Stary 11-02-2017, 14:43   #1
beethoven
Imię: Thierry Walterus
Zarejestrowany: 04-09-2016
Model: mondeo titanium 2015
Silnik: 2.0 tdci
Postów: 112
Domyślnie battery monitoring
I know it doesn't exist, but it would have been handy if we could monitor battery capacity(visual, not numeric display) on the instrument cluster.
Is this possible to develop?
Just a question
Ostatnio edytowane przez beethoven ; 11-02-2017 o 14:57
beethoven jest offline   Odpowiedź z Cytatem
Stary 11-02-2017, 14:53   #2
MaXyM
Avatar MaXyM
Imię: Michał
Zarejestrowany: 06-12-2008
Model: Mondeo MK5 FL Vignale
Silnik: 2.0EcoBlue
Postów: 3,394
Domyślnie Odp: battery monitoring
How can you imagine to measure the capacity?
You can measure voltage drop in function of current. But it's quite rough approximation of it's actual capacity. And this is what Convers+ does: shows a message about bad battery condition.
Ostatnio edytowane przez MaXyM ; 11-02-2017 o 14:58
Stary 11-02-2017, 14:55   #3
pankrakus
Avatar pankrakus
Zarejestrowany: 18-06-2013
Silnik: 1.6
Postów: 1,517
for example
pankrakus
katalog części online
Instrukcje obsługi PDF
pankrakus jest offline   Odpowiedź z Cytatem
Stary 11-02-2017, 15:10   #4
beethoven
Silnik: 2.0 tdci
Postów: 112
I know those monitors exist, but it is, for me, a bit 'old fashioned', 'normal', 'vulgar'.
A fine car like the Mondeo Mk5 would be better with a "built-in" system.
How to monitor? Well, by exactly the same way as the old fasioned ones, they take the battery voltage via the 12V plug. Make it visible in the instrument cluster, in some way...
Czasy w strefie GMT +1. Teraz jest 12:01.
