Stary 12-01-2021, 18:07   #50
kaan1
Avatar kaan1
Imię: Andrzej
Zarejestrowany: 12-11-2015
Model: MK5
Silnik: 180 KM
Postów: 2,054
Domyślnie Odp: Tryb awaryjny podczas jazdy P02FA P228C P0251
“Ford has identified a number of faulty diesel fuel injectors in certain vehicles fitted to 2.0-litre EcoBlue engines built from 2 February and 6 August 2019,” said Moran. ... The issue could lead to a misfire and reduced engine performance in affected vehicles
What’s causing the Ford EcoBlue injector issue?
Further to this, we understand that supplier is Continental, and that the failure is related to a surface coating inside the injectors. On some injectors this has been found to come unstuck, which soon leads to the injector becoming blocked and preventing it operating correctly.
A tak w ogóle to Continental "wykopuje" dywizję Powertrain i dział wtryskiwaczy - pod indywidualną markę "Vitesco" która pójdzie pod młotek
A wtryski Delphi to teraz już BorgWarner
Ostatnio edytowane przez kaan1 ; 12-01-2021 o 18:12
kaan1 jest offline   Odpowiedź z Cytatem
