thanks redmann - the main issue is that radiaror fan is not working. I checked F8 fuse and relay and found no issue with them, then i to connect 12V directly to fan but nothing happened. There must be some issue with electric motor. I wanted to ask if someone managed to fix this motor or if there is some other type of electric motor for replacement. I don't wanna buy new fan set just because of failed electric motor.
i have got similiar fan -
http://ford-esklep.pl/index.php?prod...870&cat_id=631
