Nikt?
Te bledy sie ciagle zdarzaja. Czasami pojade miesiac bez bledu. A czasami 3x dziennie.
Moze to nie blad pedaly gazu a blad czegos na drugiej stronie kabla?
Serwis ktoremu dosc wierze twierdzi ze u Focusow to by byl na 100% zespol zegarow. Ale w Mondeo nie slyszalem o takim przypadku.
Wymienilismy pedal gazu ale nie pomoglo.
Ciekawe ze blad wyskakuje zawsze z polaczeniu z Invalid Data z modulow ABS, CCMii. Przypuszczam ze te moduly juz tylkko reaguja na blad z PCM
Jakies sugestie?
Kod:
===PCM DTC P2138:00-2F===
Code: P2138 - Throttle/Pedal Position Sensor/Switch D/E Voltage Correlation
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Freeze Frame :
-GLOBTIM: 337711128 s - Global real time
-TOTDIST: 264962.0 km - Total Distance
-MAINECUV: 14.75 V - Main ECU voltage supply
-ESTSERUN: Yes - Engine status - engine running
-ESTSECRK: No - Engine status - engine in crank
-INCARTMP: 9 °C - In car temperature
-OUTTMP: 7 °C - External Temperature From Sensor
===END PCM DTC===
===OBDII DTC ===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC===
===SASM DTC ===
Module: Steering Angle Sensor Module
===END SASM DTC===
===CCMii DTC U0401:86-AF===
Code: U0401 - Invalid Data Received from ECM/PCM A
Additional Fault Symptom:
- Signal Invalid
Status:
- Malfunction Indicator Lamp is On for this DTC
Module: Cruise Control Module
===END CCMii DTC===
===CCMii DTC U0415:86-AF===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module A
- Signal Invalid
Status:
===END CCMii DTC===
===ABS DTC U0401:68-8A===
- Event Information
Status:
Module: Antilock braking system
===END ABS DTC===
===RCM DTC ===
Unable to read DTC
Module: Restraint Control Module
===END RCM DTC===
===HCM DTC ===
Module: Headlamp Control Module
===END HCM DTC===
===BCMii DTC ===
Module: Body Control Module
===END BCMii DTC===
