03-01-2019, 20:09 | #1 |
Zarejestrowany: 14-10-2018
Model: Escape
Silnik: 1.6 EcoBoost
Postów: 46
usunięcie Sirius ze źródeł dźwięku (audio sources)
Hej. Gdyby ktos potrzebowal usunac Sirius ze zodel dzwieku:
Needed: -Desire to eliminate your unused Sirius menu option -My Ford Touch (SYNC2 8" Touchscreen) -FORScan (I'm running 2.3.6 beta with free extended license on a WIN 7 Pro 64-bit Dell e6530) -Interface device (I'm using an old, clone, USB ELM327 home-modified with HS/MS switch) (this isn't a FORScan tutorial - please get familiar with it and you interface device elsewhere) For NON-SONY entertainment (proven to work for me): -Connect and read all modules using FORScan -In "Configuration and Programming" choose APIM -Save your existing configuration to a file (always) -At 7D0-01-01 you should see 2###-####-#### (where # is a hexadecimal value) -Change 2 to 0 -Write the new entry to your APIM; follow the onscreen instructions to cycle the key off-then-on; let SYNC run through it's self-initiated maintenance screen. VOILA! No more 'Sirius' on the menu and it doesn't show as I scroll through choices with the steering wheel controls. It's gone. Done, tested and proven on my Escape (see signature block for details on my car). This had no effect on other reprogramming I'd done to my APIM (self-enabled Navigation still works perfectly). No DTC's were detected before or after I did the re-programming. For SONY entertainment (not proven by me - I don't have a SONY system) -Connect and read all modules using FORScan (this isn't a FORScan tutorial - get familiar with it elsewhere) -In "Configuration and Programming" choose APIM -Save your existing configuration to a file (always) -At 7D0-01-01 you should see A###-####-#### (where # is a hexadecimal value) -Change A to 8 -Write the new entry to your APIM; follow the onscreen instructions to cycle the key off-then-on; let SYNC run through it's self-initiated maintenance screen. zrodlo: [Tylko zarejestrowani użytkownicy widzą linki. ] U mnie w Escape 2014 dzialaGoście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. |
03-01-2019, 20:33 | #2 |
Imię: Przemek
Zarejestrowany: 26-02-2018
Model: Escape
Postów: 97
Odp: - usunięcie Sirius ze źródeł dźwięku (audio sources)
Jaki cel tej operacji co daje usunięcie, tak po prostu dla hecy?
Wysłane z mojego RNE-L21 przy użyciu Tapatalka |
03-01-2019, 20:58 | #3 |
Zarejestrowany: 23-10-2012
Silnik: 2.0 180KM-> ~205
Postów: 2,893
A korzystasz z niego? Cześć osób chce usunąć bo i tak nie przydaje się.
Trzeba być wytrwałym żeby się ze mną skontaktować, oczywiście nie gwarantuje to możliwości spotkania |
03-01-2019, 20:59 | #4 |
Imię: Przemek
Model: Escape
Postów: 97
Czyli tylko o to chodzi. Ok. Nie korzystam ale mi nie przeszkadza. Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
03-01-2019, 21:58 | #5 |
Imię: danwit2
Zarejestrowany: 01-01-2017
Model: Escape / Edge
Silnik: 2.0 Ecoboost / 3.5 V6
Rocznik: 2017 / 2017
Postów: 444
Dokładnie ja też mam i mimo że jest bezużyteczne mi to nie przeszkadzaGoście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Pytanie mam natomiast takie - czy można uaktywnić odbiór DAB+ |
03-01-2019, 22:00 | #6 |
Model: Escape
Postów: 46
Mi przeszkadzal, przy przelaczaniu z bluetooth na fm np. za pomoca przycisku "M" na kierownicy trwalo to znacznie dluzej, poniewaz trzeba bylo przebrnac przez bodajze 2x Sirius, ktory i tak nie smiga. Obecnie zajmuje to mniej czasu. Zabieg mozna powiedziec kosmetyczny, ale przydatny.
03-01-2019, 22:02 | #7 |
Imię: Przemek
Model: Escape
Postów: 97
Nie da się na terenie PL do tego abonamentu wykupić?
03-01-2019, 22:08 | #8 |
Imię: danwit2
Postów: 444
abonament można sobie wykupić jak ktoś chce ale po co? W Europie nie odbiera Sirius bo nie ma nadajników
03-01-2019, 22:38 | #9 |
Imię: Przemek
Model: Escape
Postów: 97
A to nie jest czasem radio satelitarne?
03-01-2019, 23:19 | #10 | |
Zarejestrowany: 03-11-2011
Postów: 17,035
Wykupienie abonamentu Siriusa jest tak samo roztropne jak kupienie abonamentu jakiejś kablówki z Los Angeles na przykład...Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
------------------------------------------------------------------------------------------------ Nadal tu jestem - choć jeżdżę Mitsubishi Outlander PHEV 4x4 2019 224KM |
