Temat: [Edge 2015- ] Filtr paliwa 2.0 Ecoboost
Stary 19-07-2018, 19:11   #5
leszek_ford
Imię: Leszek
Zarejestrowany: 16-02-2016
Model: Edge Titanium
Silnik: 3,5
Postów: 104
Domyślnie Odp: Filtr paliwa 2.0 Ecoboost
Z instrukcji do 2,0l:
AUTOMATIC TRANSMISSION
FLUID CHECK - 2.0L
ECOBOOST™
Note:Transmission fluid should be checked
by an authorized dealer. If required, fluid
should be added by an authorized dealer.
The automatic transmission does not have
a transmission fluid dipstick.
Have an authorized dealer check and
change the transmission fluid at the
correct service interval. See Scheduled
Maintenance (page 456). Your
transmission does not consume fluid.
However, the fluid level should be checked
if the transmission is not working properly,
(i.e., if the transmission slips or shifts
slowly) or if you notice some sign of fluid
leakage.
Do not use supplemental transmission
fluid additives, treatments or cleaning
agents. The use of these materials may
affect transmission operation and result
in damage to internal transmission
components.
leszek_ford jest offline   Odpowiedź z Cytatem
