for EEC Programming
U1005 SCP (J1850) Invalid or Missing Data for EEC Programming
U1006 SCP (J1850) Invalid or Missing Data for Primary Id $06
U1007 SCP (J1850) Invalid or Missing Data for Primary Id $07
U1008 SCP (J1850) Invalid or Missing Data for Engine Torque
U1009 SCP (J1850) Invalid or Missing Data for Engine Torque
U1010 SCP (J1850) Invalid or Missing Data for Engine Air Intake
U1011 SCP (J1850) Invalid or Missing Data for Engine Air Intake
U1012 SCP (J1850) Invalid or Missing Data for Primary Id $0C
U1013 SCP (J1850) Invalid or Missing Data for Primary Id $0D
U1014 SCP (J1850) Invalid or Missing Data for Primary Id $0E
U1015 SCP (J1850) Invalid or Missing Data for Primary Id $0F
U1016 SCP (J1850) Invalid or Missing Data for Primary Id $10
U1017 SCP (J1850) Invalid or Missing Data for Primary Id $11
U1018 SCP (J1850) Invalid or Missing Data for Throttle
U1019 SCP (J1850) Invalid or Missing Data for Throttle
U1020 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
U1021 SCP (J1850) Invalid or Missing Data for Air Conditioning Clutch
U1022 SCP (J1850) Invalid or Missing Data for Primary Id $16
U1023 SCP (J1850) Invalid or Missing Data for Primary Id $17
U1024 SCP (J1850) Invalid or Missing Data for Primary Id $18
U1025 SCP (J1850) Invalid or Missing Data for Primary Id $19
U1026 SCP (J1850) Invalid or Missing Data for Engine RPM
U1027 SCP (J1850) Invalid or Missing Data for Engine RPM
U1028 SCP (J1850) Invalid or Missing Data for Primary Id $1C
U1029 SCP (J1850) Invalid or Missing Data for Primary Id $1D
U1030 SCP (J1850) Invalid or Missing Data for Experimental #1
U1031 SCP (J1850) Invalid or Missing Data for Experimental #1
U1032 SCP (J1850) Invalid or Missing Data for Primary Id $20
U1033 SCP (J1850) Invalid or Missing Data for Primary Id $21
U1034 SCP (J1850) Invalid or Missing Data for Primary Id $22
U1035 SCP (J1850) Invalid or Missing Data for Primary Id $23
U1036 SCP (J1850) Invalid or Missing Data for Wheels
U1037 SCP (J1850) Invalid or Missing Data for Wheels
U1038 SCP (J1850) Invalid or Missing Data for Primary Id $26
U1039 SCP (J1850) Invalid or Missing Data for Primary Id $27
U1040 SCP (J1850) Invalid or Missing Data for Vehicle Speed
U1041 SCP (J1850) Invalid or Missing Data for Vehicle Speed
U1042 SCP (J1850) Invalid or Missing Data for Traction Control
U1043 SCP (J1850) Invalid or Missing Data for Traction Control
U1044 SCP (J1850) Invalid or Missing Data for Traction Motor
U1045 SCP (J1850) Invalid or Missing Data for Traction Motor
U1046 SCP (J1850) Invalid or Missing Data for Primary Id $2E
U1047 SCP (J1850) Invalid or Missing Data for Primary Id $2F
U1048 SCP (J1850) Invalid or Missing Data for Primary Id $30
U1049 SCP (J1850) Invalid or Missing Data for Primary Id $31
U1050 SCP (J1850) Invalid or Missing Data for Brakes
U1051 SCP (J1850) Invalid or Missing Data for Brakes
U1052 SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel
U1053 SCP (J1850) Invalid or Missing Data for Steering / Steering Wheel
U1054 SCP (J1850) Invalid or Missing Data for Primary Id $36
U1055 SCP (J1850) Invalid or Missing Data for Primary Id $37
U1056 SCP (J1850) Invalid or Missing Data for Vehicle Configuration
U1057 SCP (J1850) Invalid or Missing Data for Vehicle Configuration
