#1001 | |
![]() Imię: Tomi
Zarejestrowany: 31-10-2005
Model: FUSION 4x4
Silnik: 2.0EB
Postów: 7,281
Moja zabawa z nawigacjami Moje mody we własnym aucie - C+/Tempomat/ACC/BLISS/CTA/CHIP/SYNC2>SYNC3 LOGA stacji Radiowych w SYNC3 bez wymiany ACMa |
#1002 | |
![]() Imię: Marcin
Zarejestrowany: 21-07-2006
Model: Mondeo MK5
Silnik: 2,0TDCI
Postów: 7,603
@[Tylko zarejestrowani użytkownicy widzą linki. ] ,co do Twojego błędu,tutaj są spisane wszystkie błędy,które mogą być wygenerowane przez sync: NAVVOICE_ERR01 - Error is NAV_VOICE_ERROR BGMAP_ERR01 - Error is BGMAP_ERROR LIC_ERR01 - Error is MAP_LICENSE_MISMATCH_ERROR LIC_ERR02 - Error is LICENSE_READING_ERROR INSTL_ERR03 - Error is SCRIPT_PERMISSION_CHANGE_ERROR INSTL_ERR04 - Error is SCRIPT_FILE_NOT_PRESENT_ERROR INSTL_ERR05 - Error is POPUP_UTILITY_EXECUTION_ERROR INSTL_ERR06 - Error is IMAGE_MOVING_ERROR INSTL_ERR07 - Error is WRITING_NAV_LICENSE_TO_DPS_ERROR INSTL_ERR08 - Error is APPS_TOGGLE_ERROR INSTL_ERR09 - Error is IMAGE_TOGGLE_ERROR INSTL_ERR10 - Error is APPS_UPDATE_BOOT_ERROR INSTL_ERR11 - Error is APPS_UPDATE_PART_ERROR INSTL_ERR12 - Error is DIR_CREATION_ERROR INSTL_ERR13 - Error is UNMOUNT_ERROR INSTL_ERR14 - Error is ACTIVATION_PENDING_ERROR INSTL_ERR15 - Error is UNABLE_TO_FIND_PASSIVE_PARTITION_ERROR LST_ERR03 - Error is LST_ERR_NO_APPROPRIATE_SECTION LST_ERR04 - Error is LST_ERR_NO_SECTION LST_ERR05 - Error is LST_PKG_FILE_NOT_FOUND LST_ERR06 - Error is LST_ERR_MALICIOUS_CHAR LST_ERR07 - Error is LST_ERR_NO_OPEN1_PARAM LST_ERR08 - Error is LST_ERR_OPEN_LIMIT_EXCEEDED VER_ERR01 - Error is VER_UNABLE_TO_FIND_VER_FILE VER_ERR02 - Error is VER_FPN_EMPTY VER_ERR03 - Error is VER_ERR_PARSE_VER_INF VER_ERR04 - Error is VER_FILENAME_EMPTY VER_ERR05 - Error is VER_VIN_MISMATCH VER_ERR06 - Error is VER_ESN_MISMATCH VER_ERR07 - Error is VER_TIME_LIMIT_EXCEED VER_ERR08 - Error is VER_SETTING_VER_INFO_ERROR VER_ERR09 - Error is VER_SAVE_LOCATION_EMPTY_INVALID_ERROR VER_ERR10 - Error is VER_FPN_VERSION_MOVING_IN_TMP_ERROR VER_ERR11 - Error is VER_FPN_IMAGE_FILE_NOT_PRESENT VER_ERR12 - Error is VER_FILE_HASH_VALUE_NOT_PRESENT VER_ERR13 - Error is VER_FILE_SIZE_NOT_PRESENT VER_ERR14 - Error is VER_PKG_TYPE_NOT_PRESENT VER_ERR15 - Error is VER_FILE_NOT_PRESENT_TO_CALC_HASH MEM_ERR01 - Error is MEM_NOSPACE_TO_COPY MEM_ERR03 - Error is MEM_NOSPACE_TO_EXTRACT PKG_ERR02 - Error is PKG_DWNLD_PKG_NOT_FOUND PKG_ERR03 - Error is PKG_UNTAR_FAILURE PKG_ERR04 - Error is PKG_REVOKED SIGN_ERR01 - Error is UNSIGN_ERROR SIGN_ERR02 - Error is SIGN_HASH_VALUE_MISMATCH SIGN_ERR03 - Error is SIGN_CERTS_NOT_PRESENT_ON_SYNC SIGN_ERR04 - Error is INSTALL_ERROR SIGN_ERR05 - Error is SCRIPT_INSTALL_ERROR
Moje mody w mk5:Elektryczna klapa +"machanie nogą",BLIS,Webasto,Kamera tylna i przednia,Aktywne Zawieszenie,Active Park Assist,Premium Sound,ACC,Sync1->Sync2->Sync3,Fotele grzane/wentylowane z masażem,Elektryczna kolumna kierownicza,Active Noise Control Ostatnio edytowane przez mm32 ; 02-02-2020 o 13:36 |
#1003 | |
![]() Zarejestrowany: 11-02-2004
Model: BMW seria 5 , było kiedyś Mondeo MK2,MK3,MK4,MK5
Silnik: różne TDCI
Postów: 876
#1004 | |
![]() Imię: Tomi
Model: FUSION 4x4
Silnik: 2.0EB
Postów: 7,281
#1005 | ||
![]() Imię: Tadeusz
