Temat: [Focus 2014-2018] Reset BMS po zmianie akumulatora
Stary 17-01-2020, 20:29   #2
marey
Imię: Robert
Zarejestrowany: 20-07-2018
Model: Focus MK3 Panther Black Metalik
Silnik: 1.0 EcoBoost 125 KM
Postów: 150
Domyślnie Odp: Reset Bms (Focus 3 FL)
Procedura:
- Turn on the key without running the engine
- Turn on beam lights
- Press 5x the rear fog light button [is not switched on and off 5x, just press the button 5x]
- Press 3x press 3x hazard light button [the same, just press the button 3x]
- After that the battery light on the dashboard will flash
- Done!
marey jest online   Odpowiedź z Cytatem
