![]() Zarejestrowany: 07-07-2009
Model: Focus MK2
Silnik: 1.6 TDCI (109KM)
Postów: 2,165
Szukając czegoś o moim problemie z dławieniem, znalazłem coś takiego jak Ford Special Service Message.
Może się komuś przydać, bo ciekawe rzeczy tu wypisują. Według mnie the best jest: SSM 5310 :-) Latest Update 11/04/2008 *** NEW C-MAX TIPS & TRICKS *** If you want me to add one, PM me. Nick Door Window Motor Initialization WARNING: The door window anti-trap function will not operate during the door window motor initialization procedure. Make sure that the door window opening is free of all foreign material. Failure to follow this instruction may result in personal injury. Note: After the battery has been disconnected it is necessary to initialize each door window motor separately. Note: If a single door window motor has been disconnected, it is necessary to initialize that door window motor. Note: If the fuse for a front or rear door window motor has been disconnected, it is necessary to initialize that door window motor. Note: If the battery junction box (BJB) fuse for the front power windows has been disconnected, it is necessary to initialize both front door window motors. Note: If the battery junction box (BJB) fuse for the rear power windows has been disconnected, it is necessary to initialize both rear door window motors. Note: Leave a period of at least one minute before connecting the battery, fuse or door window motor(s). 1. Press and hold the power window control switch close button until the door window is fully closed. 2. Release the power window control switch close button and press again for three seconds. 3. Briefly press the power window control switch open button to the second detent and release the button. The door window should open automatically. 4. Briefly press the power window control switch close button to the second detent and release the button. If the door window does not close automatically, repeat the complete procedure. 5. Repeat the door window motor initialization for each door window motor. ***Ford known fixes*** Subject/Concern: Ticking noise from B-pillar when driving / cornering on rough roads Model: Focus C-MAX 2003.75 (06/2003–) Build Date: 01.06.2003 Onwards Build Code: 3Y Onwards Focus 2004.75 (07/2004–) - only 5-door and wagon Build Date: 07/2004 Onwards Build Code: 4D Onwards Markets: All Section: 501-25G Summary Should a customer express concern that there is ticking noise from the B-pillar, in the area of the opening for the front safety belt, when driving / cornering on rough roads, the probable cause is the sheet metal sticking between the B-pillar panel spot welding points. The noise is generated by the sheet metal breaking away from the spot welds between the panel. In general this noise can only be heard/recognised on the driver or the passenger side. To rectify this concern, the dip-primer between the B-pillar spot panel welding points should be "cracked" with the use of the weaker plastic side of the wheel brace (part of the vehicle tools). To prevent further sticking of the sheet metals between the B-pillar panel spot welding points, multi-function spray should be applied to the reworked areas. CAUTION: Make sure that only the weaker plastic side of the wheel brace is used. The use of any metal object may cause damage