Temat: [Kuga 2020- ] Dziwne stuki po odpaleniu FHEV
Stary 21-12-2021, 09:32   #15
MrQ
Avatar MrQ
Imię: Qba
Zarejestrowany: 22-01-2011
Model: Ford Kuga
Silnik: 2.5 FHEV AWD
Postów: 136
Domyślnie Odp: Dziwne stuki po odpaleniu FHEV
W UK na forum też znalazłem sporo przypadków. Też serwis ich odsyła z niczym. Ja odebrałem auto nie naprawione. "Mam obserwować". Zostaje raczej pisanie do Ford Polska żeby sie określili chociaż co to za usterka i kiedy będzie akcja serwisowa.
Bump: Znalazłem na zagrnicznym forum. Ten sam problem co u nas i te same stuki
"They finally released a TSB on this.
TECHNICAL SERVICE BULLETIN
HF45 Transmission - Rattle Noise On Cold Start - Built On Or Before 01-Apr-2021
21-2129
26 April 2021
Model:
Ford
2020-2021 Escape Transmission/Transaxle: (H4F45)
Issue: Some 2020-2021 Escape vehicles equipped with a HF45 transmission may exhibit a rattle noise on cold start up only when the engine is running. This noise may be more prevalent in cold weather conditions, typically at or below 0°C (32°F). This may be due to the software in the secondary on-board diagnostic control module C (SOBDMC). To correct this condition, follow the Service Procedure steps to reprogram the SOBDMC.
Action: Follow the Service Procedure steps to correct the condition on vehicles that meet all of the following criteria:
2020-2021 Escape
Built on or before 01-Apr-2021
Rattle noise on cold start up only when the engine is running
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
Description Operation No. Time
2020-2021 Escape HF45 Transmission: Reprogram The Appropriate Modules As Required By The Software Update And Service Procedure (Do Not Use With Any Other Labor Operations)
MT212129
Actual Time
Repair/Claim Coding
Causal Part: RECAL
Condition Code: 04
Service Procedure
1. Reprogram the PCM using the latest software level of the appropriate Ford diagnostic scan tool.
2. Check the availability for software updates on the following modules (if equipped) and update as required:
(1). Secondary on-board diagnostic control module (SOBDM)
(2). Battery energy control module (BECM)
(3). Secondary on-board diagnostic control module B (SOBDMB)
(4). Secondary on-board diagnostic control module C (SOBDMC)
(5). Anti-lock brake system (ABS) module
NOTE: Only one module may be updated at a time."
https://www.fordescape.org/threads/m....116456/page-3
"The dealer called yesterday with the latest. Ford said they don't have a fix for this problem and told the dealer to remove the transmission and ship it to Ford for examination so they can develop a repair procedure. Ford also authorized a new transmission for our Escape but with shipping and all the work needed it will be another week before we get the vehicle back."
Z tego co piszą to aktualizacja TSB czasami coś daje ale w niskich temperaturach problem pozostał. Napisałem do Ford Polska ale nie licze na jakieś konkrety skoro problem jest nie rozwiązany od ponad roku. Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Ostatnio edytowane przez MrQ ; 21-12-2021 o 10:23 Powód: link
MrQ jest offline   Odpowiedź z Cytatem
