#921 |
![]() Imię: Piotr
Zarejestrowany: 06-09-2005
Model: Ford Kuga 2021 ST-Line X
Silnik: 1.5 EcoBoost 150 KM
Rocznik: 2021
Postów: 211
Na stronie Forscana można już pobrać wersję 2.3.1 beta.
#922 |
![]() Zarejestrowany: 21-12-2007
Model: mondeo mk IV
Silnik: 1,6
Rocznik: mikołaj '07
Postów: 1,397
czy jest jakaś kolosalna różnica przy np. Torque , czy to generalnie to samo ?
#923 |
![]() Imię: Piotr
Rocznik: 2021
Postów: 211
Opisane jest wszystko co dodali(zmienili).
+ Vehicle database update + Service function "Reset the High Pressure Fuel System Learned Values" for: Mondeo Mk5 2.0 TDCi 2015 model year Mondeo Mk4 1.6/2.0 TDCi 2007/2011 model year Galaxy/SMax 2.0 TDCi 2015 model year Galaxy/SMax 1.6/2.0 TDCi 2010 model year Everset 2.0 TDCi 2015 model year Kuga 2.0 TDCi 2008/2013 model year Focus/CMax Mk3 1.6/2.0 TDCi 2011/2015 model year Ranger / Mazda B-Series / Troller TDCi 2011 Transit 2.2/3.2 TDCi (Siemens) 2006 model year Transit 2.2 TDCi 2012/2014 model year Transit Connect 1.6 TDCi 2014 Mazda 3 1.6 Y6 Mazda 5 1.6 Y6 + Service function "PATS programming" for: Focus Mk1 1.6 Zetec-SE 1999 Transit 2006-2011 Galaxy/SMax 2006-2011 Mondeo Mk4 2007-2011 Fiesta 2008-2011 + Service procedure "DPF Static Regeneration", "Reset the Diesel Particulate Filter Learned Values", "Reset Differential Pressure Sensor Learned Values" for: Transit 2.2/2.4/3.2 TDCi 2006-2012 model year Ranger/ Mazda B-series/ Troller TDCi 2011 model year + Service procedures "Reset the Intake Air Throttle Valve Learned Values", "Reset Charge Air Cooler Bypass Valve Position Offset" for: Focus Mk2/Cmax 1.6 TDCi 2003-2008 model year Fiesta/Fusion 1.6 TDCi 2002-2006 model year + Service procedure "Headlamp Alignment And Calibration" for the following vehciles, equipped with HCM module: Focus Mk1 200-2002 model year Focus/CMax Mk2 2003-2008 model year Kuga 2008 model year + Service procedure "Calibrate Steering Angle Sensor" for: Mazda 6 GH/Atenza + Module configuration parameter "All Wheel Drive Gauge", "Engine Hours Counter" (Enaled/Disabled) for: Taurus 2013-2016 model year + OBDII mode 6 tests for pre-CAN vehicles + Double click on selected PID in PID selection dialog (in Windows version) now removes the PID from the list of selected parameters - incorrect work with HS2/HS3/MS CAN using ELM327 adapter equipped with HS/MS CAN switch - incorrect manufacturing year and month detection in some cases * fixes and improvements in as-built and central configuration management functions |
#924 |
![]() Imię: andrzej
Zarejestrowany: 24-05-2015
Model: mondeo mk4
Postów: 61
Witam serdecznie. Panowie mały problem!proszę o pomoc. Po skanówaniu przez fordScan wyskakuje mi cały czas błąd taki jak na zdjęciu 2. Pytanie czy ten czujnik map to jest ten co na zdjęciu 1 czy to jakiś inny czujnik w innym miejscu? Dodam że auto na moje oko chodzi normalnie. Jedyny problem to taki ze jak jest temperatura w przedziale -5 do +10 stopni to po odpaleniu zaczyna silnik nierówno pracować tak do 10 minut na postoju.później obroty się wyrównuja.podczas jazdy wszytko jest ok.czy ta usterka ma coś wspólnego z opisanym zachowaniem silnika? Jakie są obawy uszkodzonego czujnika map? czy jest możliwość wyczyszczenia tego czujnika?
#925 |
![]() Zarejestrowany: 17-05-2007
Model: Mondeo Mk5
Silnik: 2.0 TDCI @205KM
Postów: 1,346
#926 | |
![]() Zarejestrowany: 11-02-2004
Model: BMW seria 5 , było kiedyś Mondeo MK2,MK3,MK4,MK5
Silnik: różne TDCI
Postów: 876
![]() Cytat:
#927 |
![]() Imię: andrzej
Model: mondeo mk4
Postów: 61
Teraz długi weekend to będę się bawił i sprawdzę ten czujnik co piszecie.odezwę się i dam znać co z tego wyjdzie. Pozdrawiam
#928 |
![]() Imię: Patryk
Zarejestrowany: 08-02-2011
Model: Mondeo Mk4
Silnik: 2.0 Tdci
Postów: 9
mam do Was pytanie czy może ktoś wrzucić test z PCM w Ford Mondeo Mk3 2.0 TDDi 2001r.? Mój problem jest taki, że auto pali około 11-12 Litrów / 100 km. - Było 14l ale wtryski zostały wymienione na inne używane. Podobno sprawdzone i wszystko jest z nimi ok. Czy może ktoś wrzucić swój log z MK3 TDDI ? Oraz zobaczyć czy wartości odchylenia wtrysków, zapotrzebowanie na dawkę paliwa FIP, Wymagana masa paliwa w mg, oraz kąty wtrysku są dobre, oraz czy sygnał odniesienia wału korbowego ma u Was jakąś wartość. Z tego co wyczytałem Wymagana masa paliwa w mg, powinna mieć wartość około 5mg ? Niżej moje wartości: Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Dodatkowe wartości: 1. Zadany kąt wtrysku 3,55 stopnia 2. Aktualny kąt wtrysku 3,50 stopnia 3. Sygnał odniesienia wału korbowego przy FIP - 0 - tutaj cału czas jest Zero, tak powinno być, (U was tak samo jest czy ta wartość powinna się zmieniać?) 4. Zapotrzebowanie na dawkę paliwa FIP - 5.5 mg Wartości zrobione po około 3 km drogi. Co było robione: Wymienione wtrysku na używane, filtr powietrza, filtr paliwa, sprawdzany kąt wtrysku podobno jest dobry (Przed tym jak dostałem wartości ale możecie zerknąć), kiedyś pompa wtryskowa ostatnio naprawiony sterownik pompy wtryskowej i wymieniona coś pod sterownikiem (czujnik obrotów), świece żarowe, pompa paliwa w baku, termostat duży, termostat mały - olejowy - To chyba tyle, proszę o pomoc bo jak widać to wszystko przyniosło wymierny skutek a samochód wciąż pali jak Hummer tylko moc nie ta... Proszę o pomoc. Ostatnio edytowane przez patryk898 ; 07-05-2016 o 12:21 Powód: Dodanie kilku informacji |
#929 |
![]() Zarejestrowany: 13-12-2012
Model: Focus 2
Silnik: 1,6
Postów: 541
Mam pytanie. Czy Forscan wyświetla tylko aktualnie występujące błędy? Czy można wyświetlić też historię błędów występujących wcześniej albo takich, które pojawiły się kiedyś tylko na chwilę?
#930 |
![]() Imię: Marcin
Zarejestrowany: 28-05-2012
Model: OOOO A6
Silnik: V6
Rocznik: Adekwatny do wieku
Postów: 1,773
Tagi |
mondeo mk4 |