Postów: 18,052
1) Brak info co za pakiet został ściągnięty. 2) Brak info kiedy został ściągnięty. 3) Brak info co wchodzi w skład pakietu, jakie są długości i daty poszczególnych plików 4) brak treści pliku autoinstall.lst. Jedyne co z wynika z opisu to: "mam problem i oczekuję pomocy". Jedyne co na takie teksty można z sensem napisać to "Współczujemy. Nasza rada - musisz zrobić tak, by było dobrze!".Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Ostatnio edytowane przez tedi_k ; 02-02-2020 o 20:07 |
#1006 | |
![]() Imię: Tomi
Model: FUSION 4x4
Silnik: 2.0EB
Postów: 7,281
Moja zabawa z nawigacjami Moje mody we własnym aucie - C+/Tempomat/ACC/BLISS/CTA/CHIP/SYNC2>SYNC3 LOGA stacji Radiowych w SYNC3 bez wymiany ACMa Ostatnio edytowane przez leszcz ; 02-02-2020 o 21:32 |
#1007 | |
![]() Imię: Marcin
Model: Mondeo MK5
Silnik: 2,0TDCI
Postów: 7,603
Ja uważam,że jednak coś tam możesz podpowiedzieć koledze bo Twój post #1006 był już pomocny,jak nie dla kolegi @[Tylko zarejestrowani użytkownicy widzą linki. ] to na pewno dla wielu innych,tylko tak na prawdę w/w post powinien paść już wcześniej,np za miast Twojego postu #999. Inna sprawa to jeśli kolega podał mało informacji to można zawsze poprosić go o więcej(kolega nie musi wiedzieć wszystkiego o aktualizacji s3) o ile chce mu się pomóc Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Moje mody w mk5:Elektryczna klapa +"machanie nogą",BLIS,Webasto,Kamera tylna i przednia,Aktywne Zawieszenie,Active Park Assist,Premium Sound,ACC,Sync1->Sync2->Sync3,Fotele grzane/wentylowane z masażem,Elektryczna kolumna kierownicza,Active Noise Control |
#1008 |
Silnik: różne TDCI
Postów: 876
zip sprawdzony - poprawny , pliki też właściwych rozmiarów , Tadeusz z całym szacunkiem do twojej wiedzy i wymienionych punktów, posiadacza forda guzik powinno interesować jakie pliki wchodzą w skład archiwum i jak wygląda autoinstall , konsument ma podać vin na stronie pobrać pliki , rozpakować na pendrive, wlożyć w usb i automatycznie auto powinno zaktualizować soft czego nie robi a ta operacja to nie lot w kosmos, patrząc na skalę nie powodzeń w tym temacie ktoś dał du....py, stąd moje pytanie jak sobie radzicie a najwyraźniej nie zetkneliście się z tym problemem, a nie polega na uszkodzonym pobranym pliku
Ostatnio edytowane przez wojtekn ; 04-02-2020 o 17:26 |
#1009 | |
![]() Imię: Tadeusz
Postów: 18,052
Jeśli ja mam pomagać, to potrzebuję niezbędnych info - najlepiej wręcz link do pobrania "feralnego" pakietu. Wtedy jestem w stanie wydać opinię czy winny generator pakietów czy winny "pobierający". Inaczej, to robi się dyskusja typu "jak sobie radzicie ze złym humorem żony"... Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. A jak wiadomo - w tej dyskusji najlepsza i zawsze kończąca dyskusję jest odpowiedź - "przecież Twoja żona wg mnie nie ma nigdy złych humorów"...Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. |
#1010 |
![]() Zarejestrowany: 30-09-2014
Model: kuga, bmw 530i, stelvio, bmw x5
Silnik: 0,7
Rocznik: 1997
Postów: 279
Nie widzę sensu w ściąganiu " nowych " map do nawigacji fabrycznej. One są zawsze opóźnione w stosunku do faktycznego przebiegu róg. Nie płaćcie za to nikomu, bo szkoda pieniędzy. Są inne aplikacje.
