18-09-2017, 11:44 | #1 |
Imię: Wojciech
Zarejestrowany: 02-09-2008
Model: Transit
Silnik: 2,0 TDCI
Postów: 13,996
Transit ekstremalny tuning
Na brytyjskim ebayu zakończyła się właśnie licytacja Transita z silnikiem o mocy 750 BHP i momencie 840Nm. Cena Kup teraz wynosiła 40.000 GBP, sprzedano (18.09.2017) za 20.600 GBP. Było 39 podbić ceny, czyli chłopcy dosyć ostro licytowali. Auto wyposażone jest w silnik V8 z australijskiego Holdena Commodore, resztę zmian zacytuję po angielsku, nie mam siły tłumaczyć na polski: Ford Transit rwd with Holden Comodore botom end and rb26 skyline head, 750bhp and 840 torque ported polished head with oil galery oil drain to sump and bigger oil drain holes Tomei 280 degrese and 10.9 lift camshafts Tomei shims Tomei lifters Tomei valve springs Tomei valves biger 1mm Tomei 1.8 head gasket HKS camshaft pulleys Dayco timing belt kit RB30 block with 1mm oil restrictor CP 87mm forged pistons ARP head bolts ARP 2000 forged conrods balanced crankshaft (jeff bull enginering) ACL main and rod bearings fluid damper biger sump with oil bufle exedy balansed clutch tein plate carbon lightened balanced flywhell ( Jeff Bull Enginering) RB26 intake manifold with 6 throttle bodies 1050cc sard injectors gredy fuel rail 2x1 Epman fuel regulator electric power steering new brake pipes with special cover Mercedes brake servo clutch master cilinder from Jeep Samurai custom made exaust manifold HKS t04z turbocharger HKS 60mm wastegate greddy boost controller 4" exhaust splitfire coils EWP150 water pump with ecu radiator aluminium in the back 2 fans on radiator 2 in back doors aluminium 38 l fuel tank and 3 l fuel rezervoir armed fuel pipes x3 Bosch 044 fuel pumps Epman blow off 50mm 3" intercooller with 3" pipes 15 row oil cooler Tomei oil pump 6 pint accusum with electric valve switch r34 GTT gearbox custom made string propshaft strong rear axle with welded diff 4 link rear axle adjustable rear coilowers front voilowers 3.5cm front and rear wheel spacers from standard transit to 114.3 x 5 alloy wheels and drag slicks FIA approved bucket seat FIA 6 point harnes custom made front dash all gauges hydraulic handbrake plastic side windows link g4 plus ecu extingusher system emergency cut out swith big wheel fenders easy remove front bumper bonnet and side door for drifting i got 3cm longer arms front hubs welded all suspension its brand new aluminium door cards Sparco quick reliese steering wheel OMP steering wheel FIA approved roll cage Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Zgredzik Ostatnio edytowane przez wojtekjanus ; 18-09-2017 o 21:32 |
