Stary 17-10-2018, 22:41   #1541
leszcz
Avatar leszcz
Imię: Tomi
Zarejestrowany: 31-10-2005
Model: FUSION 4x4
Silnik: 2.0EB
Postów: 7,281
Domyślnie Odp: Nowa Nawigacja SYNC 3 - dyskusja , linki
@1222nap exactly . will be resuscitated very professionally.
It is unfortunate that other people are still discrediting here. And he thinks himself almighty and almighty.
Bump:
Napisał 1222nap Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
it will work with 2016 mustang? After as-built coding obviosly.
use a UCDS cable and load data using the DIRECT CONFIG option.
You must indicate that you have a navigation because in Mustang it was not from the factory.
After these actions you will have navigation: P
It is easy and everything will work as it should.
Moja zabawa z nawigacjami
