Stary 19-10-2011, 14:17   #1
Duke258
Zarejestrowany: 04-01-2011
Model: Galaxy
Silnik: 1.9 Tdi AUY 170KM/374NM
Postów: 210
Domyślnie Bardzo prosze o rozszyfrowanie logow z turbiny czy wszystko jest ok.
Witam robilem diagnostyke turbo prosze powiedziedz czy wszystko ok z cisnieniem doladowania.Z gory dziekuje.
Wednesday,19,October,2011,14:00:20
038 906 019 FA ,,1.9l R4 EDC G001SG 1561,
,Group A:,'011,,,,Group B:, Not Running,,,,Group C:, Not Running
,,Engine speed,Spec. intake press.,Actual intake press.,D.cycle MAP,,,,,,,,,,
,TIME,2850-3150,,,,TIME,,,,,TIME,,,,
MARKER,STAMP, /min, mbar, mbar, %,STAMP,,,,,STAMP,,,,
,0.02,3150,1162.8,1203.6,50.6,,,,,,,,,,
,0.37,3129,1142.4,1213.8,49.4,,,,,,,,,,
,0.75,3108,1122.0,1224.0,48.6,,,,,,,,,,
,1.15,3087,1111.8,1234.2,48.2,,,,,,,,,,
,1.55,3087,1132.2,1244.4,48.6,,,,,,,,,,
,1.95,3066,1162.8,1254.6,50.2,,,,,,,,,,
,2.35,3045,1203.6,1264.8,51.4,,,,,,,,,,
,2.75,3024,1264.8,1305.6,56.2,,,,,,,,,,
,3.15,3024,1336.2,1336.2,54.6,,,,,,,,,,
,3.55,3024,1387.2,1377.0,55.0,,,,,,,,,,
,3.93,3045,1387.2,1428.0,56.6,,,,,,,,,,
,4.34,3066,1377.0,1438.2,58.2,,,,,,,,,,
,4.73,3066,1356.6,1417.8,59.0,,,,,,,,,,
,5.13,3066,1336.2,1387.2,58.2,,,,,,,,,,
,5.54,3087,1326.0,1346.4,57.0,,,,,,,,,,
,5.93,3087,1305.6,1315.8,56.2,,,,,,,,,,
,6.34,3087,1295.4,1305.6,55.8,,,,,,,,,,
,6.73,3087,1295.4,1295.4,55.4,,,,,,,,,,
,7.13,3087,1295.4,1295.4,55.4,,,,,,,,,,
,7.54,3087,1295.4,1295.4,55.0,,,,,,,,,,
,7.93,3087,1295.4,1295.4,55.0,,,,,,,,,,
,8.32,3087,1295.4,1295.4,55.4,,,,,,,,,,
,8.72,3087,1295.4,1295.4,55.8,,,,,,,,,,
,9.12,3087,1295.4,1305.6,55.8,,,,,,,,,,
,9.50,3087,1295.4,1305.6,55.8,,,,,,,,,,
,9.91,3087,1295.4,1295.4,55.8,,,,,,,,,,
,10.30,3087,1295.4,1305.6,55.8,,,,,,,,,,
,10.70,3087,1295.4,1305.6,55.8,,,,,,,,,,
,11.10,3087,1295.4,1305.6,55.8,,,,,,,,,,
,11.49,3087,1295.4,1305.6,55.8,,,,,,,,,,
,11.89,3108,1285.2,1295.4,56.2,,,,,,,,,,
,12.29,3087,1295.4,1305.6,56.2,,,,,,,,,,
,12.69,3087,1295.4,1295.4,55.8,,,,,,,,,,
,13.09,3087,1295.4,1295.4,55.8,,,,,,,,,,
,13.49,3087,1295.4,1305.6,55.8,,,,,,,,,,
,13.89,3108,1295.4,1305.6,56.2,,,,,,,,,,
,14.29,3087,1295.4,1305.6,56.2,,,,,,,,,,
,14.67,3087,1295.4,1305.6,56.2,,,,,,,,,,
,15.07,3108,1295.4,1305.6,56.2,,,,,,,,,,
,15.49,3108,1295.4,1305.6,56.2,,,,,,,,,,
,15.89,3087,1275.0,1295.4,56.2,,,,,,,,,,
,16.28,3087,1224.0,1285.2,58.2,,,,,,,,,,
,16.68,3087,1183.2,1254.6,51.4,,,,,,,,,,
,17.08,3087,1162.8,1234.2,50.2,,,,,,,,,,
,17.47,3066,1132.2,1224.0,49.0,,,,,,,,,,
,17.87,3045,1111.8,1234.2,48.2,,,,,,,,,,
,18.27,3024,1101.6,1244.4,47.4,,,,,,,,,,
,18.65,3003,1081.2,1254.6,46.6,,,,,,,,,,
,19.05,3003,1091.4,1254.6,47.0,,,,,,,,,,
,19.45,3003,1111.8,1275.0,47.8,,,,,,,,,,
,19.87,2961,1142.4,1275.0,49.0,,,,,,,,,,
,20.27,3003,1193.4,1285.2,51.0,,,,,,,,,,
,20.67,2982,1224.0,1315.8,52.2,,,,,,,,,,
,21.07,2961,1254.6,1356.6,59.0,,,,,,,,,,
