Stary 16-12-2025, 15:11   #37
teiksef
Zarejestrowany: 08-06-2023
Model: Escape
Postów: 387
Domyślnie Odp: Adaptacja/kalibracja skrzyni biegów 8F....
Ten Typ Tak Ma, proszę nie regulować odbiorników:
The 2019-2021 Edges had really rough shifting 8-speeds from the factory. Lots of surging and bucking in the first 3 gears. There were multiple TSB’s going all the way up to 2022 for PCM reflashes to address these issues. People with ford edges constantly ask if this update is worth it. I am showing that the latest one completely takes 2 out of the equation whether you baby it or gun it. Manual shifting is the only way now. (link)
Ford altered the shift parameters of the transmission in such a way that the second gear is no longer part of the vehicle's regular operation. The move essentially cuts out the second gear via software. (2021 Ford Edge ST Gains 'New' 7-Speed Automatic Transmission: Exclusive)
Zapewne drugi bieg "wypadł" z tym lub którymś z podobnych TSB: 21-2081.
teiksef jest offline   Odpowiedź z Cytatem
