Stary 01-08-2015, 12:00   #68
blazeyzem
Avatar blazeyzem
Imię: Błażej
Zarejestrowany: 19-10-2008
Model: Mondeo MK V Titanium White Platinium
Silnik: 2.0 EB 240hp -> 260hp AT + SYNC2 -> SYNC3
Postów: 103
Domyślnie Odp: Jaki to model nowa nawigacja 8 calowa ?
http://www.2gfusions.net/showthread.php?tid=346&page=3
EA5T-14D544-AB
ABOUT THIS SOFTWARE UPDATE
The latest SYNC update includes all of the improvements from previous updates, plus additional benefits, such as:
Language and Driving
Language support for UK English, EU Spanish, EU French, German, EU Portuguese, Italian, Dutch, Russian, Turkish, Swedish*, Polish*, and Australian English
Right-hand drive occupancy mode Navigation
Navigation
Map content for Europe and Australia/New Zealand regions
Traffic Message Channel (TMC) Support (Europe and other markets)
Mute button added to Navigation map screen
Estimated Time of Arrival instead of Time to Destination now displayed on map screen
GPS Coordinate entry (Europe only)
Hazard spot warnings
Radio
Digital Audio Broadcasting (DAB)
Radio Data System (RDS) support
*Only graphical text is supported for these languages. UK voice prompts are only supported with these languages.
INSTALLING THE SOFTWARE UPDATE IN YOUR VEHICLE
The installation of this update will take up to 30 minutes to complete.
Throughout the installation process, keep your engine running, not in accessory mode. Turning off your vehicle during the update installation will disrupt the process. Although your vehicle must be in park when you begin the installation process, you may drive your vehicle while the update is installing to SYNC.
If your vehicle is equipped with the Intelligent Access with Push Button Start feature, you will need to temporarily disable the Automatic Engine Idle Shutdown (AEIS) component before beginning the installation in order to prevent your vehicle from timing out and shutting off the engine before the software update is complete. To disable this feature, use your steering wheel controls to navigate to the Settings menu on your left-hand Instrument Cluster LCD display. From there, select Vehicle >Auto Engine Off >Off. (If you do not see this setting, there is no need to make any changes before starting the update.) Alternatively, after initiating the installation, you may drive the vehicle during the update process to avoid the engine shutting off. The AEIS will automatically reset to "On" the next time you start your vehicle.
Please note: During the update installation, SYNC will temporarily appear to not recognize your mobile phone or media device. This is normal.
When your system has been successfully updated, SYNC will display a notification saying, "Installation complete."
Date Confirmed:
Sep 23, 2014
Version:
Gen2 - V3.7.11
https://drive.google.com/file/d/0B_V...NfM2V1dEU/edit
Tutaj Gen2v3713build14122updatepackageNARev3
http://www.mediafire.com/download/79...kageNARev3.zip
Ostatnio edytowane przez blazeyzem ; 01-08-2015 o 12:53
blazeyzem jest offline   Odpowiedź z Cytatem