U1058 SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL
U1059 SCP (J1850) Invalid or Missing Data for Transmission / Transaxle / PRNDL
U1060 SCP (J1850) Invalid or Missing Data for Primary Id $3C
U1061 SCP (J1850) Invalid or Missing Data for Primary Id $3D
U1062 SCP (J1850) Invalid or Missing Data for Primary Id $3E
U1063 SCP (J1850) Invalid or Missing Data for Primary Id $3F
U1064 SCP (J1850) Invalid or Missing Data for Primary Id $40
U1065 SCP (J1850) Invalid or Missing Data for Primary Id $41
U1066 SCP (J1850) Invalid or Missing Data for Primary Id $42
U1067 SCP (J1850) Invalid or Missing Data for Primary Id $43
U1068 SCP (J1850) Invalid or Missing Data for Primary Id $44
U1069 SCP (J1850) Invalid or Missing Data for Primary Id $45
U1070 SCP (J1850) Invalid or Missing Data for Engine Sensors
U1071 SCP (J1850) Invalid or Missing Data for Engine Sensors
U1072 SCP (J1850) Invalid or Missing Data for Engine Coolant
U1073 SCP (J1850) Invalid or Missing Data for Engine Coolant
U1074 SCP (J1850) Invalid or Missing Data for Engine Oil
U1075 SCP (J1850) Invalid or Missing Data for Engine Oil
U1076 SCP (J1850) Invalid or Missing Data for Primary Id $4C
U1077 SCP (J1850) Invalid or Missing Data for Primary Id $4D
U1078 SCP (J1850) Invalid or Missing Data for Primary Id $4E
U1079 SCP (J1850) Invalid or Missing Data for Primary Id $4F
U1080 SCP (J1850) Invalid or Missing Data for Primary Id $50
U1081 SCP (J1850) Invalid or Missing Data for Primary Id $51
U1082 SCP (J1850) Invalid or Missing Data for Engine Systems Other
U1083 SCP (J1850) Invalid or Missing Data for Engine Systems Other
U1084 SCP (J1850) Invalid or Missing Data for Powertrain Status Request
U1085 SCP (J1850) Invalid or Missing Data for Powertrain Status Request
U1086 SCP (J1850) Invalid or Missing Data for Primary Id $56
U1087 SCP (J1850) Invalid or Missing Data for Primary Id $57
U1088 SCP (J1850) Invalid or Missing Data for Suspension
U1089 SCP (J1850) Invalid or Missing Data for Suspension
U1090 SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics
U1091 SCP (J1850) Invalid or Missing Data for Non-Legislated Diagnostics
U1092 SCP (J1850) Invalid or Missing Data for Primary Id $5C
U1093 SCP (J1850) Invalid or Missing Data for Primary Id $5D
U1094 SCP (J1850) Invalid or Missing Data for Experimental #2
U1095 SCP (J1850) Invalid or Missing Data for Experimental #2
U1096 SCP (J1850) Invalid or Missing Data for Primary Id $60
U1097 SCP (J1850) Invalid or Missing Data for Primary Id $61
U1098 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control
U1099 SCP (J1850) Invalid or Missing Data for Vehicle Speed Control
U1100 SCP (J1850) Invalid or Missing Data for Primary Id $64
U1101 SCP (J1850) Invalid or Missing Data for Primary Id $65
U1102 SCP (J1850) Invalid or Missing Data for Primary Id $66
U1103 SCP (J1850) Invalid or Missing Data for Primary Id $67
U1104 SCP (J1850) Invalid or Missing Data for Chassis Status Request
U1105 SCP (J1850) Invalid or Missing Data for Chassis Status Request
U1106 SCP (J1850) Invalid or Missing Data for Legislated Diagnostics
U1107 SCP (J1850) Invalid or Missing Data for Legislated Diagnostics
U1108 SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)
