05-03-2016, 20:17 | #1 |
Imię: Piotrek
Zarejestrowany: 04-03-2016
Model: Mondeo MK4 kombi
Postów: 8
Błędy w kompie, problem z czujnikami parkowania - potrzebny dobry elektromechanik
Witam drogich kolegów i koleżanki piszę z pewnymi tematami :
Błędy w silniku : -Kod Usterki Status B0001 - Driver's frontal stage 1 - deployment control General electrical failure - circuit resistance below threshold -Kod Usterki Status P0071 - Ambient air temperature sensor range/performance Algorithm based failure - signal plausibility failure -Nieobecny P0135 - O2 sensor heater circuit malfunction (bank 1 sensor 1) General electrical failure - circuit short to ground -Nieobecny -Kod Usterki Status C2003 - Steering wheel switch left module System internal failure - internal electronic failure Nieobecny B109B - Lampka tablicy rej estracyj nej General electrical failure - circuit short to battery or open Nieobecny U0010 - Medium speed CAN communication bus General electrical failure - circuit short to battery Obecne P0071 - Ambient air temperature sensor range/performance Algorithm based failure - signal plausibility failure Nieobecny P0135 - O2 sensor heater circuit malfunction (bank 1 sensor 1) General electrical failure - circuit short to ground Nieobecny B0001 - Driver's frontal stage 1 - deployment control General electrical failure - circuit resistance below threshold Obecne Kod Usterki Status U0184 - Lost communication with audio unit General failure information - no sub type information Obecne U0401 - Invalid data received from engine control module/powertrain control module Algorithm based failure - event information Obecne U0415 - Invalid data received from ABS control module Algorithm based failure - event information Obecne U0416 - Invalid data received from vehicle dynamics control module Algorithm based failure - event information Obecne U0422 - Invalid data received from the body control module Algorithm based failure - event information Obecne Dodatkowo problem z czujnikami parkowania z przodu i z tyłu, po wbiciu wstecznego tylko pisk.. tutaj albo naprawa albo elm by wejść w opcje i pozmieniać by tego dźwięku nie było. Kolejnym problemem jest czujnik doładowania turbiny, raz pojawił się błąd i awaryjny tryb silnika, czujnik został wyczyszczony itd teraz jest bez błędnie. Kolejna sprawa autoalarm prawdopodobnie coś jest nie tak, ponieważ zamykam auto a od środka można otworzyć drzwi bez problemowo. Dodatkowo brakuje mi kilku kostek bezpieczników z tyłu w bagażniku RC2 oraz RC1, RB2 chyba jest spalony. Ktoś potrafi ogarnąć w/w problemy? Potrzebowałbym jeszcze zmienić tryb pracy silnika z 140 na 163km, plus aktualizacja convers+ plus mapy do nawigacji do czytnika (niestety jest problem bo ponoć tylko oryginalne skrypty działają do uruchomienia navi) odległość obojętna wszędzie mogę zawitać, aczkolwiek wolałbym by ktoś był na miejscu ze względu na przyszłe naprawy. |
05-03-2016, 20:20 | #2 |
Moderator
Zarejestrowany: 17-02-2004
Model: Fiesta
Silnik: 1.4L Duratec 16V PFI
Rocznik: 3/2012 / 4/2011
Postów: 3,985
Odp: Błędy w kompie, problem z czujnikami parkowania - potrzebny dobry elektromechani
Proszę poprawić tytuł tematu.
Poradnik, czyli jak pisać zgodnie z zasadami panującymi na tym forum http://forum.fordclubpolska.org/showthread.php?t=145988
IDS |Forscan| UCDS - Doposażanie | Programownie sterowników | IMMO // WSZYSTKIE MODELE EUROPA-USA ZMIANA MOCY - MONTAŻ TEMPOMATU - SPOLSZCZENIA - NAWIGACJE - PRZERÓBKI LAMP |
