Stary 10-02-2017, 06:17   #1
beethoven
Imię: Thierry Walterus
Zarejestrowany: 04-09-2016
Model: mondeo titanium 2015
Postów: 112
Domyślnie part/OEM number of windsreen
​Hello, I need the part/OEM number of the windscreen, meant for the LIDAR camera. You can recognize the screen by the fact that the place for the rainsensor is on the left in staed of the right side. Hope someone can help?
Thanks
beethoven jest offline   Odpowiedź z Cytatem
Stary 10-02-2017, 08:11   #2
CERES
Avatar CERES
Zarejestrowany: 12-03-2004
Model: Ford Edge 2016 Sport/Scorpio mk2 94 2.9
Silnik: 2.7 V6 Biturbo/2.9 EFI
Rocznik: 2016/1994
Postów: 1,597
Domyślnie Odp: part/OEM number of windsreen
Panowie pomóżcie koledze z zagranicy
CERES jest offline   Odpowiedź z Cytatem
Stary 10-02-2017, 08:22   #3
bartoszek
Avatar bartoszek
Imię: Bartosz
Zarejestrowany: 13-05-2013
Postów: 761
Give me the VIN number - i will check.
§23
bartoszek jest offline   Odpowiedź z Cytatem
Stary 10-02-2017, 09:33   #4
beethoven
Postów: 112
I want to explain something, first. My VIN number is not the right one for this windscreen,that I need, because my windscreen is for only 1 camera & rainsensor, the windscreen I need must have the place to mount also LIDAR cam. Hope you understand.
What I do have is FINIS number of one windscreen, but I do not know if this windscreen is the windscreen for lidar. Can you check this? Thank you very much
FINIS 1923544 -
Bump:
Napisał CERES Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
miło z twojej strony
Stary 10-02-2017, 12:16   #5
SRS
Moderator
Avatar SRS
Zarejestrowany: 17-02-2004
Model: Fiesta
Silnik: 1.4L Duratec 16V PFI
Rocznik: 3/2012
Postów: 3,916
catalog number of the glass is correct
FINIS 1923544 -
Windscreen/Inside Rear View Mirror, From: 29-09-2014 With Heated Windscreen, With Automatic Windscreen Wiper -
  • From: 29-09-2014 LHD, Standard Green Glass Windscreen, Low Speed Safety System
Stary 10-02-2017, 13:20   #6
bartoszek
Avatar bartoszek
Imię: Bartosz
Postów: 761
I can add, that the part numer is DS73-F03100-DK Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
§23
Czasy w strefie GMT +1. Teraz jest 01:35.
