Stary 28-09-2018, 22:36   #301
adam127777
Imię: Adam
Zarejestrowany: 02-04-2010
Model: Mondeo MK5 STL / Kuguar STL
Silnik: EcoBiust R7 3.0 365 KM ;)
Rocznik: 2017 / 2021
Postów: 248
Domyślnie Odp: SYNC3 - aktualizacja map
Kod php:
   <p:ModuleName>ECU</p:ModuleName>
p:RequestRole>
d2p1:Role>CONSUMER</d2p1:Role>
d2p1:RoleSource>OTA</d2p1:RoleSource>
d2p1:RoleDesc>SYNC</d2p1:RoleDesc>
d2p1:RoleID>OTA</d2p1:RoleID>
p:RequestRole>
p:BroadcastDTCType/>
p:Node isFlashed="false" specificationCategory="GGDS">
d2p1:Address>7D0</d2p1:Address>
d2p1:ECUAcronym name="APIM">
d2p1:State>
d2p1:Gateway gatewayType="NONE">
d2p1:DID didFormat="ASCII" didType="Embedded Consumer Operating System Part Number" didValue="8033" responseLength="24">
d2p1:Response>JR3T-14G381-AL</d2p1:Response>
d2p1:IsConfig>false</d2p1:IsConfig>
d2p1:DID>
d2p1:DID didFormat="Packeted" didType="Embedded Consumer Applications Part Numbers 1" didValue="8060" responseLength="384">
d2p1:Response>4a4c37542d3134473432342d4241000000000000000000004a4c37542d3134473432312d4241000000000000000000004a4c37542d3134473339312d4142000000000000000000004a4c37542d3134473432322d4241000000000000000000004a4c37542d3134473432332d414100000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
d2p1:DID>
d2p1:DID didFormat="Packeted" didType="Embedded Consumer Applications Part Numbers 1" didValue="8061" responseLength="384">
d2p1:Response>000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</d2p1:Response>
d2p1:DID>
d2p1:DID didFormat="HEX" didType="ECU Checksum 1" didValue="D704" responseLength="4">
d2p1:Response>e7b7e36b</d2p1:Response>
d2p1:DID>
d2p1:DID didFormat="HEX" didType="ECU Checksum 2" didValue="D705" responseLength="4">
d2p1:Response>d2a723f3</d2p1:Response>
d2p1:DID>
d2p1:DID didType="Direct Configuraation DID DE00" didValue="DE00">
d2p1:Response>0a6a05921002ae0206c2</d2p1:Response>
d2p1:IsConfig>true</d2p1:IsConfig>
d2p1:DID>
d2p1:DID didType="Direct Configuraation DID DE01" didValue="DE01">
d2p1:Response>504c0106c00b488000000000</d2p1:Response>
d2p1:DID>
d2p1:DID didType="Direct Configuraation DID DE02" didValue="DE02">
d2p1:Response>0203000000</d2p1:Response>
d2p1:DID>
d2p1:DID didType="Direct Configuraation DID DE03" didValue="DE03">
d2p1:Response>01001d00240107</d2p1:Response>
d2p1:DID>
d2p1:DID didType="Direct Configuraation DID DE04" didValue="DE04">
d2p1:Response>1ac21aa42bd0</d2p1:Response>
d2p1:DID>
d2p1:DID didType="Direct Configuraation DID DE05" didValue="DE05">
d2p1:Response>80</d2p1:Response>
d2p1:DID>
d2p1:DID didType="Direct Configuraation DID DE06" didValue="DE06">
d2p1:Response>07003300000000171c000056566e006a</d2p1:Response>
d2p1:DID>
d2p1:DID didType="Direct Configuraation DID DE07" didValue="DE07">
d2p1:Response>00000000000000000000</d2p1:Response>
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="Private Sub Node #2 Software Number" didValue="F0E9" responseLength="24">
d2p1:Response></d2p1:Response>
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="ECU Cal-Config Part Number" didValue="F10A" responseLength="24">
d2p1:Response>GB5T-14G373-AA</d2p1:Response>
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="On-line Diagnostic Database Reference Number" didValue="F110" responseLength="24">
d2p1:Response>DS-GB5T-14G371-CD</d2p1:Response>
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="ECU Core Assembly Number" didValue="F111" responseLength="24">
d2p1:Response>HB5T-14G380-CB</d2p1:Response>
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="ECU Delivery Assembly Number" didValue="F113" responseLength="24">
d2p1:Response>HB5T-14G371-FFB</d2p1:Response>
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="ECU Calibration Data #1 Number" didValue="F124" responseLength="24">
