U mnie jest tak:
Recall Date: JUL 17, 2018
Recall Title: SHIFTER CABLE BUSHINGS
NHTSA Recall Number: 18V471
Ford Recall Number: 18S20
Recall Description: ON YOUR VEHICLE, THE BUSHING IN THE TRANSMISSION SHIFTER CABLE MAY DEGRADE OVER TIME. THIS MAY CAUSE THE TRANSMISSION SHIFTER CABLE TO NOT BE ABLE TO FULLY MOVE THE TRANSMISSION TO THE SELECTED GEAR POSITION.
Risk to Safety: IF THE DRIVER ATTEMPTS TO SHIFT TO PARK IN THIS CONDITION, THE TRANSMISSION MAY NOT BE IN THE PARK POSITION EVEN THOUGH THE SHIFTER POSITION INDICATES THE VEHICLE IS IN PARK, AND THE TRANSMISSION NOT IN PARK WARNING MAY NOT APPEAR.THIS COULD RESULT IN UNINTENDED VEHICLE MOVEMENT, INCREASING THE RISK OF INJURY OR CRASH.
Remedy Program: FORD MOTOR COMPANY HAS AUTHORIZED YOUR DEALER TO REPLACE THE TRANSMISSION SHIFTER CABLE BUSHING FREE OF CHARGE (PARTS AND LABOR).
Status: 11 - RECALL INCOMPLETE
Manufacturer Notes: TO CHECK FOR NON-SAFETY-RELATED PROGRAMS APPLICABLE TO YOUR VEHICLE, SEE
HTTP://WWW.FORD.COM/ OR CALL YOUR FORD DEALER.
Tylko kiedyś gdzieś czytałam, że w Polsce tego nie robią...
