Stary 01-07-2010, 09:45   #11
grafmarr
Zarejestrowany: 30-04-2010
Model: Mondeo MKIV Kombi Ghia
Silnik: 2.5T
Postów: 209
Domyślnie Odp: Radio Sony, jaka wersja firmware?
Dla zainteresowanych podaję instrukcję (opublikowaną przez "dbeyzade" na fordmondeo.org) aktualizowania oprogramowania (firmware) systemów audio Sony.
Oczywiście w większości naszych ASO, jeśli zapytamy o taką możliwość, otrzymamy odpowiedź, że się nie da lub mamy brak odpowiedzi.
Oto instrukcja:
1. Obtain and record the audio unit keycode and preset radio frequencies.
2. Connect the IDS portable diagnostic unit to the vehicle and establish communication (VID the vehicle).
3. Select the <Toolbox> tab at the top of the screen.
4. Select the <Module Programming>.
Press the tick.
5. Select <Module Reprogramming>, then select <ACM>.
Press the tick.
6. Press the tick then enter the VIN if required.
7. Select <YES> to accept the calibration update.
8. IDS will now check the calibration level of the audio unit.
Select <YES> then press the tick.
9. NOTE: The audio unit display will go blank during this process.
• NOTE: If the calibration level is already at the latest level, IDS will display the message 'no later calibration is available'. This bulletin does not apply and further diagnosis will be necessary. For additional information, refer to Focus 2004.75 (07/2004-)/Focus C-MAX 2003.75 (06/2003-)/Mondeo 2001 (10/2000-) Workshop Manual Section 415-00, 415-00 Entertainment System - General Information - Diagnosis and Testing.
Follow the on screen instructions to program the audio unit.
10. Select the tick to confirm the calibration has loaded.
11. Follow the on screen instructions, ignoring the instruction to reprogram further modules.
12. Enter the preset radio frequencies.
13. Reprogramming is now complete. Run the <Self Test>. Clear any stored DTCs related to this concern and disconnect IDS from the vehicle.
grafmarr jest offline   Odpowiedź z Cytatem
Stary 01-07-2010, 22:15   #12
keisim
Avatar keisim
Zarejestrowany: 09-07-2007
Model: Audi A6 Allroad C8
Silnik: 3.0 TDI 349KM
Postów: 1,018
Niestety u mnie wyświetla brak dostępnych kalibracji...
Ford Mondeo TitaniumX MK4 2.0 TDCi kombi 2007 - w 2012 zmienił właściciela ale zostawił miłe wspomnienia
Audi A6 Allroad 55 TDI C8 2019 3.0 TDI + mod by MOTOTRONIK >> 393KM 830Nm
keisim jest offline   Odpowiedź z Cytatem
Stary 04-07-2010, 20:25   #13
Decybelq
Imię: Grzes
Zarejestrowany: 10-05-2010
Model: Ford Focus
Silnik: 1.6 TDCI 115KM
Postów: 50
Może ktoś to przetłumaczyć na zrozumiały dla laika język,
co trzeba mieć; jakie urządzenie, oprogramowanie,
gdzie wpiąć sie,
gdzie takie coś dostać
i opisać po koleji kroki.
Decybelq jest offline   Odpowiedź z Cytatem
Stary 06-07-2010, 10:07   #14
grafmarr
Silnik: 2.5T
Postów: 209
Trzeba mieć oprogramowanie IDS Forda oraz interfejs VCM do podłączenia się do samochodu w złącze diagnostyczne. W MKIV złącze znajduje się pod klapką schowka po lewej stronie kierownicy (w górnej części). Zestaw IDS/VCM to wydatek rzędu kilku do kilkunastu tysięcy zł (w zależności od rodzaju zestawu) i chyba nikt rozsądny nie kupi go prywatnie do zabawy. Chyba, że może jakaś forumowa zrzutka i wspólny zakup przez ok. 20-30 zainteresowanych osób. Moglibyśmy wtedy sami bez pomocy niekompetentnych ASO diagnozować i programować ustawienia w samochodzie.
@keisim: gdzie sprawdzałeś swoje radio i jaki jest jego typ? No i co najważniejsze, czy IDS miał zainstalowane wszystkie najnowsze pliki kalibracyjne?
Niestety w większości ASO jest tak, że mają IDS-a w takiej wersji jaką im dostarczono po zakupie (w najlepszym razie aktualizacje są robione raz w roku lub przy jakiejś okazji), a o tym, że oprogramowanie trzeba ciągle aktualizować nikt nie myśli. Najczęściej dlatego, że nikt za to nie jest odpowiedzialny, a nikt rozsądny sam sobie nie dodaje pracy.
Stary 12-10-2010, 13:00   #15
jendrekmak
Avatar jendrekmak
Zarejestrowany: 30-06-2008
Model: 2x Citroen C5 Aircross
Silnik: 1.6 PT Hybrid
Postów: 3,963
a może mi ktoś powiedzieć jaki jest kolor podświetlenia przycisków w Sony montowanym w MK4? wyświetlacz to widać ale rzadko są pokazane przyciski. wydaje mi się, że przyciski podświetlone są na biało ale szukam potwierdzenia.
Stary 12-10-2010, 13:32   #16
Pastoo
Imię: Mateusz
Zarejestrowany: 07-06-2009
Model: Kuga 2 FL/Octavia 3 RS
Silnik: 1.5EB/2.0TSI
Rocznik: 2019/2016
Postów: 519
Napisy przycisków są białe, ale podświetlenie jest czerwone.
Tutaj zdjęcie:
http://www.google.pl/imgres?imgurl=h...0&tx=131&ty=80
Pastoo pozdrawia
Pastoo jest offline   Odpowiedź z Cytatem
Stary 12-10-2010, 13:37   #17
jendrekmak
Avatar jendrekmak
Postów: 3,963
widziałem to zdjęcie ale u mnie podświetlenie wyglądało na wpadające lekko w czerwień (pomijam górne przyciski i wyświetlacz a chodzi mi głównie o boczne). chciałem się upewnić. dzięki
Stary 14-10-2010, 11:19   #18
jendrekmak
Avatar jendrekmak
Postów: 3,963
a czy ktoś ma w soniaku tuner DAB i odbiera sygnał testowy? bo ciężko jest znaleźć informację czy sony zamontowało tuner DAB czy DAB+ a sygnał testowy jest nadawany w DAB+ (ACC). testy są z PKiN Warszawie i RTON Wrocław/Żórawina i Wrocław Instytut Łączności
Czasy w strefie GMT +1. Teraz jest 07:45.
