Temat: [Mondeo 2007-2014] Afs
Stary 08-08-2009, 19:08   #2
TOMAS
Moderator
Avatar TOMAS
Imię: T O M A S
Zarejestrowany: 16-11-2008
Model: VW TIGUAN 2023 / Ford Fiesta 2022
Silnik: 2.0 TDI 150 KM / 1.1 75KM
Rocznik: 2023 / 2022
Postów: 2,754
Domyślnie Odp: Afs
1. W ksenonach są dodatkowe zarówki pełniące role doświetlenia zakrętów
2. Kolego znalazłem coś takiego w necie niestety albo stety Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. to zależy dla kogo Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Ford has successfully developed its very own Adaptive Front Lighting System (AFS) and has moved to incorporate this innovative piece of engineering into its new Mondeo model, allowing the vehicle to beam light around corners that could potentially alert the driver of upcoming obstacles which could not normally be seen from other standard headlamp equipped vehicles. The AFS system claims to improve visibility while negotiating tight bends courtesy of its halogen lamps that are linked to sensors which are smart enough to detect steering input, swiveling these lamps up to 15 degrees when required. Sounds like a pretty nifty feature to have in your vehicle while you are driving through curvaceous (and treacherous) roads that have nothing but your headlamps (and a little moonlight if you’re lucky) to guide you.
Not only does it help you reach your destination safer, the AFS system also makes it easier to see pedestrians, animals and other objects whenever you enter a bend, while reducing glare for oncoming drivers. To date, comparative tests between conventional halogen reflector lamps and AFS have shown that the latter actually casts an additional 10 meters of light into the bend, and when allied to static corner lighting, AFS greatly improves visibility.
The AFS system’s brains do not stop there, as it comes with static, low level cornering lights that will turn on automatically whenever the vehicle travels below 37mph (why that odd number, I’m not too sure. Probably some sort of research has been done to arrive at that figure), while the steering wheel must turn at an angle of at least 30 degrees. Sounds like a pretty nifty feature to have when you’re trying to avoid accidents in reduced visibility, being particularly useful when involved in tight maneuvers such as turning into driveways. If you’re interested, the new Ford Mondeo can also be equipped with Bi-Xenon lamps that come with static cornering lights, including automatic headlamp leveling and washer jets.
zródło: http://www.coolest-gadgets.com/20071...ghting-system/
Ford EcoSport ST-Line by Delta & Tomas
Był: Escort ghia mk7, C-max, Mondeo mk4 titanium, Transit mk7, Mondeo mk4 lift titanium, Focus mk1 lift ghia, Focus mk3 titanium, EcoSport ST Line + bajery
Został VW Tiguan 2023 i Fiesta 2022 oraz pod opieką B-max 2015 latorośli.
Tomas
Ostatnio edytowane przez TOMAS ; 08-08-2009 o 19:11
TOMAS jest offline   Odpowiedź z Cytatem