U1109 SCP (J1850) Invalid or Missing Data for Electric Traction Drive (Inverter)
U1110 SCP (J1850) Invalid or Missing Data for Primary Id $6E
U1111 SCP (J1850) Invalid or Missing Data for Primary Id $6F
U1112 SCP (J1850) Invalid or Missing Data for Primary Id $70
U1113 SCP (J1850) Invalid or Missing Data for Primary Id $71
U1114 SCP (J1850) Invalid or Missing Data for Charging System
U1115 SCP (J1850) Invalid or Missing Data for Charging System
U1116 SCP (J1850) Invalid or Missing Data for Electrical Energy Management
U1117 SCP (J1850) Invalid or Missing Data for Electrical Energy Management
U1118 SCP (J1850) Invalid or Missing Data for Primary Id $76
U1119 SCP (J1850) Invalid or Missing Data for Primary Id $77
U1120 SCP (J1850) Invalid or Missing Data for Primary Id $78
U1121 SCP (J1850) Invalid or Missing Data for Primary Id $79
U1122 SCP (J1850) Invalid or Missing Data for Odometer
U1123 SCP (J1850) Invalid or Missing Data for Odometer
U1124 SCP (J1850) Invalid or Missing Data for Primary Id $7C
U1125 SCP (J1850) Invalid or Missing Data for Primary Id $7D
U1126 SCP (J1850) Invalid or Missing Data for Primary Id $7E
U1127 SCP (J1850) Invalid or Missing Data for Primary Id $7F
U1128 SCP (J1850) Invalid or Missing Data for Primary Id $80
U1129 SCP (J1850) Invalid or Missing Data for Primary Id $81
U1130 SCP (J1850) Invalid or Missing Data for Fuel System
U1131 SCP (J1850) Invalid or Missing Data for Fuel System
U1132 SCP (J1850) Invalid or Missing Data for Vehicle Motion
U1133 SCP (J1850) Invalid or Missing Data for Vehicle Motion
U1134 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
U1135 SCP (J1850) Invalid or Missing Data for Ignition Switch / Starter
U1136 SCP (J1850) Invalid or Missing Data for Telltales
U1137 SCP (J1850) Invalid or Missing Data for Telltales
U1138 SCP (J1850) Invalid or Missing Data for Primary Id $8A
U1139 SCP (J1850) Invalid or Missing Data for Primary Id $8B
U1140 SCP (J1850) Invalid or Missing Data for Gateway
U1141 SCP (J1850) Invalid or Missing Data for Gateway
U1142 SCP (J1850) Invalid or Missing Data for Primary Id $8E
U1143 SCP (J1850) Invalid or Missing Data for Primary Id $8F
U1144 SCP (J1850) Invalid or Missing Data for Primary Id $90
U1145 SCP (J1850) Invalid or Missing Data for Primary Id $91
U1146 SCP (J1850) Invalid or Missing Data for Vehicle Security
U1147 SCP (J1850) Invalid or Missing Data for Vehicle Security
U1148 SCP (J1850) Invalid or Missing Data for Audio Control
U1149 SCP (J1850) Invalid or Missing Data for Audio Control
U1150 SCP (J1850) Invalid or Missing Data for Audible Warnings
U1151 SCP (J1850) Invalid or Missing Data for Audible Warnings
U1152 SCP (J1850) Invalid or Missing Data for Experimental #3
U1153 SCP (J1850) Invalid or Missing Data for Experimental #3
U1154 SCP (J1850) Invalid or Missing Data for Compact Disc
U1155 SCP (J1850) Invalid or Missing Data for Compact Disc
U1156 SCP (J1850) Invalid or Missing Data for Digital Signal Processing
U1157 SCP (J1850) Invalid or Missing Data for Digital Signal Processing
U1158 SCP (J1850) Invalid or Missing Data for Antenna
U1159 SCP (J1850) Invalid or Missing Data for Antenna
U1160 SCP (J1850) Invalid or Missing Data for Primary Id $A0
