Odp: Usterka układu silnika - EGR - jak wyłączyć komunikat?
Jedyny blad jaki mi wyskakuje, to:
Code: P1335 - EGR Position Sensor Minimum Stop Performance
Additional Fault Symptom:
- Signal is Below Minimum Threshold
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Diagnostic Trouble Code details
EGR Position Sensor B Minimum/Maximum Stop Performance
This DTC may be caused by :
Short circuit in wiring or component.
Check for a stuck or sticking EGR actuator.
EGR valve assembly
If the EGR actuator has been renewed initiate the EGR component parameter reset.
Wysłane z mojego HTC 10 przy użyciu Tapatalka
