04-05-2017, 15:40 | #1 |
Imię: Thierry Walterus
Zarejestrowany: 04-09-2016
Model: mondeo titanium 2015
Postów: 114
210 bhp map activated on my 150 bhp/210 bhp mapy aktywowane na moim 150 bhp
Yesterday, Some guy with UCDS has activated the 210 bhp-map on the 150 bhp mondeo.
What a difference! Wczoraj, jakiś facet z UCDS uruchomił 210 bhp mapę na 150 bhp mondeo. Co za różnica! |
04-05-2017, 16:53 | #2 |
Zarejestrowany: 29-08-2012
Model: Volvo V90 T8
Silnik: 2.0 T8 390KM
Postów: 468
Odp: 210 bhp map activated on my 150 bhp/210 bhp mapy aktywowane na moim 150 bhp
Have you been able to verify the actual power? I would be surprised if you actually get 210BHP without second turbo.
PS. Very good translation to polish. Google Translate has improved recently Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
1994 Peugeot 106 1.1 60KM -> 2003 Mazda 6 GY 1.8 120KM -> 2007 Ford Mondeo Mk4 1.8TDCi 125KM Titanium HB -> 2015 Ford Mondeo Mk5 2.0TDCi 150KM Titanium X Kombi -> 2019 Volvo V90 T8 Inscription 390KM |
04-05-2017, 17:22 | #3 |
Zarejestrowany: 01-05-2011
Model: Mondeo MK5 Titanium X Sport
Silnik: 2.0 TDCi 210 Bhp BiTurbo
Postów: 1,151
Are you sure is 210bhp not 180bhp? I though 210bhp is for twin turbo?
04-05-2017, 18:39 | #4 | ||
Postów: 114
Re: Odp: 210 bhp map activated on my 150 bhp/210 bhp mapy aktywowane na moim 150 bhp
I know I do not have the actual 210bhp, but it's close, very close. I can only verify it with a proper dyno-run. I have only one turbo, that's right, but the one I'm missing is the small one, for the lower revs, and this one is not that important to obtain the 210 bhp. Bump: Cytat:
all thouhg, the full 210 bhp is theoreticly, but in reality it is pretty close |
04-05-2017, 19:17 | #5 |
Model: Volvo V90 T8
Postów: 468
If I would be you, I would go for dyno-run to know how much power the car gained Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
04-05-2017, 19:38 | #6 |
Imię: Tomi
Zarejestrowany: 31-10-2005
Model: FUSION 4x4
Silnik: 2.0EB
Postów: 7,168
Moja zabawa z nawigacjami Moje mody we własnym aucie - C+/Tempomat/ACC/BLISS/CTA/CHIP/SYNC2>SYNC3 LOGA stacji Radiowych w SYNC3 bez wymiany ACMa Licznik USA na PL i inne zabawy |
04-05-2017, 19:40 | #7 |
Zarejestrowany: 23-10-2012
Silnik: 2.0 180KM-> ~205
Postów: 2,893
, you changed only a map, anything else?
, uprzedziłes mnie Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Trzeba być wytrwałym żeby się ze mną skontaktować, oczywiście nie gwarantuje to możliwości spotkania Ostatnio edytowane przez totek2 ; 04-05-2017 o 20:22 |
04-05-2017, 20:37 | #8 | ||
Postów: 114
Bump: Cytat:
Disabled 150 hp and enabled 210 hp (power rating 3) Have changed nothing else, yet. Planning to get another air filtre and maybe another MAF sensor Ostatnio edytowane przez beethoven ; 04-05-2017 o 20:56 |
05-05-2017, 15:00 | #9 |
Postów: 1,151
Szczerze powiem że wątpię aby w tym PCM siedziała mapa na 210 koni, przecież ten na podwójnej turbinie jak sama nazwa mówi jest inny?
With all respect, I really doubt if there is stored map in that PCM for 210bhp, as you can see the "twin turbo" clearly state that is a different engine. I'm not surprised that you are impressed with power, but that is the magic of turbo diesel, these 30bhp does make a difference.Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Is like with previous generation, when you switch map from 140 to 163 you could easily feel the difference, engine was more powerful from low revs etc. Just do the dyno test to convince yourself Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. |
05-05-2017, 15:56 | #10 | |
Postów: 114
Using UCDS, you can do a lot of things, as you know. There are some guys in Germany, who done the same, just disabled 150/180 hp-map & enabled power rating 3 (210 hp ) You have UCDS? See for yourself. I am convinced, either way. But I will do a dyno-run, some day. Off course, these are theoretical figures BUT my previous map (150bhp) was chipped already to 195bhp & 450 nm torque. The current map (210hp) does better, I can really feel it, good. So, in that point of view, performance has increased. Ostatnio edytowane przez beethoven ; 05-05-2017 o 16:33 |