to the paint surface (especially when slipping down). Parts Required Description Finis Code Quantity Multi-function spray (200 ml) 1 321 554 1 Labor Time Operation Description Operation No. Time B-Pillar Trim Panel - Remove And Install (Upper) 43 614 0 - B-Pillar Trim Panel - Remove And Install (Lower) 43 617 1 - Cracking The Dip-Primer Between The B-Pillar Panel Spot Welding Points (One Side) - additional 0,2 hours Repair/Claim Coding Causal Part: 00012 RH; 00013 LH ACES Condition Code: 41 OASIS 702100, 702300 Service Instruction See Summary. 1. Remove the wheel brace which is located under the spare wheel in the luggage compartment. 2. Remove the B-Pillar trim panel (lower and upper). For additional information, refer to Focus 2004.75 / Focus C-MAX 2003.75 Workshop Manual Section 501-05. 1. Rear door opening weatherstrip 2. Front scuff plate trim panel 3. Front door opening weatherstrip 4. B-pillar upper trim panel retaining screws cover 5. B-pillar upper trim panel retaining screws 6. Front safety belt lower anchor 7. Upper B-pillar trim panel 8. Lower B-pillar trim panel retaining clips 9. Lower B-pillar trim panel 10. Lower B-pillar trim panel retaining clips 3. CAUTION: Only use the weaker plastic side of the wheel brace. Crack the dip-primer between the B-pillar panels at the rear door opening. Move the weaker plastic side of the wheel brace (part of the vehicle tools) into the gaps between the sheet panel. • NOTE: There could be areas at the B-pillar were no sticking of the sheet metal exists and accordingly no audible "cracking" noise can be heard. In these areas no further action is required. Carefully push the tool, by hand, into the gap until an audible "cracking" noise can be heard. Repeat this for all other gaps on both sides (middle/outer panel and middle/inner panel) between the lock striker and the front safety belt fixing point. 4. Repeat the previous step for the same areas of the B-pillar at the front door opening. 5. Unroll the safety belt fully from the front safety belt retractor. Fix the safety belt to the head restraint. Cover the safety belt retractor with a clean cloth to avoid any contamination. 6. CAUTION: Do not contaminate the safety belt. Apply multi-function spray (see Parts Required): Into the opened gaps between the sheet panel of the B-pillar. • NOTE: Direction of spraying. Spray the multi-function spray in the direction of the arrows into the marked holes. 7. To install all other components, reverse the removal procedure. E58153 Battery Discharging Subject/Concern: Power loss; engine difficult to start or does not start (fault code P0380 is set); battery discharged Model: Focus C-MAX 2003.75 (06/2003–) Engine: 1.6L Duratorq-TDCi (DV) Diesel Engine: 2.0L Duratorq-TDCi (DW) Diesel Focus 2004.75 (07/2004–) Engine: 1.6L Duratorq-TDCi (DV) Diesel Engine: 2.0L Duratorq-TDCi (DW) Diesel Markets: All Section: 303-07 Summary Should a customer express concern regarding power loss or that the engine is difficult to start or does not start at all or that the battery becomes discharged and if fault code P0380 is set, the probable cause is a damaged glow plug relay due to water ingress via the ground cable in the wiring harness to the glow plug relay. To rectify the concern, a new glow plug relay and a modified wiring harness from the