Temat: [Focus 1998-2004] Montaż oryginalnego pilota do radia
Stary 25-02-2025, 14:25   #26
sergioalexs
Imię: Sérgio
Zarejestrowany: 24-02-2025
Model: Ford Focus
Silnik: 1.8 TDCi
Smile Re: Odp: Czy ktoś wie jak zdemontować pilota do radia z kierownicy?
Napisał damianisko5 Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Just for a moment. maybe this will give you an idea.
Look this https://www.youtube.com/watch?v=mcsBVDwtmsw
or https://www.youtube.com/watch?v=ppnucl9d74s
Thanks for your answer, @damianisko5 .
The first video is for the removal of the radio remote control, which is very easy and I already managed to do.
It seems the second is using an interface adapter module to convert the radio remote control resistors' values to the ones of the aftermarket radio, which is what I want to avoid... What I need to do is take out the circuit board of the remote control, so that I can change the resistor values to the ones that the aftermarket radio recognizes, as shown in the previous PDF file made by a member of this forum I attached.
By the way, the radio I want to instal lis the Pioneer MVH-S520BT: https://pioneer-car.eu/mvh-s520bt/mvh-s520bt
The diagram of the car remote control is this:
And the one of the Pioneer radio is this one:
Thank you.
sergioalexs jest offline   Odpowiedź z Cytatem
