Stary 28-10-2009, 18:49   #251
marwyk
Avatar marwyk
Zarejestrowany: 11-07-2006
Model: VW SHARAN
Silnik: 1.9tdi 110KM
Postów: 1,384
Domyślnie Odp: Diagnostyka VAG
A możesz to wkleic tu na forum, bo tam trzeba się logować, anie bede zakładał konta żeby coś poczytać
marwyk jest offline   Odpowiedź z Cytatem
Stary 28-10-2009, 19:16   #252
kieras
Avatar kieras
Zarejestrowany: 29-07-2009
Model: Mondeo MkIII GHIA-X
Silnik: 2,5 V6
Postów: 101
I know this question is often asked with no-one having a definite answer.
Well, after persistent pestering from a certain member (you know who you are Wink), I have researched and tested to see if this can be done. The answer is a definite..YES!
However, this testing is in it's infancy and I can only tell you which Galaxys I can enable it on by actually doing it. It will definitely not work on the MK3 Galaxy!
So far, I have enabled it on a 2002 & 2004 MK2 Ghia, 2002 & 2006 MK2 Zetec and a 1999 MK1 Ghia. So initial signs are good! Smiley
Unfortunately, I don't think this will work on any pre-Sept 1997 models as they use a different Central Locking system. Until I try one, I won't know
Interestingly, when researching this, I have found there are other options that can be enabled.
These are:
* Single door opening: One button press on the remote unlocks the driver's door only with a second press needed to unlock the other doors.
* Anti-Hijack: Central Locking locks at speed (approx 15mph)
* Remote Global Open/Close Windows: Holding unlock button on remote opens the electric windows and holding lock button closes them
* Unlock when removing ignition key: This feature is useful if you have enabled Anti-Hijack. When you remove the ignition key, the doors unlock
* Acknowledgement of locking with horn sound: When you lock, the indicators flash as standard. You can make the alarm horn beep aswell (if fitted)
If you are still unsure what these functions are, you can witness them by viewing these videos. Listen closely when viewing the GlobalOpenClose video, you'll here the alarm horn beep when pressing the remote lock button.
Remote Global Opening and Closing
Anti-Hijack Auto Locking
Unlock on Key Removal
For a full list and how to carry out these additional functions, you will have to download my How To guide in the FAQ section. For this, you will need to be a Club Supporter and then you need to PM myself or another Mod or Admin for the password.
How To Guide
The procedure does require an amount of computer and diagnostic ability. If you are not confident about your ability to carry this out, then I suggest you don't attempt it. There is an alternative to carrying out yourself, the FGOC has various meets around the year and I try to attend most of them. I will always take my laptop and will gladly attempt this for you. All you have to do is attend the meet. Wink
You will need a laptop that will boot into pure DOS and has a serial port. It will not work under Windows XP or with a USB lead. Laptops with Windows 98 will work as they are able to boot in to DOS after making a Startup Disk. You will need to boot your laptop from the Startup Disk not the Win98 GUI.
If you have any questions, please post them here and I will try to help.
Sa jeszcze filmiki ale nie wiem jak wkleic
kieras jest offline   Odpowiedź z Cytatem
Stary 28-10-2009, 20:31   #253
mekess
Avatar mekess
Zarejestrowany: 03-05-2007
Model: GALAXY / TRANSPORTER / FREELANDER / PREMIUM / PIAGGIO SFERA / MTD YARD MAN /TRANSIT
Silnik: 1.9TDI 110KM / 2,4 D 74 KM / 120 KM / 460 KM / 0.049 / 15,5 KM / 2.0 100 KM
Rocznik: 1998 /1992 / 1998 / 2011 / 1996 / 2001 / 2001
Postów: 648
Przyznam, że bardzo interesujące, ale ten port szeregowy i DOS, tego nie bardzo rozumiem. Więc jakim programem on to robi?
Zarejestrowałem się na tym forum i czekam na potwierdzenie przez admina.
Zobaczymy co on tam napisał. Ja będę bardzo chętnie testował.