engine compartment fuse box to the glow plug relay should be installed. Parts Required Description Finis Code Quantity Glow plug relay 1 252 609 1 Glow plug relay repair wiring harness 1 363 580 1 Solder/crimp connectors locally procured - Cable ties locally procured - Labor Time Operation Description Operation No. Time WDS Vehicle Connection/Communication 29 099 0 - Stored Fault Codes - Read Out - additional 0.1 hours Headlamp Assembly - Remove And Install (One Side) 32 115 1 - Engine Undershield - Remove and Install 21 130 4 - Glow Plug Relay And Glow Plug Relay Wiring Harness - Renew - additional 0.8 hours Repair/Claim Coding Causal Part: Finis Code for glow plug relay ACES Condition Code: 49 OASIS 203000, 203100, 603300, 607000, 614000 Service Information Glow plug relay repair wiring harness 19145 - FOCUS / C-MAX 2.0 TDCI - DTC P0002/P0089 SOME FOCUS AND C-MAX 2.0 TDCI PRODUCED UNTIL JAN 2006 MAY EXHIBIT THE MIL ILLUMINATED AND VARIOUS DRIVEABILITY CONCERNS WITH DTC P0002 (FUEL VOLUME REGULATOR CONTROL CIRCUIT RANGE/PERFORMANCE) AND/OR DTC P0089 (FUEL PRESSURE REGULATOR PERFORMANCE)PRESENT. TO RECTIFY, REPROGRAM THE PCM WITH THE APPROPRIATE NEW CALIBRATION AVAILABLE IN SERVICE FROM WDS CD B42 ONWARDS (REVISED CALIBRATION'S ARE:3M51-12A650-AD; 3M51-12A650-NG; 3M5A- 12A650-HT; 4M51-12A650-ZG; 5M51-12A650-MD; 6M51-12A650-TD; 6M51-12A650-UD; 6M51-12A650-HC) EFFECTIVE DATE: 27/03/2006 19013 - NEW FOCUS/C-MAX 2.0 TDCI - DTC P1412/P0490/P1335 CONTINUING OF SSM 18859. DO NOT REPLACE THE EGR COOLER UNLESS THERE IS DIRECT EVIDENCE OF COOLER FAILURE, EVEN IF THE DEPOSITS ON THE EGR VALVE LEADS TO SUCH A CONCLUSION. A NEW DESIGNED EGR VALVE TO OVERCOME THIS LEVEL OF DEPOSITS WILL BE AVAILABLE SOON AND YOU'LL BE INFORMED WITH A SEPERATE OASIS MESSAGE. PLEASE BE ALSO REMINDED THAT THE USE OF BIO DIESEL FOR ALL FORD DIESEL ENGINES (MORE THAN 5% WHICH ARE BASICALLY PART OF DIESEL FUEL) IS NOT ALLOWED AND WILL INVALIDATE WARRANTY. IT CAN LEAD TO THIS KIND OF FAILURE ON THE EGR VALVE. EFFECTIVE DATE: 23/01/2006 18859 - NEW FOCUS/C-MAX 2.0 TDCI - DTC P1412/P0490/P1335 SOME NEW FOCUS/C-MAX 2.0L TDCI MAY EXHIBIT POOR START; ROUGH IDLE OR LOSS OF POWER WITH DTC: P1412 (EGR FROZEN); P0490 (EGR CONTROL CIRCUIT HIGH) OR P1335 (EGR POSITION SENSOR MIN/MAX STOP PERFORMANCE) PRESENT. IF SO REPROGRAM THE PCM WITH THE APPROPRIATE NEW CALIBRATION AVAILABLE IN SERVICE FROM WDS CD B39A ONWARDS (REVISED PCM PART NO.: 3M51-12A650-AC; 3M51-12A650-NF; 3M51- 12A650-HS; 4M51-12A650-ZF; 5M51-12A650-MC) AND FOLLOWING ALL THE ON SCREEN INSTRUCTION INCLUDING RESETTING THE EGR VALVE. IF ANY CODES ARE STILL PRESENT AFTER ROAD TEST FOLLOW THE DIAGNOSTIC PROCEDURES FOR THAT CODE. SHOULD A REPLACEMENT EGR VALVE STILL BE REQUIRED THE NEW VALVE MUST STILL BE RESET TO THE PCM USING WDS. THIS FUNCTION IS FOUND IN TOOLBOX, POWERTRAIN, SERVICE FUNCTIONS, COMPONENT/PARAMETER RESET. EFFECTIVE DATE: 03/10/2005 18502 - NEW FOCUS / C-MAX TDCI - DTC P0089 OR P0002 IF DURING A WDS DIAGNOSIS ON A NEW FOCUS OR FOCUS C-MAX WITH TDCI - DIESEL ENGINE, THE DTC'S: P0089 (PCV/VCV CONTROL AT MINIMUM OR MAXIMUM VALUE) OR P0002 (VCV OUTSIDE ADAPTIVE RANGE, FUEL FLOW IS LOW) IS SET, PRIOR TO MAKING ANY HARDWARE CHANGE ON THE ENGINE SUCH AS FUEL PUMP, VERIFY THAT THE FUEL LINES ARE CLEAR AND FREE FROM BLOCKAGES/KINKS FROM THE DDM