Stary 18-09-2017, 12:44   #1
wojtekjanus
Avatar wojtekjanus
Imię: Wojciech
Zarejestrowany: 02-09-2008
Model: Transit
Silnik: 2,0 TDCI
Postów: 14,106
Domyślnie Transit ekstremalny tuning
Na brytyjskim ebayu zakończyła się właśnie licytacja Transita z silnikiem o mocy 750 BHP i momencie 840Nm.
Cena Kup teraz wynosiła 40.000 GBP, sprzedano (18.09.2017) za 20.600 GBP. Było 39 podbić ceny, czyli chłopcy dosyć ostro licytowali.
Auto wyposażone jest w silnik V8 z australijskiego Holdena Commodore, resztę zmian zacytuję po angielsku, nie mam siły tłumaczyć na polski:
Ford Transit rwd with Holden Comodore botom end and rb26 skyline head, 750bhp and 840 torque
ported polished head with oil galery oil drain to sump and bigger oil drain holes
Tomei 280 degrese and 10.9 lift camshafts
Tomei shims
Tomei lifters
Tomei valve springs
Tomei valves biger 1mm
Tomei 1.8 head gasket
HKS camshaft pulleys
Dayco timing belt kit
RB30 block with 1mm oil restrictor
CP 87mm forged pistons
ARP head bolts
ARP 2000 forged conrods
balanced crankshaft (jeff bull enginering)
ACL main and rod bearings
fluid damper
biger sump with oil bufle
exedy balansed clutch tein plate carbon
lightened balanced flywhell ( Jeff Bull Enginering)
RB26 intake manifold with 6 throttle bodies
1050cc sard injectors
gredy fuel rail 2x1
Epman fuel regulator
electric power steering
new brake pipes with special cover
Mercedes brake servo
clutch master cilinder from Jeep Samurai
custom made exaust manifold
HKS t04z turbocharger
HKS 60mm wastegate
greddy boost controller
4" exhaust
splitfire coils
EWP150 water pump with ecu
radiator aluminium in the back
2 fans on radiator 2 in back doors
aluminium 38 l fuel tank and 3 l fuel rezervoir
armed fuel pipes
x3 Bosch 044 fuel pumps
Epman blow off 50mm
3" intercooller with 3" pipes
15 row oil cooler
Tomei oil pump
6 pint accusum with electric valve switch
r34 GTT gearbox
custom made string propshaft
strong rear axle with welded diff
4 link rear axle
adjustable rear coilowers
front voilowers
3.5cm front and rear wheel spacers from standard transit to 114.3 x 5
alloy wheels and drag slicks
FIA approved bucket seat
FIA 6 point harnes
custom made front dash
all gauges
hydraulic handbrake
plastic side windows
link g4 plus ecu
extingusher system
emergency cut out swith
big wheel fenders
easy remove front bumper bonnet and side door
for drifting i got 3cm longer arms
front hubs welded
all suspension its brand new
aluminium door cards
Sparco quick reliese steering wheel
OMP steering wheel
FIA approved roll cage
Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum. Goście nie mogą oglądać obrazków w postach. Zarejestruj się klikając tutaj aby uzyskać pełen dostęp do forum.
Zgredzik
Ostatnio edytowane przez wojtekjanus ; 18-09-2017 o 22:32
Czasy w strefie GMT +1. Teraz jest 11:39.