Długo o nim marzyłem - warto marzyć.
były: maluszek 0.65, trabi 0.6 (x2), lada 2107 1.3, 1.5 (x2), sierra 1.8TD (pomyłka), pony 1,5, astra 1,6, golf IV TDI kombi firmowy, NUBIRKA 2.0. Obecnie jest GALAXY 1.9 TDI , TRANSIT 2.5 D, KANGOO 1.9 D (do sprzedania)
Kolejne marzenie to jakiś bliźniak MK2, oczywiście TDI
mekess jest offline   Odpowiedź z Cytatem
Stary 28-10-2009, 20:52   #254
kieras
Avatar kieras
Silnik: 2,5 V6
Postów: 101
no i oto mi chodzilo bo szczerze ja z kompow nie jestem najlepszy a i niemam kabelka i programu a wiec jak ty cos z tego wyniesiesz to bardzo cieszy Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Stary 30-10-2009, 00:08   #255
mekess
Avatar mekess
Postów: 648
Zarejestrowałem się Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
No i lipa.
W moim laptoku niema szeregowego portu więc nic z tego.
Może poszukam gdzieś jeszcze na googlach, ale chyba nici :/
Jednak polecam te forum. "Przeleciałem je na szybko i powiem, że naprawdę warto tam zajrzeć Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Stary 30-10-2009, 21:42   #256
Łukasz
Avatar Łukasz
Imię: ŁUKASZ
Zarejestrowany: 12-11-2007
Model: GALAXY MK III , FIESTA MKVI
Silnik: 2.0 163KM, ; 1,4 TDCI
Rocznik: 2014;2007
Postów: 84
Co sądzicie o tym interfejsie? Czy będzie pasował do mojego Galaxy?
Łukasz jest offline   Odpowiedź z Cytatem
Stary 01-11-2009, 11:40   #257
Stefano
Avatar Stefano
Imię: Janusz
Zarejestrowany: 20-02-2005
Model: VW Sharan
Silnik: 1,9 TDI, AUY, 115 PS
Postów: 2,688
Napisał luk1969 Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Niby pisze, że auta 96-2009, ale najlepiej wypytaj sprzedającego czy kabel obsłuży twój model /rocznik auta / i jaką wersją programu VAG!
W aukcji pokazuje jakiś swój program, który chyba nie będziesz kupował z kabelkiem, bo jest nie bardzo czytelny, czy przyswajalny i będzie kosztawał nie wiadomo ile.
pOZDR.
Stefano jest offline   Odpowiedź z Cytatem
Stary 01-11-2009, 15:16   #258
Łukasz
Avatar Łukasz
Imię: ŁUKASZ
Rocznik: 2014;2007
Postów: 84
Dziękuję Stefano! Mam zatem pytanie do Ciebie- moze Ty mógłbyś mi coś polecić, czy też doradzić.Widzę,że jestes tu mózgiem duuuużej wiedzy.
Pozdrawiam!
P.S.Oczywiście zapytam sprzedającego!
Stary 04-11-2009, 09:20   #259
muflon137
Avatar muflon137
Imię: marcin
Zarejestrowany: 25-06-2007
Model: galaxy mk2
Silnik: 1.9/116
Postów: 367
pytanie trochę z innej beczki : jakim programem sprawdzić czasy wtrysków w silniku 2.0b DOHC i 2.3 b ?
ps. dodam,że mam kabelek do forda
nikt się nie zna na diagnostyce silników forda ?
Ostatnio edytowane przez muflon137 ; 07-11-2009 o 22:02
muflon137 jest offline   Odpowiedź z Cytatem
Stary 09-11-2009, 21:49   #260
Stefano
Avatar Stefano
Imię: Janusz
Model: VW Sharan
Postów: 2,688
Pozdrawiam!
Co tutaj radzić, jest tego cała masa, trza pytać sprzedajacego czy obsłuży twój pojazd, rocznik i jakim programem. Patrz na ceny, bo to samo jest po 150 zeta jak i po 70 zł.
Nie chciałbym tu wymieniać firm, aby nie reklamować, ale Viaken jest dość porzadny, bo interesuje się klientem, wymienia niesprawne kabelki, doradza jak są jakieś kłopoty po zakupie. Daje trochę oprogramowania.
Ale inni też sa dość przyjażni.
Ostatnio edytowane przez Stefano ; 09-11-2009 o 22:04
diagnostyka , elektryka , interfejs diagnostyczny , kod
Czasy w strefie GMT +1. Teraz jest 01:58.
