Stary 22-07-2018, 11:30   #1
quier
Zarejestrowany: 20-08-2017
Model: Galaxy MK3
Silnik: 2.0tdci
Postów: 8
Domyślnie Uderzenie pioruna - mam nastepujaca listę błędów
Witam, wczoraj podczas jazdy w deszczu samochod zostal trafiony piorunem Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. . natychmiast silnik przestal pracowac, ale zegary, radio dzialaly. po sciagnieciu auta pod dom podlaczylem auto do komputera i mam nastepujaca liste...
All modules reading DTC stating...
08:48:29 niedziela 22 lipiec 2018
DTC Error read - VDM
The module does not answer
DTC Error read - BCM
DTC Errors: 10
B1097 - Heated windshield relay
B1097 - Audio System Tweeter Circuit Fault
Status: 14 - Circuit Short To Ground Or Open
6C- Error Ext. status not found in base....
B10AF - Blower Fan Relay
B10D7 - PATS Key
Status: 94 - Unexpected Operation
68- Error Ext. status not found in base....
B10EA - Positive temperature coefficient heater
Status: 13 - Circuit Open
B113D - Sunroof Global Open/Close Control
B113D - Rear Climate Control Switch Stuck or Short to Ground
Status: 12 - Circuit Short To Battery
B1C55 - Horn Relay Coil Circuit
B1C84 - Heated Rear Window Relay Output Circuit
B1D39 - Rear Wiper Motor
U0100 - Lost Communication With ECM/PCM A
U0100 - Lost communication with the PCM
00- Error status not found in base....
U0121 - Lost Communication With ABS Control Module
U0121 - Lost Communication With The ABS Control Module
DTC Error read - SECM
DTC Error read - HCM
DTC Error read - RCM
DTC Errors: 1
ED- Error Ext. status not found in base....
DTC Error read - PBM
DTC Error read - ABS
DTC Error read - CCM
DTC Error read - SASM
DTC Errors: 0
DTC Error read - SODL
DTC Error read - SODR
DTC Error read - PCM
DTC Error read - TCM
DTC Error read - IPC
DTC Errors: 6
P1607 - MIL Output Circuit
Status: 82 - Alive/Sequence Counter Incorrect/Not Updated
Ext.Status: 2F - No Communication Or Incorrectly Connected.(DTC) Present at Time of Request.
U0422 - Invalid Data Received from Body Control Module
Status: 68 - Event Information
Ext.Status: 2B - Closed.(DTC) Present at Time of Request.
B1A84 - Car Configuration Data
Status: 51 - Not Programmed
U0401 - Invalid Data Received From ECM/PCM
U0401 - Invalid or Missing CAN Data From The PCM
U0415 - Invalid Data Received From ABS Control Module
U0415 - Invalid Data Received from the ABS Control Module
Ext.Status: AB - Closed.(DTC) Maturing - Intermittent at Time of Request.
U0420 - Invalid Data Received From PSCM
DTC Error read - ACM
DTC Errors: 0
DTC Error read - RFA
DTC Error read - HVAC
DTC Errors: 1
B10B9 - Blower Control
DTC Error read - PAM
DTC Error read - DDM
DTC Errors: 1
U3003 - Battery Voltage
Status: 62 - Signal Compare Failure
DTC Error read - PDM
DTC Errors: 1
DTC Error read - DSM
DTC Errors: 2
U2100 - Initial Configuration Not Complete
Ext.Status: 2E - Leaking.(DTC) Present at Time of Request.
Status: 17 - Circuit Voltage Above Threshold
Ext.Status: 27 - Output Not Switching Or Short Circuit To Ground.(DTC) Present at Time of Request.
DTC Error read - SPRM
DTC Errors: 0
DTC Errors: 0
DTC Error read - TRM
DTC Errors: 2
B1102 - Trailer stop lamp
B1102 - Mirror Power Fold Switch Input Short to Ground
DTC Error read - AHCM
Czy jest ktos w stanie poradzic od czego zaczac poszukiwania. Sprawdzilem bezpieczniki i wygladaja na cale. Jutro wezme z pracy miernik to sprawdze kazdy z nich osobno.
Pozdrawiam i z gory dziekuje.
quier jest offline   Odpowiedź z Cytatem
Stary 22-07-2018, 22:45   #2
BrunoJ
Zarejestrowany: 10-03-2018
Model: LDR110
Silnik: 2.2 TDCI 122KM
Postów: 265
Domyślnie Odp: Uderzenie pioruna - mam nastepujaca listę błędów
Współczuje. Oby Twoje ubezpieczenie ogarniało takie rzeczy.
Próbowałeś te błędy skasować o zobaczyć co zostanie? Bo masz chyba wszystko możliwe wymienione, od głośników po tylna wycieraczkę i zbyt duże napięcie na akumulatorze.
To pachnie usmażonym komputerem, pytanie którym i czy jednym.
Z bezpiecznikach problem jest taki ze one chronią od „plusa” akumulatora, przed urządzeniem. A przepięcie najprawdopodobniej przyszło od strony masy (obudowa auta). A może właśnie jakieś kable masowe się upalily stąd większość cześć urządzeń nie działa.
BrunoJ jest offline   Odpowiedź z Cytatem
Czasy w strefie GMT +1. Teraz jest 06:42.
