Stary 12-01-2015, 18:10   #591
leszcz
Avatar leszcz
Imię: Tomi
Zarejestrowany: 31-10-2005
Model: FUSION 4x4
Silnik: 2.0EB
Postów: 7,282
Domyślnie Odp: [mk3][mk4]Forscan - program do diagnostyki i nie tylko
Napisał krystianen Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Napisał mm32
Pojawiła się nowa wersja Forscan'a 2.2.0. Zaciekawiła mnie jedna opcja dostępna dla starszych fordów póki co i to w rozszerzonej wersji "+ Service function "PATS programming" (requires extended license)".
ktos wie jak działa??
This article describes PATS programming procedure. The article is actual for version 2.2.1 (PATS programming is implemented for European Ford models of 1999-2002 model year). If PATS programming functions is not available in the list of service functions, it means it is not implemented for this model. If the PATS programming function is available in the Service chapter, it is implemented for this model and must work in full.
There are 2 types of secure access: coded and timed. Coded requires an incode generation by the outcode provided by vehicle. Timed access requires that operator has wait for some period of time (usually 10-12 minutes) with diagnostic tester connected. Some vehicles support only coded access, some only timed access, some support both. FORScan supports all of these options. If both access types are available, FORScan asks user to select the preferred one. Coded access can be done fast, but requires incode/outcode calculator. Timed access doesn't require any code exchange, but requires signfificant timeframe (at least 10 mins). If Module Initialization option is selected (available for Duratorq DI models), it will require getting access to PCM first (coded or timed), then for FIP module (only timed).
Moja zabawa z nawigacjami
Stary 12-01-2015, 19:17   #592
Maniak
Avatar Maniak
Zarejestrowany: 23-01-2011
Model: Mondeo Titanium X
Silnik: 2.2 TDCI
Postów: 395
fajnie, można mieć extended licence przez 2 miesiące za free. Szkoda tylko ze lista samochodów jest jeszcze taka uboga.
Mondeo mk4 Titanium X Sport Panther Black 2.2 TDCI
Maniak jest offline   Odpowiedź z Cytatem
Stary 12-01-2015, 19:35   #593
mayak
Avatar mayak
Zarejestrowany: 17-05-2006
Model: Smax / Fusion Energy
Rocznik: 2019 / 2017
Postów: 5,365
Szkoda???
A czy na pewno chciałbyś aby każdy co wyda 50zl na ELMa mógł łatwo odjechać Twoim mondkiem?
Stary 12-01-2015, 22:10   #594
Wikar2
Zarejestrowany: 02-10-2012
Silnik: 1.8 TD
Rocznik: 1995
Domyślnie Re: Odp: [mk3][mk4]Forscan - program do diagnostyki i nie tylko
Jest jasno napisane że PATS jest obsługiwany do rocznika 2001
Mylisz sie, MK3 do konca produkcji.
Wikar2 jest offline   Odpowiedź z Cytatem
Stary 13-01-2015, 08:01   #595
Maniak
Avatar Maniak
Silnik: 2.2 TDCI
Postów: 395
Szkoda???
Wciąż trzeba mieć kalkulator incode. Jak maja ukraść to i tak ukradną.
Ostatnio edytowane przez Maniak ; 13-01-2015 o 08:04
Stary 22-01-2015, 19:50   #596
jarowo
Zarejestrowany: 03-03-2008
Model: MKII/MKIII/MKIV/S-Max/C-Max/Kuga2012/Kuga2018
Postów: 244
mayak wysłałem pw, ciężko się do Ciebie dobić.
Było Mondeo MK II, III, IV, S-max, obecnie jest C-Max ....
jarowo jest offline   Odpowiedź z Cytatem
Stary 22-01-2015, 21:32   #597
Hipesz
Imię: Hipesz
Zarejestrowany: 16-06-2014
Model: S-max
Silnik: 1.8 TDCI 125KM
Postów: 139
Napisał Maniak Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Kalkulatory in-out code dostępne są online z poziomu smartfona. Dekodują w czasie rzeczywistym. Ograniczenie to szybkość wpisywania cyferek na małym ekranie smartfona.
Hipesz jest offline   Odpowiedź z Cytatem
Stary 05-02-2015, 20:19   #598
DevonPL
Avatar DevonPL
Imię: Sebastian
Zarejestrowany: 15-09-2013
Model: Ford Galaxy mk3
Silnik: 2.0 Diesel 140k
Postów: 40
Do Ford Galaxy mk3 2006 -> można też zastosować ? czytałem sporo i ten program jest chyba ... CHYBA najlepszy Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Ps. Pełno kabelków na allegro, czy ktoś ma sprawdzone ?
DevonPL jest offline   Odpowiedź z Cytatem
Stary 05-02-2015, 20:37   #599
Speedo
Junior Moderator
Avatar Speedo
Zarejestrowany: 09-09-2004
Postów: 3,060
Napisał DevonPL Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Stary 05-02-2015, 20:40   #600
DevonPL
Avatar DevonPL
Imię: Sebastian
Postów: 40
Napisał Speedo Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
podziękował! Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
mondeo mk4
Czasy w strefie GMT +1. Teraz jest 02:12.
