Rozumiem że nie ma co szukać problemu i trafiłem po prostu na usterkę zwaną TSB 22-2229, czyli wyciek płynu do cylindra?
Czym różni się nowa poprawiona głowica od starej?
Summary
This article supersedes TSB 22-2133 to update the Parts List.
Issue: Some 2015-2018 Edge and 2017-2019 Fusion/MKZ/Escape/MKC vehicles equipped with a 2.0L EcoBoost engine may exhibit a low coolant level, white exhaust smoke and/or a runs rough condition with or without an illuminated malfunction indicator lamp (MIL). Diagnostic trouble codes (DTCs) may include P0300, P0301-P0304, P0316, P0217, P1285 and/or P1299 stored in powertrain control module (PCM). This may be due to coolant intrusion into the cylinder. To correct the condition, follow the Service Procedure to replace the long block engine assembly.
