![]() Imię: gary
Zarejestrowany: 17-09-2014
Model: mondeo
Postów: 11
Hello friends
First I apologise for posting in English, but using translator is terrible. I am hoping some very knowledgeable people here can help or advise me I am nearly finished installing IVDC. I have nearly all parts fitted now except shock absorbers. I have made my own wiring harness and used all the correct plugs. All 4 height sensors 3 accelerometers switch and module fitted. I have joined into Can with twisted cables. I have turned on in elm config and as expected I get "IVDC malfunction" in convers. I thought this was because I didn't have shock absorbers fitted. I have both (new) front shocks. So today I plugged in front shocks and I got 2 bulbs with 5 ohm resistance (same as front) to plug into rears. Fooling the module that all shocks are fitted. I still get "IVDC malfunction" So i plugged in forscan and read DTCs. I am getting a DTC in ABS module that says "invalid data received from suspension module" I know I have the right ABS module because I changed it when I fitted adaptive cruise control earlier this year The suspension module I have is 6G9N-3B494-AB When I clear DTC it comes straight back If I unplug suspension module, error can be cleared. Can wires are definitely the right way around, switch doesnt even light up if I swap them over, and I get other errors Anyone any ides? Please Ostatnio edytowane przez Adept ; 09-11-2015 o 21:57 Powód: improvement of administration |
![]() Imię: Tomek
Zarejestrowany: 06-12-2011
Model: NieFord-Skoda Octavia vRS
Silnik: 2.0 TSI
Postów: 1,434
Hello my friend. First idea-maybe suspension module is faulty?Second-maybe this module have to be configured by IDS. Simmilary as was with ABS pump and YAW sensor?
http://s1069.photobucket.com/albums/u468/cliner66/ http://forum.fordclubpolska.org/album.php?albumid=786 --------------------------------------------------- 269KM/429Nm by Heko(było),następne(było) 275KM/427Nm...jest 324KM/483Nm... |
Rocznik: '07_'99_'06_'07
Postów: 9,191
0) if You can connect to the IVDC module and configure them or red errors (about not connectet shock absorbers), CAN wires are conected correctly.
1) pleas write Your DTC errors with OBD DTC numbers. It might be easier to understand them 2) maybe, You need to "pair" the ABS and IVDC module, i mean "to say to your ABS module that You have IVDC module" but i'm not sure so: 3) i try to translate Your problem, mayby it will be more easily to get right answer. Kolega ma problem, poniżej moje niedoskonałe tłumaczenie. Może coś ktoś pomoże: Cześć przyjaciele Po pierwsze przepraszam za post w języku angielskim, ale tłumaczenie z pomocą translatora jest straszne. Mam nadzieję, że ktoś z dużym doświadczeniem lub wiedzą będzie mógł mi pomóc lub doradzić. Jestem na etapie kończenia instalacji IVDC. Mam prawie wszystkie części zamontowane z wyjątkiem amortyzatorów. Zrobiłem własną wiązkę przewodów stosując wszystkie odpowiednie wtyczki (oryginalne). Wszystkie 4 czujniki wysokości oraz 3 akcelerometry oraz moduł zamontowane. Podłączone do szyny CAN skręconymi przewodami. Właczyłem ELM configiem IVDC i zgodnie z oczekiwaniami pojawił sie błąd "awaria IVDC" w Convers. Myślałem, że to dlatego, że nie mam zamontowanych amortyzatorów. Mam oba nowe przednie amortyzatory, więc dzisiaj je podłączyłem, a zamiast tylnych amortyzatorów podłączyłem żarówki o oporności 5 Omów, takiej jak przednie amortyzatory, żeby oszukać moduł że wszystkie 4 amortyzatory sa podłączone. Mimo to wciąż jest błąd "awaria IVDC" więc podłączyłem forscan i odczytałem kody DTC. Otrzymuję DTC w module ABS, który mówi "nieprawidłowe dane otrzymane z modułu zawieszenia" Wiem, że mam odpowiedni moduł ABS, bo zmieniłem go, kiedy montowałem ACC - Adaptive Cruise Control w tym roku Moduł zawieszenia mam 6G9N-3B494-AB Kiedy wykasuje błąd DTC, wraca z powrotem od razu. Gdybym odłączył moduł zawieszenia, błąd można wyczyścić. Przewody od CAN raczej nie są zamienione, bo jak je zamienię, to nie chce nawet odpalić i pojawiają się inne błędy. Ktokolwiek jakieś pomysły? Proszę o pomoc.
Mechanika - Elektryka! Klimatyzacja-Opony! Montaż LPG!! - Warsztat, Ul. św. Teresy 56/58 bud C Mail: rafantek@ford-service.eu tel: 791 054 854 www.ford-service.eu Ostatnio edytowane przez Rafał A.(antek) ; 09-11-2015 o 08:44 |
![]() Imię: Tomek
Silnik: 2.0 TSI
Postów: 1,434
Chciał uniknąć tłumacza z Googla...Łatwiej jest to zrozumieć po angielskuGoście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Napisałem o parowaniu tego modułu..jest też opcja,że może być uszkodzony.
![]() Imię: gary
Model: mondeo
Postów: 11
Hello. Thank you for the replies
I am sorry, I don't understand what is wrong with title topic. I am asking for help with IVDC. Please explain I have tried to post some pictures but can't upload them for some reason. I get code U043A. 68-A8 Invalid data received from suspension module B. Additional fault symptom. Event Information Module. Anti lock brake/traction control module When I read modules I have this ABS module Part number. AG91-2C405-FA Strategy. AG91-14C036-FA Calibration. AG91-14C037-FA Vehicle dynamics module Part number. 6G9N-3B494-AB Strategy. 6G9N-14C155-BC Calibration. 6G9N-14C156-BC Hope this means something Thanks again Gary |
![]() Imię: Tomek
Silnik: 2.0 TSI
Postów: 1,434
Hello Gary.Wrong title of topic is because IVDC-Help it's not to much precision.Better be a write title''IVDC-module problem''?Could you made adaptation procedures by IDS with IVDC module?
#7 |
![]() Imię: gary
Model: mondeo
Postów: 11
I see. I have changed now. Thank you
Yes it is possible it needs to be configured |
