Stary 17-02-2017, 22:04   #1521
Mruczus007
Zarejestrowany: 06-03-2013
Model: Mondeo MK4 seria 66
Silnik: 2.3 Duratec-HE 161KM, AWF21
Postów: 47
Domyślnie Odp: Program konfiguracji - ELMconfig
Czy ktoś już robił upgrade do ostatniego firmware (v. 4.2.4) w interface Viaken opartego na chipsecie STN1170?
Mruczus007 jest offline   Odpowiedź z Cytatem
Stary 17-02-2017, 22:28   #1522
arpo
Imię: Patryk
Zarejestrowany: 22-10-2011
Model: V40 CC AWD
Silnik: T5
Postów: 214
A jaka jest potencjalna korzyść z takiej operacji?
arpo jest offline   Odpowiedź z Cytatem
Stary 17-02-2017, 22:56   #1523
Mruczus007
Postów: 47
Wg opisu to taka:
"v4.2.4 - 2017/01/27
- CHG: Improved CAN Bus Off state handling by removing auto-recovery, now requiring protocol to be manually reopened in addition to the 128 occurances of 11 recessive bits, before transmitter will be reenabled
- CHG: Improved CAN Tx error handling, where the transmitter will back off even before reaching Bus Off state, minimizing impact on a bus in case the problem is on the scan tool side
- CHG: Improved CAN message printing when monitoring CAN bus in receive-all mode - there's now less data printed from previous messages if bus error occurs after DLC field is received
- CHG: Increased CAN default propagation segment to maximum possible to get closer to the implied ISO 15765-4 spec
- CHG: Added the ability to print RTR messages using ISO 11898 without requiring CAN auto-formatting turned off
- BUG: In rare instances, segmented CAN message transmission could get silently corrupted if one of the frames fails to transmit due to CAN bus errors
- BUG: In rare instances, when encountering certain CAN bus errors, an OBD request on a CAN protocol would never go out on the bus, returning NO DATA
- BUG: STPBR may set the baud rate to an incorrect value, when custom CAN timing registers are used (STPBRR will still return the actual baud rate that was set)
- BUG: STFBA, STFFCA, and STFPA may add incorrect filters when odd length filters are entered"
Po drodze (względem firmware, który jest w moim, niedawno zakupionym interface - v3.3.1, 2012/09/25) były jeszcze takie wersje firmware:
v4.2.0 - 2016/12/01
v4.1.2 - 2015/08/21
Ponieważ na stronie Viakena nie widzę żadnych firmware do tego chipsetu (pomimo informacji w opisie interface, że jest możliwość upgrade firmware), dlatego zadałem tutaj pytanie, czy ktoś coś wie na ten temat.
Swoją drogą, to jakie macie wersje oprogramowania w swoich kabelkach od Viakena (oczywiście tych na chipsecie STN1170)?
Stary 17-02-2017, 23:15   #1524
Postów: 18,078
This major release fixed several bugs including:
CAN message loss or corruption due to CAN bus errors
ATPB could cause auto-filtering not to be set up correctly
Undefined behavior if reset during startup
ATMA command cleared CAN H/W filter on exit
ATMP commands cleared all current filters on OUT OF MEMORY error
ATBI/STPO did not activate pending USER1 protocol configuration changes
When ATMA on startup is enabled, device may fail to exit boot mode or enter pairing mode
Automatic generation of 11-bit flow control ID pairs for segmented message transmission
UART transmission lock ups
ISO 9141 keep-alive messages
STDIX would not display the new BT device name until 2 PORs from issuing STBTDND command
The major release added many new features including:
Turn LEDs off/on
Extra data parameter for the STPX command
Set CAN addressing modes
Set and read CAN timing registers
Support for 7F xx 78 response pending messages
Support for new Bluetooth modem firmware
Report factory calibration status
Fail-safe clock monitor
Complete ISO 15765 multi-frame message support
CAN Rx multi-frame message assembly
CAN Tx message segmentation
Arbitrary OBD message transmission
Set Bluetooth device name
Set minimum time between the last OBD response and the next request
GPIO control for most digital I/O pins
Other stability and performance improvements
See stn1170-changelog.txt inside the archive for detailed descriptions of the changes.
Stary 17-02-2017, 23:43   #1525
Mruczus007
Postów: 47
Widzę, że Guru forumowy wie, co w trawie piszczy, tylko... no właśnie: co z tego wynika?
Zrobiłeś upgrade (zakładam, że masz ten kabelek)?
Stary 17-02-2017, 23:53   #1526
Postów: 18,078
Wynika tyle, że różnicy nie zauważysz.
Ja tam wychodzę z założenia, że jak jest coś poprawione, to może się przyda...
Stary 18-02-2017, 00:01   #1527
Mruczus007
Postów: 47
OK. Dzięki za odpowiedź.
Gdyby ktoś był już po testach kabelka z softem w wersji 4.2.4, to niech pochwali się jak to działa.
Stary 18-02-2017, 00:18   #1528
arpo
Imię: Patryk
Model: V40 CC AWD
Silnik: T5
Postów: 214
Ja nawet nie wiem jaką mam wersję. Do tej pory w celu zmian konfiguracji i kasowania błędów służył bezproblemowo, więc chyba tak to zostawię.
Stary 18-02-2017, 00:44   #1529
Mruczus007
Postów: 47
Wersję widać w FORScanie:
Typ Pliku: png ForScan_interface.png (16.1 KB, 276 wyświetleń)
Stary 18-02-2017, 00:55   #1530
arpo
Imię: Patryk
Model: V40 CC AWD
Silnik: T5
Postów: 214
No to też mam 3.3.1. Faktycznie lekko już leciwy, choć jak widać zbyt wielu update'ów nie potrzebował na przestrzeni lat.
diagnostyka , elmconfig
Czasy w strefie GMT +1. Teraz jest 22:12.
