Stary 05-06-2018, 13:05   #45
FM2014
Zarejestrowany: 17-03-2014
Model: Kuga ST-Line X FHEV AWD
Silnik: 2.5L, 183KM
Rocznik: 2025
Postów: 27
Domyślnie Odp: Czujniki ciśnienia w kołach i ich adaptacja
Znalazłem takie, może ktoś przetestuje:
Hey guys and girls. I came across a way to train new TPMS sensors. Use this if you're installing winter wheels/tires that have sensors already installed, or even if you are just doing a tire rotation. Not sure if this has been posted before. I tried searching but didn't see it posted anywhere. No need to go and buy the TPMS learning tool.
1) Make sure your tires are inflated to the recommended psi. Mine is 40psi.
2) Turn ignition to the on position. If you have a push button start, push the start button without pressing the brake pedal.
3) Push the hazard light button 6 times. The horn should honk and you should see "Train left front tire" in the LCD display between the tach and speedo.
4) Release air pressure in the front left tire until you hear the horn honk. The LCD display should now read "Train right front tire".
5) Release air pressure in the right front tire until you hear the horn honk.
6) Repeat for the the right rear tire, and then the left rear tire.
7) You should now see "Training Complete" in the LCD display.
Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Fill your tires back up to the recommended pressure.
Enjoy!
Mod Edit:
If the above does not work try this (2017+)
Quote:
Originally Posted by Zirnius View Post
I had an issue with the sequence to get into the TPMS training mode (hitting the hazard light button 6 times) in the first post not working on my focus.
I did find a method that worked, I'm not sure what the reason behind it is, did they change it for the newer model years? I have the 1.0L manual, without push button start.
Here's how I did it:
1. Starting with the ignition Off, press and release the brake pedal.
2. Turn the ignition from Off to On 3 times, ending in the On position.
3. Press the brake pedal again for about 2 seconds and release.
4. Turn the ignition back to off, then turn the ignition from Off to On 3 times, ending in the On position again.
If done correctly the car should honk and you can proceed the same way as the directions in the original post.
Maybe this will help someone else who is having trouble getting into the actual training mode.
a tak to wygląda https://www.youtube.com/watch?v=GuSvamjMzb8
FM2014 jest offline   Odpowiedź z Cytatem
