Temat: [Mondeo 2007-2014] Program konfiguracji - ELMconfig
Stary 17-02-2017, 22:56   #1523
Mruczus007
Zarejestrowany: 06-03-2013
Model: Mondeo MK4 seria 66
Silnik: 2.3 Duratec-HE 161KM, AWF21
Postów: 47
Domyślnie Odp: Program konfiguracji - ELMconfig
Wg opisu to taka:
"v4.2.4 - 2017/01/27
- CHG: Improved CAN Bus Off state handling by removing auto-recovery, now requiring protocol to be manually reopened in addition to the 128 occurances of 11 recessive bits, before transmitter will be reenabled
- CHG: Improved CAN Tx error handling, where the transmitter will back off even before reaching Bus Off state, minimizing impact on a bus in case the problem is on the scan tool side
- CHG: Improved CAN message printing when monitoring CAN bus in receive-all mode - there's now less data printed from previous messages if bus error occurs after DLC field is received
- CHG: Increased CAN default propagation segment to maximum possible to get closer to the implied ISO 15765-4 spec
- CHG: Added the ability to print RTR messages using ISO 11898 without requiring CAN auto-formatting turned off
- BUG: In rare instances, segmented CAN message transmission could get silently corrupted if one of the frames fails to transmit due to CAN bus errors
- BUG: In rare instances, when encountering certain CAN bus errors, an OBD request on a CAN protocol would never go out on the bus, returning NO DATA
- BUG: STPBR may set the baud rate to an incorrect value, when custom CAN timing registers are used (STPBRR will still return the actual baud rate that was set)
- BUG: STFBA, STFFCA, and STFPA may add incorrect filters when odd length filters are entered"
Po drodze (względem firmware, który jest w moim, niedawno zakupionym interface - v3.3.1, 2012/09/25) były jeszcze takie wersje firmware:
v4.2.0 - 2016/12/01
v4.1.2 - 2015/08/21
Ponieważ na stronie Viakena nie widzę żadnych firmware do tego chipsetu (pomimo informacji w opisie interface, że jest możliwość upgrade firmware), dlatego zadałem tutaj pytanie, czy ktoś coś wie na ten temat.
Swoją drogą, to jakie macie wersje oprogramowania w swoich kabelkach od Viakena (oczywiście tych na chipsecie STN1170)?
Mruczus007 jest offline   Odpowiedź z Cytatem