d2p1:Response>Blank</d2p1:Response>
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="Private Sub Node #2 Part Number" didValue="F12A" responseLength="24">
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="Private Sub Node #3 Part Number" didValue="F12B" responseLength="24">
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="Private Sub Node #4 Part Number" didValue="F12C" responseLength="24">
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="Private Sub Node #1 Serial Number" didValue="F141" responseLength="16">
d2p1:Response>LWAL01D4</d2p1:Response>
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="Private Sub Node #2 Serial Number" didValue="F142" responseLength="16">
d2p1:DID>
d2p1:DID didFormat="State Encoded" didType="Software Download Specification Version" didValue="F162" responseLength="1">
d2p1:DID>
d2p1:DID didFormat="State Encoded" didType="Diagnostic Specification Version" didValue="F163" responseLength="1">
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="ECU Cal-Config #2 Part Number" didValue="F16B" responseLength="24">
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="Vehicle Manufacturer ECU Software Number" didValue="F188" responseLength="24">
d2p1:DID>
d2p1:DID didFormat="ASCII" didType="ECU Serial Number" didValue="F18C" responseLength="16">
d2p1:DID>
d2p1:DID didFormat="HEX" didType="ECU MAC Address 1" didValue="F1D0" responseLength="6">
d2p1:Response>9c:1d:58:3f:c7:45</d2p1:Response>
d2p1:DID>
d2p1:DID didFormat="HEX" didType="ECU MAC Address 2" didValue="F1D1" responseLength="6">
d2p1:Response>9c:1d:58:3f:c7:46</d2p1:Response>
d2p1:DID>
d2p1:Gateway>
d2p1:State>
d2p1:ECUAcronym>
d2p1:ODLNetwork d2p1:NetworkDataRate="500" d2p1:NetworkName="HS1" d2p1:NetworkProtocol="CAN" d2p1:DLCName="SAE J1962" d2p1:Pins="6,14"/>
d2p1:AdditionalAttributes logGeneratedDateTime="2018-03-13T15:57:10+00:00" RAM="1490219008" vmcuVersion="Vector_VMCU_02.02.20">
d2p1:PartitionHealth type="/dev/hd0t180" total="21074352128" available="115781600"/>
d2p1:PartitionHealth type="/dev/hd0t181" total="770003968" available="2097120"/>
d2p1:PartitionHealth type="/dev/hd0t177" total="133709824" available="2097152"/>
d2p1:InstallationLog/>
d2p1:SyncData>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</d2p1:SyncData>
d2p1:AdditionalAttributes>
p:Node>
p:OTAModuleSnapShot
A może ktoś mi powiedzieć co się Panu Fordu nie podoba w tym logu ?? że go nie chce łyknąć ?? Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum., coś się nie zrobiło, zrobiło źle czy ki cholera ??
Dzisiaj próbowałem raz jeszcze tego loga wcisnąć na stronce i dalej to samo "Sorry, error, try again later!" ......
adam127777 jest offline   Odpowiedź z Cytatem
Stary 30-09-2018, 19:00   #302
Macki85
Zarejestrowany: 28-05-2016
Model: Mondeo mk5
Silnik: 2.0 ecoboost
Faktycznie po jakimś czasie pojawiła mi się aktualizacja mapGoście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Niby wszystko poszło dobrze, ale zauważyłem że gracenote teraz nie ma żadnej wersji i nie pojawiają się okładki albumów mp3. Ktoś wie jak to naprawić?Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Macki85 jest offline   Odpowiedź z Cytatem
Stary 30-09-2018, 20:09   #303
O-conek
Zarejestrowany: 13-01-2017
Model: Connect
Silnik: 1,5
Postów: 28
Chciałem zaktualizować mapy i najpierw pobrałem aktualizację do samego synca po wpisaniu vin na stronie forda bo myślą, że mam 2.2 a ja już wcześniej nieoficjalnego żródła zainstalowałem wersję 3.0 17194. I teraz jak pobrałem z forda to zaczyna się instalować ale wersji mi nie zmienia, i nie tworzy pliku do wysłania. Czyżby Connect miał tylko taką wersje sync czy coś mam nie tak?