U1161 SCP (J1850) Invalid or Missing Data for Primary Id $A1
U1162 SCP (J1850) Invalid or Missing Data for Digital Audio Tape
U1163 SCP (J1850) Invalid or Missing Data for Digital Audio Tape
U1164 SCP (J1850) Invalid or Missing Data for Tuner / Receiver
U1165 SCP (J1850) Invalid or Missing Data for Tuner / Receiver
U1166 SCP (J1850) Invalid or Missing Data for Cassette Tape
U1167 SCP (J1850) Invalid or Missing Data for Cassette Tape
U1168 SCP (J1850) Invalid or Missing Data for Primary Id $A8
U1169 SCP (J1850) Invalid or Missing Data for Primary Id $A9
U1170 SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System
U1171 SCP (J1850) Invalid or Missing Data for Cellular Phone / Paging System
U1172 SCP (J1850) Invalid or Missing Data for Remote Button Control
U1173 SCP (J1850) Invalid or Missing Data for Remote Button Control
U1174 SCP (J1850) Invalid or Missing Data for Primary Id $AE
U1175 SCP (J1850) Invalid or Missing Data for Primary Id $AF
U1176 SCP (J1850) Invalid or Missing Data for Primary Id $B0
U1177 SCP (J1850) Invalid or Missing Data for Primary Id $B1
U1178 SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)
U1179 SCP (J1850) Invalid or Missing Data for Climate Control (HVAC)
U1180 SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features
U1181 SCP (J1850) Invalid or Missing Data for Personalization (Memory) Features
U1182 SCP (J1850) Invalid or Missing Data for Primary Id $B6
U1183 SCP (J1850) Invalid or Missing Data for Primary Id $B7
U1184 SCP (J1850) Invalid or Missing Data for Window Wiper / Washer
U1185 SCP (J1850) Invalid or Missing Data for Window Wiper / Washer
U1186 SCP (J1850) Invalid or Missing Data for Primary Id $BA
U1187 SCP (J1850) Invalid or Missing Data for Primary Id $BB
U1188 SCP (J1850) Invalid or Missing Data for Primary Id $BC
U1189 SCP (J1850) Invalid or Missing Data for Primary Id $BD
U1190 SCP (J1850) Invalid or Missing Data for Primary Id $BE
U1191 SCP (J1850) Invalid or Missing Data for Primary Id $BF
U1192 SCP (J1850) Invalid or Missing Data for Primary Id $C0
U1193 SCP (J1850) Invalid or Missing Data for Primary Id $C1
U1194 SCP (J1850) Invalid or Missing Data for Mirrors
U1195 SCP (J1850) Invalid or Missing Data for Mirrors
U1196 SCP (J1850) Invalid or Missing Data for Door Locks
U1197 SCP (J1850) Invalid or Missing Data for Door Locks
U1198 SCP (J1850) Invalid or Missing Data for External Access (Doors)
U1199 SCP (J1850) Invalid or Missing Data for External Access (Doors)
U1200 SCP (J1850) Invalid or Missing Data for Seat Motion / Control
U1201 SCP (J1850) Invalid or Missing Data for Seat Motion / Control
U1202 SCP (J1850) Invalid or Missing Data for Windows
U1203 SCP (J1850) Invalid or Missing Data for Windows
U1204 SCP (J1850) Invalid or Missing Data for Steering Column
U1205 SCP (J1850) Invalid or Missing Data for Steering Column
U1206 SCP (J1850) Invalid or Missing Data for Primary Id $CE
U1207 SCP (J1850) Invalid or Missing Data for Primary Id $CF
U1208 SCP (J1850) Invalid or Missing Data for Seat Switches
U1209 SCP (J1850) Invalid or Missing Data for Seat Switches
U1210 SCP (J1850) Invalid or Missing Data for Restraints
U1211 SCP (J1850) Invalid or Missing Data for Restraints
