Odp: Modyfikacja fabrycznego audio
Podmienię jutro rca.
Dodatkowe przewody są wymagane tylko przy usuwaniu fabrycznego Sony DSP. Jak go nie było, to przewody są w wiązce.
If coming from the Sony amp you will need to add two wires to the ACM Harness (Pins 8, 21) and tap into the APIM Harness to connect those wires to the existing wires coming out of (Pins 3,4) respectively. This is not a requirement, but if these wires are not added then you will not have any Voice Navigation or Voice Command Prompts. These two wires are to hear the Female Sync Voice which were previously sent down to the Sony Amp. Ford Part Number: DU2Z-14474-CA
- Vehicles without the Sony amp (other than hybrid/energi) should already have these wires in place so this extra wiring step is not necessary.”
