Nie wiem czy jest w Mondeo, jest w Fieście:
In the L mode, the car remains in the lowest possible gear for most responsive acceleration until the engine speed reaches the red line around 6000 RPM. We did few lamps of straight line sprints from 0 to 140 KMPH in the Fiesta and we found out that the L mode is surely sporty, but flooring the pedal is a quicker way as it does not rev all the way up to 6000 RPM, but close to 5000 RPM where the torque peaks (at 4500), so it gives you a better acceleration in D more with pedal floored rather than L mode. The L more in more useful for uphill climbs and places where the load on the car fluctuates because of bad weather, inclines and winds.
L jest w hybrydzie, wiem bo jeździłem na jeździe próbnej, ale nie testowałem akurat Lki