U1212 SCP (J1850) Invalid or Missing Data for Primary Id $D4
U1213 SCP (J1850) Invalid or Missing Data for Primary Id $D5
U1214 SCP (J1850) Invalid or Missing Data for Primary Id $D6
U1215 SCP (J1850) Invalid or Missing Data for Primary Id $D7
U1216 SCP (J1850) Invalid or Missing Data for External Lamp Outage
U1217 SCP (J1850) Invalid or Missing Data for External Lamp Outage
U1218 SCP (J1850) Invalid or Missing Data for External Lamps
U1219 SCP (J1850) Invalid or Missing Data for External Lamps
U1220 SCP (J1850) Invalid or Missing Data for Interior Lamp Outage
U1221 SCP (J1850) Invalid or Missing Data for Interior Lamp Outage
U1222 SCP (J1850) Invalid or Missing Data for Interior Lamps
U1223 SCP (J1850) Invalid or Missing Data for Interior Lamps
U1224 SCP (J1850) Invalid or Missing Data for Primary Id $E0
U1225 SCP (J1850) Invalid or Missing Data for Primary Id $E1
U1226 SCP (J1850) Invalid or Missing Data for Body Status Request
U1227 SCP (J1850) Invalid or Missing Data for Body Status Request
U1228 SCP (J1850) Invalid or Missing Data for Tires
U1229 SCP (J1850) Invalid or Missing Data for Tires
U1230 SCP (J1850) Invalid or Missing Data for Electric Defrost
U1231 SCP (J1850) Invalid or Missing Data for Electric Defrost
U1232 SCP (J1850) Invalid or Missing Data for Navigation
U1233 SCP (J1850) Invalid or Missing Data for Navigation
U1234 SCP (J1850) Invalid or Missing Data for Displays
U1235 SCP (J1850) Invalid or Missing Data for Displays
U1236 SCP (J1850) Invalid or Missing Data for Memory Storage
U1237 SCP (J1850) Invalid or Missing Data for Memory Storage
U1238 SCP (J1850) Invalid or Missing Data for Experimental #4
U1239 SCP (J1850) Invalid or Missing Data for Experimental #4
U1240 SCP (J1850) Invalid or Missing Data for Primary Id $F0
U1241 SCP (J1850) Invalid or Missing Data for Primary Id $F1
U1242 SCP (J1850) Invalid or Missing Data for Exterior Environment
U1243 SCP (J1850) Invalid or Missing Data for Exterior Environment
U1244 SCP (J1850) Invalid or Missing Data for Interior Environment
U1245 SCP (J1850) Invalid or Missing Data for Interior Environment
U1246 SCP (J1850) Invalid or Missing Data for Primary Id $F6
U1247 SCP (J1850) Invalid or Missing Data for Primary Id $F7
U1248 SCP (J1850) Invalid or Missing Data for Time / Date
U1249 SCP (J1850) Invalid or Missing Data for Time / Date
U1250 SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)
U1251 SCP (J1850) Invalid or Missing Data for Vehicle Id (VIN)
U1252 SCP (J1850) Invalid or Missing Data for Class A Functions
U1253 SCP (J1850) Invalid or Missing Data for Class A Functions
U1254 SCP (J1850) Invalid or Missing Data for Network Control
U1255 SCP (J1850) Invalid or Missing Data for Network Control
U1256 SCP(J1850) Invalid or Missing Data for Primary ID $FF
U1260 SCP (J1850) Single Ended (+) Circuit Failure
U1261 SCP (J1850) Single Ended (-) Circuit Failure
U1262 SCP (J1850) Communication Bus Fault B911, B912, B913, B914, B915, B916, B917, B918
U1263 Invalid or Missing Data From Second SCP Link
U1308 SCP (J1850) Invalid or Missing Data for Function Read Engine Torque
U1341 SCP (J1850) Invalid or Missing Data for Function Read Vehicle Speed
U1430 SCP (J1850) Invalid or Missing Data for Function Read Fuel System
