No ja czekam ale ciagle nie ma.
Poniej fragment z dashcamtalk ukazujacy roznice miedzy kamerami A118 i A119. Troche sie obawiam zbyt waskiego FOV. Najlepiej jakby w miedzyczasie wyszlo cos od konkurencji. Mnie by interesowala kamera odpowiadajaca G90 lub Vantrue X2 ale w obudowie A119
At present I have the choice of:
1/ A118C >
bigger angle view, many reflections, not sure by who was made maybe in a garage, complicate and expensive GPS, 1 second overlap between videos
2/ A118C2 >
CPL will fit, smaller angle view (but better because you will see much more details), better components than A118, complicate and expensive GPS,, 1 second overlap between videos. Good if you dont want GPS and to be cheaper than A119.
3/ A119 >
CPL will fit, 1440p, cheaper than A119S, 160 degrees, no overlap between videos, the fastest removal from the windshield from any dashcam on the market
4/ A119S >
compared to A119: just 1080p 60fps, 120 degrees lens, better day/night video than any A11x model, a little more expensive
5/ DDPai Mini2 (sorry!) - I like the Time Lapse mode, but maybe A118/119 can do this too? >
I am not sure it is working as you expected because parking mode as you expect can be done by using 12V input, not 5V, because when input is for example 13V (running engine) camera will record normally and when is 12V (for example) camera will enter in parking mode. I answered in the other thread
