Stary 08-05-2022, 12:24   #1
5te
Imię: Stefano
Zarejestrowany: 28-11-2021
Model: mondeo
Domyślnie IPMA firmware upgrade for FCW/CMbB
Dear friends, apologies for writing in english.
I upgraded my Mondeo with ACC and would like to enable Forward Collision Warning/Collision Mitigation by Breaking. I have run the bus wire to IPMA and configured everything with FORScan, but I get the "Collision assistant is not available" message in IPC and I have the following DTC in CCM: C1001:08 (and the equivalent in IPMA).
I did some research in the internet and I found that IPMA (mine is DU5A-17E678-ES) need to be re-flashed to S-series to support Collision assistant. Unfortunately I could not find anywhere the necessary firmware files to perform the update.
Can please someone share the following IPMA firmware:
FS7T-14G019-SJ
FS7T-14G024-SJ
many thanks!
Stefano
PS. great forum
5te jest offline   Odpowiedź z Cytatem
Stary 08-05-2022, 13:19   #2
tombalt
Avatar tombalt
Imię: Tomasz
Zarejestrowany: 31-08-2011
Model: S-MAX ST / Focus Active, wnętrze Vignale
Silnik: 2.0 TwinTurbo/1.5 EB
Rocznik: 2020/2020
Postów: 1,603
Domyślnie Odp: IPMA firmware upgrade for FCW/CMbB
Flashing the IPMA camera may not be enough if the hardware does not support it. Are you sure your camera can be upgraded?
S-MAX: AmbientLEDx25 /CANbox /Heated 2nd row /2nd USB HUB /DSP B&O / FullDigital
FOCUS: AmbientLEDx15 /TSR /DAS /AHB /BLIS /CTA /iACC /PCA /NAVI /Alarm /FrontCAM /CANbox /Towbar /WACM /2nd USB HUB /Electric seats x2 /right door lock switch /storage seat x2
tombalt jest offline   Odpowiedź z Cytatem
Stary 08-05-2022, 17:04   #3
5te
Imię: Stefano
Model: mondeo
Thank you very much for your answer. From the information that I found in the internet, E-series IPMAs can be flashed to S-series. To add some extra information, I tried to update IPMA with FORScan to the following S-series level:
FS7T-14G019-SF
FS7T-14G024-SE
FT4T-14G081-HE
FT4T-14G082-HE
I successfully flashed it and maintains the same level of functionality of the starting E-series level, but I still get the same DTCs in CCM/IPMA regarding the messages exchanged over the MS2CAN.
I flashed to SF level because it was the best I could find, hoping it would be enough to solve. Apparently it is not enough. Some guy in the 2gfusion forum says that flashing to SJ level solved the issue for him.
Best
Stefano
Stary 27-07-2022, 20:32   #4
EW1
Zarejestrowany: 19-07-2014
Rocznik: 2006 , 2016
Postów: 1,410
skąd można pobrać owe FW FS7T-14G019-SF FS7T-14G024-SE
EW1 jest offline   Odpowiedź z Cytatem
Stary 27-07-2022, 21:09   #5
Antej
Zarejestrowany: 15-08-2014
Postów: 9,101
UCDS pobiera je
Stary 27-07-2022, 21:14   #6
Postów: 18,073
skąd...
UCDS pobiera bez problemu. Zapewne więc z serwerów Forda 'standardową drogą' też się da - choć nie chciało mi się tego sprawdzać...
Stary 27-07-2022, 21:23   #7
EW1
Postów: 1,410
Dziękuję zatem bardzo. Nie działa strona pobierania z serwerów forda przynajmniej ta którą zawsze używałem . ForScanem też zawsze dało się pobrać ale musiał bym mieć IPMA z końcówką Sx i nie było by problemu ale ja mam Ex i tylko daje mi najnowszą aktualizacje
Stary 27-07-2022, 21:43   #8
Postów: 18,073
... Nie działa strona pobierania z serwerów forda przynajmniej ta którą zawsze używałem...
Faktycznie. Tę dostępną dotychczas "swobodnie" stronę do pobierania aktualizacji IDSa oraz plików kalibracyjnych obecnie przenieśli do PTSa po zalogowaniu...
Tak więc "trwają prace uszczelniające"...
Stary 28-07-2022, 12:43   #9
karoolpl
Imię: Karol
Zarejestrowany: 15-01-2017
Model: Ford Edge
Silnik: 2.0 Ecoboost
Postów: 291
Już jak wypowiedziałeś się w wątku , to chciałbym podpytać specjalistę w kwestii wiedzy i możliwości modyfikacji Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Sporo przeczytałem materiału tu na forum odnośnie kamer, z info które tu pisaliście wychodzi że można wgrać inny firmware, dzięki czemu kamera może zyskać dodatkowe funkcjonalności. Ja obecnie mam taki typ kamery:
IPMA - Moduł przetwarzania obrazu A
Nr części: DU5A-17E678-EP
Calibration level: DU5A-17E678-EP (latest known: DU5A-17E678-ES)
Strategia: DS7T-14G019-EL
Mam rozpoznawanie znaków i lane assist, ale nie mam asystenta pre-collison, którego miałem w hybrydzie. Czy dając komuś kto zrobiłby mi upgrade softu w kamerze, zyskałbym pre-collison i kamera byłaby gotowa (również po dołożeniu radaru odległości) do aktywnego tempomatu, czy w przypadku mojej kamery już trzeba myśleć o wymianie na najbogatszy model?
Również kwestia awaryjności, czy upgrade softu w kamerze, żeby umiała więcej niż fabrycznie, nie skraca jej żywotności?
Dzięki z góry za odpowiedź Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
karoolpl jest offline   Odpowiedź z Cytatem
Stary 28-07-2022, 17:24   #10
EW1
Postów: 1,410
Kupiłem lusterko z końcówką EP za śmieszne 70 zł właśnie po to by pobawić się w kalibracje .Jest kilka wątków odnośnie flashowania i można to chyba osiągnąć .
Moim zamiarem też jest doposażenie fusiona w radar odległości i zbieram gratki by mieć pełną funkcjonalność. Jeśli nie uda się IPMA przeflashować to będę szukał odpowiedniego lusterka .
Bump: Tylko chyba w mojej prośbie machnąłem błąd a miałem poprosić o FS7T-14G019-SJ
FS7T-14G024-SJ
Czasy w strefie GMT +1. Teraz jest 00:05.