,21.47,2982,1285.2,1366.8,58.2,,,,,,,,,,
,21.85,2982,1295.4,1397.4,60.2,,,,,,,,,,
,22.25,2982,1264.8,1397.4,61.8,,,,,,,,,,
,22.70,3003,1275.0,1397.4,61.8,,,,,,,,,,
,23.09,3003,1254.6,1387.2,62.6,,,,,,,,,,
,23.50,3003,1254.6,1377.0,63.0,,,,,,,,,,
,23.90,3024,1234.2,1356.6,63.0,,,,,,,,,,
,24.30,3024,1224.0,1346.4,62.6,,,,,,,,,,
,24.70,3024,1213.8,1326.0,62.6,,,,,,,,,,
,25.10,3045,1213.8,1315.8,61.8,,,,,,,,,,
,25.50,3024,1203.6,1305.6,61.8,,,,,,,,,,
,25.90,3045,1203.6,1295.4,61.0,,,,,,,,,,
,26.28,3045,1203.6,1285.2,51.8,,,,,,,,,,
,26.68,3045,1203.6,1295.4,51.8,,,,,,,,,,
,27.08,3045,1193.4,1285.2,51.4,,,,,,,,,,
,27.47,3045,1193.4,1285.2,51.4,,,,,,,,,,
,27.88,3045,1193.4,1285.2,51.4,,,,,,,,,,
,28.28,3024,1193.4,1285.2,51.4,,,,,,,,,,
,28.69,3045,1193.4,1285.2,51.4,,,,,,,,,,
,29.08,3045,1203.6,1285.2,51.8,,,,,,,,,,
,29.48,3024,1203.6,1295.4,51.8,,,,,,,,,,
,29.89,3024,1203.6,1285.2,51.8,,,,,,,,,,
,30.28,3045,1193.4,1295.4,51.8,,,,,,,,,,
,30.68,3024,1193.4,1295.4,51.4,,,,,,,,,,
,31.08,3024,1203.6,1295.4,51.4,,,,,,,,,,
,31.48,3024,1203.6,1285.2,51.8,,,,,,,,,,
,31.87,3024,1213.8,1295.4,52.2,,,,,,,,,,
,32.27,3024,1213.8,1295.4,52.2,,,,,,,,,,
,32.67,3024,1234.2,1305.6,53.0,,,,,,,,,,
,33.07,3003,1234.2,1315.8,53.0,,,,,,,,,,
,33.47,3003,1244.4,1315.8,57.8,,,,,,,,,,
,33.87,3003,1244.4,1285.2,56.2,,,,,,,,,,
,34.27,3003,1264.8,1275.0,54.6,,,,,,,,,,
,34.67,3003,1275.0,1285.2,54.6,,,,,,,,,,
,35.07,2982,1295.4,1295.4,54.6,,,,,,,,,,
,35.47,3003,1315.8,1305.6,54.2,,,,,,,,,,
,35.87,3003,1326.0,1336.2,55.0,,,,,,,,,,
,36.27,3003,1315.8,1356.6,56.6,,,,,,,,,,
,36.66,3003,1305.6,1356.6,57.8,,,,,,,,,,
,37.06,3003,1295.4,1346.4,57.4,,,,,,,,,,
,37.47,3024,1305.6,1336.2,56.6,,,,,,,,,,
,37.86,3024,1295.4,1326.0,56.6,,,,,,,,,,
,38.26,3024,1295.4,1326.0,56.6,,,,,,,,,,
,38.66,3003,1305.6,1315.8,56.2,,,,,,,,,,
,39.06,3024,1295.4,1315.8,56.6,,,,,,,,,,
,39.46,3024,1295.4,1315.8,57.0,,,,,,,,,,
,39.85,3003,1295.4,1315.8,56.6,,,,,,,,,,
,40.25,3024,1305.6,1315.8,56.2,,,,,,,,,,
,40.65,3024,1315.8,1326.0,56.2,,,,,,,,,,
,41.03,3024,1315.8,1326.0,56.6,,,,,,,,,,
,41.43,3024,1305.6,1336.2,57.4,,,,,,,,,,
,41.84,3024,1295.4,1326.0,57.4,,,,,,,,,,
,42.23,3045,1285.2,1305.6,57.4,,,,,,,,,,
,42.63,3024,1285.2,1305.6,57.4,,,,,,,,,,
,43.02,3024,1285.2,1295.4,57.0,,,,,,,,,,
,43.42,3024,1275.0,1295.4,57.0,,,,,,,,,,
,43.82,3045,1264.8,1295.4,57.0,,,,,,,,,,
Duke258 jest offline   Odpowiedź z Cytatem
Stary 19-10-2011, 16:04   #2
DDiablo
Avatar DDiablo
Zarejestrowany: 11-10-2008
Model: Alhambra
Silnik: 1.9TDI AUY
Postów: 929
Domyślnie Odp: Bardzo prosze o rozszyfrowanie logow z turbiny czy wszystko jest ok.
Po pierwsze źle zrobione logi a po drugie masz wyżej podklejony temat Diagnostyka Vag w nim umieść poprawnie zrobione logi.
DDiablo jest offline   Odpowiedź z Cytatem
Czasy w strefie GMT +1. Teraz jest 06:14.