O-conek jest offline   Odpowiedź z Cytatem
Stary 01-10-2018, 10:46   #304
O-conek
Model: Connect
Silnik: 1,5
Postów: 28
Ogarnięte, zrobiłem downgrade do 2.2 i instalacja przeszła prawidłowo. Teraz czekam aż pojawią się nowe mapy do pobrania.
Stary 06-10-2018, 19:28   #305
fancomp
Imię: Adam
Zarejestrowany: 21-02-2010
Silnik: 2.0 EB (240KM)
Postów: 114
Czy jak pobieraliście aktualizacje do SYNC3, czy to z strony UK, czy ze strony PL, to nazwa pliku ZIP była VINem "nie Waszego" samochodu ?
Wpisuję swój VIN, podaje że jest aktualizacja, pobieram, a nazwa pliku jest VINem innego Forda ... i to jakiegoś "małego kaszlaka" ...
fancomp jest offline   Odpowiedź z Cytatem
Stary 06-10-2018, 19:57   #306
Danio's
Zarejestrowany: 22-08-2016
Rocznik: 201X
Postów: 480
może być inny VIN... to w niczym nie przeszkadza
Danio's jest offline   Odpowiedź z Cytatem
Stary 22-10-2018, 09:18   #307
Jędrzej Lubomirski
Imię: Jędrzej
Zarejestrowany: 24-05-2017
Silnik: 1.5 EB
Postów: 15
Cześć,
zrobiłem aktualizację Sync 3 2.2 do Sync 3 v.3 i pobrałem mapy, które serwer po przesłaniu mu pliku xml mi zapodał. Czy proces ich instalacji jest identyczny, jak w przypadku samego softu Synca? Tzn rozpakowuję te 22GB na pendrive, wtykam i tyle, tak?
Jędrzej Lubomirski jest offline   Odpowiedź z Cytatem
Stary 31-10-2018, 12:08   #308
Jędrzej Lubomirski
Imię: Jędrzej
Silnik: 1.5 EB
Postów: 15
Wszyscy uciekli? Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. U mnie jest tak - zrobiłem z mapami jak z aktualizacją SYNCa, czyli rozpakowałem na dużego pendraka i zainstalowałem. Nie mogłem - jak pisał ktoś wcześniej - zrobić tego jedynie przy włączonym zapłonie, bo system wyłączył się po ok. 30 minutach. Efekt jest taki, że mam obecnie Sync3, v3 plus mapy F7, jednak sync nie utworzył pliku na pendrive. Musze jeszcze raz?
Stary 24-11-2018, 10:34   #309
jozek661
Zarejestrowany: 28-05-2014
Model: Focus MK3
Silnik: 1.5 tdci
Postów: 34
Napisał O-conek Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
hej mam analogiczny problem, skad wziales wersje 2.2?
byl inny problem ale polaczylem sync przez wifi i dogadal sie z serwerami forda, aktualnie sync wersja 3 kompilacja 18205 i mapy f7
Ostatnio edytowane przez jozek661 ; 25-11-2018 o 11:49
jozek661 jest offline   Odpowiedź z Cytatem
Stary 26-11-2018, 21:06   #310
bigtomi
Avatar bigtomi
Imię: bigtomi
Zarejestrowany: 25-01-2014
Model: Ford Kuga mk2
Silnik: 2.0 Tdci 180PS
Postów: 233
Witam chciałem koledze zaktualizować mapę ford mondeo 2016r WF0EXXWPCEGD77040
na stronie forda [Tylko zarejestrowani użytkownicy widzą linki. ] pobrałem pliki 2.8GB skopiowałem na USB w samochodzie sync3 wersja 2.0 odpaliłem samochód włożyłem USB i po 40min aktualizacja przebiegła pomyślnie kazała jeszcze raz odpalić samochód i wersja 3.0 ale mapa ta sama EU 4 14 na USB powstał plik
Sync_LV6M00BS_WF0EXXWPCEGD77040
wskazuje plik dziennika i nic do pobrania niema tylko aktualizacja przebiegła pomyślnie co mam zrobić aby zaktualizować mapę a jak sprawdzam to Przykro nam, Twój pojazd nie jest kompatybilny z oprogramowaniem „Mapy”
bigtomi jest offline   Odpowiedź z Cytatem
Czasy w strefie GMT +1. Teraz jest 11:12.
