To może przypomnę:
https://media.ford.com/content/fordm...nce-recal.html
In the affected vehicles, a lack of coolant circulation could cause an engine to overheat, resulting in a crack in the cylinder head. A cracked cylinder head can result in a pressurized oil leak. Oil that comes into contact with a hot engine surface increases the risk of a fire in the engine compartment.
Przeczytaj to zrozumieniem co jest następstwem czego.
