Odp: Diagnostyka VAG
Witam serdecznie. Proszę was o odczyt logów i ich analizę. Pozdrawiam serdecznie
Wednesday,14,December,2011,19:34:43:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 7M - VW Sharan
Scan: 25 01 02 03 08 09 15 16 17 18 19 22 29 36 37 39 45 46 55 56
76
Mileage: 187280km/116370miles
Address 01: Engine Labels: None
Part No: 038 906 019 LD
Component: 1,9l R4 EDC 0000SG 1595
Coding: 00002
Shop #: WSC 00020
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: Redir Fail!
Part No: 7M3 907 379 E
Component: ESP FRONT MK25 0102
Coding: 0006666
Shop #: WSC 00020 000 00000
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 7M5 907 049 D
Component: Klimabetaetigung 0404
Shop #: WSC 00000 000 00000
1 Fault Found:
00926 - Terminal 30
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: None
Part No: 7M3 962 258 AD
Component: Multifunkt.Einh 0001
Coding: 16393
Shop #: WSC 00000
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605
Component: 1D AIRBAG VW51 0L 0008
Coding: 12612
Shop #: WSC 00020
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 7Mx-920-xxx-17.lbl
Part No: 7M5 920 820 Q
Component: KOMBIINSTRUMENT VDO V59
Coding: 13101
Shop #: WSC 19411
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00020
End
