Stary 18-12-2009, 14:01   #1
prezes2117
Avatar prezes2117
Zarejestrowany: 13-12-2009
Postów: 16
Cool Rozklad i opis bezpiecznikow
Engine Bay Fuse Information
F1 - 30A - ABS.
F2 - 50A - Ignition Relay
F3 - 60A - Diesel Engine Heater
F4 - 30A - Heated Rear Window
F5 - 20A - Heated Seats (Facelift only)
F6 - 40A - Heater Blower Relay
F7 - 50A - Main Power
F8 - 60A - Engine Cooling, Pre-glow relay
F9 - 20A - PCM Relay
F10 - 40A - Engine Cooling
F11 - 30A - Heated Windscreen
F13 - 30A - Heated Windscreen
F15 - 3A - Heated Windscreen
F16 - 20A - LH Xenon Headlight - 7.5A - LH Halogen Headlight
F17 - 10A - Automatic Transmission
F18 - 20A - RH Xenon Headlight - 7.5A - RH Halogen Headlight
F20 - 20A - ABS
F21 - 15A - Light Switch
F22 - 20A - Headlight Cleaning Relay
F23 - 7.5A - Battery Backup Sounder ( petrol ) - 15A - Injection Relays, Booster Heater (diesel )
F24 - 20A - Central Timer Unit
F25 - 15A - Central Timer Unit
F26 - 20A - Horn Relay
F27 - 15A - Fuel Pump Relay, Windscreen Heater
F28 - 20A - Ignition Switch
F29 - 30A - Starter Relay
F30 - 7.5A - Alternator
F31 - 7.5A - Air Conditioning
F32 - 3A - Automatic Transmission, Engine Control Module
F33 - 7.5A - PCM Module Relay
F37 - 15A - Oxygen Sensor
F40 - 7.5A - Engine
F42 - 10A - Engine
Glovebox Fuse Information
F60 - 25A - Electric Windows
F61 - 25A - Electric Windows
F62 - 15A - Light Switch
F63 - 7.5A - Direction Indicators
F64 - 7.5A - Direction Indicators
F65 - 7.5A - Air Conditioning
F66 - 30A - Drivers Power Seat
F67 - 7.5A - Alarm
F68 - 15A - Cigarette Lighter
F69 - 7.5A - Radio, Instrument Cluster
F70 - 15A - RH Rear Power Point ( Estate Models )
F71 - 10A - Rear Seat Entertainment (Video Screens)
F72 - 20A - Radio
F73 - 20A - Sunroof
F74 - 20A - Trailer
F75 - 7.5A - Electric Mirrors
F76 - 7.5A - Air Conditioning
F77 - 7.5A - ABS, Traction Control
F78 - 7.5A - Instrument Cluster, Airbag
F80 - 7.5A - Automatic Transmission, Reverse Lights
F81 - 7.5A - Temperature Sensor, Automatic Transmission, Seat Sensor
F82 - 7.5A - Air Conditioning, Windscreen Washer Heater, Booster Heater, Cruise Control
F83 - 15A - Heated Seats
F84 - 20A - Light Switch
F85 - 7.5A - LH Headlight
F86 - 7.5A - RH Headlight
F88 - 15A - Low Beam Relay, Light Switch
F89 - 7.5A - Airbag
F90 - 15A - Rear Wiper Motor
F91 - 7.5A - Electric Windows, Dimming Mirror, Sunroof
F92 - 10A - Trailer
F93 - 10A - Headlights, Brake lights, Heater Blower
F94 - 20A - Wash/Wipe
F95 - 7.5A - Low Beam Headlights
F97 - 7.5A - License Plate Lights, Glove Box Light, Central Timer Unit
F98 - 7.5A - Electric Mirrors, Heated Mirrors
F99 - 7.5A - Interior Lights
F100 - 7.5A - Multimedia Module ( Inline fuse under the centre console - Pre facelift mondy )
F101 - 3A - CD Changer ( Under the passenger front seat - Pre facelift mondy )
2.0 TDCi 130 bhp
prezes2117 jest offline   Odpowiedź z Cytatem
Stary 23-12-2009, 20:19   #2
prezes2117
Avatar prezes2117
Postów: 16
Domyślnie Odp: Rozklad i opis bezpiecznikow
Moglby to ktorys moderator do garazu albo czegos w tym stylu wrzucic????
Dla potomnych by bylo Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
2.0 TDCi 130 bhp
Stary 23-12-2009, 21:19   #3
Zawika
Avatar Zawika
Zarejestrowany: 21-12-2006
Model: Mondeo Sedan Ghia
Silnik: 2.0 TDDI
Postów: 1,363
Napisał prezes2117 Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Takie rozpisanie był już dawno i po Polsku i w graficznej formie.
Wystarczy poszukać na forum.
POZDRAWIAM.
Zawika jest offline   Odpowiedź z Cytatem
Stary 23-12-2009, 22:45   #4
prezes2117
Avatar prezes2117
Postów: 16
O nie wiedzialem Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum..
Szukalem tego na forum ale nie moglem znalezc wiec wstawilem to Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
To nic, moze tez sie komus przyda Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
2.0 TDCi 130 bhp
Stary 23-12-2009, 23:42   #5
Zawika
Avatar Zawika
Silnik: 2.0 TDDI
Postów: 1,363
Przyda się, przyda... za kilka miesięcy ktoś znowu zapoda "dziewiczą" rozpiskę Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum..
POZDRAWIAM.
Stary 24-12-2009, 11:35   #6
Paleczny
Imię: Bartosz
Zarejestrowany: 03-08-2008
Model: Mondeo MK3
Postów: 37
od przybytku głowa nie boli...
Wesołych Świąt Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
__________________________________________________ ___
Gdynia - miasto seksu i biznesu
Problem z odszkodowaniem z OC sprawcy? POMOGĘ !!!!!
Paleczny jest offline   Odpowiedź z Cytatem
Stary 24-12-2009, 22:25   #7
Luk@s
Avatar Luk@s
Zarejestrowany: 11-01-2007
Silnik: 2.0 TDDI 90 KM
Postów: 1,151
Tylko, że moja łamana angielszczyzna mówi mi, że opis podany wyżej i ten który jest na forum są różne. No chyba, że ja znalazłem jeszcze jakiś inny opis bezpiecznikówGoście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Nie każda mo... pasuje do Forda
President Johnny II ASC + Sirio AS ML-145
Luk@s jest offline   Odpowiedź z Cytatem
Stary 25-12-2009, 13:10   #8
prezes2117
Avatar prezes2117
Postów: 16
Napisał Lukas22 Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Mozliwe, ze znalazles inna Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.. Ja porownalem ta z rozstawieniem bezpiecznikow u mnie i ich przypisem do danych funkcji i sie zgadza Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
WESOLYCH SWIAT!!!! Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
2.0 TDCi 130 bhp
Przeszukaj ten temat:
Zaawansowane wyszukiwanie
Czasy w strefie GMT +1. Teraz jest 13:46.