U1451 SCP (J1850) Invalid or Missing Data for Function Read Audible Warnings
U1612 SCP (J1850) Lack of Acknowledgment for Primary Id $0C
U1736 SCP (J1850) Lack of Acknowledgment for Telltales
U1750 SCP (J1850) Lack of Acknowledgment for Audible Warnings
U1751 SCP (J1850) SCLM system status missing from REM
U1752 SCP (J1850) SCLM system status missing from FEM
U1794 SCP (J1850) Lack of Acknowledgment for Mirrors
U1797 SCP (J1850) Lack of Acknowledgment for Door Locks
U1798 SCP (J1850) Lack of Acknowledgment for External Access (Doors)
U1806 SCP (J1850) Lack of Acknowledgement for Primary Id $CE
U1900 CAN Communication Bus Fault - Receive Error B902
U1901 CAN Network #2 Communication Bus Fault - Receive Error B905
U1950 UBP Communication Bus Fault B903
U2000 Audio Rear Control Unit is Not Responding
U2001 Audio Tape Deck Unit is Not Responding
U2002 Audio Bezel is Not Responding
U2003 Audio Compact Disk / Disk Jockey Unit is Not Responding
U2004 Audio Steering Wheel Control Unit is Not Responding
U2005 Audio Rear Integrated Control Panel Unit / RDM is Not Responding
U2006 Audio Remote Climate Control Unit is Not Responding
U2007 Audio Navigation Unit is Not Responding
U2008 Audio Phone is Not Responding
U2009 Audio Front Control Module (ACM) is Not Responding
U2010 Module is Not Responding (Non SCP)
U2011 Module Transmitted Invalid Data (Non SCP)
U2012 Communication Bus Error (Non SCP)
U2013 Compass Module is not Responding
U2014 Audio Subwoofer Unit is Not Responding
U2015 Signal Link Fault (Non SCP)
U2016 Signal Link Short to Ground (Non SCP)
U2017 Driver Side Crash Sensor Communication Fault (Non SCP)
U2018 Passenger Side Crash Sensor Communication Fault (Non SCP)
U2019 Audio Voice Module Not Responding
U2020 Audio Center Amp is not responding
U2021 Invalid /fault data received (Non SCP)
U2022 Communication Fault on Dedicated Protocol
U2023 Fault Received From External Node
U2024 Audio Redundant Steering Wheel Control not responding
U2025 SDARS Module is Not Responding
U2026 Family Entertainment System is Not Responding
U2027 Left Side Crash Sensor Communication Fault (Non SCP)
U2028 Right Side Crash Sensor Communication Fault (Non SCP)
U2029 DVD Unit is not Responding
U2030 Rain Sensor Communication Fault
U2031 Inner Left Rear (ILR) Tire Pressure Sensor is Not Responding
U2032 Inner Right Rear (IRR) Tire Pressure Sensor is Not Responding
U2050 No Application Present
U2051 One or More Calibration Files Missing / Corrupt
U2060 ECU Redundant Power Circuit Open
U2061 ECU Redundant Power Circuit Short to Ground
U2062 ECU Redundant Ground Circuit Open
U2063 ECU Redundant Ground Circuit Short to Battery
U2064 Warning Indicator Requested by Another Control Module
U2150 SCP (J1850) Invalid Data from REM
U2152 SCP (J1850) Invalid Data from GEM
U2160 SCP (J1850) Invalid Data from IC
U2195 SCP (J1850) Invalid Data from SCLM
U2196 Invalid 'Engine RPM' data
U2197 Invalid 'Vehicle Speed' data
U2198 Invalid 'Fuel Pulse' data
U2199 Invalid 'Engine Coolant Temperature' data
U2200 Invalid 'ODO Count' data
U2201 Invalid 'Ambient Temperature' data
U2202 Invalid Configuration Data Received
E210 - E465 UBP Invalid Data DTCs as defined in Part 1 Sp ecification
U2226 UBP Invalid Data From Node ID $10
