Stary 21-01-2019, 21:27   #191
Svedrus
Zarejestrowany: 01-09-2018
Model: Mondeo mk4
Postów: 111
Domyślnie Odp: Usterka oświetlenia przedniego
Pokazuje żółta kropkę z przodu auta, sprawdzałem wszystkie żarówki swieca, soczewki się poziomujące bo widać przy ścianie jak włączam
Bump: A jak miałem podłączonego kompa jakiś czas temu to nie pokazywało żadnych błędów związanych z oswiatleniem
Svedrus jest offline   Odpowiedź z Cytatem
Stary 24-01-2019, 11:28   #192
Tummps
Imię: Timmy
Zarejestrowany: 24-01-2019
Silnik: 2.0tdci
I also have an issue with my headlights on my 2014 mk4 mondeo bi-xenon. I get the error b1a58 when checking with forscan. What happens is that my right headlight is pointing straight / upwards, the left is working correctly however I had a fault code for that too, b1a57 I believe.
When I start the car both lights go down and then up, however the right one doesn't go as low as the left (also it's not as smooth as the left) and then it goes higher, which means that I blind oncoming traffic.
I've tried multiple times, initiated via forscan, to set the height on the right headlamp but it refuses to stick to the correct height.
I'm able to set the correct height manually, but when trying to adjust it lower the knob starts to click after one turn or so, could that be the issue?
This issue started after I changed bulbs to philips xtreme vision gen 2. After I swapped the bulbs I adjusted the lights a bit with adjusters on the headlight, everything was perfect until i started the car the next time, that's where this issue started. There's no lighting issue or so in the dash, everything works but it's the height adjuster for the right side that is the culprit here.
Ostatnio edytowane przez Tummps ; 24-01-2019 o 11:44
Tummps jest offline   Odpowiedź z Cytatem
Stary 24-01-2019, 20:20   #193
Svedrus
Model: Mondeo mk4
Postów: 111
Światła się poziomuja, widać słabsze światło z lewej lampy.
Stary 25-01-2019, 12:29   #194
Tummps
Imię: Timmy
Silnik: 2.0tdci
Is it possible to use prefacelift headlights to the facelifted model? I'm thinking of the connector in the first place, are the leads the same except the obvious extra for parking light?
Stary 25-01-2019, 14:32   #195
artur1970
Avatar artur1970
Imię: Artur
Zarejestrowany: 07-08-2012
Silnik: 1.25 , 2.0
Rocznik: 2014, 2019
Postów: 3,053
Sprawdzałeś czujnik poziomowania przy kołach?
artur1970 jest offline   Odpowiedź z Cytatem
Stary 25-01-2019, 14:47   #196
Svedrus
Model: Mondeo mk4
Postów: 111
Nie sprawdzalem
Stary 27-01-2019, 13:05   #197
algreen
Imię: Krzysztof
Zarejestrowany: 20-01-2014
Model: MK IV
Silnik: 2.2 TDCI
Postów: 59
Komputer nie pokazał błędów związanych z oświetleniem - piszesz, a jakie pokazał?
Mając ubity czujnik wysokości poziomowanie będzie działać po włączeniu świateł, w sensie reflektory ustawią się ze strumieniem światła tuż przed zderzakiem, jak na twoim filmie.
algreen jest offline   Odpowiedź z Cytatem
Stary 27-01-2019, 15:55   #198
Svedrus
Model: Mondeo mk4
Postów: 111
Nie pokazuje żadnych błędów pod kompem. Czyli voczujnik jest niehalo? Światła czemu słabo świeca zwłaszcza te lewe?
Stary 31-01-2019, 18:49   #199
lukasz..
Zarejestrowany: 13-07-2018
Model: Mondeo MK IV
Silnik: 2.2 TDCI 175km
Postów: 21
Mam podobny problem, nie działa sapomoziomowanie i lewa żarówka doświetlania. Bład B1A57 i bład B1C98 jakieś pomysły?
lukasz.. jest offline   Odpowiedź z Cytatem
Stary 31-01-2019, 21:54   #200
Svedrus
Model: Mondeo mk4
Postów: 111
Zarowke doświetlenie też miałem przepalona i wymieniłem ja ale nie wiem co z ta usterka :-\
Czasy w strefie GMT +1. Teraz jest 00:44.
