Odp: Wartości luzów zaworowych i regulacja 2.0 Ti-VCT
Valve Clearance Check
Refer to: Valve Cover (303-01A Engine - 2.0L Duratec-HE (125kW/170PS) - MI4, Removal and Installation).
NOTE: Turn the engine clockwise only, and only use the crankshaft bolt.
NOTE: Before removing the camshafts, measure the clearance of each valve at base circle, with the lobe pointed away from the tappet. Failure to measure all clearances prior to removing the camshafts will necessitate repeated removal and installation and wasted labor time.
Measure the clearance of each valve and record its location. A midrange clearance is the most desirable.
General Equipment : Feeler Gauge
NOTE: The number on the valve tappet reflects the thickness of the valve tappet. For example, a tappet with the number 3.310 has the thickness of 3.31 mm (0.1303 in).
Intake: 0.23 mm (0.0091 in) - 0.33 mm (0.0130 in).
Exhaust: 0.31 mm (0.0122 in) - 0.41 mm (0.0161 in).
If any of the valve clearances are out of specification, select new tappets using this formula: tappet thickness = measured clearance + the base tappet thickness - most desirable thickness. Select the tappets and mark the installation location.
If any tappets do not measure within specifications, install new tappets in these locations.
Refer to: Valve Tappets (303-01A Engine - 2.0L Duratec-HE (125kW/170PS) - MI4, Removal and Installation).
Bump:
Bump: Adjunto archivo traducido automaticamente