U2235 UBP Invalid Data From Node ID $19
U2306 UBP Invalid Data From Node ID $60
U2338 UBP Invalid Data From Node ID $80
U2355 UBP Invalid Data From Node ID $91
U2362 UBP Invalid Data From Node ID $98
U2366 UBP Invalid Data From Node ID $9C
U2367 UBP Invalid Data From Node ID $9D
U2385 UBP Invalid Data From Node ID $AF
U2403 UBP Invalid Data From Node ID $C1
U2428 UBP Invalid Data From Node ID $DA
U2469 Power Liftgate Disabled by Customer Interface
U2470 Unexpected Keyfob / Keypad Button Press
U2471 Unexpected PRNDL State
U2472 Unexpected Ignition State
U2473 Unexpected Vehicle Speed (VSS)
U2474 Unexpected Fuel Tank Pressure Sensor #1 Value
U2475 Unexpected Fuel Tank Temperature Sensor #1 Value
U2499 ECU Overheat Protection
U2500 (CAN) Lack of Acknowledgement from Engine Management
E500 - E799 CAN Bus DTCs
U2501 Missing Token From Engine Management System For ACC
U2502 Missing Token From Transmission Control Module For ACC
U2503 Missing Token From Instrument Cluster For ACC
U2504 Missing Token From ABS For ACC
U2505 Missing Message From Smart Booster Controller For ACC
U2506 Missing Token From Adaptive Cruise Control For Smart Booster
U2507 Missing Token From Engine Management System For Smart Booster
U2508 Missing Token From ABS For Smart Booster
U2509 Torque Reduction Request Cannot be Fullfilled by EMS
U2510 CAN - Invalid data for Vehicle Security.
U2511 CAN - Data Mis-Match (Receive data does not match expected)
U2512 Missing message for Engine Speed
U2513 Missing message for Transmission Gear Selected
U2514 Missing message for Vehicle Speed
U2515 Missing message for Adaptive Cruise Control
U2516 CAN bus off - Transmit Error (Use DTC $C073 instead)
U2517 Reserved for Jaguar CAN Faults
U2518 Reserved for Jaguar CAN Faults
U2519 Reserved for Jaguar CAN Faults
U2520 Reserved for Jaguar CAN Faults
U2521 Reserved for Jaguar CAN Faults
U2522 Reserved for Jaguar CAN Faults
U2523 Reserved for Jaguar CAN Faults
U2524 Reserved for Jaguar CAN Faults
U2525 Reserved for Jaguar CAN Faults
U2526 Reserved for Jaguar CAN Faults
U2527 CAN network #2 bus off - Transmit Error
U2528 PRNDL Data Mismatch
U2600 (D2B) Wake-up Line Short to Batt
E600 - E765 Other and will start with D2B
U2601 (D2B) Wake-up Line Short to Ground
U2602 Fault DTC (CM): Incomplete ring-fault report received 9114
U2603 Incomplete ring- NO fault report received
U2604 Incomplete ring- corrupted fault report received
U2605 Master ECU unable to initialize it's address
U2606 Fault DTC (CM): Slave ECU unable to initialize it's address 9118
U2607 Fault DTC (CM): Slave switched into bypass mode 9119
U2609 D2B Wakeup pulse width out of spec
U2610 D2B slave ECU failed to receive a report position
U2611 D2B slave ECU failed to receive an alarm clear command
U2613 NAV Module Not Responding on D2B
U2614 AMP Module Not Responding on D2B
U2615 Rear Ent Module Not Responding on D2B
U2616 Left Front Tire Pressure Sensor is Not Responding
U2617 Right Front Tire Pressure Sensor is Not Responding
U2618 Left Rear Tire Pressure Sensor is Not Responding
U2619 Right Rear Tire Pressure Sensor is Not Responding
Tylko po co wierzyć anonimowemu kolesiowi w internecie........
mihowe jest offline   Odpowiedź z Cytatem
