Wróć   Forum Ford Club Polska > Forum Ogólne > Ford Garage > Skrzynie automatyczne
Stary 07-10-2020, 15:13   #1
Dragao84
Imię: Dragos
Zarejestrowany: 02-06-2020
Silnik: 2.0Tdci 150hp
Postów: 7
Domyślnie Powershift vibration
Hello everyone
I have 2015 tdci Ford Mondeo 132 000km with DCT451 transmission.
I have this car for a 2 years.
My issue is: when i decelerate and vehicle has stopped a vibration can be felt through the body. It seems like the vibration comes from a drivetrain.
I have visited several services ( I work in one), and comments are: we don`t know were it`s coming from, we think it is inside of the gearbox
video of the sound it makes when braking [Tylko zarejestrowani użytkownicy widzą linki. ]
and when going forward [Tylko zarejestrowani użytkownicy widzą linki. ]
vibrations are hard to record, but are at the same time. The higher the speed from which i stop the vibrations are stronger.
For me it looks like powershift is not disengaging gears as fast as it suppose to.
Has anyone encountered this problem? Does anyone have an idea where it can come from?
Otherwise, the car works perfectly, has no symptoms of a broken gearbox, does not skid the clutches, absolutely nothing, changes gears smoothly and without wrinkling, has changed oil.
Dragao84 jest offline   Odpowiedź z Cytatem
Stary 07-10-2020, 18:06   #2
gibaj
Avatar gibaj
Imię: Artur
Zarejestrowany: 01-10-2017
Postów: 1,497
Domyślnie Odp: Powershift vibration
gibaj jest offline   Odpowiedź z Cytatem
Stary 08-10-2020, 14:06   #3
Dragao84
Imię: Dragos
Postów: 7
Thanks for the answer ... I kept looking in these topics, but I didn't find anything similar to my problem, or any similar symptom. That's why I opened a new topic, maybe I'll find someone else with this problem?
Am I the only bad guy?
Stary 08-10-2020, 18:56   #4
Fiesta Mk8 ST Line
Avatar Fiesta Mk8 ST Line
Zarejestrowany: 04-07-2018
Model: Fiesta Mk8 ST-Line, Mondeo Mk5 Turnier PS
Silnik: 1.0 EB, 2.0 ropniok
Rocznik: 2018, 2019
Postów: 1,039
looks like it's some kind of mechanical damage inside the gearbox. Nobody will make a diagnosis at a distance. It is necessary to unfold the gearbox. This is my opinion, the sound is very strange and disturbing.
Wysłane z mojego Mi 9T Pro przy użyciu Tapatalka
Fiesta Mk8 ST Line jest offline   Odpowiedź z Cytatem
Stary 09-10-2020, 15:04   #5
Dragao84
Imię: Dragos
Postów: 7
Yes, that seems to be ...
The boys from the gearbox service did no know either, being the DCT451 gearbox,they did not open any 451. I thought maybe someone had run into this problem before. To know where to start looking, or what to expect.
Stary 09-10-2020, 15:23   #6
Piotr_V6
Zarejestrowany: 23-05-2017
Silnik: Chrysler Stratus 2.5V6, MK3 2.5V6 Jatco było jest 2.0 TDCI 163KM PS ,Kia Ceed, Freemont AWD, 508GT
Rocznik: 99,2004,2011,2015,2015,2015
Postów: 696
This could be a problem with the torsional vibration damper. If the gear changes are not smooth, there are vibrations in a certain speed range when accelerating, this may be a problem, the problem may also be worn engine cushions, especially the hydraulic cushion, the problem may also be the wear of the pistons of the clutch pressing forks or the solenoids themselves and even contaminated mechatronics of the gearbox. I suggest changing the oil after draining the old oil, filter it thoroughly through the stocking, in order to catch all possible impurities that may be there, if there are solids in it, except for a small amount of filings which are always, but only small amounts like dust or sand, the box should be dismantled to find out where is the problem .
Ostatnio edytowane przez Piotr_V6 ; 09-10-2020 o 15:25
Piotr_V6 jest offline   Odpowiedź z Cytatem
Stary 11-10-2020, 13:32   #7
Dragao84
Imię: Dragos
Postów: 7
Hello
The oil has been changed according to the manufacturer's specifications. I changed the oil 17,000km ago. It was clean, with no residue in it. The box does not wrinkle, changes gears smoothly and linearly, pulls constantly up to 200+ without problems.
The only time it vibrates is when starting, in D or R, without accelerating, or especially when you brake, before stopping, it is as if it would delay the isengagement. I calibrated the clutches and forks, after I changed the flywheel, because the mechanics said from there it's the problem, it wasn't, money wasted.
Czasy w strefie GMT +1. Teraz jest 03:42.
