10-01-2020, 12:43 | #1 |
Zarejestrowany: 21-06-2011
Model: Focus SE, 163 KM
Postów: 25
Opis adresu IPC 720-01-01
Poszukuję opisu bajtów adresu IPC 720-01-01 xxxx xxxx xxxx aby sprawdzić prawidłowość konfiguracji, dotyczy Focusa SE z 2017 r. z rynku kanadyjskiego silnik 2.0l 160 km, IPC - nr części: F1ET-10849-CXN (latest known: F1ET-10849-CXP) Strategia: F1ET-14C026-BBD. Z góry dziękuję kolegom za dzielenie się wiedzą ! PS.: Zależy mi na stworzeniu takiego opisu jak poniżej ale pasującego do powyższego IPC 720-01-01 1xxx xxxx xxxx Auto Engine Off option absent 720-01-01 0xxx xxxx xxxx 2wd (doesn't show 4wd gears in cluster) 720-01-01 2xxx xxxx xxxx 4wd 720-01-01 xCxx xxxx xxxx Adaptive Cruise Control disabled and CC menu absent from settings 720-01-01 xx2x xxxx xxxx AdvanceTrac disabled 720-01-01 xxx* xxxx xxxx AdvanceTrac Hard Button Control (AHB) & Auto High Beam (AHB) & Autolamp Delay (AD) & Autolock (AL) 0=AHB disabled, AHB absent, AD absent, AL absent 8=AHB enabled, AHB absent, AD absent, AL absent 1=AHB disabled, AHB absent, AD absent, AL present 9=AHB enabled, AHB absent, AD absent, AL present 2=AHB disabled, AHB absent, AD present, AL absent A=AHB enabled, AHB absent, AD present, AL absent 3=AHB disabled, AHB absent, AD present, AL present B=AHB enabled, AHB absent, AD present, AL present 4=AHB disabled, AHB present, AD absent, AL absent C=AHB enabled, AHB present, AD absent, AL absent 5=AHB disabled, AHB present, AD absent, AL present D=AHB enabled, AHB present, AD absent, AL present 6=AHB disabled, AHB present, AD present, AL absent E=AHB enabled, AHB present, AD present, AL absent 7=AHB disabled, AHB present, AD present, AL present F=AHB enabled, AHB present, AD present, AL present 720-01-01 xxxx x4xx xxxx Adds an "Average Speed" menu item to Trip/Fuel menu 720-01-01 xxxx xxx4 xxxx Chimes forwarded to ACM / Vehicle Speakers - Default DanMc85's findings 720-01-01 xxxx xxx0 xxxx Chimes IPC Internal Speaker Only 720-01-01 xxxx 3xxx xxxx Auto StartStop shows under Trip/Fuel menu 720-01-01 xxxx xxxx 66xx Cross Traffic Alert absent 720-01-01 xxxx xxxx 36xx Navigation/Compass absent 720-01-01 xxxx xxxx 86xx Navigation/Compass absent, Cross Traffic Alert absent 720-01-01 xxxx xx2x xxxx Driver seatbelt minder status off 720-01-01 xxxx xx4x xxxx Passenger seatbelt minder status off 720-01-01 xxxx xx0x xxxx Driver & passenger seatbelt minder status off Dodano: W tym Adresie znajduje się ustawienie jregionu Pl odczytałem istniejący (z tym kupiłem i robię porządki) wpis 720-01-01 506C 20C9 CE tak jest w oryginale fabryki -<DATA LABEL="720-01-01"> <CODE>4301</CODE> <CODE>0000</CODE> <CODE>6D</CODE> wg As build miało być 4301 000 6D (binarnie: 01000011 00000001 00000000 00000000, Hex 4:301) oczywiście daje to angielski amerykański+fr+hiszp. Obecny wpis daje język PL i inne europejskie. PYTANIE jakie zmiany powoduje nowy wpis oprócz zmiany regionu a w konsekwencji języka, ale według mnie powinno być:4336 0000 6D Wiem, że trzeba wcześniej ustawić PL w adresach moduł FCDIM 7A5-02-01 oraz moduł APIM 7D0-02-01 i moduł ACM 727-04-01, wpisać w odpowiednie miejsca kod języka PL tj 504c, w moim przypadku zamienić 4341 Canada na 504C polska. Naprawdę nikt nie wie i nie nawiąże dyskusji? PS Proszę się nie zrażać moim poziomem ford::amateur bo moja wiedza jest troszkę wyższa i możemy wzajemnie na tym skorzystać Ostatnio edytowane przez markokon ; 12-01-2020 o 23:01 Powód: brak odpowiedzi |
11-01-2020, 15:18 | #2 | ||
Imię: Ponury żniwiarz
Zarejestrowany: 08-02-2014
Postów: 4,366
Odp: Opis adresu IPC 720-01-01
Masz pewność, że korzystasz z poprawnego 'translator'a' ? Cytat:
Będę w stanie pomóc jak zaczniemy mówić w tym samym języku. Więc albo piszemy po angielsku, albo po polsku. |
11-01-2020, 15:24 | #3 |
Postów: 25
Dzięki za odpowiedź Edmun, postaram się po polsku...
