Stary 01-04-2023, 11:03   #185
EW1
Imię: Mariusz
Zarejestrowany: 19-07-2014
Model: jeszcze focus mk2 GHIA ale już jest fusion 2016 se 2.0 EcoBoost
Silnik: 2.0 tdci , 2.0 EcoBoost
Rocznik: 2006 , 2016
Postów: 1,408
Domyślnie Odp: Konwersja z 4.2" (SYNC) na 8" (SYNC2/3)
Zapożyczone z tabelki kodowania F150 W/g tego masz "D" a powinno chyba być "9"
Kod:
727-01-01	*xxx	xxxx	xxxx
Internal SDARS & APIM type (gen1/gen2) & EFP (CAN/LIN) & APIM
				1=Int SDARS enabled & APIM gen2 & EFP CAN based & APIM available	8=Int SDARS disabled & APIM gen2 & EFP CAN based & APIM not available
				0=Int SDARS enabled & APIM gen2 & EFP CAN based & APIM not available	9=Int SDARS disabled & APIM gen2 & EFP CAN based & APIM available
				2=Int SDARS enabled & APIM gen2 & EFP LIN based & APIM not available	A=Int SDARS disabled & APIM gen2 & EFP LIN based & APIM not available
				3=Int SDARS enabled & APIM gen2 & EFP LIN based & APIM available	B=Int SDARS disabled & APIM gen2 & EFP LIN based & APIM available
				4=Int SDARS enabled & APIM gen1 & EFP CAN based & APIM not available	C=Int SDARS disabled & APIM gen1 & EFP CAN based & APIM not available
				5=Int SDARS enabled & APIM gen1 & EFP CAN based & APIM available	D=Int SDARS disabled & APIM gen1 & EFP CAN based & APIM available
				6=Int SDARS enabled & APIM gen1 & EFP LIN based & APIM not available	E=Int SDARS disabled & APIM gen1 & EFP LIN based & APIM not available
				7=Int SDARS enabled & APIM gen1 & EFP LIN based & APIM not available	F=Int SDARS disabled & APIM gen1 & EFP LIN based & APIM available
EW1 jest offline   Odpowiedź z Cytatem