IN THE FUEL TANK, RIGHT THROUGH TO THE FUEL PUMP INLET ON THE ENGINE.A FEW CASES WERE REPORTED WHERE, DUE TO CUSTOMER MISS-USE, THE PLASTIC INSERT IN THE UPPER FILLER NECK GOT DAMAGED. A DAMAGED PLASTIC INSERT CAN BE EASILY DETECTED BY VISUALLY INSPECTING THE INSIDE OF THE FILLER NECK WHEN THE FILLER CAP IS REMOVED. VISUAL SIGNS ARE A DEFORMED METAL FLAP OR CRACKS IN THE PLASTIC MATERIAL. EFFECTIVE DATE: 23/03/2005 18429 - NEW FOCUS / C-MAX 2.0 TDCI - DTC P0089 OR P0002 IF DURING A WDS DIAGNOSIS ON A NEW FOCUS OR FOCUS C-MAX EQUIPPED WITH 2.0 TDCI, THE DTC'S : P0089 (PCV/VCV CONTROL AT MINIMUM OR MAXIMUM VALUE) OR P0002 (VCV OUTSIDE ADAPTIVE RANGE, FUEL FLOW IS LOW) IS SET, PRIOR TO MAKING ANY HARDWARE CHANGE ON THE ENGINE SUCH AS FUEL PUMP, VERIFY THAT THE FUEL LINES ARE CLEAR AND FREE FROM BLOCKAGES/KINKS FROM THE DDM IN THE FUEL TANK, RIGHT THROUGHTO THE FUEL PUMP INLET ON THE ENGINE. EFFECTIVE DATE: 22/02/2005 17898 - FOCUS C-MAX - CLUSTER WARNING LIGHTS ON. FOCUS C-MAX ALL EXCEPT 1.6 PETROL ENGINE - ALL INSTRUMENT CLUSTER WARNING LIGHTS ERRATIC READING AND ENGINE LOSS OF POWER/NO START. THIS CAN BE CAUSED BY AN INTERRUPTION OF THE CAN BUS VIA THE ELECTRO- HYDRAULIC POWER ASSISTED STEERING (EHPAS) UNIT. TO VERIFY, PLEASE DISCONNECT THE WIRING CONNECTOR OF THE EHPAS UNIT AND CHECK WHETHER ALL SYMPTOMS ARE STILL PRESENT. IF THE CONCERN CANNOT BE REPRODUCED WITH THE EHPAS UNIT DISCONNECTED, THEN CONTACT THE EHPAS PRE-APPROVAL HELPDESK FOR ASSISTANCE BEFORE REPLACING ANY PARTS EFFECTIVE DATE: 29/06/2004 TECHNICAL SERVICE BULLETINS : 017/2005 FOCUS C-MAX 2003.75 AND FOCUS 2004.75 WITH 1.6/2.0L DURATORQ-TDCI (DV) DIESEL: POWER LOSS; ENGINE DIFFICULT TO START OR DOES NOT START (DTC P0380 STORED); ENGINE UNDERSHOOTS TO ASTOP; BATTERY DISCHARGED EFFECTIVE DATE: 16/03/2005 ____________________________________ 607400 - DRIVEABILITY STALLS/QUITS AT IDLE SPECIAL SERVICE MESSAGES : 18715 - C-MAX 1.8 DURATEC 120 / 125PS - POOR PULL AWAY SOME FOCUS C-MAX EQUIPPED WITH 1.8 DURATEC HE 120 AND 125 PS, MAY EXHIBIT POOR PULL AWAY WHEN THE AIR CONDITIONING IS ON AND THE AMBIENT TEMPERATURE IS ABOVE 20�C. TO RECTIFY THIS, REPROGRAMM THE PCM WITH THE LATEST LEVEL CALIBRATION WHICH IS ON WDS CD38 ONWARDS. PCM PART NO.: 5M51-12A650-RC FOR 125 PS AND 3M51-12A650-GF FOR 120 PS ) EFFECTIVE DATE: 06/07/2005 SSM 19168 EFFECTIVE DATE: 18/04/2006 FOCUS AND C-MAX - INTERMITTENT ELECTRICAL CONCERNS SOME FOCUS AND C-MAX MAY EXHIBIT INTERMITTET ELECTRICAL CONCERNS, FOR EXAMPLE, WIPER PARKED IN MIDDLE POSITION; CLUSTER WARNING LIGHTS ON; RADIO INTERFERENCE OR ENGINE WON'T CRANK. BEFORE STARTING A DIAGNOSIS WITH WDS OR EXCHANGING ANY HARDWARE IT IS ESSENTIAL TO ENSURE SECURE B+ CONNECTIONS (3 OF): 1) NUT M6 (1-OF), FIXING OF B+ CLAMP TO BATTERY POLE: 5,4NM +/- 0.8. 2) NUT M8 (2-OF), FIXING OF B+ CABLES TO BATTERY CLAMP: 15NM +/- 2.3-. TSB 7/2006 Subject/Concern: Hesitations; Poor or no start; Deteriorated fuel economy; Diagnostic trouble codes (DTC) P1412, P0490 and P1335 stored Model: Focus C-MAX 2003.75 (06/2003�) Build Date: 14.02.2004-01.03.2006 Build Code: 4R-6S Assembly Plant: Saarlouis Engine: 2.0L Duratorq-TDCi (DW) Diesel Focus 2004.75 (07/2004�) Build Date: Up to 01.03.2006 Build Code: Up to 6S Assembly Plant: Saarlouis Assembly Plant: Valencia Engine: 2.0L Duratorq-TDCi (DW) Diesel