![]() Imię: Łukasz
Zarejestrowany: 20-11-2012
Model: Focus C-Max
Silnik: 1.6 TDCI 90KM
Rocznik: 12/2005
Postów: 11
Witam, chciałbym prosić o przetłumaczenie informacji. Dane pobrane ze strony etis.ford.com. U mnie niestety info w wersji angielskiej. Z góry dziękuje.
Minor Features Saarlouis Plant Built Security Lock Group No.1 With Convenience Group Marketing Flex Prep Pack 1 Less SVO Application/Label Marketing Level 1 Less Electronic Stability Control Less Global/Auto Closing Power Front Windows One Touch Down With Manual Rear Windows With Tinted Glass All Round Less Windshield Heat Shielding Less Heated Windscreen With Mini Overhead Console With Small Floor Console Less Rear Floor Console Less Special Inter Appliques With Conventional Headlining With Load Area Cover With Dipping Rear View Mirror Drivers Power Heated Convex Mirror With Pass Convex Elec/Heated Mirror With Rear Center Head Restraint With Drivers Manual Lumbar Support Less Passenger Seat Lumbar Support With Driver 4 Way Mnl.Seat Adjuster With Pass 2 Way Manual Seat Adjust Less Trailer Coupling Ignition Key With Remote Unit With Moulded Gearshift Knob With Second Remote Ignition Key With Central Locking System With Variable Intermittent Windscreen Wiper Air Crtn Rstrnt LH With Driver Air Bag With Passenger Air Bag With Side Air Bag - Drivers Side With Side Air Bag - Passenger Side With Isofix Hard Point Attachment With Mini Steel Spare Wheel With Standard Rear Shock Absorbers 6.5 x 16" Alloy - Style A 205/55VR-16 BSW Tyre Non Locking Lug Nuts With Standard Suspension With Mechanical Parking Brake With Brake Emergency Assist 4 Wheel Anti-Lock Braking System Less Skid Plates Standard Front Seat With Fixed Foot Pedals 4 Spoke Leather Steering Wheel With Speed Control With Supplemental Air Heater Conventional Instruments - Level 2 With KMH Speedometer With Rear Parking Aid Less Radio Pre-Equipment Pack (+)RDS Less A/V Jack With Centre Antenna ICE-Low Level CD + AM/FM Radio Ice Feature Pack 2 With 6 Speakers Less Family Entertainment System With Column Stalk Radio Controls With Auto Headlamps With Halogen Headlamp With Front Fog Lamps Less Headlamp Control |
![]() Imię: Piotr
Zarejestrowany: 14-07-2009
Model: Mondeo Mk4
Silnik: 1,6 Ti-VCT
Postów: 685
Przecież w zakładce na gorze ETIS możesz sam ustawić język. Jest tam też język polski.
![]() Imię: Mariusz
Zarejestrowany: 19-08-2008
Model: Mondeo Mk3-DENSO
Rocznik: VII/2OO5 Sedan
Postów: 1,941
![]() 668855686 |
#4 | |
![]() Imię: Łukasz
Model: Focus C-Max
Rocznik: 12/2005
Postów: 11
Mniej ważne funkcje Wyprodukowano w fabr.w Saarlouis Zestaw bezpiecznych zamków nr 1 Bez grupy zwiększenia wygody Zest. mat. market. nr 1 Bez aplik./naklej. SVO Poziom marketingowy 1 Bez el. uk. stabilizacji toru jazdy Bez globalnego/automat. zamykania Ok. przednie zamykane 1 dotknieciem Z Szybami Tylnymi Sterow. Ręcznie Ze standardowš przyciemnianš szybš Bez osł.termicznej szyby przedniej Bez Ogrzewanej Szyby Przedniej Z mini-konsolš górnš Z mala konsola Bez tylnej konsoli podłog. Bez spec.apl.wewn. Z konwencjonalnš podsufitkš Z pokrywš przestrzeni bagażowej Z Regulowanym Lusterkiem Wstecznym Ogrzew. wypukle lusterko kierowcy Z wypukł.el.ster/ogrz.luster.pasaż. Z rodk. zagłówkiem z tyłu Z ręcznie reg. podporš lęd. kier. B. podpory ledzw siedzenia pasazera z regulatorem 4-poz.pol.siedz.kier. Z reczn.2-kier.reg. siedz.pas Bez sprzegu przyczepy Kluczyk zapł. ze zdalnym ster. Z profilowa galka dzwigni zm biegów Z 2.klucz. zapł.ze zdaln.otw. Z Centralnym Zamkiem Z czest.pracy przeryw Air Crtn Rstrnt LH Kurtyna powietrzna - prawa strona Z poduszka powietrzna kierowcy Z Poduszkš Powietrznš Pasażera Z bocznš podusz.pow.- str. kierowcy Z bocznš podusz.pow.- str. Pasażera Z mocowaniem Isofix Z małym stalowym kołem zapasowym Ze Standard.Amortyzatorami Tylnymi Koło ze stopu 6.5 x 16"-Styl A 205/55VR-16 BSW Tyre Nieblokujšce nakrętki kół Z Zawieszeniem Standardowym Z mechanicznym hamulcem postojowym Ze wspomag. awaryjnym hamulców Układ ABS na wszystkie koła Bez osłon ochronnych Standardowe siedzenie przednie Ze stałymi pedałami 4-ramienna kierownica skórzana Ze Sterowaniem Prędkociš Z dod. nagrzewn. Konwencjonalne wskaniki - Poziom 2 Z prędkociom. km/h Z ukladem wspomag.przy parkow.tylem Bez zestawu do zamontowania radia (+)RDS Bez gniazdka A/V Z antenš rodk. Wyp.podst.CD + Radio AM/FM Pakiet wyposażenia systemu ICE 2 Z 6 glosnikami Bez ukł. zapewn.rozrywki rodzinie Ze Sterow.Radiem Na Kolumn. Kierown Z autom. reflektorami Z reflektorami halogenowymi Z Przednimi Lampami Przeciwmgieln. Bez regulacji ustaw. reflektorów |
