Odp: 1.8 tdci na wyłączonym gorącym silniku błędy wtrysku i filtra
update
today i change the filter and test the car again . from idle to 120 km or 130 km run very good the problem is up and this problem apear with immediately start, so if i run the car with constant engine speed there is not problem olso if i superate 140 km or up.