Markets: All Section: 303-08 Summary Should a customer express concern about one of the following: * hesitations, * poor or no start, * deteriorated fuel economy, and upon investigation diagnostic trouble codes (DTC) P1412, P0490 and P1335 are stored in the powertrain control module (PCM), the probable cause is a sticky exhaust gas recirculation (EGR) valve. To rectify this concern, a new EGR valve with a stronger EGR valve motor and revised PCM calibration should be installed. � NOTE: Use CD-42 or a later version. TSB 5/2006 Subject/Concern: Inaccurate fuel gauge and inaccurate trip computer (if equipped) SSM 19013 EFFECTIVE DATE: 23/01/2006 NEW FOCUS/C-MAX 2.0 TDCI - DTC P1412/P0490/P1335 CONTINUING OF SSM 18859. DO NOT REPLACE THE EGR COOLER UNLESS THERE IS DIRECT EVIDENCE OF COOLER FAILURE, EVEN IF THE DEPOSITS ON THE EGR VALVE LEADS TO SUCH A CONCLUSION. A NEW DESIGNED EGR VALVE TO OVERCOME THIS LEVEL OF DEPOSITS WILL BE AVAILABLE SOON AND YOU'LL BE INFORMED WITH A SEPERATE OASIS MESSAGE. PLEASE BE ALSO REMINDED THAT THE USE OF BIO DIESEL FOR ALL FORD DIESEL ENGINES (MORE THAN 5% WHICH ARE BASICALLY PART OF DIESEL FUEL) IS NOT ALLOWED AND WILL INVALIDATE WARRANTY. IT CAN LEAD TO THIS KIND OF FAILURE ON THE EGR VALVE. SSM 18859 EFFECTIVE DATE: 03/10/2005 NEW FOCUS/C-MAX 2.0 TDCI - DTC P1412/P0490/P1335 SOME NEW FOCUS/C-MAX 2.0L TDCI MAY EXHIBIT POOR START; ROUGH IDLE OR LOSS OF POWER WITH DTC: P1412 (EGR FROZEN); P0490 (EGR CONTROL CIRCUIT HIGH) OR P1335 (EGR POSITION SENSOR MIN/MAX STOP PERFORMANCE) PRESENT. IF SO REPROGRAM THE PCM WITH THE APPROPRIATE NEW CALIBRATION AVAILABLE IN SERVICE FROM WDS CD B39A ONWARDS (REVISED PCM PART NO.: 3M51-12A650-AC; 3M51-12A650-NF; 3M51- 12A650-HS; 4M51-12A650-ZF; 5M51-12A650-MC) AND FOLLOWING ALL THE ON SCREEN INSTRUCTION INCLUDING RESETTING THE EGR VALVE. IF ANY CODES ARE STILL PRESENT AFTER ROAD TEST FOLLOW THE DIAGNOSTIC PROCEDURES FOR THAT CODE. SHOULD A REPLACEMENT EGR VALVE STILL BE REQUIRED THE NEW VALVE MUST STILL BE RESET TO THE PCM USING WDS. THIS FUNCTION IS FOUND IN TOOLBOX, POWERTRAIN, SERVICE FUNCTIONS, COMPONENT/PARAMETER RESET. SSM 5310 FOCUS AND C-MAX 1.6 TDCI - LOSS OF POWER SOME NEW FOCUS OR C-MAX EQUIPPED WITH 1.6 TDCI BUILT BETWEEN JUNE 2003 AND JAN 2005, MAY EXHIBIT THE FOLLOWING DRIVEABILITY ISSUES: 1.MIL ON DTC P0404/P1412 (EGR) REDUCED POWER. 2. MIL ON DTC P0234 TURBO OVERBOOST REDUCED POWER. 3. MIL ON DTC P0238 TURBO BOOST SENSOR VOLTAGE UPPER LIMIT REDUCED POWER. 4. RUN DOWN ROUGHNESS. ALSO REDUCES OIL BACKFLOW IN AIR INTAKE SYSTEM IN COMBINATION WITH SSM 18120. 5. MIL ON DTC P0116 ECT REDUCED POWER.IN CASE OF THESE CONCERNS, A REVISED PCM CALIBRATION IS NEEDS TO BE INSTALLED. THIS NEW LEVEL CALIBRATION WILL BECOME AVAILABLE ON WDS CD B41. REVISED PCM NO: 3M51-12A650-MH; 4M51-12A650-NF;-KG TSB 40/2005 * Loss of power,* Engine does not start, * Engine undershooting to a stop with immediate restarting possible, * "POWER STEERING FAILURE" displayed on the instrument cluster, Focus C-MAX 2003.75 (06/2003�) Build Date: 23.06.2003-03.01.2005 Build Code: 3Y-5J Engine: 1.6L Duratorq-TDCi (DV) Diesel Engine: 2.0L Duratorq-TDCi (DW) Diesel Transmission/Transaxle: CFT23 Transmission/Transaxle: MTX-75 one probable cause is a damaged wiring harness in the area of the manual/automatic transaxle TSB 11/2006 