IPC i sync ma polskie napisy według tych ustawień, a SYNC nawet mówi po PL. Czy te informacje pomogą 720 <F108>F1ET-14C318-BA</F108> <F110>DSF1ET-10849-AF</F110> <F111>F1ET-14F094-BB</F111> <F113>F1ET-10849-CXN</F113> <F120>F1ET-14C026-BCB</F120> <F121>F1ET-14C026-BKC</F121> <F188>F1ET-14C026-BBD</F188> Plik z IPC nazywa się F1ET-14C026-BBD.VBF Napisz, jakie informacje są Ci potrzebne to podeślę na PW Ostatnio edytowane przez markokon ; 11-01-2020 o 15:53 |
11-01-2020, 16:06 | #4 |
Postów: 4,366
Całej rozpiski nigdy nie udało mi się znaleźć :/
Kojarzysz czy .vbf można bezpośrednio zaczytać do UCDS'a ? Chyba wtedy pokazuje po kolei każdą opcję wraz z numerami. |
11-01-2020, 21:22 | #5 |
Postów: 25
Dziekuję za szybką odpowiedź Edmun
Niestety nie mam UCDSa mam tylko ForscanaGoście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Ciekawe czy IDS ma takie opcje, ale pewnie po numerze win będzie można wgrać oryginalną konfigurację na kanadę, wiem że jest tam opcja programowania modułów z programowaniem parametrów programowalnych ale czy tym się da to podejrzeć to wątpię bo tam jest lista rozwijana opcji i nie pokazuje bajtów, wygląda na to że tylko UCDS. Teraz mam wszystko ustawione chyba dobrze, błędów nie ma żadnych, zegary mają PL, radio mówi i rozumie po PL, też stroi po częstotliwości EU (0,1 MHz) teoretycznie nie ma się czego czepić , ale niepokoi mnie ten wpis w 720-01-01 506C 20C9 CE , jaki powinien być prawidłowy? Dlaczego, bo nie ma angielskiego a powinien być !!!!! a jest nawet ruski Może ktoś odczyta swoją konfigurację z takim samym IPC i wtedy się wyjaśni. A może ktoś z kolegów z tego forum co ma UCDSa powie czy plik konfiguracji vbf da się wczytac do programu i wyświetli opcje adresu 720.01.01 Ostatnio edytowane przez markokon ; 11-01-2020 o 21:59 |
11-01-2020, 22:21 | #6 | |
Zarejestrowany: 03-11-2011
Postów: 17,034
Każdemu już teraz się wydaje, że jak obejrzał parę filmików na YT to jest "guru" i może "wszelakie Fordy ogarnąć"...Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Otóż adresy "720-01-01" i temu podobne NIE SĄ ZAPISYWANE Z ŻADNEGO VBF. To są parametry konfiguracyjne z pliku AS BUILD (.ab). |
11-01-2020, 22:24 | #7 |
Postów: 25
Tedi nie denerwuj się kolega Edmun zasugerował, a ja nie mam UCDSa i nie mogę sprawdzić OK?
To może Ty powiesz co jest nie tak z ustawieniami w 720-01-01 506C 20C9 CE (a może co innego?), jaki powinien być prawidłowy? Dlaczego tak myślę, bo nie ma angielskiego a powinien być !!!!! a jest nawet ruski !!!!!!!!!! Ostatnio edytowane przez markokon ; 11-01-2020 o 22:28 |
11-01-2020, 22:31 | #8 | |
Postów: 17,034
11-01-2020, 22:34 | #9 |
Postów: 25
Taka dyskusja nic nie wnosi do tematu, o tym to ja wiem że każdy bajt ma swoje znaczenia, ktoś kto szykował do sprzedania tylko tak potrafił a ja chcę to z Waszą pomocą poprawić, Uda się?
11-01-2020, 22:52 | #10 |
Postów: 17,034
Nie "bit ma znaczenie" a bit to jakiś język". Sugeruję nabyć UCDS - będzie prościej i najszybciej.
Ja "z lenistwa" tego nie przeliczam na FORScana, bo to każdy może. Ja pomagam podając schematy, bo - szczególnie z serwerów amerykańskich - to zdecydowanie trudniejsze. |