Clock in Radio resets after engine crank Should a customer express concern that the displayed time and date in the audio unit or the instrument cluster reverts back to always the same values after engine start, the probable cause is a voltage drop during the cranking process of the engine. This could lead to a reset of the instrument cluster. To rectify this concern a voltage buffer module should be installed to the production wiring harness for the instrument cluster SSM 18579 EFFECTIVE DATE: 26/04/2005 CLOCK IN RADIO LOOSES TIME SOME NEW FOCUS AND C-MAX VEHICLES MAY HAVE A RADIO UNIT WITH THE CLOCK DISPLAY RUNNING SLOW, A FEW SECONDS PER DAY COULD BE LOST. TO RECTIFY THIS UPDATE THE INSTRUMENT CLUSTER WITH REVISED SOFTWARE WHICH IS AVAILABLE WITH WDS CD37 ONWARDS. ID THE VEHICLE AS NORMAL; CHOOSE INSTRUMENT CLUSTER UNDER "BODY" IN THE GUIDED DIAGNOSTIC TAB MENU; SELECT CLOCK TIME FROM THE DIAGNOSTIC MENU AND PRESS THE BLUE TICK; FOLLOW THE ON SCREEN COMMANDS UNTIL THE PROCEDURE IS COMPLETE, THEN EXIT THE GUIDED DIAGNOSTIC. SSM 17927 Desc: When the ignition is switched on, occasionally a Low Fuel Warning is shown. Fix: Updated Cluster firmware. SSM 7608 Desc: When the ignition is switched on, a yellow warning with 'Limited EPB function!' is shown. Fix: Firmware update SSM 18122 Desc: Noticeable flat spot in first gear around 1700rpm (TDCi engines) when pulling away from standstill. Fix: ECU Firmware update TSB 13/2005 Desc: Leak from Turbocharger outlet pipe (1.6 TDCi) Oil pipe unseated during assembly. Fix: A revised turbocharger outlet pipe is installed Applies to models up-to 31/07/2004 Code 4D TSB 05/2005 Desc: Light application of the brakes when reversing causes a loud squeel. Fix: Replacement Brake Pads. (Under Warranty) TSB 41/2004 Desc: The time randomly changes on the radio clock. Fix: Updated Instrument Cluster firmware (current version 4.24 shown as ROM Level 0424 in TEST mode Later versions include the fixes) SSM 18356 EFFECTIVE DATE: 22/12/2004 RADIO (SONY/5000/6000) INCORRECT CLOCK DISPLAY SOME NEW FOCUS AND C-MAX EQUIPPED WITH RADIO: 5000/6000/SONY MAY EXHIBIT THE RADIO DISPLAY SHOWING DIFFERENT CLOCK VALUES AFTER E.G. CRANK, DURING DRIVING. TO RECTIFY 1.DISCONNECT BATTERY FOR AT MINIMUM 5 SEC. TO INITIALIZE A CLUSTER RESET ( CLOCK DRIVER ). AFTERWARDS SET CLOCK AND DATE TO THE ACTUAL TIME. 2. ON C-MAX BUILT UNTIL 08.06.04 (4K) PLEASE WORK ACCORDING TO TSB 41/04. ALL VEHICLES BUILT AFTER HAVE ALREADY THE LATEST LEVEL SOFTWARE AND IT IS NOT RECOMMENDED TO REFLASH THESE VEHICLES AGAIN. IF THE ISSUE STILL OCCURS NO FURTHER REPAIR WILL IMPROVE THE SITUATION. THIS IS CURRENTLY UNDER INVESTIGATION. TSB 45/2004 Desc: Ocassionally HID headlamp fails to ignite. Fix: Uprated Earthing Cable
_______________________ 115KM i 275Nm... z serii :-) / "Nie kłóć się z idiotą - sprowadzi Cię do swojego poziomu i pokona doświadczeniem" |
![]() Zarejestrowany: 11-10-2008
Model: FFII
Silnik: 1.6 benzyna (100KM)
Postów: 153
Nie masz "przypadkiem" takich ciekawostek dla 1.6 benzyny z 2005?
Always look on the bright side of life ... Focus idzie na sprzedaż |
Model: Focus MK2
Postów: 2,165
Niestety nie.
Znalazłem jeszcze coś takiego: [Tylko zarejestrowani użytkownicy widzą linki. ] Niestety nie ma tam fix`ów, ale są opisane problemy, zatem zawsze można do ASO uderzyć!
